Hello
I bought the DM388 a few days ago but I'm having problems. Evaluating the manual, after turning it on, should show a log with the RTSP urls for external connection but nothing appears. I am unable to access the system running on the camera as indicated in the manual.
I'm waiting Below the part of the log initialization.
[ 18.265410] UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 179
[ 18.292797] UBIFS (ubi1:0): recovery needed
[ 18.312412] UBIFS (ubi1:0): recovery completed
[ 18.317043] UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
[ 18.325003] UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 18.335001] UBIFS (ubi1:0): FS size: 35299328 bytes (33 MiB, 278 LEBs), journal size 1777664 bytes (1 MiB, 14 LEBs)
[ 18.345506] UBIFS (ubi1:0): reserved for root: 1667274 bytes (1628 KiB)
[ 18.352159] UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID 9DC7267B-2874-4B37-98CA-7F1DA97C7C15, small LPT model
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org ti81xx ttyS0
Arago 2016.05 ti81xx ttyS0
[ 18.879650] autorun-usecase.sh[112]: wifi: in STA mode
ti81xx login: [ 19.664327] cfg80211: World regulatory domain updated:
[ 19.669618] cfg80211: DFS Master region: unset
[ 19.673999] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 19.683833] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 19.691899] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 19.699957] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 19.708018] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 19.717559] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 19.727100] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 19.735245] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 19.743287] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 20.426556] wl18xx_driver wl18xx.1.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
[ 20.825883] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 20.853194] wlcore: loaded
[ 21.461683] wlcore: PHY firmware version: Rev 8.2.0.0.232
[ 21.575875] random: nonblocking pool is initialized
[ 21.583513] wlcore: firmware booted (Rev 8.9.0.0.48)
[ 21.601809] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 22.966186] cpsw 4a100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 22.974120] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 25.708225] autorun-usecase.sh[112]: SSID: MAP
[ 25.711713] autorun-usecase.sh[112]: SSID: Gabriel Werner
[ 25.713621] autorun-usecase.sh[112]: SSID: Isa
[ 26.099081] <1>SysLink version : 2.21.02.10
[ 26.099081] SysLink module created on Date:Feb 13 2017 Time:19:16:30
[ 26.109767] <1>Trace enabled
[ 26.112664] <1>Trace SetFailureReason enabled
[ 26.217873] autorun-usecase.sh[112]: /dev/mem opened.
[ 26.219617] autorun-usecase.sh[112]: Phy Addr : 0x48181560 Data : 0x00000002
[ 26.224151] autorun-usecase.sh[112]: Phy Addr : 0x48180f10 Data : 0x00000000
[ 26.231170] autorun-usecase.sh[112]: Phy Addr : 0x48180508 Data : 0x00000302
[ 26.232837] autorun-usecase.sh[112]: Phy Addr : 0x48180520 Data : 0x00000002
[ 26.234420] autorun-usecase.sh[112]: Phy Addr : 0x48180524 Data : 0x00000002
[ 26.236048] autorun-usecase.sh[112]: Phy Addr : 0x48180528 Data : 0x00000002
[ 26.239827] autorun-usecase.sh[112]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 26.241662] autorun-usecase.sh[112]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 26.243117] autorun-usecase.sh[112]: DDR IOs RX is shutdown
[ 26.244535] autorun-usecase.sh[112]: Phy Addr : 0x48180a04 Data : 0x00000000
[ 27.172768] autorun-usecase.sh[112]: /opt/ipnc/autorun-usecase.sh: line 52: kill: (228) - No such process
[ 27.196342] autorun-usecase.sh[112]:
[host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
[ 27.204383] autorun-usecase.sh[112]:
[host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00080000 )
[ 27.209488] autorun-usecase.sh[112]:
[host] Setting L3 bandwidth regulator for [ISS ] to [press=[3,3] BW=400, WM Cycles=2500]
[ 27.214834] autorun-usecase.sh[112]:
[host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
[ 27.290115] autorun-usecase.sh[112]: insmod: ERROR: could not insert module sbull.ko: File exists
[ 28.314802] autorun-usecase.sh[112]: mkfs.fat 3.0.28 (2015-05-16)
[ 28.316546] autorun-usecase.sh[112]: unable to get drive geometry, using default 255/63
[ 28.319081] autorun-usecase.sh[112]: /dev/sbulla has 255 heads and 63 sectors per track,
[ 28.327466] autorun-usecase.sh[112]: hidden sectors 0x0000;
[ 28.329311] autorun-usecase.sh[112]: logical sector size is 512,
[ 28.330942] autorun-usecase.sh[112]: using 0xf8 media descriptor, with 1024 sectors;
[ 28.334411] autorun-usecase.sh[112]: drive number 0x80;
[ 28.337606] autorun-usecase.sh[112]: filesystem has 2 16-bit FATs and 4 sectors per cluster.
