EVMK2GX: identifier "TaskAip" is undefined, but it is defined in app.cfg!!!
Part Number: EVMK2GX
"../framework/systemInit.c", line 276: error #20: identifier "TaskAfp" is undefined
"../framework/systemInit.c", line 277: error #20: identifier "TaskAip" is undefined
"../framework/systemInit.c", line 278: error #20: identifier "TaskAsip" is undefined
"../framework/systemInit.c", line 279: error #20: identifier "TaskAsop" is undefined
**** Build of configuration Debug_DH for project test_dsp ****
"C:\\ti\\ccs1020\\ccs\\utils\\bin\\gmake" -k all
Building file: "../application/app.cfg"
Invoking: XDCtools
"C:/ti/xdctools_3_55_02_22_core/xs" --xdcpath="C:/ti/bios_6_76_03_01/packages;C:/ti/ipc_3_50_04_08/packages;C:/ti/uia_2_30_01_02/packages;C:/ti/xdais_7_24_00_04/packages;C:/ti/xdais_7_24_00_04/examples;C:/ti/dsplib_c66x_3_4_0_4/packages;C:/ti/pdk_k2g_1_0_16/packages;C:/ti/edma3_lld_2_12_05_30E/packages;C:/ti/ccs1020/ccs/ccs_base;" xdc.tools.configuro -o configPkg -t ti.targets.elf.C66 -p ti.platforms.evmTCI66AK2G02:core0 -r release -b "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/shared/config.bld" -c "C:/ti/ti-cgt-c6000_8.3.2" --cfgArgs "{ profile: \"debug\" }" -Dxdc.platform.custom.check=false -DProjName=pa_i13_evmk2g_c66x -DHsDevBuild=0 --compileOptions "-g --optimize_with_debug" "../application/app.cfg"
making package.mak (because of package.bld) ...
generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ...
configuring app.xe66 from package/cfg/app_pe66.cfg ...
SoC Type is k2g
SoC Type is k2g
generating custom ti.sysbios library makefile ...
generating custom ti.sdo.ipc library makefile ...
Linking with library ti.drv.i2c:./lib/k2g/c66/release/ti.drv.i2c.ae66
Linking with library ti.drv.spi:./lib/k2g/c66/release/ti.drv.spi.ae66
Linking with library ti.drv.uart:./lib/k2g/c66/release/ti.drv.uart.ae66
Linking with library ti.osal:./lib/tirtos/k2g/c66/release/ti.osal.ae66
Inside EDMA3 Drv Sample getLibs
will link with ti.sdo.edma3.drv.sample:lib/tci66ak2g02-evm/66/release/edma3_lld_drv_sample.ae66
Linking with library ti.csl:./lib/k2g/c66/release/ti.csl.ae66
Inside EDMA3 Drv getLibs
will link with ti.sdo.edma3.drv:lib/66/release/edma3_lld_drv.ae66
Inside EDMA3 RM getLibs
will link with ti.sdo.edma3.rm:lib/tci66ak2g02-evm/66/release/edma3_lld_rm.ae66
Starting build of library sources ...
making C:/Users/cctv/workspace_v10/test_dsp/application/src/ipc.ae66 ...
cle66 C:/ti/ipc_3_50_04_08/packages/ti/sdo/utils/NameServer.c ...
are66 Ipc.obj ...
making C:/Users/cctv/workspace_v10/test_dsp/application/src/sysbios/sysbios.ae66 ...
cle66 C:/ti/bios_6_76_03_01/packages/ti/sysbios/BIOS.c ...
asme66 C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c64p/Exception_asm.s64P ...
asme66 C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c64p/Hwi_asm.s62 ...
asme66 C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c64p/Hwi_asm_switch.s62 ...
asme66 C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c64p/Hwi_disp_always.s64P ...
asme66 C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c62/TaskSupport_asm.s62 ...
asme66 C:/ti/bios_6_76_03_01/packages/ti/sysbios/rts/ti/tls_get_tp.asm ...
asme66 C:/ti/bios_6_76_03_01/packages/ti/sysbios/timers/timer64/Timer_asm.s64P ...
are66 BIOS.obj c64p_Exception_asm.obj c64p_Hwi_asm.obj c64p_Hwi_asm_switch.obj c64p_Hwi_disp_always.obj c62_TaskSupport_asm.obj ti_tls_get_tp.obj timer64_Timer_asm.obj ...
Build of libraries done.
cle66 package/cfg/app_pe66.c ...
