Part Number: DRA72XEVM
We've recently encountered a problem in which we have to add a delay before starting the user space application in order to properly create a message queue.
The platform is DRA71, configured with one A15 core running Linux and one C66 running SYS/BIOS. TI IPC MessageQ is used to communicate. Linux user-space app fails when trying to open the remote messageQ.
It seems that NameServer_attach fails when trying to connect to the socket. Adding 300ms sleep before running this procedure makes it work correctly.
Any ideas what could cause that? Both, working (with 300ms sleep) and not working example (starting immediately) hit (Invalid argument) error but one succeeds on the fourth try while the other one still fails.
Below you'll find LAD logs for when the process fails and for when the process succeeds.
Log, in which app starts OK:
[0.027673]
Initializing LAD... [0.028638] NameServer_setup: entered, refCount=0
[0.028796] NameServer_setup: creating listener thread
[0.029271] NameServer_setup: exiting, refCount=1
[0.029682] NameServer_create(): 'GateMP'
[0.029845]
opening FIFO: /tmp/LAD/LADCMDS
[0.030129] listener_cb: Entered Listener thread.
[0.030217] NameServer: waiting for unblockFd: 0, and socks: maxfd: 0
[2.484640] Retrieving command...
[2.484702]
LAD_CONNECT:
[2.484713] client FIFO name = /tmp/LAD/278
[2.484721] client PID = 278
[2.484729] assigned client handle = 0
[2.484760] FIFO /tmp/LAD/278 created
[2.484867] FIFO /tmp/LAD/278 opened for writing
[2.484906] sent response
[2.484914] DONE
[2.484921] Retrieving command...
[2.484999] Sending response...
[2.485015] Retrieving command...
[2.485053] LAD_MULTIPROC_GETCONFIG: calling MultiProc_getConfig()...
[2.485067] MultiProc_getConfig() - 5 procs
[2.485075] # processors in cluster: 5
[2.485082] cluster baseId: 0
[2.485089] ProcId 0 - "HOST"
[2.485096] ProcId 1 - "IPU2"
[2.485104] ProcId 2 - "IPU1"
[2.485111] ProcId 3 - "DSP2"
[2.485118] ProcId 4 - "DSP1"
[2.485125] status = 0
[2.485132] DONE
[2.485139] Sending response...
[2.485151] Retrieving command...
[2.485202] LAD_NAMESERVER_SETUP: calling NameServer_setup()...
[2.485211] NameServer_setup: entered, refCount=1
[2.485219] NameServer_setup: already setup
[2.485225] NameServer_setup: exiting, refCount=2
[2.485233] status = 1
[2.485240] DONE
[2.485246] Sending response...
[2.485258] Retrieving command...
[2.485295] LAD_MESSAGEQ_GETCONFIG: calling MessageQ_getConfig()...
[2.485305] status = 0
[2.485312] DONE
[2.485319] Sending response...
[2.485331] Retrieving command...
[2.485367] LAD_MESSAGEQ_SETUP: calling MessageQ_setup()...
[2.485377] MessageQ_setup: entered, refCount=0
[2.485385] NameServer_create(): 'MessageQ'
[2.485398] MessageQ_setup: exiting, refCount=1
[2.485406] status = 0
[2.485413] DONE
[2.485419] Sending response...
[2.485431] Retrieving command...
[2.485634] NameServer_attach: --> procId=1, refCount=0
[2.485662] NameServer_attach: created send socket: 6, procId 1
[2.485692] NameServer_attach: connect failed: procId=1, errno=22 (Invalid argument)
[2.485715] closing send socket: 6
[2.485739] NameServer_attach: <-- refCount=0, status=-1
[2.485748] Sending response...
[2.485792] Retrieving command...
[2.485809] NameServer_attach: --> procId=2, refCount=0
[2.485824] NameServer_attach: created send socket: 6, procId 2
[2.485835] NameServer_attach: connect failed: procId=2, errno=22 (Invalid argument)
[2.485846] closing send socket: 6
[2.485862] NameServer_attach: <-- refCount=0, status=-1
[2.485871] Sending response...