[ 28.341272] autorun-usecase.sh[112]: FAT size is 1 sector, and provides 247 clusters.
[ 28.343885] autorun-usecase.sh[112]: There is 1 reserved sector.
[ 28.346884] autorun-usecase.sh[112]: Root directory contains 512 slots and uses 32 sectors.
[ 28.352268] autorun-usecase.sh[112]: Volume ID is 9c088a12, no volume label.
[ 28.573690] Mass Storage Function, version: 2009/09/11
[ 28.578964] LUN: removable file: (no medium)
[ 28.608463] LUN: removable file: /dev/sbulla
[ 28.612777] Number of LUNs=1
[ 28.631823] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
[ 28.638914] g_mass_storage gadget: userspace failed to provide iSerialNumber
[ 28.646024] g_mass_storage gadget: g_mass_storage ready
[ 28.689753] autorun-usecase.sh[112]: Creat queue id:0
[ 28.691938] autorun-usecase.sh[112]: queue id:0
[ 28.695418] autorun-usecase.sh[112]: Creat queue id:32769
[ 28.701186] autorun-usecase.sh[112]: queue id:32769
[ 28.706281] autorun-usecase.sh[112]: Creat queue id:65538
[ 28.710116] autorun-usecase.sh[112]: queue id:65538
[ 28.718416] autorun-usecase.sh[112]: Creat queue id:98307
[ 28.727516] autorun-usecase.sh[112]: queue id:98307
[ 28.732373] autorun-usecase.sh[112]: queue id:32769
[ 28.777300] autorun-usecase.sh[112]:
[host] Attached to slave procId 1.
[ 29.919616] autorun-usecase.sh[112]:
[host] Attached to slave procId 0.
[ 29.922305] autorun-usecase.sh[112]:
[host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 1.
[ 30.122148] autorun-usecase.sh[112]:
[host] Started slave procId 1.
[ 30.167617] autorun-usecase.sh[112]:
[host] After Ipc_loadcallback status [0x00000000]
[ 30.210755] autorun-usecase.sh[112]:
[host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 0.
[ 30.212673] autorun-usecase.sh[112]:
[host] Started slave procId 0.
[ 30.214287] autorun-usecase.sh[112]:
[ 30.314934] autorun-usecase.sh[112]:
[host] After Ipc_startcallback status [0x00000000]
[ 30.323420] autorun-usecase.sh[112]:
[ 30.396456] autorun-usecase.sh[112]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 30.398523] autorun-usecase.sh[112]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 30.408722] autorun-usecase.sh[112]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 30.411355] autorun-usecase.sh[112]: [m3vpss ] Received character 's'
[ 30.493285] autorun-usecase.sh[112]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 30.495085] autorun-usecase.sh[112]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 30.496502] autorun-usecase.sh[112]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 30.497834] autorun-usecase.sh[112]: [m3video] Received character 's'
[ 30.510762] autorun-usecase.sh[112]: queue id:65538
[ 30.512661] autorun-usecase.sh[112]: Creat queue id:131076
[ 30.514229] autorun-usecase.sh[112]: queue id:131076
[ 30.515718] autorun-usecase.sh[112]: CPU is TI812x
[ 30.519997] autorun-usecase.sh[112]: vsenable : 0
[ 30.932577] autorun-usecase.sh[112]: Creat queue id:163845
[ 30.934419] autorun-usecase.sh[112]: queue id:163845
[ 30.935862] autorun-usecase.sh[112]: queue id:65538
[ 30.984801] autorun-usecase.sh[112]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 30.986628] autorun-usecase.sh[112]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 30.990860] autorun-usecase.sh[112]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 31.057587] autorun-usecase.sh[112]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 31.059741] autorun-usecase.sh[112]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 31.061402] autorun-usecase.sh[112]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 31.062896] autorun-usecase.sh[112]: [m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 31.064353] autorun-usecase.sh[112]: [m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 31.065869] autorun-usecase.sh[112]: [m3video]
[ 31.067312] autorun-usecase.sh[112]: [m3vpss ] notify_attach rtnVal 0
[ 31.068764] autorun-usecase.sh[112]: [m3video] *** UTILS: CPU KHz = 400000 Khz ***
[ 31.070442] autorun-usecase.sh[112]: [m3video]
[ 31.071944] autorun-usecase.sh[112]: [m3video] 38: SYSTEM : System Common Init in progress !!!
[ 31.073409] autorun-usecase.sh[112]: [m3video] 38: SYSTEM: IPC init in progress !!!
[ 31.074864] autorun-usecase.sh[112]: [m3video] 38: SYSTEM: Attaching to [HOST] ...
[ 31.076353] autorun-usecase.sh[112]: [m3video] 88: SYSTEM: Attaching to [HOST] ...
