I am trying the voice pre-processing demo with 6Mic setup. I am using I20,1,2 for configuring Mics 5&6,1&2,3&4 respectively. But during DRC initialisation I am getting not enough heap error as below:
...Initializing DRC
Not enough heap, exiting
Correct me if i am wrong. If the projects works on C5517EVM it should also work on c5535ezdsp as both have same memory capacity.
Please indicate solution if any for this. I have also attached log file and code file.
6153.AudioCodec_DMA.c
/* ============================================================================ * Copyright (c) 2017 Texas Instruments Incorporated. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the * distribution. * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * */ /** @file AudioCodec_DMA.c * * @brief Test code to verify the CSL I2S functionality * * \page page6 I2S EXAMPLE DOCUMENTATION * * \section I2S6 I2S EXAMPLE6 - AUDIO CODEC1 DMA IDLE LOOP * * \subsection I2S6x TEST DESCRIPTION: * 1. Clear SEL_I2C_S0 and SEL_I2C_S1 (IO Expander lines P02,P03) to direct I2C data and scl lines to AIC0. * 2. Set AIC_MCBSP_MODE (IO Expander line P01) to choose AIC mode. * 3. Set SEL_MMC0_I2S to choose I2S mode. (IO Expander line P10). * 4. Send a reset to AIC0 by clearing AIC_RST (IO Expander line P00). * 5. Enable Clk to DMA and I2S0 and bring them out of reset. * 6. Configure I2S0 to be slave, l-justified stereo, loopback-datapack-sign extension disabled, * wordlength 16-bit, Tx on rising edge, L-channel txn when FS low. * 7. Configure DMA channels 0,1,2,3 for L-R I2S audio tx and rx, 1 32-bit burst word, interrupts * enabled, pingpong disabled, auto-reload enabled. * 8. Configure the Audio codec to collect line in over IN2_L and IN2_R, send it over to C5517 * over I2S0 and on the way back, collect data from * C5517 over I2S0, finally send it out of the HPL and HPR. * 9. Start the Rx-dma, and wait for two Rx-DMA transaction complete interrupts. * 10. The received audio data is stored in i2sDmaReadBufLeft and i2sDmaReadBufRight. * 11. Transfer this collected data into i2sDmaWriteBufLeft and i2sDmaWriteBufRight. * 12. Start the Tx-dma channels that will transfer this received data out of C5517 to the headphone. * 13. The process is repeated in a while(1). * * * NOTE: THIS TEST HAS BEEN DEVELOPED TO WORK WITH CHIP VERSIONS C5515/C5517. * MAKE SURE THAT PROPER CHIP VERSION MACRO IS DEFINED IN THE FILE * c55xx_csl\inc\csl_general.h. * * \subsection I2S6y TEST PROCEDURE: * Open the CCS and connect the target (C5515 EVM or C5517 EVM) * Open the project "BF_rt_bios.pjt" and build it * Load the program on to the target * Set the PLL frequency to 100MHz * Run the program and observe the test result * * \subsection I2S6z TEST RESULT: * All the CSL APIs should return success * Audio lineout from PC should be heard in the Headphone * */ /* ============================================================================ * Revision History * ================ * 07th-Aug-2014 Created * 09th-Mar-2016 Header update * ============================================================================ */ #include <log.h> #include <std.h> #include <mbx.h> #include <sem.h> #include <tsk.h> #include "stdio.h" #include "stdlib.h" #include "string.h" /* CSLR include files */ #include "soc.h" #include "cslr.h" #include "cslr_sysctrl.h" /* CSL include files */ #include "csl_gpio.h" #include "csl_i2s.h" #include "csl_dma.h" #include "csl_intc.h" #include "csl_sysctrl.h" #include "pll_control.h" #include "codec_aic3254.h" #include "codec_pcm186x.h" #include "IdleLoop.h" #include "BF_rt_bios_cfg.h" //#define PRINT #ifdef PROFILE_CYCLES #include "csl_gpt.h" #endif #define I2S_INSTANCE ( I2S_INSTANCE2 ) #define DMA_CHAN_TX_L ( CSL_DMA_CHAN4 ) #define DMA_CHAN_TX_R ( CSL_DMA_CHAN5 ) #define DMA_CHAN_RX_L ( CSL_DMA_CHAN6 ) #define DMA_CHAN_RX_R ( CSL_DMA_CHAN7 ) #ifdef INSTANCE3_I2S #define I2S_INSTANCE_2 ( I2S_INSTANCE0 ) #define DMA_CHAN_RX_L2 ( CSL_DMA_CHAN13 ) #define DMA_CHAN_RX_R2 ( CSL_DMA_CHAN14 ) #endif #ifdef INSTANCE0_I2S #define I2S_INSTANCE_3 ( I2S_INSTANCE0 ) #define DMA_CHAN_RX_L3 ( CSL_DMA_CHAN0 ) #define DMA_CHAN_RX_R3 ( CSL_DMA_CHAN1 ) #endif #ifdef PROFILE_CYCLES typedef struct cycles_s { long max; /**< running maximum of cycles */ long avg; /**< running average of cycles (using exponential averaging) */ } cycles_t; extern CSL_Handle hGpt; extern CSL_Config hwConfig; CSL_Status statusInt = 0; Uint32 timeCntInt1= 0; Uint32 timeCntInt2 = 0; cycles_t cyclesDmaInt = {0, 0}; static inline void process_cycles(long cycles, cycles_t * cyclesPtr) { if (cycles > cyclesPtr->max) { cyclesPtr->max = cycles; } cyclesPtr->avg = ((cyclesPtr->avg) * 255 + cycles) >> 8; } #endif extern void VECSTART(void); // defined in vector table CSL_IRQ_Dispatch dispatchTable; CSL_GpioObj gGpioObj; GPIO_Handle hGpio; CSL_I2sHandle hI2s; CSL_DMA_Handle dmaLeftTxHandle; CSL_DMA_Handle dmaRightTxHandle; CSL_DMA_ChannelObj dmaObj0, dmaObj1, dmaObj2, dmaObj3; volatile Uint16 dmaTxFrameCount = 0, dmaRxFrameCount=0; CSL_DMA_Handle