[2.485909] Retrieving command...
[2.485924] NameServer_attach: --> procId=3, refCount=0
[2.485938] NameServer_attach: created send socket: 6, procId 3
[2.485949] NameServer_attach: connect failed: procId=3, errno=22 (Invalid argument)
[2.485960] closing send socket: 6
[2.485976] NameServer_attach: <-- refCount=0, status=-1
[2.485985] Sending response...
[2.486023] Retrieving command...
[2.486038] NameServer_attach: --> procId=4, refCount=0
[2.486051] NameServer_attach: created send socket: 6, procId 4
[2.486077] NameServer_attach: created receive socket: 7, procId 4
[2.487310] NameServer: back from select()
[2.487339] NameServer: listener thread, event: REFRESH
[2.487350] NameServer: waiting for unblockFd: 0, and socks: maxfd: 7
[2.487370] NameServer_attach: <-- refCount=1, status=0
[2.487381] Sending response...
[2.487503] Retrieving command...
[2.487522] LAD_GATEMP_ISSETUP: calling GateMP_isSetup()...
[2.487530] status = 0
[2.487537] DONE
[2.487544] Sending response...
[2.487578] Retrieving command...
[2.487593] LAD_GATEMP_ATTACH: calling GateMP_attach(4)...
[2.487615] NameServer_getRemote: Sending request via sock: 6
[2.487625] NameServer_getRemote: requesting from procId 4, GateMP: _GateMP_TI_dGate
[2.487656] NameServer_getRemote: pending on waitFd: 1
[2.487759] NameServer: back from select()
[2.487773] NameServer: Listener got NameServer message from sock: 7!
[2.487805] listener_cb: recvfrom socket: fd: 7
[2.487815] Received ns msg: nbytes: 484, from addr: 61, from vproc: 2
[2.487823] NameServer Reply: instanceName: GateMP, name: _GateMP_TI_dGate, value: 0x770bf
[2.487837] NameServer: waiting for unblockFd: 0, and socks: maxfd: 7
[2.487857] NameServer_getRemote: value for GateMP:_GateMP_TI_dGate not found.
[2.487869] GateMP_attach: failed to open default gate on procId 4
[2.487887] status = -5
[2.487893] DONE
[2.487900] Sending response...
[2.487934] Retrieving command...
[2.487949] LAD_GATEMP_ISSETUP: calling GateMP_isSetup()...
[2.487956] status = 0
[2.487963] DONE
[2.487969] Sending response...
[2.488003] Retrieving command...
[2.488018] LAD_GATEHWSPINLOCK_GETCONFIG: calling GateHWSpinlock_getConfig()...
[2.488026] GateHWSpinlock_getConfig() baseAddr = 0x4a0f6000
[2.488033] size = 0x1000
offset = 0x800
[2.488040] status = 0
[2.488047] DONE
[2.488053] Sending response...
[2.488188] Retrieving command...
[2.488207] LAD_GATEMP_START: calling GateMP_start()...
[2.488215] status = 0
[2.488222] DONE
[2.488228] Sending response...
[2.488258] Retrieving command...
[2.488272] LAD_GATEMP_GETNUMRESOURCES: calling GateMP_getNumResources()...
[2.488280] status = 0
[2.488287] DONE
[2.488294] Sending response...
[2.488336] Retrieving command...
[2.488352] LAD_NAMESERVER_GET: calling NameServer_get(0x30228, '_GateMP_TI_dGate'[2.488361] )...
[2.488373] NameServer_getLocal: entry key: '_GateMP_TI_dGate' not found!
[2.488381] NameServer_getRemote: no socket connection to processor 1
[2.488389] NameServer_getRemote: no socket connection to processor 2
[2.488396] NameServer_getRemote: no socket connection to processor 3
[2.488403] NameServer_getRemote: Sending request via sock: 6
[2.488410] NameServer_getRemote: requesting from procId 4, GateMP: _GateMP_TI_dGate
[2.488433] NameServer_getRemote: pending on waitFd: 1
[2.488514] NameServer: back from select()
[2.488526] NameServer: Listener got NameServer message from sock: 7!
