CSL library chooses the defined code for c5517 instead of C5515 even after commenting define c5517 in csl_general.h
Other Parts Discussed in Thread: TMS320C5515, TMS320C5517, TMS320C5514, TMS320C5504, TMS320C5505
I recently started programming with ezdsp TMS320C5515 using CSL library.  I read a lot of CSL examples. I commented the #define c5515 on CSL_general.h , but all my csl functions are taking the code defined for c5517 instead of c5515. I am very confused , why this happens. Should i change somewhere else or have i not done it properly ? i am attaching the csl_general.h
* Copyright (c) 2008-2012 Texas Instruments Incorporated.
* Except for those rights granted to you in your license from TI, all rights
* reserved.
* Software License Agreement
* Texas Instruments (TI) is supplying this software for use solely and
* exclusively on TI devices. The software is owned by TI and/or its suppliers,
* and is protected under applicable patent and copyright laws. You may not
* combine this software with any open-source software if such combination would
* cause this software to become subject to any of the license terms applicable
* to such open source software.
* THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
* NO WARRANTIES APPLY TO THIS SOFTWARE, WHETHER EXPRESS, IMPLIED OR STATUTORY.
* EXAMPLES OF EXCLUDED WARRANTIES ARE IMPLIED WARRANTIES OF MERCHANTABILITY
* AND FITNESS FOR A PARTICULAR PURPOSE AND WARRANTIES OF NON-INFRINGEMENT,
* BUT ALL OTHER WARRANTY EXCLUSIONS ALSO APPLY. FURTHERMORE, TI SHALL NOT,
* UNDER ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, CONSEQUENTIAL
* OR PUNITIVE DAMAGES, FOR ANY REASON WHATSOEVER.
/** @file csl_general.h
* @brief CSL general header file
* This file contains the general CSL macros or definitions that are required
* to enable few functionalities specific to the chip revision. This file is
* included in all the cslr files. All the CSL applications should include
* this file.
* Path: \(CSLPATH)\ inc
* Revision History
* 07-Jan-2009 Created
* 28-Apr-2010 Added new macro definitions
* 30-Jun-2010 Added new macro definitions for platforms
* 13-Aug-2010 CSL v2.10 release
* 06-Jul-2011 CSL v2.50 release
* 20-Jun-2012 Removed VC5504/05 chip versions and added C5517 chip version
* 13-Sep-2012 CSL v3.00 release
* 20-Dec-2012 CSL v3.01 release
#ifndef _CSL_GENERAL_H_
#define _CSL_GENERAL_H_
#ifdef __cplusplus
extern "C" {
#endif
* CAUTION: DEFINE EITHER THE MACROS IN PART1 OR PART2.
* DO NOT DEFINE MACROS IN BOTH PARTS.
* PART1: CHIP VERSION MACRO DEFINITION FOR PG2.1 CSL
* Below macros are used to enable the source code specific to chip version
* TMS320C5517C5504.
* 'CHIP_C5517' indicates TMS320C5517 DSP.
* Defining the macro below will enable the code for the DSP TMS320C5517.
/* TMS320C5517 */
//#define CHIP_C5517
/******************************* END OF PART1 *******************************/
* PART2: CHIP VERSION MACRO DEFINITION FOR PG2.0 CSL
* Below macros are used to enable the source code specific to chip versions
* TMS320C5505, TMS320C5515, TMS320C5504, and TMS320C5514.
* Design revision(DesignRev) of the DIE ID regsiter(0x1C43 & 0x1C44) will have
* the value '5' for this chip set.
* 'CHIP_C5505_C5515' indicates TMS320C5505 and TMS320C5515.
* 'CHIP_C5504_C5514' indicates TMS320C5504 and TMS320C5514.
* DSPs TMS320C5505 and TMS320C5515 are similar but certain LDOs not bonded out
* for TMS320C5505 DSP.
* DSPs TMS320C5504 and TMS320C5514 are similar but certain LDOs not bonded out
* for TMS320C5504 DSP.
* DSPs TMS320C55x5 and TMS320C55x4 are having the same peripherals but
* they differ in the internal memory available. 'x' stands for 0 or 1.
* Defining any of the below macros will enable the code for all the DSPs
* TMS320C5504, TMS320C5505, TMS320C5514 and TMS320C5515.
* Current CSL software does not have the code that is specific to TMS320C5504
* and TMS320C5514 DSPs.
#ifndef CHIP_C5517
/* TMS320C5505 and TMS320C5515 */
#define CHIP_C5505_C5515
* Below macro was the used to indicate TMS320C5505 and TMS320C5515 in old
* CSL version. Here it is provided for backward compatibility
#define CHIP_5515
/** Mapping of the old macros to the new macros */
#ifdef CHIP_5515
#endif
/** TMS320C5504 and TMS320C5514 */
#define CHIP_C5504_C5514
* Below macro was the used to indicate TMS320C5504 and TMS320C5514 in old
#define CHIP_5514
#ifdef CHIP_5514
#endif
#endif
/******************************* END OF PART2 *******************************/
* PART3: EVM VERSION MACRO DEFINITION FOR PG2.0 and PG2.1 CSL
* Below macros are used to enable the source code specific to EVM versions
#if (defined(CHIP_C5517))
/** Macro to define platform as C5517 */
#define C5517_EVM
#else
#define C5515_EVM
#if (!(defined(C5515_EVM)))
/** Macro to define platform as C5515 eZdsp */
//#define C5515_EZDSP
#endif
#if ( !((defined(C5515_EVM)) | (defined(C5515_EZDSP))) )
/** Macro to define platform as C5535 eZdsp */
#define C5535_EZDSP
#endif
#endif
/******************************* END OF PART3 *******************************/
#ifdef __cplusplus
#endif
#endif // _CSL_GENERAL_H_
