Other Parts Discussed in Thread: MATHLIB
I built a sample application(DSPLIB) of C66x, and executed target file(ccxml) on TDA2P EVM, but I got following errors.
Does not match the target endianness, not loaded.
Check project build options and target configuration file (ccxml).
Is there any additional options which should be set when I build?
If you have more detailed manuals to build samples, please share the URL.
Followings are the details of my procedure.
* Environment
- OS
Windows10 pro
- Tools
Code Composer Studio 8.1.0
Code Generation Tools 7.4.2
dsplib_c66x_3_4_0_0
mathlib_c66x_3_1_0_0
* Procedure
1. I made environment by following the manual.
DSPLIB User's Manual ⇒ Building ⇒ CCS Build Process
2. I selected the folder(DSP_add16_66_BE_COFF) from "Select CCS projects to Import".
3. I generated NewTargetConfiguration.ccxml from "File -> New -> Target Configuration File".
Connection : Spectrum Digital XD5560V2 STM USB Emulator
Board : TDA2Px
-->Save (Test was passed.)
4. I selected Launch Selected Configuration.
5. I selected followins from "debug";
"CortexA15_0 -> system_Reset -> Connect_Target"
"TDA2Px_MULTICORE_Initialization -> TDA2Px_MULTICORE_Enable_ALLCores"
"C66xx_DSP1 -> Connect_Target -> CPU_Reset"
"Load_program -> DSP_add16_66_BE_COFF.out"
* Results
Koji