dmaLeftRxHandle; CSL_DMA_Handle dmaRightRxHandle; /* Ping/pong buffers for serilizer 1 (I2S2) */ #pragma DATA_ALIGN(i2sDmaWriteBufLeft, 8); Uint32 i2sDmaWriteBufLeft[I2S_DMA_BUF_LEN]; // left Tx write ping/pong buffer #pragma DATA_ALIGN(i2sDmaWriteBufRight, 8); Uint32 i2sDmaWriteBufRight[I2S_DMA_BUF_LEN]; // right Tx write ping/pong buffe #pragma DATA_ALIGN(i2sDmaReadBufLeft, 8); Uint32 i2sDmaReadBufLeft[I2S_DMA_BUF_LEN]; // left Rx read ping/pong buffer #pragma DATA_ALIGN(i2sDmaReadBufRight, 8); Uint32 i2sDmaReadBufRight[I2S_DMA_BUF_LEN]; // right Rx read ping/pong buffer #ifdef INSTANCE3_I2S CSL_I2sHandle hI2s2; /* Ping/pong buffers for serilizer 2 (I2S3) */ #pragma DATA_ALIGN(i2sDmaReadBufLeft2, 8); Uint32 i2sDmaReadBufLeft2[I2S_DMA_BUF_LEN]; // left Rx read ping/pong buffer 2 #pragma DATA_ALIGN(i2sDmaReadBufRight2, 8); Uint32 i2sDmaReadBufRight2[I2S_DMA_BUF_LEN]; // right Rx read ping/pong buffer 2 CSL_DMA_Handle dmaLeftRxHandle2; CSL_DMA_Handle dmaRightRxHandle2; CSL_DMA_ChannelObj dmaObj4, dmaObj5; #endif #ifdef INSTANCE0_I2S CSL_I2sHandle hI2s3; /* Ping/pong buffers for serilizer 3 (I2S0) */ #pragma DATA_ALIGN(i2sDmaReadBufLeft3, 8); Uint32 i2sDmaReadBufLeft3[I2S_DMA_BUF_LEN]; // left Rx read ping/pong buffer 3 #pragma DATA_ALIGN(i2sDmaReadBufRight3, 8); Uint32 i2sDmaReadBufRight3[I2S_DMA_BUF_LEN]; // right Rx read ping/pong buffer 3 CSL_DMA_Handle dmaLeftRxHandle3; CSL_DMA_Handle dmaRightRxHandle3; CSL_DMA_ChannelObj dmaObj6, dmaObj7; #endif // Initializes device CSL_Status DeviceInit(void); #ifndef CHIP_C5517 // USB LDO Switch void UsbLdoSwitch(Uint16 mode); #endif // Initializes DMA CSL_Status DmaInit(void); // GPIO initialization CSL_Status GpioInit(Uint32 ioDir, Uint32 intEn, Uint32 intEdg); // I2S and DMA initialization CSL_Status I2sDmaInit(void); // User defined algorithm void UserAlgorithm(void); // Put CPU in idle void UserIdle(void); // DMA ISR void DmaIsr(void); CSL_Status ioExpander_Setup(void); CSL_Status ioExpander_Read(Uint16 port, Uint16 pin, Uint16 *rValue); CSL_Status ioExpander_Write(Uint16 port, Uint16 pin, Uint16 value); extern int *inFramePtr[]; extern int *buf_Outptr; extern int *buf_Outptr2; void bf_main (void); int bf_process(void); void main(void) { CSL_Status status; // Enable HWA, CPU, DPORT, MPORT, XPORT, and IPORT in ICR */ *(volatile ioport Uint16 *)(0x0001) = 0x000E; /* Execute idle instruction */ asm(" idle"); // enable all the peripherals CSL_SYSCTRL_REGS->PCGCR1 = 0x0000; CSL_SYSCTRL_REGS->PCGCR2 = 0x0000; // enable the CLKOUT to be the PLL #ifdef CHIP_C5517 CSL_SYSCTRL_REGS->CLKOUTCR = 0; #endif printf("Audio Pre-processing Demo for C5517 EVM with CMB\n"); printf("This Demo Will Continuously Get Audio Input from "); printf("CMB, Process the Audio Using BF+ASNR+MSS, then\n"); printf(" Send the Processed Audio to the Left Channel of the On-Board Codec (AIC3204-2)\n"); printf(" Bypass Audio Input from Mic2 of CMB to the Right Channel of the On-Board Codec\n\n"); printf("Please Connect the Headphone to the Audio Output (Headphone) "); printf("Jack (P9)\n\n"); // Initialize the audio DMA TX buffers memset(i2sDmaWriteBufLeft, 0, I2S_DMA_BUF_LEN*sizeof(Uint32)); memset(i2sDmaWriteBufRight, 0, I2S_DMA_BUF_LEN*sizeof(Uint32)); // Initialize DSP status = DeviceInit(); if (status != CSL_SOK) { printf("ERROR: Unable to initialize DSP\n"); exit(EXIT_FAILURE); } #ifdef CHIP_C5517 status = ioExpander_Setup(); if (status != CSL_SOK) { printf("ERROR: ioExpander_Setup Failed\n"); exit(EXIT_FAILURE); } /* Configure I2C address for AIC3204-2 */ status = ioExpander_Write(0, 2, 1);// SEL_I2C_S0 = 1 status = ioExpander_Write(0, 3, 0);// SEL_I2C_S1 = 0 /* Configure SPI2 mux for AIC3204-2 */ status = ioExpander_Write(0, 5, 1);// SPI_I2S2_S0 = 1 status = ioExpander_Write(0, 6, 1); // SPI_I2S2_S1 = 1 /* Release AIC3204 reset */ status = ioExpander_Write(0, 0, 0);// AIC_RST = 0 if (status != CSL_SOK) { printf("ERROR: ioExpander_Write Failed\n"); exit(EXIT_FAILURE); } #endif // Initialize DMA status = DmaInit(); if (status != CSL_SOK) { printf("ERROR: Unable to initialize DMA\n"); exit(EXIT_FAILURE); } #ifndef CHIP_C5517 /* GPIO10 for AIC3204 reset */ Uint32 gpioIoDir = (((Uint32)CSL_GPIO_DIR_OUTPUT)<<CSL_GPIO_PIN10); status = GpioInit(gpioIoDir, 0x00000000, 0x00000000); if (status != CSL_SOK) { printf("ERROR: Unable to initialize GPIO\n"); exit(1); } #endif // Initialize I2S with DMA status = I2sDmaInit(); if (status != CSL_SOK) { printf("ERROR: Unable to initialize I2S and DMA\n"); exit(1); } /* Intialize AIC3204 codec */ status = AIC3254_init(16000, 16000, PLL_MHZ); if (status != CSL_SOK) { printf("ERROR: Unable to initialize AIC3204\n"); exit(1); } /* Intialize PCM1864 codec */ status = PCM186x_init(16000, PLL_MHZ); if (status != CSL_SOK) { printf("ERROR: Unable to initialize PCM186x\n"); exit(1); } /* Set CPUI bit in ICR */ //*(volatile ioport Uint16 *)(0x0001) |= 0x000F; /* Set CPUI, DPORTI, XPORTI, and IPORTI in ICR */ *(volatile ioport Uint16 *)(0x0001) |= 0x016F; /* Enable global interrupt */ IRQ_globalEnable(); if(!dmaRxFrameCount) { /* Start left Rx DMA I2S2 */ status = DMA_start(dmaLeftRxHandle); if (status != CSL_SOK) { printf("I2S Dma Left Rx for I2S2 Failed!!