Finished building: "../application/app.cfg"
Building file: "../bin/debug/configuro/package/build.cfg"
Invoking: XDCtools
"C:/ti/xdctools_3_55_02_22_core/xs" --xdcpath="C:/ti/bios_6_76_03_01/packages;C:/ti/ipc_3_50_04_08/packages;C:/ti/uia_2_30_01_02/packages;C:/ti/xdais_7_24_00_04/packages;C:/ti/xdais_7_24_00_04/examples;C:/ti/dsplib_c66x_3_4_0_4/packages;C:/ti/pdk_k2g_1_0_16/packages;C:/ti/edma3_lld_2_12_05_30E/packages;C:/ti/ccs1020/ccs/ccs_base;" xdc.tools.configuro -o configPkg -t ti.targets.elf.C66 -p ti.platforms.evmTCI66AK2G02:core0 -r release -b "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/shared/config.bld" -c "C:/ti/ti-cgt-c6000_8.3.2" --cfgArgs "{ profile: \"debug\" }" -Dxdc.platform.custom.check=false -DProjName=pa_i13_evmk2g_c66x -DHsDevBuild=0 --compileOptions "-g --optimize_with_debug" "../bin/debug/configuro/package/build.cfg"
configuring build.xe66 from package/cfg/build_pe66.cfg ...
cle66 package/cfg/build_pe66.c ...
Finished building: "../bin/debug/configuro/package/build.cfg"
Building file: "../bin/debug/configuro/package/cfg/app_pe66.cfg"
Invoking: XDCtools
"C:/ti/xdctools_3_55_02_22_core/xs" --xdcpath="C:/ti/bios_6_76_03_01/packages;C:/ti/ipc_3_50_04_08/packages;C:/ti/uia_2_30_01_02/packages;C:/ti/xdais_7_24_00_04/packages;C:/ti/xdais_7_24_00_04/examples;C:/ti/dsplib_c66x_3_4_0_4/packages;C:/ti/pdk_k2g_1_0_16/packages;C:/ti/edma3_lld_2_12_05_30E/packages;C:/ti/ccs1020/ccs/ccs_base;" xdc.tools.configuro -o configPkg -t ti.targets.elf.C66 -p ti.platforms.evmTCI66AK2G02:core0 -r release -b "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/shared/config.bld" -c "C:/ti/ti-cgt-c6000_8.3.2" --cfgArgs "{ profile: \"debug\" }" -Dxdc.platform.custom.check=false -DProjName=pa_i13_evmk2g_c66x -DHsDevBuild=0 --compileOptions "-g --optimize_with_debug" "../bin/debug/configuro/package/cfg/app_pe66.cfg"
configuring app_pe66.xe66 from package/cfg/app_pe66_pe66.cfg ...
cle66 package/cfg/app_pe66_pe66.c ...
Finished building: "../bin/debug/configuro/package/cfg/app_pe66.cfg"
Building file: "../application/acp_main_cus.c"
Invoking: C6000 Compiler
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="application/acp_main_cus.d_raw" --obj_directory="application" --cmd_file="configPkg/compiler.opt" "../application/acp_main_cus.c"
Finished building: "../application/acp_main_cus.c"
Building file: "../application/main.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="application/main.d_raw" --obj_directory="application" --cmd_file="configPkg/compiler.opt" "../application/main.c"
Finished building: "../application/main.c"
Building file: "../application/itopo/evmk2g/atboot.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="application/itopo/evmk2g/atboot.d_raw" --obj_directory="application/itopo/evmk2g" --cmd_file="configPkg/compiler.opt" "../application/itopo/evmk2g/atboot.c"
>> Compilation failure
application/itopo/evmk2g/subdir_rules.mk:9: recipe for target 'application/itopo/evmk2g/atboot.obj' failed
"C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha/i13_a.h", line 63: fatal error #1965: cannot open source file "ddpat_a.h"
1 catastrophic error detected in the compilation of "../application/itopo/evmk2g/atboot.c".
Compilation terminated.
gmake: *** [application/itopo/evmk2g/atboot.obj] Error 1
Building file: "../application/itopo/evmk2g/audio_dc_cfg.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="application/itopo/evmk2g/audio_dc_cfg.d_raw" --obj_directory="application/itopo/evmk2g" --cmd_file="configPkg/compiler.opt" "../application/itopo/evmk2g/audio_dc_cfg.c"
Finished building: "../application/itopo/evmk2g/audio_dc_cfg.c"
Building file: "../application/itopo/evmk2g/dcs7_params.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="application/itopo/evmk2g/dcs7_params.d_raw" --obj_directory="application/itopo/evmk2g" --cmd_file="configPkg/compiler.opt" "../application/itopo/evmk2g/dcs7_params.c"
"../application/itopo/evmk2g/dcs7_params.c", line 109: warning #190-D: enumerated type mixed with another type
Finished building: "../application/itopo/evmk2g/dcs7_params.c"
Building file: "../application/itopo/evmk2g/edma_cfg.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="application/itopo/evmk2g/edma_cfg.d_raw" --obj_directory="application/itopo/evmk2g" --cmd_file="configPkg/compiler.opt" "../application/itopo/evmk2g/edma_cfg.c"
Finished building: "../application/itopo/evmk2g/edma_cfg.c"
Building file: "../application/itopo/evmk2g/io.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="application/itopo/evmk2g/io.d_raw" --obj_directory="application/itopo/evmk2g" --cmd_file="configPkg/compiler.opt" "../application/itopo/evmk2g/io.c"
>> Compilation failure
application/itopo/evmk2g/subdir_rules.mk:9: recipe for target 'application/itopo/evmk2g/io.obj' failed
1 catastrophic error detected in the compilation of "../application/itopo/evmk2g/io.c".