[ 31.078208] autorun-usecase.sh[112]: [m3vpss ] initProxyServer rtnVal 0
[ 31.079850] autorun-usecase.sh[112]: [m3vpss ]
[ 31.081778] autorun-usecase.sh[112]: [m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
[ 31.083548] autorun-usecase.sh[112]: [m3vpss ]
[ 31.085115] autorun-usecase.sh[112]: [m3vpss ] 67: SYSTEM : System Common Init in progress !!!
[ 31.086663] autorun-usecase.sh[112]: [m3vpss ] 67: SYSTEM: IPC init in progress !!!
[ 31.088194] autorun-usecase.sh[112]: [m3vpss ] 67: SYSTEM: Attaching to [HOST] ...
[ 31.106604] autorun-usecase.sh[112]: [m3vpss ] 117: SYSTEM: Attaching to [HOST] ...
[ 31.118923] autorun-usecase.sh[112]: [m3video] 118: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 31.130174] autorun-usecase.sh[112]: [m3vpss ] 126: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 31.140147] autorun-usecase.sh[112]: [m3video] 118: SYSTEM: Attaching to [VPSS-M3] ...
[ 31.142054] autorun-usecase.sh[112]: [m3vpss ] 126: SYSTEM: Attaching to [VIDEO-M3] ...
[ 31.143869] autorun-usecase.sh[112]: [m3video] 168: SYSTEM: Attaching to [VPSS-M3] ...
[ 31.149474] autorun-usecase.sh[112]: [m3video] 177: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[ 31.151486] autorun-usecase.sh[112]: [m3vpss ] 176: SYSTEM: Attaching to [VIDEO-M3] ...
[ 31.156607] autorun-usecase.sh[112]: [m3video] 177: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 31.160642] autorun-usecase.sh[112]: [m3vpss ] 177: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[ 31.162585] autorun-usecase.sh[112]: [m3vpss ] 177: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 31.164230] autorun-usecase.sh[112]: [m3vpss ] 177: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[ 31.165801] autorun-usecase.sh[112]: [m3vpss ] 178: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[ 31.167391] autorun-usecase.sh[112]: [m3vpss ] 179: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 31.169227] autorun-usecase.sh[112]: [m3vpss ] 180: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[ 31.170978] autorun-usecase.sh[112]: [m3vpss ] 180: SYSTEM: IPC init DONE !!!
[ 31.172575] autorun-usecase.sh[112]: [m3vpss ] 191: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 31.178870] autorun-usecase.sh[112]: [m3vpss ] 191: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 31.180914] autorun-usecase.sh[112]: [m3vpss ] 193: SYSTEM : System Common Init Done !!!
[ 31.182678] autorun-usecase.sh[112]: [m3video] 277: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 31.188069] autorun-usecase.sh[112]: [m3video] 277: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[ 31.189992] autorun-usecase.sh[112]: [m3video] 278: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[ 31.191718] autorun-usecase.sh[112]: [m3video] 279: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 31.193542] autorun-usecase.sh[112]: [m3video] 280: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[ 31.195091] autorun-usecase.sh[112]: [m3video] 280: SYSTEM: IPC init DONE !!!
[ 31.196574] autorun-usecase.sh[112]: [m3video] 291: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 31.198040] autorun-usecase.sh[112]: [m3video] 291: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 31.199635] autorun-usecase.sh[112]: [m3video] 293: SYSTEM : System Common Init Done !!!
[ 31.201291] autorun-usecase.sh[112]: [m3vpss ] 793: SYSTEM : System VPSS Init in progress !!!
[ 31.202825] autorun-usecase.sh[112]: [m3vpss ] === I2C0/2 Clk is active ===
[ 31.204588] autorun-usecase.sh[112]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_1_0
[ 31.206158] autorun-usecase.sh[112]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to ISS_PLATFORM_CPU_REV_2_1
[ 31.207649] autorun-usecase.sh[112]: [m3vpss ] 812: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[ 31.209235] autorun-usecase.sh[112]: [m3vpss ] 812: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[ 31.210867] autorun-usecase.sh[112]: [m3vpss ] 813: SYSTEM: ListElem Shared Addr = 0xbe984180
[ 31.212380] autorun-usecase.sh[112]: [m3vpss ] 815: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[ 31.214322] autorun-usecase.sh[112]: [m3vpss ] 815: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[ 31.216106] autorun-usecase.sh[112]: [m3vpss ] 816: SYSTEM: ListElem Shared Addr = 0xbe987680
[ 31.217693] autorun-usecase.sh[112]: [m3vpss ] 829: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[ 31.219367] autorun-usecase.sh[112]: [m3vpss ] 829: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[ 31.553363] autorun-usecase.sh[112]: [m3vpss ] 830: SYSTEM: ListElem Shared Addr = 0xbe98ab80
[ 31.555081] autorun-usecase.sh[112]: [m3vpss ] 832: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[ 31.556755] autorun-usecase.sh[112]: [m3vpss ] 832: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[ 31.558368] autorun-usecase.sh[112]: [m3vpss ] 833: SYSTEM: ListElem Shared Addr = 0xbe9aa580
[ 31.559894] autorun-usecase.sh[112]: [m3vpss ] 835: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_26] in region 0 ...