\n"); exit(EXIT_FAILURE); } /* Start right Rx DMA for I2S2 */ status = DMA_start(dmaRightRxHandle); if (status != CSL_SOK) { printf("I2S Dma Right Rx for I2S2 Failed!!\n"); exit(EXIT_FAILURE); } #ifdef INSTANCE3_I2S /* Start left Rx DMA for I2S3 */ status = DMA_start(dmaLeftRxHandle2); if (status != CSL_SOK) { printf("I2S Dma Left Rx for I2S3 Failed!!\n"); exit(EXIT_FAILURE); } /* Start right Rx DMA for I2S3 */ status = DMA_start(dmaRightRxHandle2); if (status != CSL_SOK) { printf("I2S Dma Right Rx for I2S3 Failed!!\n"); exit(EXIT_FAILURE); } #endif #ifdef INSTANCE0_I2S /* Start left Rx DMA for I2S0 */ status = DMA_start(dmaLeftRxHandle3); if (status != CSL_SOK) { printf("I2S Dma Left Rx for I2S0 Failed!!\n"); exit(EXIT_FAILURE); } /* Start right Rx DMA for I2S0 */ status = DMA_start(dmaRightRxHandle3); if (status != CSL_SOK) { printf("I2S Dma Right Rx for I2S0 Failed!!\n"); exit(EXIT_FAILURE); } #endif } if(!dmaTxFrameCount) { /* Start left Tx DMA */ status = DMA_start(dmaLeftTxHandle); if (status != CSL_SOK) { printf("I2S Dma Left Tx Failed!!\n"); exit(EXIT_FAILURE); } /* Start right Tx DMA */ status = DMA_start(dmaRightTxHandle); if (status != CSL_SOK) { printf("I2S Dma Right Tx Failed!!\n"); exit(EXIT_FAILURE); } } /* Enable I2S */ CSL_I2S2_REGS->I2SSCTRL |= 0x8000; #ifdef INSTANCE3_I2S CSL_I2S1_REGS->I2SSCTRL |= 0x8000; /*****************************************/ #endif #ifdef INSTANCE0_I2S CSL_I2S0_REGS->I2SSCTRL |= 0x8000; #endif #ifndef LOOPBACK_ONLY // setup BF, ASNR and MSS bf_main(); #endif printf("Pumping PC lineout to the HP Output Started!!\n"); } void audioLoopTask() { while (1) { #ifdef PRINT printf(" Wait I2S DMA transfer \n\n"); #endif // wait for the I2S DMA is done SEM_pend(&SEM_i2s_dmaTransferDone, SYS_FOREVER); /* Perform your algorithm here */ #ifdef PRINT printf(" User Algorithm \n\n"); #endif UserAlgorithm(); /* Set CPU to Idle */ //UserIdle(); } } //***************************************************************************** // DeviceInit //***************************************************************************** // Description: // Sets up interrupt vector table, // Disables and clears interrupts, // Resets all peripherals, // Sets PLL output to desired MHz, // Disables USB LDO // // Arguments: // none // // Return: // CSL_Status: CSL_SOK - Device initialization successful // other - Device initialization unsuccessful // //***************************************************************************** CSL_Status DeviceInit(void) { Uint16 prcr; CSL_Status status; // Set up dispatch table status = IRQ_init(&dispatchTable, 0); if (status != CSL_SOK) { //printf("IRQ_init() fail, status=%d\n", status); return status; } // Disable global interrupts IRQ_globalDisable(); // Disable all the interrupts IRQ_disableAll(); // Clear any pending interrupts IRQ_clearAll(); // Set the interrupt vector table address status = IRQ_setVecs((Uint32)&VECSTART); if (status != CSL_SOK) { //printf("IRQ_setVecs() fail, status=%d\n", status); return status; } // Reset all peripherals CSL_SYSCTRL_REGS->PSRCR = 0x0020; CSL_SYSCTRL_REGS->PRCR = 0x00BF; do { prcr = CSL_SYSCTRL_REGS->PRCR; } while (prcr != 0); #ifndef CHIP_C5517 // Set PLL output frequency // Note: desired frequency must be allowed for core voltage setting status = pll_sample(PLL_MHZ); if (status != CSL_SOK) { //printf("pll_sample() fail, status=%d\n", status); return status; } // Turn off USB LDO UsbLdoSwitch(0); #else // Set PLL to 200Mhz for C5517 status = pll_sample(200); if (status != CSL_SOK) { printf("pll_sample(200) fail, status=%d\n", status); return status; } #endif return CSL_SOK; } #ifndef CHIP_C5517 //***************************************************************************** // UsbLdoSwitch //***************************************************************************** // Description: Enables/disables USB LDO // // Arguments: // mode: 0 - disable USB LDO // 1 - enable USB LDO // other - no change // // Return: // none // //***************************************************************************** void UsbLdoSwitch(Uint16 mode) { Uint16 pcgcr2; pcgcr2 = CSL_SYSCTRL_REGS->PCGCR2; // save PCGCR2 /* Enable the Analog Register only */ CSL_SYSCTRL_REGS->PCGCR2 &= ~(0x0040); #if (defined(CHIP_C5517)) if (mode == 0) { /* Disable USB LDO (clear bit 0) */ CSL_LDO_REGS->LDOCTRL &= 0xFFFE; } if (mode == 1) { /* Enable USB LDO (set bit 0) */ CSL_LDO_REGS->LDOCTRL |= 0x0001; } #else if (mode == 0) { /* Disable USB LDO (clear bit 0) */ CSL_SAR_REGS->USBLDOCNTL &= 0xFFFE; } if (mode == 1) { /* Enable USB LDO (set bit 0) */ CSL_SAR_REGS->USBLDOCNTL |= 0x0001; } #endif CSL_SYSCTRL_REGS->PCGCR2 = pcgcr2; // restore PCGCR2 } #endif//CHIP_C5517 //***************************************************************************** // DmaInit //***************************************************************************** // Description: Initializes DMA, enables