gmake: *** [application/itopo/evmk2g/io.obj] Error 1
Building file: "../application/itopo/evmk2g/mcasp_cfg.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="application/itopo/evmk2g/mcasp_cfg.d_raw" --obj_directory="application/itopo/evmk2g" --cmd_file="configPkg/compiler.opt" "../application/itopo/evmk2g/mcasp_cfg.c"
Finished building: "../application/itopo/evmk2g/mcasp_cfg.c"
Building file: "../application/itopo/evmk2g/platform_osal.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="application/itopo/evmk2g/platform_osal.d_raw" --obj_directory="application/itopo/evmk2g" --cmd_file="configPkg/compiler.opt" "../application/itopo/evmk2g/platform_osal.c"
Finished building: "../application/itopo/evmk2g/platform_osal.c"
Building file: "../application/itopo/evmk2g/sample_cs.c"
Invoking: C6000 Compiler
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="application/itopo/evmk2g/sample_cs.d_raw" --obj_directory="application/itopo/evmk2g" --cmd_file="configPkg/compiler.opt" "../application/itopo/evmk2g/sample_cs.c"
Finished building: "../application/itopo/evmk2g/sample_cs.c"
Building file: "../application/itopo/evmk2g/sample_k2g_cfg.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="application/itopo/evmk2g/sample_k2g_cfg.d_raw" --obj_directory="application/itopo/evmk2g" --cmd_file="configPkg/compiler.opt" "../application/itopo/evmk2g/sample_k2g_cfg.c"
Finished building: "../application/itopo/evmk2g/sample_k2g_cfg.c"
Building file: "../application/itopo/evmk2g/sample_k2g_int_reg.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="application/itopo/evmk2g/sample_k2g_int_reg.d_raw" --obj_directory="application/itopo/evmk2g" --cmd_file="configPkg/compiler.opt" "../application/itopo/evmk2g/sample_k2g_int_reg.c"
Finished building: "../application/itopo/evmk2g/sample_k2g_int_reg.c"
Building file: "../application/itopo/evmk2g/sap_d10.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_suppress=1934 --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="application/itopo/evmk2g/sap_d10.d_raw" --obj_directory="application/itopo/evmk2g" --cmd_file="configPkg/compiler.opt" "../application/itopo/evmk2g/sap_d10.c"
Finished building: "../application/itopo/evmk2g/sap_d10.c"
Building file: "../application/itopo/ipce_nodelay.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="application/itopo/ipce_nodelay.d_raw" --obj_directory="application/itopo" --cmd_file="configPkg/compiler.opt" "../application/itopo/ipce_nodelay.c"
Finished building: "../application/itopo/ipce_nodelay.c"
Building file: "../bin/debug/configuro/package/package_configuro.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="bin/debug/configuro/package/package_configuro.d_raw" --obj_directory="bin/debug/configuro/package" --cmd_file="configPkg/compiler.opt" "../bin/debug/configuro/package/package_configuro.c"
Finished building: "../bin/debug/configuro/package/package_configuro.c"
Building file: "../bin/debug/configuro/package/cfg/app_pe66.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="bin/debug/configuro/package/cfg/app_pe66.d_raw" --obj_directory="bin/debug/configuro/package/cfg" --cmd_file="configPkg/compiler.opt" "../bin/debug/configuro/package/cfg/app_pe66.c"
Finished building: "../bin/debug/configuro/package/cfg/app_pe66.c"
Building file: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/asp0.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="common/asp0.d_raw" --obj_directory="common" --cmd_file="configPkg/compiler.opt" "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/asp0.c"
Finished building: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/asp0.c"
Building file: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/aspDecOpCircBuf_common.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="common/aspDecOpCircBuf_common.d_raw" --obj_directory="common" --cmd_file="configPkg/compiler.opt" "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/aspDecOpCircBuf_common.c"
Finished building: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/aspDecOpCircBuf_common.c"
Building file: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/aspOutInitSync_common.c"
Invoking: C6000 Compiler
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="common/aspOutInitSync_common.d_raw" --obj_directory="common" --cmd_file="configPkg/compiler.opt" "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/aspOutInitSync_common.c"
Finished building: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/aspOutInitSync_common.c"
Building file: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/audioStreamProc_common.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="common/audioStreamProc_common.d_raw" --obj_directory="common" --cmd_file="configPkg/compiler.opt" "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/audioStreamProc_common.c"
Finished building: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/audioStreamProc_common.c"
Building file: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/dbgCapAf.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="common/dbgCapAf.d_raw" --obj_directory="common" --cmd_file="configPkg/compiler.opt" "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/dbgCapAf.c"
Finished building: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/dbgCapAf.c"
Building file: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/dbgDib.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="common/dbgDib.d_raw" --obj_directory="common" --cmd_file="configPkg/compiler.opt" "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/dbgDib.c"
Finished building: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/dbgDib.c"
Building file: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/evmc66x_gpio_dbg.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="common/evmc66x_gpio_dbg.d_raw" --obj_directory="common" --cmd_file="configPkg/compiler.opt" "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/evmc66x_gpio_dbg.c"
Finished building: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/evmc66x_gpio_dbg.c"
Building file: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/fwkPort.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="common/fwkPort.d_raw" --obj_directory="common" --cmd_file="configPkg/compiler.opt" "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/fwkPort.c"
Finished building: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/fwkPort.c"
