Tool/software: TI-RTOS
Hello all,
We have a problem in loading the firmware & start immediately the apps.out service as part of systemd services. If we start apps.out service after 2 seconds, it is working. This will affect our KPI for bootlogo.
Can you please support in solving this issue.?
"[0][ 0.342] 2.836058 s: CHAINS: Application Started !!! 2.836332 s: SYSTEM: ERROR: No link registered at link ID [88] !!!
root@mmt2020-a880:~# cat /sys/kernel/debug/remoteproc/remoteproc0/trace0
[0][ 0.000] 18 Resource entries at 0x3000
[0][ 0.000] 2.494631 s: SYSTEM: System Common Init in progress !!!
[0][ 0.010] 2.504148 s: SYSTEM: IPC init in progress !!!
[0][ 0.010] 2.504392 s: SYSTEM: Notify init done !!!
[0][ 0.012] 2.506191 s: SYSTEM: MsgQ init done !!!
[0][ 0.013] 2.507198 s: RpmsgInit in progress...
[0][ 0.013] 2.507381 s: Connection established with HLOS, calling rpmsgInit
[0][ 0.014] registering rpmsg-proto:rpmsg-proto service on 80 with HOST
[0][ 0.014] 2.508174 s: SYSTEM: IPC init DONE !!!
[0][ 0.020] 2.514640 s: SYSTEM: System Common Init Done !!!
[0][ 0.021] 2.514853 s: SYSTEM: System Init in progress !!!
[0][ 0.021] 2.515067 s: SYSTEM: BSP Common Init in progress !!!
[0][ 0.021] 2.515250 s: SYSTEM: BSP Common Init Done !!!
[0][ 0.021] 2.515433 s: SYSTEM: BSP Platform Init in progress !!!
[0][ 0.021] 2.515646 s: SYSTEM: BSP Platform Init Done !!!
[0][ 0.021] 2.515799 s: SYSTEM: FVID2 Init in progress !!!
[0][ 0.022] 2.516073 s: SYSTEM: FVID2 Init Done !!!
[0][ 0.022] 2.516226 s: SYSTEM: VPS Init in progress !!!
[0][ 0.022] 2.516409 s: SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0x80000000 -> 0x80000000]
[0][ 0.025] 2.519398 s: *** VPDMA Firmware Loading... ***
[0][ 0.025] 2.519642 s: VPDMA Firmware Address = 0xa034a500
[0][ 0.026] 2.519856 s: VPDMA Load Address = 0x4897d004
[0][ 0.026] 2.520100 s: VPDMA Firmware Version = 0x4d0001b8
[0][ 0.026] 2.520283 s: VPDMA List Busy Status = 0x00000000
[0][ 0.026] 2.520466 s: *** VPDMA Firmware Load Success ***
[0][ 0.026]
[0][ 0.027] 2.520923 s: *** VPDMA Firmware Loading... ***
[0][ 0.027] 2.521137 s: VPDMA Firmware Address = 0xa034a500
[0][ 0.027] 2.521320 s: VPDMA Load Address = 0x4899d004
[0][ 0.027] 2.521533 s: VPDMA Firmware Version = 0x4d0001b8
[0][ 0.027] 2.521747 s: VPDMA List Busy Status = 0x00000000
[0][ 0.028] 2.521930 s: *** VPDMA Firmware Load Success ***
[0][ 0.028]
[0][ 0.028] 2.522387 s: *** VPDMA Firmware Loading... ***
[0][ 0.028] 2.522601 s: VPDMA Firmware Address = 0xa034a500
[0][ 0.028] 2.522784 s: VPDMA Load Address = 0x489bd004
[0][ 0.029] 2.523028 s: VPDMA Firmware Version = 0x4d0001b8
[0][ 0.029] 2.523211 s: VPDMA List Busy Status = 0x00000000
[0][ 0.029] 2.523394 s: *** VPDMA Firmware Load Success ***
[0][ 0.029]
[0][ 0.084] 2.578753 s: SYSTEM: VPS Init Done !!!
[0][ 0.085] 2.579698 s: UTILS: DMA: HWI Create for INT34 !!!
[0][ 0.086] 2.580125 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[0][ 0.086] 2.580400 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 260672 B (254 KB)
[0][ 0.087] 2.580796 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
[0][ 0.087] 2.581162 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x86203000, Total size = 67108864 B (64 MB), Free size = 67108864 B (64 MB)
[0][ 0.087] 2.581589 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xa0100000, Total size = 1047168 B (0 MB), Free size = 1047168 B (0 MB)
[0][ 0.088] 2.581986 s: SYSTEM: Initializing Links !!!
[0][ 0.341] 2.835509 s: SYSTEM: Initializing Links ... DONE !!!
[0][ 0.353] 2.847190 s: BOARD: Board Init in progress !!!
[0][ 0.353] 2.847739 s: BOARD: Board Init Done !!!
[0][ 0.362] 2.856280
Gokul