DMA interrupts // // Arguments: // none // // Return: // CSL_Status: CSL_SOK - DMA initialization successful // other - DMA initialization unsuccessful // //***************************************************************************** CSL_Status DmaInit(void) { Uint16 ifrValue; CSL_Status status; // Disable DMA interrupt IRQ_disable(DMA_EVENT); // Clear DMA interrupt IRQ_clear(DMA_EVENT); // Disable DMA interrupts CSL_SYSCTRL_REGS->DMAIER = 0x0000; // Clear pending DMA interrupts ifrValue = CSL_SYSCTRL_REGS->DMAIFR; CSL_SYSCTRL_REGS->DMAIFR |= ifrValue; // Plug in DMA ISR int i; i=IRQ_plug(DMA_EVENT, &DmaIsr); printf("\nDMA Interrupt Enable Status: %d\n",i); // DMA initialization status = DMA_init(); if (status != CSL_SOK) { //printf("DMA_init() fail, status=%d\n", status); return status; } // Enable DMA interrupt IRQ_enable(DMA_EVENT); return CSL_SOK; } #ifndef CHIP_C5517 //***************************************************************************** // GpioInit //***************************************************************************** // Description: Initializes GPIO module // // Arguments: // hGpio - handle to GPIO (global) // gGpioObj - GPIO parameter structure (global) // ioDir - GPIO direction // intEn - GPIO interrupt enables // intEdg - GPIO edge // // Return: // CSL_Status: CSL_SOK - GPIO module initialization successful // other - GPIO module initialization unsuccessful // //***************************************************************************** CSL_Status GpioInit( Uint32 ioDir, Uint32 intEn, Uint32 intEdg ) { CSL_Status status; CSL_GpioConfig config; /* Open GPIO module */ hGpio = GPIO_open(&gGpioObj, &status); if ((hGpio == NULL) || (status != CSL_SOK)) { return status; } /* Reset GPIO module */ status = GPIO_reset(hGpio); if (status != CSL_SOK) { return status; } /* Configure GPIO module */ config.GPIODIRL = ioDir & 0xFFFF; config.GPIODIRH = ioDir >> 16; config.GPIOINTENAL = intEn & 0xFFFF; config.GPIOINTENAH = intEn >> 16; config.GPIOINTTRIGL = intEdg & 0xFFFF; config.GPIOINTTRIGH = intEdg >> 16; status = GPIO_config(hGpio, &config); if (status != CSL_SOK) { return status; } return CSL_SOK; } #endif //***************************************************************************** // I2sDmaInit //***************************************************************************** // Description: // Configures and starts I2S with DMA // // Parameters: // hI2s - I2S handle (global) // dmaLeftTxHandle - handle for I2S left DMA (global) // dmaRightTxHandle - handle for I2S right DMA (global) // // CSL_Status: CSL_SOK - I2S & DMA initialization successful // other - I2S & DMA initialization unsuccessful // //***************************************************************************** CSL_Status I2sDmaInit(void) { I2S_Config hwConfig; CSL_DMA_Config dmaConfig; CSL_Status status; /* DMA engine initialization */ /* Open the device with I2S 2 */ /*(AIC3204-2 is connected to I2S2 on C5517 EVM) */ //hI2s = I2S_open(I2S_INSTANCE, DMA_POLLED, I2S_CHAN_STEREO); if(NULL == hI2s) { status = CSL_ESYS_FAIL; return (status); } else { printf ("I2S2 Module Instance opened successfully\n"); } #ifdef INSTANCE0_I2S // Set Pinmux for I2S0 status = SYS_setEBSR(CSL_EBSR_FIELD_SP0MODE, CSL_EBSR_SP0MODE_1); #endif // Set Pinmux for I2S2 and I2S3 status = SYS_setEBSR(CSL_EBSR_FIELD_PPMODE, CSL_EBSR_PPMODE_6); #ifndef CHIP_C5517 #ifdef INSTANCE3_I2S // Serial Port mode 1 (I2S1 and GP[11:10]). //*(volatile ioport Uint16*)(CSL_SYSCTRL_REGS) |= 0x0800; status = SYS_setEBSR(CSL_EBSR_FIELD_SP1MODE, CSL_EBSR_SP1MODE_2); status = SYS_setEBSR(CSL_EBSR_FIELD_SP1MODE, CSL_EBSR_SP1MODE_1); #endif #endif if(CSL_SOK != status) { printf("SYS_setEBSR failed\n"); return (status); } /* Set the value for the configure structure */ hwConfig.dataFormat = I2S_DATAFORMAT_LJUST; hwConfig.dataType = I2S_STEREO_ENABLE; hwConfig.loopBackMode = I2S_LOOPBACK_DISABLE; hwConfig.fsPol = I2S_FSPOL_HIGH; //I2S_FSPOL_LOW; hwConfig.clkPol = I2S_RISING_EDGE;//I2S_FALLING_EDGE; hwConfig.datadelay = I2S_DATADELAY_ONEBIT; hwConfig.datapack = I2S_DATAPACK_ENABLE; //I2S_DATAPACK_DISABLE; hwConfig.signext = I2S_SIGNEXT_ENABLE; //I2S_SIGNEXT_DISABLE; hwConfig.wordLen = I2S_WORDLEN_16; hwConfig.i2sMode = I2S_SLAVE; hwConfig.clkDiv = I2S_CLKDIV2; // don't care for slave mode hwConfig.fsDiv = I2S_FSDIV32; // don't care for slave mode hwConfig.FError = I2S_FSERROR_DISABLE; hwConfig.OuError = I2S_OUERROR_DISABLE; /* Configure hardware registers */ status = I2S_setup(hI2s, &hwConfig); if(status != CSL_SOK) { return (status); } else { printf ("I2S2 Module Configured successfully\n"); } #ifdef INSTANCE3_I2S /* DMA engine initialization */ /* Open the device with instance 3 */ hI2s2 = I2S_open(I2S_INSTANCE_2, DMA_POLLED, I2S_CHAN_STEREO); if(NULL == hI2s2) { status = CSL_ESYS_FAIL; return (status); } else { printf ("I2S3 ***I2S1*** Module Instance opened successfully\n"); } /* Set the value for the configure structure */ hwConfig.dataFormat = I2S_DATAFORMAT_LJUST; hwConfig.dataType = I2S_STEREO_ENABLE; hwConfig.loopBackMode = I2S_LOOPBACK_DISABLE; hwConfig.fsPol = I2S_FSPOL_HIGH; //I2S_FSPOL_LOW; hwConfig.clkPol = I2S_RISING_EDGE;//I2S_FALLING_EDGE; hwConfig.datadelay = I2S_DATADELAY_ONEBIT; hwConfig.datapack = I2S_DATAPACK_ENABLE; //I2S_DATAPACK_DISABLE; hwConfig.signext = I2S_SIGNEXT_DISABLE; hwConfig.wordLen = I2S_WORDLEN_16; hwConfig.i2sMode = I2S_SLAVE; hwConfig.clkDiv = I2S_CLKDIV2; // don't care for slave mode hwConfig.fsDiv = I2S_FSDIV32; // don't care for slave mode hwConfig.FError = I2S_FSERROR_DISABLE; hwConfig.OuError = I2S_OUERROR_DISABLE; /* Configure hardware registers */ status = I2S_setup(hI2s2, &hwConfig); if(status != CSL_SOK) { return (status); } else { printf ("I2S3 Module Configured successfully\n"); } #endif #ifdef INSTANCE0_I2S /* DMA engine initialization */ /* Open the device with instance 3 */ hI2s3 = I2S_open(I2S_INSTANCE_3, DMA_POLLED, I2S_CHAN_STEREO); if(NULL == hI2s3) { status = CSL_ESYS_FAIL; return (status); } else { printf ("I2S0 Module Instance opened successfully\n"); } /* Set the value for the configure structure */ hwConfig.dataFormat = I2S_DATAFORMAT_LJUST; hwConfig.dataType = I2S_STEREO_ENABLE; hwConfig.loopBackMode = I2S_LOOPBACK_DISABLE; hwConfig.fsPol = I2S_FSPOL_HIGH; //I2S_FSPOL_LOW; hwConfig.clkPol = I2S_RISING_EDGE;//I2S_FALLING_EDGE; hwConfig.datadelay = I2S_DATADELAY_ONEBIT; hwConfig.datapack = I2S_DATAPACK_ENABLE; //I2S_DATAPACK_DISABLE; hwConfig.signext = I2S_SIGNEXT_DISABLE; hwConfig.wordLen = I2S_WORDLEN_16; hwConfig.i2sMode = I2S_SLAVE; hwConfig.clkDiv = I2S_CLKDIV2; // don't care for slave mode hwConfig.fsDiv = I2S_FSDIV32; // don't care for slave mode hwConfig.FError = I2S_FSERROR_DISABLE; hwConfig.OuError = I2S_OUERROR_DISABLE; /* Configure hardware registers */ status = I2S_setup(hI2s3, &hwConfig); if(status != CSL_SOK) { return (status); } else { printf ("I2S0 Module Configured successfully\n"); } #endif /* Configure DMA channel 4 for I2S2 left channel write*/ dmaConfig.pingPongMode = CSL_DMA_PING_PONG_ENABLE; dmaConfig.autoMode = CSL_DMA_AUTORELOAD_ENABLE; dmaConfig.burstLen = CSL_DMA_TXBURST_1WORD; dmaConfig.trigger = CSL_DMA_EVENT_TRIGGER; dmaConfig.dmaEvt = CSL_DMA_EVT_I2S2_TX; dmaConfig.dmaInt = CSL_DMA_INTERRUPT_ENABLE; dmaConfig.chanDir = CSL_DMA_WRITE; dmaConfig.trfType = CSL_DMA_TRANSFER_IO_MEMORY; dmaConfig.dataLen = I2S_DMA_BUF_LEN*4; // frame buffer size in bytes #if (defined(CHIP_C5517)) dmaConfig.destAddr = (Uint32)&CSL_I2S2_REGS->I2STXLTL; #else dmaConfig.destAddr = (Uint32)&CSL_I2S2_REGS->I2STXLT0; #endif dmaConfig.srcAddr = (Uint32)i2sDmaWriteBufLeft; /* Open DMA ch4 for I2S2 left channel write*/ dmaLeftTxHandle = DMA_open(DMA_CHAN_TX_L, &dmaObj0,&status); if (dmaLeftTxHandle == NULL) { printf("DMA_open CH4 Failed \n"); dmaLeftTxHandle = NULL; } /* Configure DMA channel4 */ status = DMA_config(dmaLeftTxHandle, &dmaConfig); if (status != CSL_SOK) { printf("DMA_config CH4 Failed \n"); dmaLeftTxHandle = NULL; } /* Configure DMA ch5 for I2S2 right channel write*/ dmaConfig.pingPongMode = CSL_DMA_PING_PONG_ENABLE; dmaConfig.autoMode = CSL_DMA_AUTORELOAD_ENABLE; dmaConfig.burstLen = CSL_DMA_TXBURST_1WORD; dmaConfig.trigger = CSL_DMA_EVENT_TRIGGER; dmaConfig.dmaEvt = CSL_DMA_EVT_I2S2_TX; dmaConfig.dmaInt = CSL_DMA_INTERRUPT_ENABLE; dmaConfig.chanDir = CSL_DMA_WRITE; dmaConfig.trfType = CSL_DMA_TRANSFER_IO_MEMORY; dmaConfig.dataLen = I2S_DMA_BUF_LEN*4; // frame buffer size in bytes #if (defined(CHIP_C5517)) dmaConfig.destAddr = (Uint32)&CSL_I2S2_REGS->I2STXRTL; #else dmaConfig.destAddr = (Uint32)&CSL_I2S2_REGS->I2STXRT0; #endif dmaConfig.srcAddr = (Uint32)i2sDmaWriteBufRight; /* Open DMA ch5 for I2S2 right channel write*/ dmaRightTxHandle = DMA_open(DMA_CHAN_TX_R, &dmaObj1,&status); if (dmaRightTxHandle == NULL) { printf("DMA_open CH5 Failed \n"); dmaRightTxHandle = NULL; } /* Configure DMA channel5*/ status = DMA_config(dmaRightTxHandle, &dmaConfig); if (status != CSL_SOK) { printf("DMA_config CH5 Failed \n"); dmaRightTxHandle = NULL; } /* Configure DMA channel 6 for I2S2 left channel read */ dmaConfig.pingPongMode = CSL_DMA_PING_PONG_ENABLE; dmaConfig.autoMode = CSL_DMA_AUTORELOAD_ENABLE; dmaConfig.burstLen = CSL_DMA_TXBURST_1WORD; dmaConfig.trigger = CSL_DMA_EVENT_TRIGGER; dmaConfig.dmaEvt = CSL_DMA_EVT_I2S2_RX; dmaConfig.dmaInt = CSL_DMA_INTERRUPT_ENABLE; dmaConfig.chanDir = CSL_DMA_READ; dmaConfig.trfType = CSL_DMA_TRANSFER_IO_MEMORY; dmaConfig.dataLen = I2S_DMA_BUF_LEN*4; // frame buffer size in bytes #if (defined(CHIP_C5517)) dmaConfig.srcAddr = (Uint32)&CSL_I2S2_REGS->I2SRXLTL; #else dmaConfig.srcAddr = (Uint32)&CSL_I2S2_REGS->I2SRXLT0; #endif dmaConfig.destAddr = (Uint32)i2sDmaReadBufLeft; /* Open DMA ch6 for I2S2 left channel read */ dmaLeftRxHandle = DMA_open(DMA_CHAN_RX_L, &dmaObj2,&status); if (dmaLeftRxHandle == NULL) { printf("DMA_open CH6 Failed \n"); dmaLeftRxHandle = NULL; } /* Configure DMA channel6 */ status = DMA_config(dmaLeftRxHandle, &dmaConfig); if (status != CSL_SOK) { printf("DMA_config CH6 Failed \n"); dmaLeftRxHandle = NULL; } /* Configure DMA ch7 