Hi Team,
Can you please assist with the register mapping request below from my customer?:
Antonio
Hi Team,
Antonio
Hi Antonio,
The customer doesn't have to change the kernel driver at all, the requirement can be achieved using kernel sysfs:
- to turn off USB1 DRVVBUS:
# echo musb-hdrc.1 > /sys/bus/platform/drivers/musb-hdrc/unbind
- to turn on USB1 DRVVBUS:
# echo musb-hdrc.1 > /sys/bus/platform/drivers/musb-hdrc/bind
The driver bind/unbind should work on all kernel versions.
Please share the output of command 'ls /sys/bus/platform/drivers/musb-hdrc'.
And please run the following script on the board and share its output.
#!/bin/bash # # Util to check USB subsystem for Linux kernel 3.12+ on TI Sitara devices # # Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/ # # # Redistribution and use in source and binary forms, with or without # modification, are permitted provided that the following conditions # are met: # # Redistributions of source code must retain the above copyright # notice, this list of conditions and the following disclaimer. # # Redistributions in binary form must reproduce the above copyright # notice, this list of conditions and the following disclaimer in the # documentation and/or other materials provided with the # distribution. # # Neither the name of Texas Instruments Incorporated nor the names of # its contributors may be used to endorse or promote products derived # from this software without specific prior written permission. # # THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS # "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT # LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR # A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT # OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, # SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT # LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, # DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY # THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT # (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE # OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. VERSION=0.2.8 ### functions ### # $1 command to be checked check_command() { local _cmd=$1 which $_cmd > /dev/null || { echo "Error: $_cmd command not found" exit 1 } } # check if the kernel is supported # this tool only runs on v3.12+ kernel # return 0 - if kernel version >= 3.12 # 1 - if kernel version < 3.12 has_supported_kernel() { local _ver local _t check_command uname uname -a _ver=`uname -r` _t=${_ver%%.*} # 2.x.x, unsupported [ $_t -ge 3 ] || return 1 # 4.x.x, supported [ $_t -lt 4 ] || return 0 _ver=${_ver#*.} _t=${_ver%%.*} # < 3.12.x, unsupported [ $_t -ge 12 ] || return 1 return 0 } # check if the platform is supported # $PLATFORM - global variable # return 0 - if platform is supported # 1 - if platform is not supported check_platform () { local _hw check_command grep [ "$PLATFORM" != "" ] || { _hw=`cat /proc/device-tree/compatible | tr '\0' ' '` DBG_PRINT $_hw if [[ "$_hw" == *"ti,am33xx"* ]]; then PLATFORM="am335x" elif [[ "$_hw" == *"ti,am43"* ]]; then PLATFORM="am437x" elif [[ "$_hw" == *"ti,dra7"* ]]; then PLATFORM="am57x" elif [[ "$_hw" == *"ti,k2g"* ]]; then PLATFORM="keystone" elif [[ "$_hw" == *"ti,da850"* ]]; then PLATFORM="omapl1" elif [[ "$_hw" == *"ti,am654"* ]]; then PLATFORM="am65x" else PLATFORM=$_hw fi } DBG_PRINT $PLATFORM case $PLATFORM in "am335x") USB0='/ocp/usb@47400000/usb@47401000' USB1='/ocp/usb@47400000/usb@47401800' return 0;; "am437x") USB0='/ocp/omap_dwc3@48380000/usb@48390000' USB1='/ocp/omap_dwc3@483c0000/usb@483d0000' return 0;; "am57x") USB0='/ocp/omap_dwc3_1@48880000/usb@48890000' USB1='/ocp/omap_dwc3_2@488c0000/usb@488d0000' return 0;; "keystone") USB0='/ocp/omap_dwc3_1@48880000/usb@48890000' USB1='/ocp/omap_dwc3_2@488c0000/usb@488d0000' return 