Building file: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/paf_alg_create.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="common/paf_alg_create.d_raw" --obj_directory="common" --cmd_file="configPkg/compiler.opt" "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/paf_alg_create.c"
Finished building: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/paf_alg_create.c"
Building file: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/paf_alg_malloc.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="common/paf_alg_malloc.d_raw" --obj_directory="common" --cmd_file="configPkg/compiler.opt" "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/paf_alg_malloc.c"
"C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/paf_alg_malloc.c", line 440: warning #190-D: enumerated type mixed with another type
"C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/paf_alg_malloc.c", line 490: warning #190-D: enumerated type mixed with another type
Finished building: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/paf_alg_malloc.c"
Building file: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/paf_alg_print.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="common/paf_alg_print.d_raw" --obj_directory="common" --cmd_file="configPkg/compiler.opt" "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/paf_alg_print.c"
Finished building: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/paf_alg_print.c"
Building file: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/paf_heapMgr.c"
Invoking: C6000 Compiler
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="common/paf_heapMgr.d_raw" --obj_directory="common" --cmd_file="configPkg/compiler.opt" "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/paf_heapMgr.c"
Finished building: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/paf_heapMgr.c"
Building file: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/components/clk.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="common/components/clk.d_raw" --obj_directory="common/components" --cmd_file="configPkg/compiler.opt" "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/components/clk.c"
Finished building: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/components/clk.c"
Building file: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/pfp/pfp.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="common/pfp/pfp.d_raw" --obj_directory="common/pfp" --cmd_file="configPkg/compiler.opt" "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/pfp/pfp.c"
Finished building: "C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common/pfp/pfp.c"
Building file: "../framework/alphaFuncProc.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/alphaFuncProc.d_raw" --obj_directory="framework" --cmd_file="configPkg/compiler.opt" "../framework/alphaFuncProc.c"
>> Compilation failure
framework/subdir_rules.mk:9: recipe for target 'framework/alphaFuncProc.obj' failed
"../framework/alphaFuncProc.c", line 357: error #20: identifier "TaskAfp" is undefined
1 error detected in the compilation of "../framework/alphaFuncProc.c".
gmake: *** [framework/alphaFuncProc.obj] Error 1
Building file: "../framework/alphaFuncProcParams.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/alphaFuncProcParams.d_raw" --obj_directory="framework" --cmd_file="configPkg/compiler.opt" "../framework/alphaFuncProcParams.c"
Finished building: "../framework/alphaFuncProcParams.c"
Building file: "../framework/alphaIntervalProc.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/alphaIntervalProc.d_raw" --obj_directory="framework" --cmd_file="configPkg/compiler.opt" "../framework/alphaIntervalProc.c"
Finished building: "../framework/alphaIntervalProc.c"
Building file: "../framework/as0.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/as0.d_raw" --obj_directory="framework" --cmd_file="configPkg/compiler.opt" "../framework/as0.c"
Finished building: "../framework/as0.c"
Building file: "../framework/aspDecOpCircBuf_master.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/aspDecOpCircBuf_master.d_raw" --obj_directory="framework" --cmd_file="configPkg/compiler.opt" "../framework/aspDecOpCircBuf_master.c"
"../framework/aspDecOpCircBuf_master.c", line 805: warning #515-D: a value of type "int" cannot be assigned to an entity of type "struct PAF_AudioFrame *"
"../framework/aspDecOpCircBuf_master.c", line 805: warning #154-D: conversion of nonzero integer to pointer
Finished building: "../framework/aspDecOpCircBuf_master.c"
Building file: "../framework/aspMsg_master.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/aspMsg_master.d_raw" --obj_directory="framework" --cmd_file="configPkg/compiler.opt" "../framework/aspMsg_master.c"
Finished building: "../framework/aspMsg_master.c"
Building file: "../framework/aspOutInitSync_master.c"
Invoking: C6000 Compiler
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/aspOutInitSync_master.d_raw" --obj_directory="framework" --cmd_file="configPkg/compiler.opt" "../framework/aspOutInitSync_master.c"
Finished building: "../framework/aspOutInitSync_master.c"
Building file: "../framework/audioStreamInpDec.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/audioStreamInpDec.d_raw" --obj_directory="framework" --cmd_file="configPkg/compiler.opt" "../framework/audioStreamInpDec.c"
"../framework/audioStreamInpDec.c", line 682: warning #179-D: variable "errno" was declared but never referenced
"../framework/audioStreamInpDec.c", line 1263: warning #552-D: variable "errno" was set but never used
"../framework/audioStreamInpDec.c", line 1582: warning #179-D: variable "cbErrno" was declared but never referenced
"../framework/audioStreamInpDec.c", line 500: warning #179-D: function "decodeInit" was declared but never referenced
Finished building: "../framework/audioStreamInpDec.c"
Building file: "../framework/audioStreamInpProc.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/audioStreamInpProc.d_raw" --obj_directory="framework" --cmd_file="configPkg/compiler.opt" "../framework/audioStreamInpProc.c"
Finished building: "../framework/audioStreamInpProc.c"
Building file: "../framework/audioStreamInpProcNewIO.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/audioStreamInpProcNewIO.d_raw" --obj_directory="framework" --cmd_file="configPkg/compiler.opt" "../framework/audioStreamInpProcNewIO.c"
>> Compilation failure
framework/subdir_rules.mk:9: recipe for target 'framework/audioStreamInpProcNewIO.obj' failed
"C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha/i13_a.h", line 63: fatal error #1965: cannot open source file "ddpat_a.h"
1 catastrophic error detected in the compilation of "../framework/audioStreamInpProcNewIO.c".