[ 31.561578] autorun-usecase.sh[112]: [m3vpss ] 836: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_26] in region 0 ...
[ 31.563199] autorun-usecase.sh[112]: [m3vpss ] 836: SYSTEM: ListElem Shared Addr = 0xbe9c9f80
[ 31.564956] autorun-usecase.sh[112]: [m3vpss ] 842: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in regionApproDrvInit: 7
[ 31.566626] autorun-usecase.sh[112]: queue id:163845
[ 31.568273] autorun-usecase.sh[112]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 31.570131] autorun-usecase.sh[112]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 31.571758] autorun-usecase.sh[112]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 34.287188] autorun-usecase.sh[112]: 0 ...
[ 34.289010] autorun-usecase.sh[112]: [m3vpss ] 842: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[ 34.290873] autorun-usecase.sh[112]: [m3vpss ] 843: SYSTEM: ListElem Shared Addr = 0xbe9e9980
[ 34.292703] autorun-usecase.sh[112]: [m3vpss ] 845: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_30] in region 0 ...
[ 34.294374] autorun-usecase.sh[112]: [m3vpss ] 845: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_30] in region 0 ...
[ 34.296025] autorun-usecase.sh[112]: [m3vpss ] 846: SYSTEM: ListElem Shared Addr = 0xbea03600
[ 34.297759] autorun-usecase.sh[112]: [m3vpss ] 848: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[ 34.299396] autorun-usecase.sh[112]: [m3vpss ] 848: SYSTEM : FVID2 Init in progress !!!
[ 34.301054] autorun-usecase.sh[112]: [m3vpss ] 918: SYSTEM : FVID2 Init in progress DONE !!!
[ 34.302795] autorun-usecase.sh[112]: [m3vpss ] 918: SYSTEM : Device Init in progress !!!
[ 34.304402] autorun-usecase.sh[112]: [m3vpss ] Iss_init called !!!!!!
[ 34.306030] autorun-usecase.sh[112]: [m3vpss ] CPIS_init DONE !!!!!!
[ 34.307719] autorun-usecase.sh[112]: [m3vpss ] initPrms.isI2cInitReq = 1
[ 34.309402] autorun-usecase.sh[112]: [m3vpss ] initPrms.isI2cInitReq = 0
[ 34.311057] autorun-usecase.sh[112]: [m3video] 993: SYSTEM : System Video Init in progress !!!
[ 34.312771] autorun-usecase.sh[112]: [m3video] 993: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[ 34.314402] autorun-usecase.sh[112]: [m3video] 994: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[ 34.316028] autorun-usecase.sh[112]: [m3video] 994: SYSTEM: ListElem Shared Addr = 0xbea1d280
[ 34.317660] autorun-usecase.sh[112]: [m3video] 996: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[ 34.319273] autorun-usecase.sh[112]: [m3video] 997: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[ 34.320987] autorun-usecase.sh[112]: [m3video] 997: SYSTEM: ListElem Shared Addr = 0xbea20780
[ 34.322711] autorun-usecase.sh[112]: [m3video] 1007: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[ 34.324291] autorun-usecase.sh[112]: [m3video] 1007: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[ 34.325958] autorun-usecase.sh[112]: [m3video] 1007: SYSTEM: ListElem Shared Addr = 0xbea23c80
[ 34.327613] autorun-usecase.sh[112]: [m3video] 1010: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_30] in region 0 ...
[ 34.329247] autorun-usecase.sh[112]: [m3video] 1010: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_30] in region 0 ...
[ 34.330930] autorun-usecase.sh[112]: [m3video] 1010: SYSTEM: ListElem Shared Addr = 0xbea3d900
[ 34.332651] autorun-usecase.sh[112]: [m3video] 1012: HDVICP: Doing PRCM for IVAHD[0] ...
[ 34.334248] autorun-usecase.sh[112]: [m3video] 1012: HDVICP: PRCM for IVAHD[0] ... DONE.
[ 34.335899] autorun-usecase.sh[112]: [m3video] 1013: SYSTEM : Initializing Links !!!
[ 34.337585] autorun-usecase.sh[112]: [m3video] 1013: SYSTEM : FREE SPACE : System Heap = 2088976 B, Mbx = 10240 msgs)
[ 34.339227] autorun-usecase.sh[112]: [m3video] 1014: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 34.340972] autorun-usecase.sh[112]: [m3video] 1014: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[ 34.342764] autorun-usecase.sh[112]: [m3video] 1014: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 34.344380] autorun-usecase.sh[112]: [m3video] 1015: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[ 34.345993] autorun-usecase.sh[112]: [m3video] 1016: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 34.347754] autorun-usecase.sh[112]: [m3video] Entered the MctnfLink_init()
[ 34.349424] autorun-usecase.sh[112]: [m3video] 1074: SYSTEM : Initializing Links ... DONE !!!
