Other Parts Discussed in Thread: OMAPL138, OMAP3530
I have the following issue on Ubuntu 18.04 when compiling the SDK with "./build-core-sdk.sh dra7xx-evm":
DEBUG: Executing shell function do_compile
NOTE: make -j 6 PLATFORM=DRA7XX XDC_INSTALL_DIR=/home/kickrobot/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-6.00.00.03/yocto-layers/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/ti-ipc-rtos/3.50.04.07-r0.r1.psdkla/recipe-sysroot-native/usr/share/ti/ti-xdctools-tree BIOS_INSTALL_DIR=/home/kickrobot/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-6.00.00.03/yocto-layers/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/ti-ipc-rtos/3.50.04.07-r0.r1.psdkla/recipe-sysroot/usr/share/ti/ti-sysbios-tree gnu.targets.arm.A15F=/home/kickrobot/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-6.00.00.03/yocto-layers/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/ti-ipc-rtos/3.50.04.07-r0.r1.psdkla/recipe-sysroot-native/usr/share/ti/gcc-arm-none-eabi ti.targets.elf.C66=/home/kickrobot/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-6.00.00.03/yocto-layers/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/ti-ipc-rtos/3.50.04.07-r0.r1.psdkla/recipe-sysroot-native/usr/share/ti/cgt-c6x ti.targets.elf.C66_big_endian=/home/kickrobot/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-6.00.00.03/yocto-layers/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/ti-ipc-rtos/3.50.04.07-r0.r1.psdkla/recipe-sysroot-native/usr/share/ti/cgt-c6x ti.targets.arm.elf.M4=/home/kickrobot/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-6.00.00.03/yocto-layers/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/ti-ipc-rtos/3.50.04.07-r0.r1.psdkla/recipe-sysroot-native/usr/share/ti/ti-cgt-arm JOBS=--jobs=6 JAVA_TOOL_OPTIONS=-Xss2560k -f ipc-bios.mak clean
cleaning ipc packages ...
making clean: Mon Mar 8 15:16:19 UTC 2021 ...
======== clean [./packages/ti/grcm] ========
======== clean [./packages/ti/deh] ========
======== clean [./packages/ti/ipc] ========
======== clean [./packages/ti/ipc/family/am65xx] ========
======== clean [./packages/ti/ipc/family/omap54xx] ========
======== clean [./packages/ti/ipc/family/omapl138] ========
======== clean [./packages/ti/ipc/family/tci6614] ========
======== clean [./packages/ti/ipc/family/tci6638] ========
======== clean [./packages/ti/ipc/family/vayu] ========
======== clean [./packages/ti/ipc/ipcmgr] ========
======== clean [./packages/ti/ipc/mm] ========
======== clean [./packages/ti/ipc/namesrv] ========
======== clean [./packages/ti/ipc/remoteproc] ========
======== clean [./packages/ti/ipc/rpmsg] ========
======== clean [./packages/ti/ipc/tests] ========
======== clean [./packages/ti/ipc/transports] ========
======== clean [./packages/ti/pm] ========
======== clean [./packages/ti/sdo/ipc] ========
======== clean [./packages/ti/sdo/ipc/family] ========
======== clean [./packages/ti/sdo/ipc/family/am65xx] ========
======== clean [./packages/ti/sdo/ipc/family/c647x] ========
======== clean [./packages/ti/sdo/ipc/family/arctic] ========
======== clean [./packages/ti/sdo/ipc/family/c6a8149] ========
======== clean [./packages/ti/sdo/ipc/family/da830] ========
======== clean [./packages/ti/sdo/ipc/family/dm6446] ========
======== clean [./packages/ti/sdo/ipc/family/omap3530] ========
======== clean [./packages/ti/sdo/ipc/family/omap4430] ========
======== clean [./packages/ti/sdo/ipc/family/tci663x] ========
======== clean [./packages/ti/sdo/ipc/family/ti81xx] ========
======== clean [./packages/ti/sdo/ipc/family/vayu] ========
======== clean [./packages/ti/sdo/ipc/family/tda3xx] ========
======== clean [./packages/ti/sdo/ipc/gates] ========
======== clean [./packages/ti/sdo/ipc/heaps] ========
======== clean [./packages/ti/sdo/ipc/interfaces] ========
======== clean [./packages/ti/sdo/ipc/notifyDrivers] ========
======== clean [./packages/ti/sdo/ipc/nsremote] ========
======== clean [./packages/ti/sdo/ipc/transports] ========
======== clean [./packages/ti/sdo/utils] ========
======== clean [./packages/ti/srvmgr] ========
======== clean [./packages/ti/srvmgr/omaprpc] ========
making package.mak (because of package.bld) in order to clean ...
======== clean [./packages/ti/srvmgr/omx] ========
======== clean [./packages/ti/trace] ========
Picked up JAVA_TOOL_OPTIONS: -Xss2560k
make[2]: package/cfg/nonInstrumented_pe66.src/makefile.libs: No such file or directory
make[2]: *** No rule to make target 'package/cfg/nonInstrumented_pe66.src/makefile.libs'. Stop.
package/cfg/nonInstrumented_pe66.cfg.mak:7: recipe for target 'clean' failed
make[1]: *** [clean] Error 2
gmake: *** [/home/kickrobot/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-6.00.00.03/yocto-layers/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/ti-ipc-rtos/3.50.04.07-r0.r1.psdkla/recipe-sysroot-native/usr/share/ti/ti-xdctools-tree/packages/xdc/bld/xdc_top.mak:389: packages/ti/sdo/utils,clean] Error 2
ipc-bios.mak:163: recipe for target 'clean' failed
make: *** [clean] Error 2
ERROR: oe_runmake failed
WARNING: /home/kickrobot/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-6.00.00.03/yocto-layers/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/ti-ipc-rtos/3.50.04.07-r0.r1.psdkla/temp/run.do_compile.4877:1 exit 1 from 'exit 1'
ERROR: Function failed: do_compile (log file is located at /home/kickrobot/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-6.00.00.03/yocto-layers/build/arago-tmp-external-arm-toolchain/work/dra7xx_evm-linux-gnueabi/ti-ipc-rtos/3.50.04.07-r0.r1.psdkla/temp/log.do_compile.4877)
What can I do?
Frank