Compilation terminated.
gmake: *** [framework/audioStreamInpProcNewIO.obj] Error 1
Building file: "../framework/audioStreamInpProc_paramsFxns.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/audioStreamInpProc_paramsFxns.d_raw" --obj_directory="framework" --cmd_file="configPkg/compiler.opt" "../framework/audioStreamInpProc_paramsFxns.c"
Finished building: "../framework/audioStreamInpProc_paramsFxns.c"
Building file: "../framework/audioStreamOutDec.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/audioStreamOutDec.d_raw" --obj_directory="framework" --cmd_file="configPkg/compiler.opt" "../framework/audioStreamOutDec.c"
"../framework/audioStreamOutDec.c", line 159: warning #179-D: variable "zO" was declared but never referenced
"../framework/audioStreamOutDec.c", line 159: warning #179-D: variable "zS" was declared but never referenced
"../framework/audioStreamOutDec.c", line 252: warning #552-D: variable "pOut" was set but never used
"../framework/audioStreamOutDec.c", line 253: warning #552-D: variable "zO" was set but never used
"../framework/audioStreamOutDec.c", line 642: warning #169-D: argument of type "char *" is incompatible with parameter of type "Int8 *"
"../framework/audioStreamOutDec.c", line 770: warning #552-D: variable "zO" was set but never used
"../framework/audioStreamOutDec.c", line 772: warning #179-D: variable "errno" was declared but never referenced
"../framework/audioStreamOutDec.c", line 882: warning #169-D: argument of type "char *" is incompatible with parameter of type "xdc_IArg"
"../framework/audioStreamOutDec.c", line 900: warning #169-D: argument of type "char *" is incompatible with parameter of type "xdc_IArg"
Finished building: "../framework/audioStreamOutDec.c"
Building file: "../framework/audioStreamOutInit.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/audioStreamOutInit.d_raw" --obj_directory="framework" --cmd_file="configPkg/compiler.opt" "../framework/audioStreamOutInit.c"
Finished building: "../framework/audioStreamOutInit.c"
Building file: "../framework/audioStreamOutIo.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/audioStreamOutIo.d_raw" --obj_directory="framework" --cmd_file="configPkg/compiler.opt" "../framework/audioStreamOutIo.c"
"../framework/audioStreamOutIo.c", line 241: warning #179-D: variable "zx" was declared but never referenced
"../framework/audioStreamOutIo.c", line 242: warning #179-D: variable "getVal" was declared but never referenced
"../framework/audioStreamOutIo.c", line 250: warning #179-D: variable "mcaspSetup" was declared but never referenced
"../framework/audioStreamOutIo.c", line 368: warning #552-D: variable "nbufs" was set but never used
"../framework/audioStreamOutIo.c", line 458: warning #179-D: variable "getVal" was declared but never referenced
Finished building: "../framework/audioStreamOutIo.c"
Building file: "../framework/audioStreamOutProc.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/audioStreamOutProc.d_raw" --obj_directory="framework" --cmd_file="configPkg/compiler.opt" "../framework/audioStreamOutProc.c"
"../framework/audioStreamOutProc.c", line 1120: warning #169-D: argument of type "char *" is incompatible with parameter of type "Int8 *"
"../framework/audioStreamOutProc.c", line 1185: warning #169-D: argument of type "char *" is incompatible with parameter of type "Int8 *"
"../framework/audioStreamOutProc.c", line 1233: warning #169-D: argument of type "char *" is incompatible with parameter of type "Int8 *"
"../framework/audioStreamOutProc.c", line 1650: warning #179-D: variable "decFlag" was declared but never referenced
"../framework/audioStreamOutProc.c", line 1650: warning #179-D: variable "decFlag1" was declared but never referenced
"../framework/audioStreamOutProc.c", line 928: warning #179-D: function "checkAnyOutDevSel" was declared but never referenced
Finished building: "../framework/audioStreamOutProc.c"
Building file: "../framework/audioStreamOutProc_paramsFxns.c"
Invoking: C6000 Compiler
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/audioStreamOutProc_paramsFxns.d_raw" --obj_directory="framework" --cmd_file="configPkg/compiler.opt" "../framework/audioStreamOutProc_paramsFxns.c"
Finished building: "../framework/audioStreamOutProc_paramsFxns.c"
Building file: "../framework/audioStreamProc_master.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/audioStreamProc_master.d_raw" --obj_directory="framework" --cmd_file="configPkg/compiler.opt" "../framework/audioStreamProc_master.c"
Finished building: "../framework/audioStreamProc_master.c"
Building file: "../framework/dbgIdle.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/dbgIdle.d_raw" --obj_directory="framework" --cmd_file="configPkg/compiler.opt" "../framework/dbgIdle.c"
Finished building: "../framework/dbgIdle.c"
Building file: "../framework/notifyInfoChangeGpio.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/notifyInfoChangeGpio.d_raw" --obj_directory="framework" --cmd_file="configPkg/compiler.opt" "../framework/notifyInfoChangeGpio.c"
Finished building: "../framework/notifyInfoChangeGpio.c"
Building file: "../framework/systemInit.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/systemInit.d_raw" --obj_directory="framework" --cmd_file="configPkg/compiler.opt" "../framework/systemInit.c"
>> Compilation failure
framework/subdir_rules.mk:9: recipe for target 'framework/systemInit.obj' failed