[ 34.351090] autorun-usecase.sh[112]: [m3video] 1075: SYSTEM : System Video Init Done !!!
[ 34.352824] autorun-usecase.sh[112]: [m3vpss ] Vps_deviceInit Daughter card not detected/connected!
[ 34.354493] autorun-usecase.sh[112]: [m3vpss ] 1112: SYSTEM : Device Init in progress DONE !!!
[ 34.356092] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:0
[ 34.357680] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:1
[ 34.359370] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:2
[ 34.361034] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:3
[ 34.362696] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:5
[ 34.364275] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:7
[ 34.365912] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:9
[ 34.367487] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:10
[ 34.369148] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:12
[ 34.370850] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:13
[ 34.372758] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:14
[ 34.374369] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:16
[ 34.706973] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:18
[ 34.708563] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:20
[ 34.710223] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:22
[ 34.711995] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:24
[ 34.713592] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:26
[ 34.715289] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:28
[ 34.716921] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:30
[ 34.718518] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:32
[ 34.720160] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:34
[ 34.721860] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:36
[ 34.723454] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:38
[ 34.725092] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:39
[ 34.726697] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:41
[ 34.728299] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:43
[ 34.729907] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:45
[ 34.731681] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:47
[ 34.733350] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:48
[ 34.735016] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:50
[ 34.736575] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:52
[ 34.738150] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:54
[ 34.739802] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:56
[ 34.741527] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:57
[ 34.743152] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:59
[ 34.744778] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:61
[ 34.746468] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:63
[ 34.748081] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:64
[ 34.749696] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:65
[ 34.751437] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:66
[ 34.753228] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:67
[ 34.754960] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:69
[ 36.424504] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:70
[ 36.426284] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:71
[ 36.428171] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:72
[ 36.429826] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:74
[ 36.431619] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:75
[ 36.433227] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:77
[ 36.434997] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:79
[ 36.436595] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:80
[ 36.438317] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:81
[ 36.438865] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:82
[ 36.439411] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:83
[ 36.439873] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:85
[ 36.440426] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:86
[ 36.440904] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:87
[ 36.441366] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:88
[ 36.441879] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:89
[ 36.442321] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:90
[ 36.442856] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:91
[ 36.443308] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:92
[ 36.443798] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:94
[ 36.444248] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:96
[ 36.444839] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:97
[ 36.445306] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:99
[ 36.445752] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:101
[ 36.446258] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:102
[ 36.446704] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:104
[ 36.447261] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:106
[ 36.447710] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:108
[ 36.448221] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:110
[ 36.448683] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:111
[ 36.449130] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:112
[ 36.449628] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:114
[ 36.450109] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:115
[ 36.450630] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:117
[ 36.451074] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index[ 36.662147] DMA: Module install successful, device major num = 244
:118
[ 36.451568] autorun-usecase.sh[112]: [m3vpss ] I2C wri[ 36.672332] DRV: Module install successful
te Error,index:119
[ 36.452014] autorun-usecase.sh[112]: [m3[ 36.682035] DRV: Module built on Feb 13 2017 19:26:20
vpss ] I2C write Error,index:120
[ 36.452488] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:122
[ 36.452936] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:123
[ 36.453384] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:124
[ 36.453909] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:125
[ 36.454361] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:126
[ 36.454916] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:127
[ 36.455370] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:128
[ 36.455851] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:129
[ 36.456300] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:130
[ 36.456745] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:131
[ 36.457276] aut[ 36.760582]
[ 36.760582] soc_is_dm38x
orun-usecase.sh[112]: [m3vpss ] I2C write Error,index:132
[ 36.457718] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:133
[ 36.458209] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:134
[ 36.458653] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:135
[ 36.459133] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:136
[ 36.459610] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:137
[ 36.460094] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:138
[ 36.460599] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:139
[ 36.461153] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:140
[ 36.461695] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:141
[ 36[ 36.833457] HDMI W1 rev 4.0
.462162] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,ind[ 36.839824] HDMI CEC Spec version 1.2
ex:142
[ 36.462680] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:144
[ 36.815675] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:145
[ 36.816207] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:146
[ 36.816593] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:147
[ 36.816940] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:148
[ 36.817661] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:149
[ 36.818188] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:150
[ 36.818712] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:151
[ 36.819191] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:152
[ 36.819648] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:153
[ 36.820240] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:154
[ 36.826959] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:155
[ 36.827935] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:156
[ 36.848445] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:157
[ 36.851796] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:159
[ 36.855157] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:160
[ 36.857248] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:161
[ 36.859710] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:162
[ 36.860492] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:163
[ 36.864807] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:164
[ 36.867185] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:165
[ 36.867843] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:166
[ 36.868440] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:168
[ 36.868928] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:169
[ 36.869468] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:170
[ 36.869926] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:171
[ 36.870521] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:173
[ 36.870996] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:174
[ 36.871504] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:175
[ 36.872006] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:176
[ 36.872520] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:177
[ 36.872979] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:178
[ 36.873470] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:179
[ 36.873917] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:180
[ 36.874415] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:182
[ 36.874935] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:183
[ 36.875379] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:185
[ 36.875883] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:186
[ 36.876333] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:188
[ 36.876814] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:190
[ 36.877259] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:192
[ 36.877738] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:194
[ 36.878245] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:196
[ 36.878687] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:198
[ 36.879197] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:200
[ 36.879644] autorun-usecase.sh[112]: [m3vpss ] I2C write Error,index:202
[ 36.880244] autorun-usecase.sh[112]: [m3vpss ] DONE ar0331_lvds/src/issdrv_ar0331Api.c:AR0331_Transplant_DRV_imgsSetRegs:705 !!!