[2.488538] listener_cb: recvfrom socket: fd: 7
[2.488546] Received ns msg: nbytes: 484, from addr: 61, from vproc: 2
[2.488554] NameServer Reply: instanceName: GateMP, name: _GateMP_TI_dGate, value: 0x773d3
[2.488566] NameServer: waiting for unblockFd: 0, and socks: maxfd: 7
[2.488585] NameServer_getRemote: value for GateMP:_GateMP_TI_dGate not found.
[2.488596] value = 0x10
[2.488603] status = -5
[2.488610] DONE
[2.488616] Sending response...
[2.488666] Retrieving command...
[2.488681] LAD_MESSAGEQ_CREATE: calling MessageQ_create(0x2f89c, 0x2f8bc)...
[2.488690] MessageQ_create: creating 'HOST:MsgQ:01'
[2.488700] MessageQ_create: returning obj=0x30640, qid=0x80
[2.488708] status = 0
[2.488715] DONE
[2.488721] Sending response...
[2.489843] Retrieving command...
[2.491290] LAD_MESSAGEQ_ANNOUNCE: calling MessageQ_announce(0x2f89c, 0x30640)...
[2.491309] MessageQ_announce: announcing 0x30640
[2.491323] NameServer_add: Entered key: 'HOST:MsgQ:01', data: 0x80
[2.491333] status = 0
[2.491340] DONE
[2.491347] Sending response...
[2.491415] Retrieving command...
[2.491432] LAD_NAMESERVER_GETUINT32: calling NameServer_getUInt32(0x30558, 'DSP1:MsgQ:01')...
[2.491443] NameServer_getLocal: entry key: 'DSP1:MsgQ:01' not found!
[2.491453] NameServer_getRemote: no socket connection to processor 1
[2.491460] NameServer_getRemote: no socket connection to processor 2
[2.491467] NameServer_getRemote: no socket connection to processor 3
[2.491474] NameServer_getRemote: Sending request via sock: 6
[2.491481] NameServer_getRemote: requesting from procId 4, MessageQ: DSP1:MsgQ:01
[2.491512] NameServer_getRemote: pending on waitFd: 1
[2.491598] NameServer: back from select()
[2.491610] NameServer: Listener got NameServer message from sock: 7!
[2.491624] listener_cb: recvfrom socket: fd: 7
[2.491633] Received ns msg: nbytes: 484, from addr: 61, from vproc: 2
[2.491641] NameServer Reply: instanceName: MessageQ, name: DSP1:MsgQ:01, value: 0x40080
[2.491654] NameServer: waiting for unblockFd: 0, and socks: maxfd: 7
[2.491674] NameServer_getRemote: Reply from: 4, MessageQ: name: DSP1:MsgQ:01, value: 0x40080
[2.491698] value = 0x40080
[2.491706] status = 0
[2.491713] DONE
[2.491719] Sending response...
[2.491929] Retrieving command...
Log, in which the app fails to start:
[0.955071]
Initializing LAD... [0.955315] NameServer_setup: entered, refCount=0
[0.955341] NameServer_setup: creating listener thread
[0.955456] NameServer_setup: exiting, refCount=1
[0.955538] NameServer_create(): 'GateMP'
[0.955565]
[0.959035] listener_cb: Entered Listener thread.
[0.959129] NameServer: waiting for unblockFd: 0, and socks: maxfd: 0
[-25613773.706787] Retrieving command...
[-25613773.706853]
LAD_CONNECT:
[-25613773.706863] client FIFO name = /tmp/LAD/302
[-25613773.706872] client PID = 302
[-25613773.706880] assigned client handle = 0
[-25613773.706912] FIFO /tmp/LAD/302 created
[-25613773.707020] FIFO /tmp/LAD/302 opened for writing
[-25613773.707059] sent response
[-25613773.707068] DONE
[-25613773.707075] Retrieving command...