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 446: warning #48-D: incompatible redefinition of macro "Cache_Type" (declared at line 685 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 447: warning #48-D: incompatible redefinition of macro "Cache_Type_L1P" (declared at line 701 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 448: warning #48-D: incompatible redefinition of macro "Cache_Type_L1D" (declared at line 702 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 449: warning #48-D: incompatible redefinition of macro "Cache_Type_L1" (declared at line 703 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 450: warning #48-D: incompatible redefinition of macro "Cache_Type_L2P" (declared at line 704 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 451: warning #48-D: incompatible redefinition of macro "Cache_Type_L2D" (declared at line 705 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 452: warning #48-D: incompatible redefinition of macro "Cache_Type_L2" (declared at line 706 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 453: warning #48-D: incompatible redefinition of macro "Cache_Type_ALLP" (declared at line 707 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 454: warning #48-D: incompatible redefinition of macro "Cache_Type_ALLD" (declared at line 708 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 455: warning #48-D: incompatible redefinition of macro "Cache_Type_ALL" (declared at line 709 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 456: warning #48-D: incompatible redefinition of macro "Cache_enableCache" (declared at line 727 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 457: warning #48-D: incompatible redefinition of macro "Cache_enable" (declared at line 734 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 458: warning #48-D: incompatible redefinition of macro "Cache_disable" (declared at line 736 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 459: warning #48-D: incompatible redefinition of macro "Cache_inv" (declared at line 743 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 460: warning #48-D: incompatible redefinition of macro "Cache_wb" (declared at line 744 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 461: warning #48-D: incompatible redefinition of macro "Cache_wbInv" (declared at line 745 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 462: warning #48-D: incompatible redefinition of macro "Cache_wbAll" (declared at line 747 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 463: warning #48-D: incompatible redefinition of macro "Cache_wbInvAll" (declared at line 749 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 464: warning #48-D: incompatible redefinition of macro "Cache_wait" (declared at line 735 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 465: warning #48-D: incompatible redefinition of macro "Cache_Module_name" (declared at line 751 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 466: warning #48-D: incompatible redefinition of macro "Cache_Module_id" (declared at line 752 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 467: warning #48-D: incompatible redefinition of macro "Cache_Module_startup" (declared at line 753 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 468: warning #48-D: incompatible redefinition of macro "Cache_Module_startupDone" (declared at line 754 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 469: warning #48-D: incompatible redefinition of macro "Cache_Module_hasMask" (declared at line 755 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 470: warning #48-D: incompatible redefinition of macro "Cache_Module_getMask" (declared at line 756 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 471: warning #48-D: incompatible redefinition of macro "Cache_Module_setMask" (declared at line 757 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 472: warning #48-D: incompatible redefinition of macro "Cache_Object_heap" (declared at line 758 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 473: warning #48-D: incompatible redefinition of macro "Cache_Module_heap" (declared at line 759 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 474: warning #48-D: incompatible redefinition of macro "Cache_Module_upCast" (declared at line 760 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"C:/ti/bios_6_76_03_01/packages/ti/sysbios/hal/Cache.h", line 475: warning #48-D: incompatible redefinition of macro "Cache_Module_to_ti_sysbios_interfaces_ICache" (declared at line 761 of "C:/ti/bios_6_76_03_01/packages/ti/sysbios/family/c66/Cache.h")
"../framework/systemInit.c", line 206: error #20: identifier "heapMemL2Sram" is undefined
"../framework/systemInit.c", line 207: error #20: identifier "heapMemMsmcSram" is undefined
"../framework/systemInit.c", line 208: error #20: identifier "heapMemDdr3" is undefined
"../framework/systemInit.c", line 259: error #20: identifier "TaskSystemStream" is undefined
"../framework/systemInit.c", line 276: error #20: identifier "TaskAfp" is undefined
"../framework/systemInit.c", line 277: error #20: identifier "TaskAip" is undefined
"../framework/systemInit.c", line 278: error #20: identifier "TaskAsip" is undefined
"../framework/systemInit.c", line 279: error #20: identifier "TaskAsop" is undefined
8 errors detected in the compilation of "../framework/systemInit.c".
