We are using Jacinto 7 board for our usecase. We have executables with the .xer5f extension. How to execute/load this in the hardware?
What is the procedure?
Hi Muralidharan,
You can use CCS (to load xer5f) and SBL (to load appimage).
For CCS you can use the instructions here: https://software-dl.ti.com/jacinto7/esd/processor-sdk-rtos-jacinto7/07_03_00_07/exports/docs/psdk_rtos/docs/user_guide/ccs_setup_j721e.html#debugging-without-hlos-running-on-a72-rtos-only-baremetal
For SBL you can use the instructions here: https://software-dl.ti.com/jacinto7/esd/processor-sdk-rtos-jacinto7/07_03_00_07/exports/docs/mcusw/mcal_drv/docs/drv_docs/mcusw_c_ug_top.html#mcusw_build_all_demos
When you build an application in the SDK both xer5f and appimage formats are generated for the output image.
If you need help in running a particular app, I can give you more pointed instructions.
Karan