for I2S2 right channel read */ dmaConfig.pingPongMode = CSL_DMA_PING_PONG_ENABLE; dmaConfig.autoMode = CSL_DMA_AUTORELOAD_ENABLE; dmaConfig.burstLen = CSL_DMA_TXBURST_1WORD; dmaConfig.trigger = CSL_DMA_EVENT_TRIGGER; dmaConfig.dmaEvt = CSL_DMA_EVT_I2S2_RX; dmaConfig.dmaInt = CSL_DMA_INTERRUPT_ENABLE; dmaConfig.chanDir = CSL_DMA_READ; dmaConfig.trfType = CSL_DMA_TRANSFER_IO_MEMORY; dmaConfig.dataLen = I2S_DMA_BUF_LEN*4; // frame buffer size in bytes #if (defined(CHIP_C5517)) dmaConfig.srcAddr = (Uint32)&CSL_I2S2_REGS->I2SRXRTL; #else dmaConfig.srcAddr = (Uint32)&CSL_I2S2_REGS->I2SRXRT0; #endif dmaConfig.destAddr = (Uint32)i2sDmaReadBufRight; /* Open DMA ch7 for I2S2 right channel read */ dmaRightRxHandle = DMA_open(DMA_CHAN_RX_R, &dmaObj3,&status); if (dmaRightRxHandle == NULL) { printf("DMA_open CH7 Failed \n"); dmaRightRxHandle = NULL; } /* Configure DMA channel */ status = DMA_config(dmaRightRxHandle, &dmaConfig); if (status != CSL_SOK) { printf("DMA_config CH7 Failed \n"); dmaRightRxHandle = NULL; } #ifdef INSTANCE3_I2S /* Configure DMA channel 8 for I2S3 left channel read */ dmaConfig.pingPongMode = CSL_DMA_PING_PONG_ENABLE; dmaConfig.autoMode = CSL_DMA_AUTORELOAD_ENABLE; dmaConfig.burstLen = CSL_DMA_TXBURST_1WORD; dmaConfig.trigger = CSL_DMA_EVENT_TRIGGER; dmaConfig.dmaEvt = CSL_DMA_EVT_I2S1_RX; /******************************/ dmaConfig.dmaInt = CSL_DMA_INTERRUPT_ENABLE; dmaConfig.chanDir = CSL_DMA_READ; dmaConfig.trfType = CSL_DMA_TRANSFER_IO_MEMORY; dmaConfig.dataLen = I2S_DMA_BUF_LEN*4; // frame buffer size in bytes #if (defined(CHIP_C5517)) dmaConfig.srcAddr = (Uint32)&CSL_I2S3_REGS->I2SRXLTL; #else dmaConfig.srcAddr = (Uint32)&CSL_I2S1_REGS->I2SRXLT0; /*******************************/ #endif dmaConfig.destAddr = (Uint32)i2sDmaReadBufLeft2; /* Open DMA ch8 for I2S3 left channel read */ dmaLeftRxHandle2 = DMA_open(DMA_CHAN_RX_L2, &dmaObj4, &status); if (dmaLeftRxHandle2 == NULL) { printf("DMA_open CH8 Failed \n"); dmaLeftRxHandle2 = NULL; } /* Configure DMA channel8 */ status = DMA_config(dmaLeftRxHandle2, &dmaConfig); if (status != CSL_SOK) { printf("DMA_config CH8 Failed \n"); dmaLeftRxHandle = NULL; } /* Configure DMA ch9 for I2S3 right channel read */ dmaConfig.pingPongMode = CSL_DMA_PING_PONG_ENABLE; dmaConfig.autoMode = CSL_DMA_AUTORELOAD_ENABLE; dmaConfig.burstLen = CSL_DMA_TXBURST_1WORD; dmaConfig.trigger = CSL_DMA_EVENT_TRIGGER; dmaConfig.dmaEvt = CSL_DMA_EVT_I2S1_RX; /**********************************/ dmaConfig.dmaInt = CSL_DMA_INTERRUPT_ENABLE; dmaConfig.chanDir = CSL_DMA_READ; dmaConfig.trfType = CSL_DMA_TRANSFER_IO_MEMORY; dmaConfig.dataLen = I2S_DMA_BUF_LEN*4; // frame buffer size in bytes #if (defined(CHIP_C5517)) dmaConfig.srcAddr = (Uint32)&CSL_I2S3_REGS->I2SRXRTL; #else dmaConfig.srcAddr = (Uint32)&CSL_I2S1_REGS->I2SRXRT0; /***********************************/ #endif dmaConfig.destAddr = (Uint32)i2sDmaReadBufRight2; /* Open DMA ch9 for I2S3 right channel read */ dmaRightRxHandle2 = DMA_open(DMA_CHAN_RX_R2, &dmaObj5, &status); if (dmaRightRxHandle2 == NULL) { printf("DMA_open CH9 Failed \n"); dmaRightRxHandle2 = NULL; } /* Configure DMA channel */ status = DMA_config(dmaRightRxHandle2, &dmaConfig); if (status != CSL_SOK) { printf("DMA_config CH9 Failed \n"); dmaRightRxHandle2 = NULL; } #endif #ifdef INSTANCE0_I2S /* Configure DMA channel 8 for I2S0 left channel read */ dmaConfig.pingPongMode = CSL_DMA_PING_PONG_ENABLE; dmaConfig.autoMode = CSL_DMA_AUTORELOAD_ENABLE; dmaConfig.burstLen = CSL_DMA_TXBURST_1WORD; dmaConfig.trigger = CSL_DMA_EVENT_TRIGGER; dmaConfig.dmaEvt = CSL_DMA_EVT_I2S0_RX; dmaConfig.dmaInt = CSL_DMA_INTERRUPT_ENABLE; dmaConfig.chanDir = CSL_DMA_READ; dmaConfig.trfType = CSL_DMA_TRANSFER_IO_MEMORY; dmaConfig.dataLen = I2S_DMA_BUF_LEN*4; // frame buffer size in bytes #if (defined(CHIP_C5517)) dmaConfig.srcAddr = (Uint32)&CSL_I2S0_REGS->I2SRXLTL; #else dmaConfig.srcAddr = (Uint32)&CSL_I2S0_REGS->I2SRXLT0; #endif dmaConfig.destAddr = (Uint32)i2sDmaReadBufLeft3; /* Open DMA ch0 for I2S0 left channel read */ dmaLeftRxHandle3 = DMA_open(DMA_CHAN_RX_L3, &dmaObj6, &status); if (dmaLeftRxHandle3 == NULL) { printf("DMA_open CH0 Failed \n"); dmaLeftRxHandle3 = NULL; } /* Configure DMA channel0 */ status = DMA_config(dmaLeftRxHandle3, &dmaConfig); if (status != CSL_SOK) { printf("DMA_config CH0 Failed \n"); dmaLeftRxHandle3 = NULL; } /* Configure DMA ch1 for I2S0 right channel read */ dmaConfig.pingPongMode = CSL_DMA_PING_PONG_ENABLE; dmaConfig.autoMode = CSL_DMA_AUTORELOAD_ENABLE; dmaConfig.burstLen = CSL_DMA_TXBURST_1WORD; dmaConfig.trigger = CSL_DMA_EVENT_TRIGGER; dmaConfig.dmaEvt = CSL_DMA_EVT_I2S0_RX; dmaConfig.dmaInt = CSL_DMA_INTERRUPT_ENABLE; dmaConfig.chanDir = CSL_DMA_READ; dmaConfig.trfType = CSL_DMA_TRANSFER_IO_MEMORY; dmaConfig.dataLen = I2S_DMA_BUF_LEN*4; // frame buffer size in bytes #if (defined(CHIP_C5517)) dmaConfig.srcAddr = (Uint32)&CSL_I2S0_REGS->I2SRXRTL; #else dmaConfig.srcAddr = (Uint32)&CSL_I2S0_REGS->I2SRXRT0; #endif dmaConfig.destAddr = (Uint32)i2sDmaReadBufRight3; /* Open DMA ch9 for I2S0 right channel read */ dmaRightRxHandle3 = DMA_open(DMA_CHAN_RX_R3, &dmaObj7, &status); if (dmaRightRxHandle3 == NULL) { printf("DMA_open CH1 Failed \n"); dmaRightRxHandle3 = NULL; } /* Configure DMA channel */ status = DMA_config(dmaRightRxHandle3, &dmaConfig); if (status != CSL_SOK) { printf("DMA_config CH1 Failed \n"); dmaRightRxHandle3 = NULL; } #endif return CSL_SOK; } // last DMA transfer type Bool lastDmaType; /* User defined algorithm */ void UserAlgorithm(void) { Uint16 i, offset; CSL_Status status = 0; if (dmaRxFrameCount >= NUM_OF_MICS) { dmaRxFrameCount=0; // get last DMA transfer type lastDmaType = DMA_getLastTransferType(dmaLeftRxHandle, &status); if (status != CSL_SOK) { printf("I2S Dma Left Rx Get Type Failed!!