0;; "omapl1") USB0='/soc@1c00000/usb@200000' USB1='' return 0;; "am65x") USB0='/soc0/dwc3@4000000/usb@10000' USB1='/soc0/dwc3@4020000/usb@10000' return 0;; *) echo "Unsupported \"$PLATFORM\"" return 1;; esac } # check a kernel CONFIG option # params $1 - the config option # $2 = '-q', quiet output # return 0 - undefined # 1 - defined as 'm', kernel module # 2 - defined as 'y', kernel builtin check_kernel_config() { local _cfg [ -n "$1" ] || return 0 check_command zcat _cfg=`zcat /proc/config.gz | grep "^$1\>"` case ${_cfg#*=} in "y") return 2;; "m") return 1;; *) [ "$2" = "-q" ] || echo "Error: $1 is undefined in kernel config" return 0;; esac } # check a kernel module # $1 - module name, relative path from drivers/, with .ko surfix # return 0 - found # 1 - error check_module() { local _modname local _moddep [ -n "$1" ] || return 1 _modname="/lib/modules/`uname -r`/kernel/drivers/${1}.ko" _moddep="/lib/modules/`uname -r`/modules.dep" DBG_PRINT 1 [ -f $_modname ] || { echo "Error: $_modname not found." echo " Please ensure 'make module_install' is done properly." return 1 } DBG_PRINT 2 [ -f $_moddep ] || $moddep_checked || { echo "Error: $_moddep not found." echo " Please ensure 'make module_install' is done properly." moddep_checked=true } DBG_PRINT 3 check_command lsmod check_command basename check_command tr lsmod | grep `basename $1 | tr '-' '_'` > /dev/null || { DBG_PRINT ">>>> ${1}.ko:" if grep "${1}.ko:" $_moddep > /dev/null; then DBG_PRINT 5 echo "Error: $_moddep seems to be valid," echo " but `basename $1`.ko is not loaded." echo " Please provide /proc/config.gz and /lib/module/`uname -r`/*" echo " for further investigation." else DBG_PRINT 6 echo "Error: `basename $1`: $_moddep is invalid." echo " Please run command 'depmod' on the target to re-generate it," echo " then reboot the target. If the issue still exists, please" echo " ensure 'make module_install' is done properly." fi DBG_PRINT 7 return 1 } DBG_PRINT 8 return 0 } # check kernel config, and modules (if CONFIG_*=M) for musb check_musb_drivers() { check_kernel_config CONFIG_USB_MUSB_HDRC [ $? != 1 ] || check_module 'usb/musb/musb_hdrc' check_kernel_config CONFIG_USB_MUSB_DUAL_ROLE -q [ $? != 0 ] || echo "Warning: CONFIG_USB_MUSB_DUAL_ROLE undefined." case $PLATFORM in am335x) check_kernel_config CONFIG_USB_MUSB_DSPS [ $? != 1 ] || { check_module 'usb/musb/musb_dsps' check_module 'usb/musb/musb_am335x' } ;; omapl1) check_kernel_config CONFIG_USB_MUSB_DA8XX [ $? != 1 ] || check_module 'usb/musb/da8xx' ;; esac case $PLATFORM in am335x) check_kernel_config CONFIG_AM335X_PHY_USB [ $? != 1 ] || { check_module 'usb/phy/phy-am335x' check_module 'usb/phy/phy-am335x-control' } ;; omapl1) check_kernel_config CONFIG_NOP_USB_XCEIV [ $? != 1 ] || check_module 'usb/phy/phy-generic' ;; esac check_kernel_config CONFIG_MUSB_PIO_ONLY -q [ $? != 0 ] || { if check_kernel_config CONFIG_TI_CPPI41 -q; then echo "Error: MUSB CPPI DMA mode is enabled, but CPPI moudle is not enabled in DMA Engine." echo " Please enable CONFIG_TI_CPPI41 under DMA Engine Support in kernel config." fi } } # check kernel config, and modules (if CONFIG_*=M) for dwc3 check_dwc3_drivers() { check_kernel_config CONFIG_USB_DWC3 [ $? != 1 ] || check_module 'usb/dwc3/dwc3' check_kernel_config CONFIG_USB_DWC3_DUAL_ROLE -q [ $? != 0 ] || echo "Warning: CONFIG_USB_DWC3_DUAL_ROLE undefined." check_kernel_config CONFIG_USB_OTG -q [ $? != 0 ] || echo "Warning: CONFIG_USB_OTG undefined, which is required for DRD mode." check_kernel_config CONFIG_USB_DWC3_OMAP [ $? != 1 ] || check_module 'usb/dwc3/dwc3-omap' check_kernel_config CONFIG_USB_XHCI_HCD [ $? != 1 ] || { check_module 'usb/host/xhci-plat-hcd' check_module 'usb/host/xhci-hcd' } check_kernel_config CONFIG_OMAP_CONTROL_PHY [ $? != 1 ] || check_module 'phy/phy-omap-control' if [ $PLATFORM = am437x ]; then check_kernel_config CONFIG_OMAP_USB2 [ $? != 1 ] || check_module 