gmake: *** [framework/systemInit.obj] Error 1
Building file: "../framework/systemStream.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/systemStream.d_raw" --obj_directory="framework" --cmd_file="configPkg/compiler.opt" "../framework/systemStream.c"
>> Compilation failure
framework/subdir_rules.mk:9: recipe for target 'framework/systemStream.obj' failed
"../framework/systemStream.c", line 721: error #20: identifier "TaskAsip" is undefined
"../framework/systemStream.c", line 729: error #20: identifier "TaskAsop" is undefined
"../framework/systemStream.c", line 737: error #20: identifier "TaskAip" is undefined
"../framework/systemStream.c", line 745: error #20: identifier "TaskAfp" is undefined
"../framework/systemStream.c", line 753: error #20: identifier "TaskSystemStream" is undefined
5 errors detected in the compilation of "../framework/systemStream.c".
gmake: *** [framework/systemStream.obj] Error 1
Building file: "../framework/itopo/identify.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/itopo/identify.d_raw" --obj_directory="framework/itopo" --cmd_file="configPkg/compiler.opt" "../framework/itopo/identify.c"
Finished building: "../framework/itopo/identify.c"
Building file: "../framework/itopo/params.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/itopo/params.d_raw" --obj_directory="framework/itopo" --cmd_file="configPkg/compiler.opt" "../framework/itopo/params.c"
Finished building: "../framework/itopo/params.c"
Building file: "../framework/itopo/patchs.c"
Invoking: C6000 Compiler
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/itopo/patchs.d_raw" --obj_directory="framework/itopo" --cmd_file="configPkg/compiler.opt" "../framework/itopo/patchs.c"
>> Compilation failure
framework/itopo/subdir_rules.mk:9: recipe for target 'framework/itopo/patchs.obj' failed
"../framework/itopo/patchs.c", line 115: fatal error #1965: cannot open source file "car.h"
1 catastrophic error detected in the compilation of "../framework/itopo/patchs.c".
Compilation terminated.
gmake: *** [framework/itopo/patchs.obj] Error 1
Building file: "../framework/itopo/system.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="framework/itopo/system.d_raw" --obj_directory="framework/itopo" --cmd_file="configPkg/compiler.opt" "../framework/itopo/system.c"
Finished building: "../framework/itopo/system.c"
Building file: "../io/ioBuff.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="io/ioBuff.d_raw" --obj_directory="io" --cmd_file="configPkg/compiler.opt" "../io/ioBuff.c"
Finished building: "../io/ioBuff.c"
Building file: "../io/ioData.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="io/ioData.d_raw" --obj_directory="io" --cmd_file="configPkg/compiler.opt" "../io/ioData.c"
"../io/ioData.c", line 21: warning #48-D: incompatible redefinition of macro "TRUE" (declared at line 323 of "C:/ti/xdctools_3_55_02_22_core/packages/xdc/std.h")
"../io/ioData.c", line 22: warning #48-D: incompatible redefinition of macro "FALSE" (declared at line 320 of "C:/ti/xdctools_3_55_02_22_core/packages/xdc/std.h")
Finished building: "../io/ioData.c"
Building file: "../io/ioPhy.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="io/ioPhy.d_raw" --obj_directory="io" --cmd_file="configPkg/compiler.opt" "../io/ioPhy.c"
Finished building: "../io/ioPhy.c"
Building file: "../io/test/audio_tsk.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="io/test/audio_tsk.d_raw" --obj_directory="io/test" --cmd_file="configPkg/compiler.opt" "../io/test/audio_tsk.c"
Finished building: "../io/test/audio_tsk.c"
Building file: "../io/test/frame_work.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="io/test/frame_work.d_raw" --obj_directory="io/test" --cmd_file="configPkg/compiler.opt" "../io/test/frame_work.c"
Finished building: "../io/test/frame_work.c"
Building file: "../mib/mib.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="mib/mib.d_raw" --obj_directory="mib" --cmd_file="configPkg/compiler.opt" "../mib/mib.c"
Finished building: "../mib/mib.c"
Building file: "../mob/mob.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="mob/mob.d_raw" --obj_directory="mob" --cmd_file="configPkg/compiler.opt" "../mob/mob.c"
Finished building: "../mob/mob.c"
Building file: "../sap/sap.c"
Invoking: C6000 Compiler
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_suppress=1934 --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="sap/sap.d_raw" --obj_directory="sap" --cmd_file="configPkg/compiler.opt" "../sap/sap.c"
"../sap/sap.c", line 814: warning #1219-D: arithmetic on pointer to void or function type
"../sap/sap.c", line 1217: warning #179-D: variable "oldMask" was declared but never referenced
"../sap/sap.c", line 1502: warning #225-D: function "getGlobalAddr" declared implicitly
Finished building: "../sap/sap.c"
Building file: "../sap/sap_csl_mcasp.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_suppress=1934 --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="sap/sap_csl_mcasp.d_raw" --obj_directory="sap" --cmd_file="configPkg/compiler.opt" "../sap/sap_csl_mcasp.c"
Finished building: "../sap/sap_csl_mcasp.c"
Building file: "../sap/sap_mcasp.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_suppress=1934 --diag_suppress=48 --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="sap/sap_mcasp.d_raw" --obj_directory="sap" --cmd_file="configPkg/compiler.opt" "../sap/sap_mcasp.c"
