Tool/software: TI-RTOS
I would like you to confirm about below.
* I am trying to build PRU-ICSS-ethercat-slave 01.00.07.02.
At first, I performed "bat" file to create CCS project. There is no error.
After that, I import this project to CCS(version 9.1) and build this project.
Then, I observed following error.
Error : c:/ti/ccs910/ccs/tools/compiler/gcc-arm-none-eabi-6-2017-q1-update/bin/../lib/gcc/arm-none-eabi/6.3.1/../../../../arm-none-eabi/bin/ld.exe : region `SRAM_HI1' overflowed by xxxx bytes
So, I confirmed following file to check memory map.
"amic11x_onchip_mem_app.xdt"
To increase region of ".text" section, I changed length of "SRAM_HI1".(decrease region of ".bss".)
After that, region error of "SRAM_HI1" disappeared but region error of "SRAM_HI0" appeared.
So, I doubt that this project can be closed only internal memory.
Can you build without any error by using default memory map setting ?