[ 36.880821] autorun-usecase.sh[112]: [m3vpss ] 6220: SYSTEM : System VPSS Init Done !!!
[ 36.983138] autorun-usecase.sh[112]: [m3vpss ] 6220: UTILS: DMA: HWI Create for INT62 !!!
[ 36.986629] autorun-usecase.sh[112]: [m3vpss ] 6221: SYSTEM : Initializing Links !!!
[ 36.987775] autorun-usecase.sh[112]: [m3vpss ] 6221: SY [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 36.988300] autorun-usecase.sh[112]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 36.988851] autorun-usecase.sh[112]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 36.989343] autorun-usecase.sh[112]: [m3vpss ] Received character 't'
[ 36.990403] autorun-usecase.sh[112]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 36.990976] autorun-usecase.sh[112]: [m3video] Remote Debug Shar[ 37.245255] I2C No Ack
[ 36.991456] autorun-usecase.sh[112]:
[ 36.99199[ 37.248431] HDMI failed to read E-EDID
0] autorun-usecase.sh[112]: [m3video] Received character 't'
[ 36.992949] autorun-usecase.sh[112]: rmmod: ERROR: Module osa_kermod is not currently loaded
[ 36.993884] autorun-usecase.sh[112]: queue id:0
[ 37.754755] autorun-usecase.sh[112]:
[host]
[ 37.757071] autorun-usecase.sh[112]:
[host] ORG 0x46c00524: 0
[ 37.757753] autorun-usecase.sh[112]:
[host] NEW 0x46c00524: 2
[ 37.758355] autorun-usecase.sh[112]:
[host]
[ 37.758955] autorun-usecase.sh[112]:
[host] Application Start Completed
[ 37.864200] autorun-usecase.sh[112]:
[host] 0: SYSTEM: System Common Init in progress !!!
[ 37.865124] autorun-usecase.sh[112]:
[host] 1: SYSTEM: IPC init in progress !!!
[ 37.866803] autorun-usecase.sh[112]:
[host] 10: SYSTEM: CPU [DSP] is NOT available on this platform !!!
[ 37.867644] autorun-usecase.sh[112]: [ 37.896587] DMA: ChannelID allocated:4
[host] 11: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [0] !!!
[ 37.868376] autorun-usecase.sh[112]:
[host] 11: SYSTEM: C[ 37.910851] DMA: ChannelID allocated:5
PU [VPSS-M3] syslink proc ID is [1] !!!
[ 37.869085] autorun-usecase.sh[112]:
[host] 12: SYSTEM: CPU [HOST] syslink proc ID is [2] !!!
[ 37.869929] autorun-usecase.sh[112]:
[host] 13: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 37.871323] autorun-usecase.sh[112]:
[host] 14: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[ 37.872249] autorun-usecase.sh[112]:
[host] 14: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
[ 37.872982] autorun-usecase.sh[112]:
[host] 14: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[ 37.875111] autorun-usecase.sh[112]:
[host] 15: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[ 37.876711] autorun-usecase.sh[112]:
[host] 17: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[ 37.878129] autorun-usecase.sh[112]:
[host] 17: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[ 37.879630] autorun-usecase.sh[112]:
[host] 17: SYSTEM: IPC init DONE !!!
[ 37.881403] autorun-usecase.sh[112]:
[host] 18: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[ 37.882934] autorun-usecase.sh[112]:
[host] 19: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[ 37.883771] autorun-usecase.sh[112]:
[host] 19: SYSTEM: ListElem Shared Addr = 0xb55c6580
[ 37.885397] autorun-usecase.sh[112]:
[host] 21: SYSTEM: Creating ListMP [HOST_IPC_OUT_30] in region 0 ...
[ 37.889852] autorun-usecase.sh[112]:
[host] 21: SYSTEM: Creating ListMP [HOST_IPC_IN_30] in region 0 ...