"../sap/sap_mcasp.c", line 204: warning #552-D: variable "fifoBase" was set but never used
Finished building: "../sap/sap_mcasp.c"
Building file: "../sio/dev2utils.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="sio/dev2utils.d_raw" --obj_directory="sio" --cmd_file="configPkg/compiler.opt" "../sio/dev2utils.c"
"../sio/dev2utils.c", line 123: warning #121-D: return value type does not match the function type
"../sio/dev2utils.c", line 127: warning #121-D: return value type does not match the function type
"../sio/dev2utils.c", line 131: warning #121-D: return value type does not match the function type
"../sio/dev2utils.c", line 135: warning #121-D: return value type does not match the function type
"../sio/dev2utils.c", line 139: warning #121-D: return value type does not match the function type
"../sio/dev2utils.c", line 143: warning #121-D: return value type does not match the function type
"../sio/dev2utils.c", line 147: warning #121-D: return value type does not match the function type
"../sio/dev2utils.c", line 151: warning #121-D: return value type does not match the function type
"../sio/dev2utils.c", line 155: warning #121-D: return value type does not match the function type
Finished building: "../sio/dev2utils.c"
Building file: "../sio/sio.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="sio/sio.d_raw" --obj_directory="sio" --cmd_file="configPkg/compiler.opt" "../sio/sio.c"
"../sio/sio.c", line 79: warning #515-D: a value of type "SIO_Callback *" cannot be assigned to an entity of type "SIO2_Callback *"
Finished building: "../sio/sio.c"
Building file: "../sio_dev2/dev2.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="sio_dev2/dev2.d_raw" --obj_directory="sio_dev2" --cmd_file="configPkg/compiler.opt" "../sio_dev2/dev2.c"
Finished building: "../sio_dev2/dev2.c"
Building file: "../sio_dev2/dgn2.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="sio_dev2/dgn2.d_raw" --obj_directory="sio_dev2" --cmd_file="configPkg/compiler.opt" "../sio_dev2/dgn2.c"
Finished building: "../sio_dev2/dgn2.c"
Building file: "../sio_dev2/sio2.c"
"C:/ti/ti-cgt-c6000_8.3.2/bin/cl6x" -mv6600 --abi=eabi --include_path="C:/ti/ti-cgt-c6000_8.3.2/include" --include_path="C:/ti/pdk_k2g_1_0_16/packages/ti/drv/mcasp" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/io" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sap" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/mob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio_dev2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/dwr" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/pcm1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/dec/sng1/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/arc1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ae0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/bm2/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/com" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/del" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/fil/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/ml0/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/src4/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/asp/std" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/enc/pce2/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/acp1/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dcs7/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dib" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/dob" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/sio/paf" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s2" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/s3" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/include" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/f/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/da10x_misc" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/paf/pa/util/statusop_common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/sio" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/itopo" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/framework/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/test_dsp/application/itopo/evmk2g" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/pasrc/common" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/ddp/Dolby_Digital_Plus_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/mat-thd/Dolby_MAT_Decoder_Imp/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/oar/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/car/Source_Code/alpha" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alg" --include_path="C:/ti/processor_sdk_rtos_k2g_6_03_00_106/demos/performance-audio/src/dolby_ip/bmda/Source_Code/alpha" --define=dsp0 --define=DH_BUILD --define=k2g02 --define=SOC_K2G --define=DEVICE_K2G --define=PAF_DEVICE=0xDA000000 --define=NON_CACHE_STATUS --define=INCLUDE_HDMI_CONFIG --define=UARTCALLBACK --define=EVM_K2G -g --diag_warning=225 --diag_wrap=off --display_error_number --mem_model:data=far_aggregates --preproc_with_compile --preproc_dependency="sio_dev2/sio2.d_raw" --obj_directory="sio_dev2" --cmd_file="configPkg/compiler.opt" "../sio_dev2/sio2.c"
Finished building: "../sio_dev2/sio2.c"
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