[-25613773.707151] Sending response...
[-25613773.707167] Retrieving command...
[-25613773.707206] LAD_MULTIPROC_GETCONFIG: calling MultiProc_getConfig()...
[-25613773.707220] MultiProc_getConfig() - 5 procs
[-25613773.707227] # processors in cluster: 5
[-25613773.707234] cluster baseId: 0
[-25613773.707241] ProcId 0 - "HOST"
[-25613773.707249] ProcId 1 - "IPU2"
[-25613773.707256] ProcId 2 - "IPU1"
[-25613773.707263] ProcId 3 - "DSP2"
[-25613773.707270] ProcId 4 - "DSP1"
[-25613773.707277] status = 0
[-25613773.707284] DONE
[-25613773.707291] Sending response...
[-25613773.707303] Retrieving command...
[-25613773.707354] LAD_NAMESERVER_SETUP: calling NameServer_setup()...
[-25613773.707364] NameServer_setup: entered, refCount=1
[-25613773.707371] NameServer_setup: already setup
[-25613773.707378] NameServer_setup: exiting, refCount=2
[-25613773.707386] status = 1
[-25613773.707392] DONE
[-25613773.707399] Sending response...
[-25613773.707411] Retrieving command...
[-25613773.707451] LAD_MESSAGEQ_GETCONFIG: calling MessageQ_getConfig()...
[-25613773.707460] status = 0
[-25613773.707467] DONE
[-25613773.707474] Sending response...
[-25613773.707486] Retrieving command...
[-25613773.707524] LAD_MESSAGEQ_SETUP: calling MessageQ_setup()...
[-25613773.707533] MessageQ_setup: entered, refCount=0
[-25613773.707541] NameServer_create(): 'MessageQ'
[-25613773.707554] MessageQ_setup: exiting, refCount=1
[-25613773.707561] status = 0
[-25613773.707568] DONE
[-25613773.707575] Sending response...
[-25613773.707587] Retrieving command...
[-25613773.707793] NameServer_attach: --> procId=1, refCount=0
[-25613773.707822] NameServer_attach: created send socket: 6, procId 1
[-25613773.707852] NameServer_attach: connect failed: procId=1, errno=22 (Invalid argument)
[-25613773.707876] closing send socket: 6
[-25613773.707900] NameServer_attach: <-- refCount=0, status=-1
[-25613773.707910] Sending response...
[-25613773.707952] Retrieving command...
[-25613773.707968] NameServer_attach: --> procId=2, refCount=0
[-25613773.707983] NameServer_attach: created send socket: 6, procId 2
[-25613773.707994] NameServer_attach: connect failed: procId=2, errno=22 (Invalid argument)
[-25613773.708108] closing send socket: 6
[-25613773.708130] NameServer_attach: <-- refCount=0, status=-1
[-25613773.708139] Sending response...
[-25613773.708181] Retrieving command...
[-25613773.708196] NameServer_attach: --> procId=3, refCount=0
[-25613773.708212] NameServer_attach: created send socket: 6, procId 3
[-25613773.708224] NameServer_attach: connect failed: procId=3, errno=22 (Invalid argument)
[-25613773.708235] closing send socket: 6
[-25613773.708250] NameServer_attach: <-- refCount=0, status=-1
[-25613773.708259] Sending response...
[-25613773.708297] Retrieving command...
[-25613773.708312] NameServer_attach: --> procId=4, refCount=0
[-25613773.708326] NameServer_attach: created send socket: 6, procId 4
[-25613773.708337] NameServer_attach: connect failed: procId=4, errno=22 (Invalid argument)
[-25613773.708348] closing send socket: 6
[-25613773.708363] NameServer_attach: <-- refCount=0, status=-1
[-25613773.708372] Sending response...
[-25613773.708413] Retrieving command...
