Our customer is troubled with DDR3 access failure.
The cause of DDR3 access failure is known to be due to waveform distortion of the DDR3 power supply(VTT).
As a workaround, we are considering removing the termination resistor where the DDR3 address/command signal is pulled up by VTT via the termination resistor.
This workaround has passed the DDR3 compliance test, and the DDR3 input signal is within the rating of the IC.
I know that it is recommended to pull up VTT with a termination resistor in the wiring of AM3874 and DDR3, but if there is no problem in the compliance test etc., can I think that the above workatound are satisfactory as AM3874?
If you have any other concerns or items to be confirmed, please let us know.
Shigehiro Tsuda
