  • TI Thinks Resolved
AM4379: T Topology Balanced Design
Genius 11295 points
Part Number: AM4379
For the following reference design http://www.ti.com/tool/TIDEP0012 Customer is looking for:
1. In Allegro .alg format to allow import into Altium
2. Design and layout guideline for T-Topology design
3. Guidance on configuring EMIF Tool http://www.ti.com/tool/sitara-ddr-config-tool for T-Topology application
  • Hi Lawrence,
    1) Although Altium does have a conversion tool we can't make any guarantees concerning the validity of the conversion. Conversion between one program and another often include errors or misinterpretations.
    2) I don't have any additional guidance. Micron has an extremely detailed app note which describes the difficulties in implementing a balanced-T layout. Full simulation should be preformed to ensure signal integrity.
    3) I will check with the team supporting the tool.
    Regards, Bill
    If you need more help, please reply back. If your question is answered, please click  Verify Answer
  • In reply to Bill Taboada:
    Hi Bill,
    That's perfect fine about the conversion tool may introduce error. I will set the right expectation with the customer.
    Lawrence
  • In reply to Lawrence Wong:
    Hi Lawrence,
    I have discussed this with the team and we highly recommend that the customer implement the design using the fly-by implementation described in the data manual. Implementing the layout with balanced-T should only be attempted if the customer is prepared to do extensive simulation to ensure that the signal integrity is adequate for each of the DDR signals at each of the devices. While this was implemented on the starter kit, it is not recommended for customers that don't have extensive knowledge of DDR3 implementation.
    Regards, Bill
    Hi Lawrence,
    Although there is the TI design and the layout example for the AM437 Starter Kit, it's clear to me that we don't have a good support model for the balenced-T implementation. I've requested information from other team members but haven't received many responses at this time. I'm going to close this ticket for now. If you have additional questions let me know and I will contact you if I receive more information.
    Regards, Bill