[-25613773.708428] LAD_GATEMP_ISSETUP: calling GateMP_isSetup()...
[-25613773.708451] status = 0
[-25613773.708459] DONE
[-25613773.708466] Sending response...
[-25613773.708501] Retrieving command...
[-25613773.708516] LAD_GATEHWSPINLOCK_GETCONFIG: calling GateHWSpinlock_getConfig()...
[-25613773.708524] GateHWSpinlock_getConfig() baseAddr = 0x4a0f6000
[-25613773.708532] size = 0x1000
offset = 0x800
[-25613773.708539] status = 0
[-25613773.708546] DONE
[-25613773.708553] Sending response...
[-25613773.708676] Retrieving command...
[-25613773.708693] LAD_GATEMP_START: calling GateMP_start()...
[-25613773.708701] status = 0
[-25613773.708708] DONE
[-25613773.708715] Sending response...
[-25613773.708744] Retrieving command...
[-25613773.708759] LAD_GATEMP_GETNUMRESOURCES: calling GateMP_getNumResources()...
[-25613773.708767] status = 0
[-25613773.708774] DONE
[-25613773.708780] Sending response...
[-25613773.708822] Retrieving command...
[-25613773.708837] LAD_NAMESERVER_GET: calling NameServer_get(0x30228, '_GateMP_TI_dGate'[-25613773.708846] )...
[-25613773.708858] NameServer_getLocal: entry key: '_GateMP_TI_dGate' not found!
[-25613773.708867] NameServer_getRemote: no socket connection to processor 1
[-25613773.708875] NameServer_getRemote: no socket connection to processor 2
[-25613773.708881] NameServer_getRemote: no socket connection to processor 3
[-25613773.708889] NameServer_getRemote: no socket connection to processor 4
[-25613773.708896] value = 0x10
[-25613773.708903] status = -5
[-25613773.708909] DONE
[-25613773.708915] Sending response...
[-25613773.708965] Retrieving command...
[-25613773.708979] LAD_MESSAGEQ_CREATE: calling MessageQ_create(0x2f89c, 0x2f8bc)...
[-25613773.708988] MessageQ_create: creating 'HOST:MsgQ:01'
[-25613773.708998] MessageQ_create: returning obj=0x30640, qid=0x80
[-25613773.709007] status = 0
[-25613773.709013] DONE
[-25613773.709020] Sending response...
[-25613773.709056] Retrieving command...
[-25613773.709071] LAD_MESSAGEQ_ANNOUNCE: calling MessageQ_announce(0x2f89c, 0x30640)...
[-25613773.709079] MessageQ_announce: announcing 0x30640
[-25613773.709090] NameServer_add: Entered key: 'HOST:MsgQ:01', data: 0x80
[-25613773.709099] status = 0
[-25613773.709106] DONE
[-25613773.709113] Sending response...
[-25613773.709173] Retrieving command...
[-25613773.709188] LAD_NAMESERVER_GETUINT32: calling NameServer_getUInt32(0x30558, 'DSP1:MsgQ:01')...
[-25613773.709198] NameServer_getLocal: entry key: 'DSP1:MsgQ:01' not found!
[-25613773.709207] NameServer_getRemote: no socket connection to processor 1
[-25613773.709214] NameServer_getRemote: no socket connection to processor 2
[-25613773.709221] NameServer_getRemote: no socket connection to processor 3
[-25613773.709228] NameServer_getRemote: no socket connection to processor 4
[-25613773.709235] value = 0x80
[-25613773.709241] status = -5
[-25613773.709248] DONE
[-25613773.709255] Sending response...
[-25613773.709294] Retrieving command...
[-25613772.709403] LAD_NAMESERVER_GETUINT32: calling NameServer_getUInt32(0x30558, 'DSP1:MsgQ:01')...
[-25613772.709436] NameServer_getLocal: entry key: 'DSP1:MsgQ:01' not found!
