Tool/software: Linux
Gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf.tar.tx comes from the following link:
releases.linaro.org/.../gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf.tar.xz
I encountered the following problems in the compilation process. How can I solve them?
[root@MSO:build]# [root@MSO:build]# [root@MSO:build]# . conf/setenv [root@MSO:build]# MACHINE=am57xx-evm bitbake opencl Loading cache: 100% |#########################################################################################################################################################################| Time: 0:00:01 Loaded 3236 entries from dependency cache. NOTE: Resolving any missing task queue dependencies Build Configuration: BB_VERSION = "1.32.0" BUILD_SYS = "x86_64-linux" NATIVELSBSTRING = "Ubuntu-14.04" TARGET_SYS = "arm-linux-gnueabi" MACHINE = "am57xx-evm" DISTRO = "arago" DISTRO_VERSION = "2017.05" TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard" TARGET_FPU = "hard" meta-processor-sdk = "HEAD:3d2f620a6a98b1b6abb1103d7dc986921436ed19" meta-arago-distro meta-arago-extras = "HEAD:b727bf8fce8e9cb5a6b5d5b48c45f0088e67eb53" meta-browser = "HEAD:880a7bd1d3b9a1b2003f5b0620350f03158bbd43" meta-qt5 = "HEAD:3601fd2c5306ac6d5d0d536e0be8cbb90da9b4c1" meta-networking meta-ruby meta-python meta-oe meta-gnome = "HEAD:fe5c83312de11e80b85680ef237f8acb04b4b26e" meta-ti = "HEAD:41d6fdc0fe5ea6054616cfccda13baac3ff33791" meta-linaro-toolchain meta-optee = "HEAD:d84874bad834657dd04ea69c35a74dd9dbd535b8" meta = "HEAD:ddf907ca95a19f54785079b4396935273b3747f6" Initialising tasks: 100% |####################################################################################################################################################################| Time: 0:00:01 NOTE: Executing SetScene Tasks NOTE: Executing RunQueue Tasks ERROR: external-linaro-toolchain-2016.11-r0.arago35.tisdk0 do_install: Function failed: do_install (log file is located at /root/psdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/external-linaro-toolchain/2016.11-r0.arago35.tisdk0/temp/log.do_install.29918) ERROR: Logfile of failure stored in: /root/psdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/external-linaro-toolchain/2016.11-r0.arago35.tisdk0/temp/log.do_install.29918 Log data follows: | DEBUG: Executing shell function do_install | cp: cannot stat ‘/root/factory/linux-devkit/sysroots/x86_64-arago-linux/usr/arm-linux-gnueabihf/libc/usr/share/*’: No such file or directory | WARNING: /root/psdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/external-linaro-toolchain/2016.11-r0.arago35.tisdk0/temp/run.do_install.29918:1 exit 1 from 'cp -a /root/factory/linux-devkit/sysroots/x86_64-arago-linux/usr/arm-linux-gnueabihf/libc/usr/share/* /root/psdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/external-linaro-toolchain/2016.11-r0.arago35.tisdk0/image/usr/share' | ERROR: Function failed: do_install (log file is located at /root/psdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/external-linaro-toolchain/2016.11-r0.arago35.tisdk0/temp/log.do_install.29918) ERROR: Task (/root/psdk/tisdk/sources/meta-linaro/meta-linaro-toolchain/recipes-devtools/external-linaro-toolchain/external-linaro-toolchain.bb:do_install) failed with exit code '1' NOTE: Tasks Summary: Attempted 162 tasks of which 161 didn't need to be rerun and 1 failed. Summary: 1 task failed: /root/psdk/tisdk/sources/meta-linaro/meta-linaro-toolchain/recipes-devtools/external-linaro-toolchain/external-linaro-toolchain.bb:do_install Summary: There was 1 ERROR message shown, returning a non-zero exit code. [root@MSO:build]# \ > ^C [root@MSO:build]# [root@MSO:build]# [root@MSO:build]# [root@MSO:build]# [root@MSO:build]# [root@MSO:build]# echo $PATH /root/psdk/tisdk/sources/meta-browser/scripts:/root/psdk/tisdk/sources/oe-core/scripts:/root/psdk/tisdk/sources/bitbake/bin:/root/psdk/tisdk/sources/meta-browser/scripts:/root/psdk/tisdk/sources/oe-core/scripts:/root/psdk/tisdk/sources/bitbake/bin:/root/psdk/tisdk/sources/meta-browser/scripts:/root/psdk/tisdk/sources/oe-core/scripts:/root/psdk/tisdk/sources/bitbake/bin:/root/psdk/cross_compile/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/root/factory/linux-devkit/sysroots/x86_64-arago-linux/usr/bin [root@MSO:build]# [root@MSO:build]# [root@MSO:build]# [root@MSO:build]# echo ~/. ./ .bashrc .dbus/ .lesshst .pki/ .subversion/ .viminfo .xsession-errors.old ../ .cache/ .dmrc .local/ .profile .swt/ .wgetrc .aptitude/ .compiz/ .gconf/ .minirc.dfl .python-history .ti/ .Xauthority .bash_history .config/ .ICEauthority .oracle_jre_usage/ .ssh/ .vim/ .xsession-errors [root@MSO:build]# echo ~/.bashrc /root/.bashrc [root@MSO:build]# cat ~/.bashrc # ~/.bashrc: executed by bash(1) for non-login shells. # see /usr/share/doc/bash/examples/startup-files (in the package bash-doc) # for examples # If not running interactively, don't do anything [ -z "$PS1" ] && return # don't put duplicate lines in the history. See bash(1) for more options # ... or force ignoredups and ignorespace HISTCONTROL=ignoredups:ignorespace # append to the history file, don't overwrite it shopt -s histappend # for setting history length see HISTSIZE and HISTFILESIZE in bash(1) HISTSIZE=1000 HISTFILESIZE=2000 # check the window size after each command and, if necessary, # update the values of LINES and COLUMNS. shopt -s checkwinsize # make less more friendly for non-text input files, see lesspipe(1) [ -x /usr/bin/lesspipe ] && eval "$(SHELL=/bin/sh lesspipe)" # set variable identifying the chroot you work in (used in the prompt below) if [ -z "$debian_chroot" ] && [ -r /etc/debian_chroot ]; then debian_chroot=$(cat /etc/debian_chroot) fi # set a fancy prompt (non-color, unless we know we "want" color) case "$TERM" in xterm-color) color_prompt=yes;; esac # uncomment for a colored prompt, if the terminal has the capability; turned # off by default to not distract the user: the focus in a terminal window # should be on the output of commands, not on the prompt #force_color_prompt=yes if [ -n "$force_color_prompt" ]; then if [ -x /usr/bin/tput ] && tput setaf 1 >&/dev/null; then # We have color support; assume it's compliant with Ecma-48 # (ISO/IEC-6429). (Lack of such support is extremely rare, and such # a case would tend to support setf rather than setaf.) color_prompt=yes else color_prompt= fi fi if [ "$color_prompt" = yes ]; then PS1='[${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\W\[\033[00m\]]\$ ' else PS1='[${debian_chroot:+($debian_chroot)}\u@\h:\W]\$ ' fi unset color_prompt force_color_prompt # If this is an xterm set the title to user@host:dir case "$TERM" in xterm*|rxvt*) PS1="\[\e]0;${debian_chroot:+($debian_chroot)}\u@\h: \w\a\]$PS1" ;; *) ;; esac # enable color support of ls and also add handy aliases if [ -x /usr/bin/dircolors ]; then test -r ~/.dircolors && eval "$(dircolors -b ~/.dircolors)" || eval "$(dircolors -b)" alias ls='ls --color=auto' #alias dir='dir --color=auto' #alias vdir='vdir --color=auto' alias grep='grep --color=auto' alias fgrep='fgrep --color=auto' alias egrep='egrep --color=auto' fi # some more ls aliases alias ll='ls -alF' alias la='ls -A' alias l='ls -CF' # Alias definitions. # You may want to put all your additions into a separate file like # ~/.bash_aliases, instead of adding them here directly. # See /usr/share/doc/bash-doc/examples in the bash-doc package. if [ -f ~/.bash_aliases ]; then . ~/.bash_aliases fi # enable programmable completion features (you don't need to enable # this, if it's already enabled in /etc/bash.bashrc and /etc/profile # sources /etc/bash.bashrc). #if [ -f /etc/bash_completion ] && ! shopt -oq posix; then # . /etc/bash_completion #fi #export PATH=$PATH:/home/mso/ti-processor-sdk-linux-rt-am57xx-evm-03.03.00.04/linux-devkit/sysroots/x86_64-arago-linux/usr/bin #export PATH=$PATH:/home/mso/ti-processor-sdk-linux-rt-am57xx-evm-04.00.00.04/linux-devkit/sysroots/x86_64-arago-linux/usr/bin #export PATH=$PATH:/home/mso/ti-processor-sdk-linux-rt-am57xx-evm-03.03.00.04/linux-devkit/sysroots/x86_64-arago-linux/usr/bin export PATH=/root/psdk/cross_compile/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf:$PATH export PATH=$PATH:/root/factory/linux-devkit/sysroots/x86_64-arago-linux/usr/bin #export PATH=$PATH:/root/f***_dsp/linux-devkit/sysroots/x86_64-arago-linux/usr/bin export TOOLCHAIN_PATH_ARMV7=/root/psdk/cross_compile/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf export TOOLCHAIN_PATH_ARMV8=/root/psdk/cross_compile/gcc-linaro-7.2.1-2017.11-x86_64_aarch64-linux-gnu #export http_proxy='<a href="127.0.0.1:8123/.../a> #export https_proxy='<a href="127.0.0.1:8123/.../a> #export ftp_proxy='<a href="127.0.0.1:8123/.../a> #export ALL_PROXY='socks://127.0.0.1:8123/' #export all_proxy='socks://127.0.0.1:8123/' #export no_proxy='example.com' #export GIT_PROXY_COMMAND="oe-git-proxy" #export NO_PROXY=$no_proxy [root@MSO:build]#
I made some errors while executing the "MACHINE=am57xx-evm bitbake arago-base-tisdk-image" command.
By analyzing the log, I found that the link of some files failed and the corresponding file could not be searched on the previous path of the link.The link "downloads.yoctoproject.org/.../git2_git.ti.com.ti-linux-kernel.ti-linux-kernel.git.tar.gz", for example, git2_git.ti.com.ti-linux-kernel.ti-linux-kernel.git.tar.gz this file no.How can I solve this problem?Or can you compile a DSP binary file of 512M? I will directly copy the DSP binary file you compiled.
def base_do_fetch(d): src_uri = (d.getVar('SRC_URI', True) or "").split() if len(src_uri) == 0: return try: fetcher = bb.fetch2.Fetch(src_uri, d) fetcher.download() except bb.fetch2.BBFetchException as e: bb.fatal(str(e)) base_do_fetch(d)