[ 37.890687] autorun-usecase.sh[112]:
[host] 21: SYSTEM: ListElem Shared Addr = 0xb55e0200
[ 37.898041] autorun-usecase.sh[112]:
[host] 24: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[ 37.898681] autorun-usecase.sh[112]:
[host] 24: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[ 37.899209] autorun-usecase.sh[112]:
[host] 24: SYSTEM: ListElem Shared Addr = 0xb55f9e80
[ 37.899733] autorun-usecase.sh[112]:
[host] 26: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
[ 37.900446] autorun-usecase.sh[112]:
[host] 26: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[ 37.901043] autorun-usecase.sh[112]:
[host] 26: SYSTEM: ListElem Shared Addr = 0xb5619880
[ 37.901543] autorun-usecase.sh[112]:
[host] 27: SYSTEM: Creating ListMP [HOST_IPC_OUT_26] in region 0 ...
[ 37.902080] autorun-usecase.sh[112]:
[host] 28: SYSTEM: Creating ListMP [HOST_IPC_IN_26] in region 0 ...
[ 37.902558] autorun-usecase.sh[112]:
[host] 28: SYSTEM: ListElem Shared Addr = 0xb5639280
[ 37.903085] autorun-usecase.sh[112]:
[host] 30: SYSTEM: System Common Init Done !!!
[ 37.903557] autorun-usecase.sh[112]:
[host] Vsys_allocBuf - addr = 0xa736f000,size = 65011712
[ 37.904016] autorun-usecase.sh[112]: ##########pInfo->totalsize 63897600
[ 37.912781] autorun-usecase.sh[112]:
[host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
[ 37.913437] autorun-usecase.sh[112]:
[host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 5
[ 37.917934] autorun-usecase.sh[112]:
[host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered...
[ 37.918590] autorun-usecase.sh[112]:
[host] Vsys_allocBuf - addr = 0xb6f02000,size = 33603
[ 37.923851] autorun-usecase.sh[112]:
[host] DCC buffer allocated for size 33603
[ 37.924755] autorun-usecase.sh[112]:
[host] DCC Default File Intialization Done
[ 37.925498] autorun-usecase.sh[112]:
[host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT
[ 37.996142] autorun-usecase.sh[112]:
[host]
[ 37.996814] autorun-usecase.sh[112]: ********** SMART ANALYTICS USECASE ********
[ 37.997937] autorun-usecase.sh[112]:
[host] ********* Entered Smart Analytics usecase - H264 1080p @60fps + H264 D1 @30fps + MJPEG 1080p @5fps ********
[ 37.998959] autorun-usecase.sh[112]:
[host] 141: MCFW : CPU Revision [ES1.0] !!!
[ 37.999565] autorun-usecase.sh[112]:
[host] 141: MCFW : Detected [UNKNOWN] Board !!!
[ 38.000112] autorun-usecase.sh[112]:
[host] 141: MCFW : Base Board Revision [REV A] !!!
[ 38.651111] DMA: ChannelID allocated:6
[ 38.650199] autorun-usecase.sh[112]:
[host] Vsys_eventHandler:OSA_dmaOpen [ 38.656931] DMA: ChannelID allocated:7
passed with ch id = 6
[ 38.662130] autorun-usecase.sh[112]:
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 7
[ 38.742029] DMA: ChannelID allocated:12
[ 38.741433] [ 38.747657] DMA: ChannelID allocated:13
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 12
[ 38.747169] autorun-usecase.sh[112]:
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 13
[ 38.757562] autorun-usecase.sh[112]: STEM : FREE SPACE : System Heap = 1682768 B, Mbx = 10240 msgs)
[ 38.758396] autorun-usecase.sh[112]: [m3vpss ] 6221: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 38.759298] autorun-usecase.sh[112]: [m3vpss ] 6221: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[ 38.759844] autorun-usecase.sh[112]: [m3vpss ] 6222: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 38.760475] autorun-usecase.sh[112]: [m3vpss ] 6222: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 38.760962] autorun-usecase.sh[112]: [m3vpss ] 6353: SYSTEM : Initializing Links ... DONE !!!
[ 38.761691] autorun-usecase.sh[112]: [m3vpss ] tiedVencs VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 38.762226] autorun-usecase.sh[112]: [m3vpss ] VPS_DCTRL_INST_0
[ 38.762702] autorun-usecase.sh[112]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_DVO2
[ 38.763965] autorun-usecase.sh[112]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI
[ 38.765037] autorun-usecase.sh[112]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD
[ 38.765662] autorun-usecase.sh[112]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDCOMP
[ 38.766181] autorun-usecase.sh[112]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 38.766664] autorun-usecase.sh[112]: [m3vpss ] HDCOMPCLK
[ 38.767189] autorun-usecase.sh[112]: [m3vpss ] 7741: CAMERA: Create in progress !!!