[-25613772.709448] NameServer_getRemote: no socket connection to processor 1
[-25613772.709456] NameServer_getRemote: no socket connection to processor 2
[-25613772.709464] NameServer_getRemote: no socket connection to processor 3
[-25613772.709471] NameServer_getRemote: no socket connection to processor 4
[-25613772.709478] value = 0x80
[-25613772.709486] status = -5
[-25613772.709493] DONE
[-25613772.709500] Sending response...
[-25613772.709517] Retrieving command...
[-25613771.709645] LAD_NAMESERVER_GETUINT32: calling NameServer_getUInt32(0x30558, 'DSP1:MsgQ:01')...
[-25613771.709670] NameServer_getLocal: entry key: 'DSP1:MsgQ:01' not found!
[-25613771.709681] NameServer_getRemote: no socket connection to processor 1
[-25613771.709689] NameServer_getRemote: no socket connection to processor 2
[-25613771.709697] NameServer_getRemote: no socket connection to processor 3
[-25613771.709704] NameServer_getRemote: no socket connection to processor 4
[-25613771.709728] value = 0x80
[-25613771.709737] status = -5
[-25613771.709744] DONE
[-25613771.709750] Sending response...
[-25613771.709765] Retrieving command...
[-25613770.709893] LAD_NAMESERVER_GETUINT32: calling NameServer_getUInt32(0x30558, 'DSP1:MsgQ:01')...
[-25613770.709918] NameServer_getLocal: entry key: 'DSP1:MsgQ:01' not found!
[-25613770.709929] NameServer_getRemote: no socket connection to processor 1
[-25613770.709938] NameServer_getRemote: no socket connection to processor 2
[-25613770.709945] NameServer_getRemote: no socket connection to processor 3
[-25613770.709952] NameServer_getRemote: no socket connection to processor 4
[-25613770.709959] value = 0x80
[-25613770.709967] status = -5
[-25613770.709974] DONE
[-25613770.709980] Sending response...
[-25613770.709995] Retrieving command...
[-25613769.710120] LAD_NAMESERVER_GETUINT32: calling NameServer_getUInt32(0x30558, 'DSP1:MsgQ:01')...
[-25613769.710144] NameServer_getLocal: entry key: 'DSP1:MsgQ:01' not found!
[-25613769.710155] NameServer_getRemote: no socket connection to processor 1
[-25613769.710163] NameServer_getRemote: no socket connection to processor 2
[-25613769.710171] NameServer_getRemote: no socket connection to processor 3
[-25613769.710178] NameServer_getRemote: no socket connection to processor 4
[-25613769.710185] value = 0x80
[-25613769.710193] status = -5
[-25613769.710200] DONE
[-25613769.710207] Sending response...
[-25613769.710221] Retrieving command...
[-25613768.710342] LAD_NAMESERVER_GETUINT32: calling NameServer_getUInt32(0x30558, 'DSP1:MsgQ:01')...
[-25613768.710365] NameServer_getLocal: entry key: 'DSP1:MsgQ:01' not found!
[-25613768.710376] NameServer_getRemote: no socket connection to processor 1
[-25613768.710384] NameServer_getRemote: no socket connection to processor 2
[-25613768.710392] NameServer_getRemote: no socket connection to processor 3
[-25613768.710399] NameServer_getRemote: no socket connection to processor 4
[-25613768.710407] value = 0x80
[-25613768.710414] status = -5
[-25613768.710421] DONE
[-25613768.710427] Sending response...
[-25613768.710442] Retrieving command...
[-25613767.710564] LAD_NAMESERVER_GETUINT32: calling NameServer_getUInt32(0x30558, 'DSP1:MsgQ:01')...
[-25613767.710587] NameServer_getLocal: entry key: 'DSP1:MsgQ:01' not found!
[-25613767.710597] NameServer_getRemote: no socket connection to processor 1
[-25613767.710606] NameServer_getRemote: no socket connection to processor 2
[-25613767.710613] NameServer_getRemote: no socket connection to processor 3
[-25613767.710620] NameServer_getRemote: no socket connection to processor 4
[-25613767.710627] value = 0x80
[-25613767.710634] status = -5
[-25613767.710641] DONE
[-25613767.710648] Sending response...
