Other Parts Discussed in Thread: TMDSSK3358, , DP83867IR, AM3359
Hi Team,
The customer is debugging the system constructed with AM3352 and DP83867IR. The speeds is restricted under 300Mbps in 1000M mode using iperf3 test. To orient the issue, the TMDSSK3358 is tested with iperf3 test and the speed is also restricted under 300Mbps.
http://www.ti.com/tool/TMDSSK3358?keyMatch=TMDSSK3358&tisearch=Search-EN-Everything
The iperf3 test software and some documents are attached here. As the customer had tested competitor’s board with 940Mbps using the same software, could you please tell me if anyone encountered with this situation with TMDSSK3358 before? Is the board support 1000Mbps speed?
Thanks a lot. I am looking forward to hearing from you.
Best regards
Chen Jiao