[ 38.767719] autorun-usecase.sh[112]: [m3vpss ] Channel Num Stream 0 Ch 0 ChannelNum 0
[ 38.768242] autorun-usecase.sh[112]: [m3vpss ] Channel Num Stream 1 Ch 0 ChannelNum 1
[ 38.769630] autorun-usecase.sh[112]: [m3vpss ] 7741: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!!
[ 38.770289] autorun-usecase.sh[112]: [m3vpss ] 7742: CAMERA: VIP 0: VID DEC 268436737 (0x10): 0002:20202020:20202020, AUD_STATUS 538976288
[ 38.770814] autorun-usecase.sh[112]: [m3vpss ] Iss_captCreate:1661
[ 38.771329] autorun-usecase.sh[112]: [m3vpss ] 7951: CAMERA: Create Done !!!
[ 38.771808] autorun-usecase.sh[112]: [m3vpss ] 8039: CAMERA: Detect video in progress !!!
[ 38.772265] autorun-usecase.sh[112]: [m3vpss ] 8040: CAMERA: Detect video Done !!!
[ 38.772784] autorun-usecase.sh[112]: [m3vpss ] 8112: DUP : Create Done !!!
[ 38.773235] autorun-usecase.sh[112]: [m3vpss ] 8112: IPC_OUT_M3 : Create in progress !!!
[ 38.773966] autorun-usecase.sh[112]: [m3video] 8114: IPC_IN_M3 : Create in progress !!!
[ 38.774459] autorun-usecase.sh[112]: [m3vpss ] 8114: IPC_OUT_M3 : Create Done !!!
[ 38.775017] autorun-usecase.sh[112]: [m3video] 8114: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_1] ...
[ 38.775491] autorun-usecase.sh[112]: [m3vpss ] DCC server task running
[ 38.776705] autorun-usecase.sh[112]: [m3video] 8115: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_1] ...
[ 38.777311] autorun-usecase.sh[112]: [m3video] 8118: IPC_IN_M3 : Create Done !!!
[ 38.778544] autorun-usecase.sh[112]: [m3video] Entered the MctnfLink_tskMain()
[ 38.779650] autorun-usecase.sh[112]: [m3video] inChInfo->width = 1920
[ 38.780276] autorun-usecase.sh[112]: [m3video] inChInfo->height = 1080
[ 38.780902] autorun-usecase.sh[112]: [m3video] inChInfo->pitch[0] = 1984
[ 38.781473] autorun-usecase.sh[112]: [m3video] MCTNF Algorithm Instance Creation for the Module MCTNF_TI DEV.500.V.MCTNF.IVAHD.00.13.01.00 Done...
[ 38.782048] autorun-usecase.sh[112]: [m3video] [MCTNF] startX = 0
[ 38.782523] autorun-usecase.sh[112]: [m3vpss ] 8297: IPC_IN_M3 : Create in progress !!!
[ 38.783848] autorun-usecase.sh[112]: [m3video] [MCTNF] startY = 0
[ 38.784490] autorun-usecase.sh[112]: [m3vpss ] 8297: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[ 38.785275] autorun-usecase.sh[112]: [m3video] [MCTNF] outChInfo->width = 1920
[ 38.785783] autorun-usecase.sh[112]: [m3vpss ] 8298: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[ 38.786358] autorun-usecase.sh[112]: [m3video] [MCTNF] outChInfo->height = 1080
[ 38.786827] autorsh[112]: [m3vpss ] SCLR:HEAPID:0 USED:64
[ 39.132954] autorun-usecase.sh[112]: [m3vpss ] SCLR:HEAPID:1 USED:5952
[ 39.133419] autorun-usecase.sh[112]: [m3vpss ] 8532: SCLR: Create Done !!!
[ 39.133860] autorun-usecase.sh[112]: [m3vpss ] 8539: DUP : Create Done !!!
[ 39.134547] autorun-usecase.sh[112]: [m3vpss ] 8478: VA : Create Done !!!
[ 39.135188] autorun-usecase.sh[112]: [m3vpss ] 8489: VA : ALG Init Done !!!
[ 39.135768] autorun-usecase.sh[112]: [m3vpss ] 85ApproDrvInit: 3
[ 39.136300] autorun-usecase.sh[112]: queue id:163845
[ 39.136774] autorun-usecase.sh[112]: queue id:0
[ 39.137219] autorun-usecase.sh[112]: queue id:32769
[ 40.761804] autorun-usecase.sh[112]: queue id:0
[ 56.767976] autorun-usecase.sh[112]: TimeOut occure in boot_proc.
[ 56.768748] autorun-usecase.sh[112]: Program exit.
[ 60.763694] autorun-usecase.sh[112]: TimeOut occure in boot_proc.
[ 60.764418] autorun-usecase.sh[112]: Program exit.
Thank you