[-25613767.710662] Retrieving command...
[-25613766.710782] LAD_NAMESERVER_GETUINT32: calling NameServer_getUInt32(0x30558, 'DSP1:MsgQ:01')...
[-25613766.710805] NameServer_getLocal: entry key: 'DSP1:MsgQ:01' not found!
[-25613766.710815] NameServer_getRemote: no socket connection to processor 1
[-25613766.710823] NameServer_getRemote: no socket connection to processor 2
[-25613766.710831] NameServer_getRemote: no socket connection to processor 3
[-25613766.710838] NameServer_getRemote: no socket connection to processor 4
[-25613766.710845] value = 0x80
[-25613766.710853] status = -5
[-25613766.710859] DONE
[-25613766.710865] Sending response...
[-25613766.710880] Retrieving command...
[-25613765.711005] LAD_NAMESERVER_GETUINT32: calling NameServer_getUInt32(0x30558, 'DSP1:MsgQ:01')...
[-25613765.711027] NameServer_getLocal: entry key: 'DSP1:MsgQ:01' not found!
[-25613765.711037] NameServer_getRemote: no socket connection to processor 1
[-25613765.711046] NameServer_getRemote: no socket connection to processor 2
[-25613765.711053] NameServer_getRemote: no socket connection to processor 3
[-25613765.711061] NameServer_getRemote: no socket connection to processor 4
[-25613765.711068] value = 0x80
[-25613765.711076] status = -5
[-25613765.711083] DONE
[-25613765.711105] Sending response...
[-25613765.711121] Retrieving command...
[-25613764.711242] LAD_NAMESERVER_GETUINT32: calling NameServer_getUInt32(0x30558, 'DSP1:MsgQ:01')...
[-25613764.711265] NameServer_getLocal: entry key: 'DSP1:MsgQ:01' not found!
[-25613764.711276] NameServer_getRemote: no socket connection to processor 1
[-25613764.711284] NameServer_getRemote: no socket connection to processor 2
[-25613764.711292] NameServer_getRemote: no socket connection to processor 3
[-25613764.711299] NameServer_getRemote: no socket connection to processor 4
[-25613764.711306] value = 0x80
[-25613764.711314] status = -5
[-25613764.711320] DONE
[-25613764.711327] Sending response...
[-25613764.711341] Retrieving command...
[-25613764.711638] LAD_MESSAGEQ_DESTROY: calling MessageQ_destroy()...
[-25613764.711652] MessageQ_destroy: entered, refCount=1
[-25613764.711660] MessageQ_delete: deleting 0x30640
[-25613764.711678] MessageQ_delete: returning 0
[-25613764.711693] MessageQ_destroy: exiting, refCount=0
[-25613764.711701] status = 0
[-25613764.711708] DONE
[-25613764.711715] Sending response...
[-25613764.711728] Retrieving command...
[-25613764.711769] LAD_NAMESERVER_DESTROY: calling NameServer_destroy()...
[-25613764.711779] NameServer_destroy: entered, refCount=2
[-25613764.711786] NameServer_destroy(): refCount(1) > 0, exiting
[-25613764.711794] NameServer_destroy: exiting, refCount=1
[-25613764.711801] status = 0
[-25613764.711808] DONE
[-25613764.711815] Sending response...
[-25613764.711827] Retrieving command...
[-25613764.711961]
LAD_DISCONNECT: [-25613764.711973]
client handle = 0[-25613764.711980]
closing FIFO /tmp/LAD/302 (filePtr=0x303f0)
[-25613764.712020] done, unlinking /tmp/LAD/302
[-25613764.712052] DONE
[-25613764.712061] Retrieving command...
[-25613763.101535] EOF detected on FIFO, closing FIFO: /tmp/LAD/LADCMDS
[-25613763.101603]