\n"); exit(EXIT_FAILURE); } // set offset for data copy if (lastDmaType==0) offset = 0; // data is in Ping buffer else offset = I2S_DMA_BUF_LEN/2; // data is in Pong buffer /* --- Insert algorithm here --- */ #ifdef LOOPBACK_ONLY for (i=0; i<I2S_DMA_BUF_LEN/2; i++) { // i2sDmaReadBufLeft (I2S2 left) - mic1 */ // i2sDmaReadBufRight (I2S2 right) - mic2 */ // i2sDmaReadBufLeft2 (I2S3 left) - mic4 */ // i2sDmaReadBufRight2 (I2S3 right) - mic3 */ // i2sDmaReadBufLeft3 (I2S0 left) - mic5 */ // i2sDmaReadBufRight3 (I2S0 right) - mic6 */ #ifdef INSTANCE0_I2S // loopback mic1 and mic2 ///i2sDmaWriteBufLeft[offset+i] = i2sDmaReadBufLeft[offset+i]; ///i2sDmaWriteBufRight[offset+i] = i2sDmaReadBufRight[offset+i]; // loopback mic3 and mic4 ///i2sDmaWriteBufLeft[offset+i] = i2sDmaReadBufRight2[offset+i]; ///i2sDmaWriteBufRight[offset+i] = i2sDmaReadBufLeft2[offset+i]; // loopback mic5 and mic6 i2sDmaWriteBufLeft[offset+i] = i2sDmaReadBufLeft3[offset+i]; i2sDmaWriteBufRight[offset+i] = i2sDmaReadBufRight3[offset+i]; #else #ifdef INSTANCE3_I2S // loopback mic1 and mic2 ///i2sDmaWriteBufLeft[offset+i] = i2sDmaReadBufLeft[offset+i]; ///i2sDmaWriteBufRight[offset+i] = i2sDmaReadBufRight[offset+i]; // loopback mic3 and mic4 i2sDmaWriteBufLeft[offset+i] = i2sDmaReadBufRight2[offset+i]; i2sDmaWriteBufRight[offset+i] = i2sDmaReadBufLeft2[offset+i]; #else // loopback mic1 and mic2 i2sDmaWriteBufLeft[offset+i] = i2sDmaReadBufLeft[offset+i]; i2sDmaWriteBufRight[offset+i] = i2sDmaReadBufRight[offset+i]; #endif #endif } #else // BF+ASNR+MSS signal processing // i2sDmaReadBufLeft (I2S2 left) - mic1 */ // i2sDmaReadBufRight (I2S2 right) - mic2 */ // i2sDmaReadBufLeft2 (I2S3 left) - mic4 */ // i2sDmaReadBufRight2 (I2S3 right) - mic3 */ // i2sDmaReadBufLeft3 (I2S0 left) - mic5 */ // i2sDmaReadBufRight3 (I2S0 right) - mic6 */ // set up the input frame pointers // set up the input frame pointers inFramePtr[0] = (int *)(&i2sDmaReadBufLeft[offset]); inFramePtr[1] = (int *)(&i2sDmaReadBufRight[offset]); #ifdef INSTANCE3_I2S inFramePtr[2] = (int *)(&i2sDmaReadBufRight2[offset]); inFramePtr[3] = (int *)(&i2sDmaReadBufLeft2[offset]); #endif #ifdef INSTANCE0_I2S #ifdef INSTANCE3_I2S inFramePtr[4] = (int *)(&i2sDmaReadBufLeft3[offset]); inFramePtr[5] = (int *)(&i2sDmaReadBufRight3[offset]); #else inFramePtr[2] = (int *)(&i2sDmaReadBufRight3[offset]); inFramePtr[3] = (int *)(&i2sDmaReadBufLeft3[offset]); #endif #endif // set up the processed audio output to left ear buf_Outptr = (int *)(&i2sDmaWriteBufLeft[offset]); // set up the processed audio output to right ear buf_Outptr2 = (int *)(&i2sDmaWriteBufRight[offset]); // process next frame bf_process(); #endif } /* Clear DMA frame count */ if(dmaTxFrameCount>=NUM_OF_OUTPUT_CH) { dmaTxFrameCount = 0; } } // Put CPU in idle void UserIdle(void) { /* Set CPUI bit in ICR */ //*(volatile ioport Uint16 *)(0x0001) |= 0x000F; /* Set CPUI, DPORTI, XPORTI, and IPORTI in ICR */ //*(volatile ioport Uint16 *)(0x0001) |= 0x016F; /* Execute idle instruction */ asm(" idle"); } volatile Uint32 dmaIntCount = 0; volatile Uint32 dmaSemCount = 0; // DMA ISR interrupt void DmaIsr(void) { volatile Uint16 ifrValue; #ifdef PRINT printf(" Interrupt \n\n"); #endif #ifdef PROFILE_CYCLES statusInt = GPT_getCnt(hGpt, &timeCntInt1);; #endif /* Clear the DMA interrupt */ ifrValue = CSL_SYSCTRL_REGS->DMAIFR; CSL_SYSCTRL_REGS->DMAIFR |= ifrValue; /* Check for DMA DMA_CHAN_TX_L transfer completion */ if (ifrValue & (1<<DMA_CHAN_TX_L)) { dmaTxFrameCount++; } /* Check for DMA DMA_CHAN_TX_R transfer completion */ if (ifrValue & (1<<DMA_CHAN_TX_R)) { dmaTxFrameCount++; } /* Check for DMA DMA_CHAN_RX_L transfer completion */ if (ifrValue & (1<<DMA_CHAN_RX_L)) { dmaRxFrameCount++; } /* Check for DMA DMA_CHAN_RX_R transfer completion */ if (ifrValue & (1<<DMA_CHAN_RX_R)) { dmaRxFrameCount++; } #ifdef INSTANCE3_I2S /* Check for DMA DMA_CHAN_RX_L2 transfer completion */ if (ifrValue & (1<<DMA_CHAN_RX_L2)) { dmaRxFrameCount++; } /* Check for DMA DMA_CHAN_RX_R2 transfer completion */ if (ifrValue & (1<<DMA_CHAN_RX_R2)) { dmaRxFrameCount++; } #endif #ifdef INSTANCE0_I2S /* Check for DMA DMA_CHAN_RX_L3 transfer completion */ if (ifrValue & (1<<DMA_CHAN_RX_L3)) { dmaRxFrameCount++; } /* Check for DMA DMA_CHAN_RX_R3 transfer completion */ if (ifrValue & (1<<DMA_CHAN_RX_R3)) { dmaRxFrameCount++; } #endif // wait up the audio task when both RX and TX DMAs are done if ((dmaRxFrameCount>=NUM_OF_MICS)&&(dmaTxFrameCount>=NUM_OF_OUTPUT_CH)) { SEM_post(&SEM_i2s_dmaTransferDone); dmaSemCount++; } dmaIntCount++; #ifdef PROFILE_CYCLES statusInt = GPT_getCnt(hGpt, &timeCntInt2); process_cycles((timeCntInt1-timeCntInt2)<<(hwConfig.preScaleDiv+1), &cyclesDmaInt); #endif }