'phy/phy-omap-usb2' else check_kernel_config CONFIG_TI_PIPE3 [ $? != 1 ] || check_module 'phy/phy-ti-pipe3' fi } check_musb_dt() { local _dt_dir local _ent local _sts case $PLATFORM in am335x) _dt_dir='/proc/device-tree/ocp/usb@47400000' _ent='. control@44e10620 usb-phy@47401300 usb-phy@47401b00 dma-controller@47402000' ;; omapl1) _dt_dir='/proc/device-tree/soc@1c00000' _ent='usb@200000 chip-controller@1417c/usb-phy usb@200000/dma-controller@201000' ;; *) return ;; esac for _t in $_ent; do _sts=$(tr -d '\0' <${_dt_dir}/${_t}/status) [ "$_sts" != "disabled" ] || echo $_t: disabled in devicetree done } ### debug ### g_log_file=/tmp/chkusb.log DBG_ENABLE() { g_dbg_enabled=true; } DBG_DISABLE() { g_dbg_enabled=false; } DBG_LOG_RESET() { ! $g_dbg_enabled || echo > $g_log_file; } DBG_PRINT() { ! $g_dbg_enabled || echo "$(date +%H:%M:%S) [$(basename $0)]: $*"; } DBG_LOG() { DBG_PRINT $* >> $g_log_file; } DBG_LOG_MARK() { DBG_PRINT "----------------" >> $g_log_file; } ### main #### moddep_checked=false echo "chkusb.sh Version $VERSION" [ "$V" = "1" ] && DBG_ENABLE && DBG_LOG_RESET || DBG_DISABLE has_supported_kernel || { echo "Unsupported kernel version: `uname -r`"; exit 1; } check_platform || exit 2 DBG_PRINT device: $PLATFORM check_command lsusb if lsusb > /dev/null 2>&1; then echo "USB is initialized" else echo "USB initialization failed" fi # check kernel configs if [ -f /proc/config.gz ]; then case $PLATFORM in am335x | omapl1) check_musb_drivers;; am437x | am57x | keystone | am65x) check_dwc3_drivers;; *) echo "Error: unsupported platform $PLATFORM" exit 5;; esac else echo "Error: /proc/config.gz not found" fi case $PLATFORM in am335x | omapl1) _debugfs=`sed -ne 's/^debugfs \(.*\) debugfs.*/\1/p' /proc/mounts` [ -z "$_debugfs" ] || grep -i 'power\|devctl\|testmode' ${_debugfs}/musb-hdrc.?/regdump ;; esac # check dr_mode & gadget drivers [ -d /proc/device-tree ] || { echo "Warning: /proc/device-tree/ not found" if [ -d "/lib/modules/`uname -r`/" ]; then echo "The list of USB gadget drivers installed:" ls -1Rp "/lib/modules/`uname -r`/kernel/drivers/usb/gadget/" fi exit 0 } check_command basename for _usb in "${USB0}" "${USB1}"; do [ -n "$_usb" ] || continue _usb_dir="/proc/device-tree/${_usb}" _status=`tr -d '\0' <$_usb_dir/status` _dr_mode=`tr -d '\0' <$_usb_dir/dr_mode` echo `basename $_usb`: $_dr_mode, $_status [ "$_status" = "disabled" -o "$_dr_mode" = "host" ] || gadget_mode=true done case $PLATFORM in am335x | omapl1) check_musb_dt;; *) ;; esac DBG_PRINT $gadget_mode $gadget_mode || exit 0 echo check_kernel_config CONFIG_USB_LIBCOMPOSITE case $? in 0) echo "Error: no any gadget driver enabled" exit 6;; 1) is_gadget_builtin=false;; 2) echo "The gadget driver is built-in" is_gadget_builtin=true;; esac check_kernel_config CONFIG_USB_ZERO -q || echo "Gadget Kernel Config: g_zero is enabled" check_kernel_config CONFIG_USB_AUDIO -q || echo "Gadget Kernel Config: g_audio is enabled" check_kernel_config CONFIG_USB_ETH -q || echo "Gadget Kernel Config: g_ether is enabled" check_kernel_config CONFIG_USB_G_NCM -q || echo "Gadget Kernel Config: g_ncm is enabled" check_kernel_config CONFIG_USB_MASS_STORAGE -q || echo "Gadget Kernel Config: g_mass_storage is enabled" check_kernel_config CONFIG_USB_G_SERIAL -q || echo "Gadget Kernel Config: g_serial is enabled" check_kernel_config CONFIG_USB_G_PRINTER -q || echo "Gadget Kernel Config: g_printer is enabled" g_driver=`grep '^DRIVER=' /sys/class/udc/*/uevent 2>/dev/null` echo "gadget driver loaded: ${g_driver:-(none)}" echo if ! $is_gadget_builtin; then if [ -d "/lib/modules/`uname -r`/" ]; then echo "The list of USB gadget drivers installed:" ls -1Rp "/lib/modules/`uname -r`/kernel/drivers/usb/gadget/" else echo "Error: /lib/modules/`uname -r`/ not found" echo " Please ensure 'make modules_install' is done properly." exit 7 fi fi # vim: ft=sh:ts=4:sw=4:et