Log_6Mics.txt
Audio Pre-processing Demo for C5517 EVM with CMB This Demo Will Continuously Get Audio Input from CMB, Process the Audio Using BF+ASNR+MSS, then Send the Processed Audio to the Left Channel of the On-Board Codec (AIC3204-2) Bypass Audio Input from Mic2 of CMB to the Right Channel of the On-Board Codec Please Connect the Headphone to the Audio Output (Headphone) Jack (P9) DMA Interrupt Enable Status: 1 I2S2 Module Instance opened successfully I2S2 Module Configured successfully I2S3 ***I2S1*** Module Instance opened successfully I2S3 Module Configured successfully I2S0 Module Instance opened successfully I2S0 Module Configured successfully bf required buffers: Buffer Size(twords) Alignment Volatile address 0 82 1 no 0x0 1 138 0 no 0x0 2 144 0 no 0x0 3 184 1 yes 0x0 4 320 1 yes 0x0 Buffers allocated by SIU for bf: Buffer Size(twords) Alignment Volatile address 0 82 1 no 0x1 1 138 0 no 0x1 2 144 0 no 0x1 3 184 1 yes 0x1 4 320 1 yes 0x1 bf required buffers: Buffer Size(twords) Alignment Volatile address 0 82 1 no 0x0 1 138 0 no 0x0 2 144 0 no 0x0 3 184 1 yes 0x0 4 320 1 yes 0x0 Buffers allocated by SIU for bf: Buffer Size(twords) Alignment Volatile address 0 82 1 no 0x1 1 138 0 no 0x1 2 144 0 no 0x1 3 184 1 yes 0x1 4 320 1 yes 0x1 bf required buffers: Buffer Size(twords) Alignment Volatile address 0 82 1 no 0x0 1 138 0 no 0x0 2 144 0 no 0x0 3 184 1 yes 0x0 4 320 1 yes 0x0 Buffers allocated by SIU for bf: Buffer Size(twords) Alignment Volatile address 0 82 1 no 0x1 1 138 0 no 0x1 2 144 0 no 0x1 3 184 1 yes 0x1 4 320 1 yes 0x1 bf required buffers: Buffer Size(twords) Alignment Volatile address 0 82 1 no 0x0 1 138 0 no 0x0 2 144 0 no 0x0 3 184 1 yes 0x0 4 320 1 yes 0x0 Buffers allocated by SIU for bf: Buffer Size(twords) Alignment Volatile address 0 82 1 no 0x1 1 138 0 no 0x1 2 144 0 no 0x1 3 184 1 yes 0x1 4 320 1 yes 0x1 bf required buffers: Buffer Size(twords) Alignment Volatile address 0 82 1 no 0x0 1 138 0 no 0x0 2 144 0 no 0x0 3 184 1 yes 0x0 4 320 1 yes 0x0 Buffers allocated by SIU for bf: Buffer Size(twords) Alignment Volatile address 0 82 1 no 0x1 1 138 0 no 0x1 2 144 0 no 0x1 3 184 1 yes 0x1 4 320 1 yes 0x1 bf required buffers: Buffer Size(twords) Alignment Volatile address 0 82 1 no 0x0 1 138 0 no 0x0 2 144 0 no 0x0 3 184 1 yes 0x0 4 320 1 yes 0x0 Buffers allocated by SIU for bf: Buffer Size(twords) Alignment Volatile address 0 82 1 no 0x1 1 138 0 no 0x1 2 144 0 no 0x1 3 184 1 yes 0x1 4 320 1 yes 0x1 Buffers requested by NR: Buffer Size(twords) Alignment Volatile 0 44 1 no 1 774 1 yes 2 516 1 yes 3 387 1 yes 4 192 1 no 5 516 1 no 6 14 1 no Buffers allocated for NR: Buffer Size(twords) Alignment Volatile address 0 88 3 no 0x1 1 1552 3 yes 0x1 2 1032 3 yes 0x1 3 776 3 yes 0x1 4 384 2 no 0x1 5 1032 2 no 0x1 6 32 3 no 0x1 Buffers requested by NR: Buffer Size(twords) Alignment Volatile 0 44 1 no 1 774 1 yes 2 516 1 yes 3 387 1 yes 4 192 1 no 5 516 1 no 6 14 1 no Buffers allocated for NR: Buffer Size(twords) Alignment Volatile address 0 88 3 no 0x1 1 1552 3 yes 0x1 2 1032 3 yes 0x1 3 776 3 yes 0x1 4 384 2 no 0x1 5 1032 2 no 0x1 6 32 3 no 0x1 Buffers requested by NR: Buffer Size(twords) Alignment Volatile 0 44 1 no 1 774 1 yes 2 516 1 yes 3 387 1 yes 4 192 1 no 5 516 1 no 6 14 1 no Buffers allocated for NR: Buffer Size(twords) Alignment Volatile address 0 88 3 no 0x1 1 1552 3 yes 0x1 2 1032 3 yes 0x1 3 776 3 yes 0x1 4 384 2 no 0x1 5 1032 2 no 0x1 6 32 3 no 0x1 Buffers requested by NR: Buffer Size(twords) Alignment Volatile 0 44 1 no 1 774 1 yes 2 516 1 yes 3 387 1 yes 4 192 1 no 5 516 1 no 6 14 1 no Buffers allocated for NR: Buffer Size(twords) Alignment Volatile address 0 88 3 no 0x1 1 1552 3 yes 0x1 2 1032 3 yes 0x1 3 776 3 yes 0x1 4 384 2 no 0x1 5 1032 2 no 0x1 6 32 3 no 0x1 Buffers requested by NR: Buffer Size(twords) Alignment Volatile 0 44 1 no 1 774 1 yes 2 516 1 yes 3 387 1 yes 4 192 1 no 5 516 1 no 6 14 1 no Buffers allocated for NR: Buffer Size(twords) Alignment Volatile address 0 88 3 no 0x1 1 1552 3 yes 0x1 2 1032 3 yes 0x1 3 776 3 yes 0x1 4 384 2 no 0x1 5 1032 2 no 0x1 6 32 3 no 0x1 Buffers requested by NR: Buffer Size(twords) Alignment Volatile 0 44 1 no 1 774 1 yes 2 516 1 yes 3 387 1 yes 4 192 1 no 5 516 1 no 6 14 1 no Buffers allocated for NR: Buffer Size(twords) Alignment Volatile address 0 88 3 no 0x1 1 1552 3 yes 0x1 2 1032 3 yes 0x1 3 776 3 yes 0x1 4 384 2 no 0x1 5 1032 2 no 0x1 6 32 3 no 0x1 MSS required buffers: Buffer Size(twords) Alignment Volatile address 0 122 1 no 0x0 Buffers allocated by SIU for MSS: Buffer Size(twords) Alignment Volatile address 0 220 1 no 0x1 ...Initializing DRC Not enough heap, exiting
