Other Parts Discussed in Thread: TMDSEVM6678
could you please advise if OK using the above on the TSIP I/F translating 1.8V into 3.3V?
Erez.
Erez.
Erez,
The '245 is not a good choice for this level conversion. The data lines can be bidirectional per programmed timeslot. The TXS0108 is a better choice for true bidirectional level shifting. This is implemented on the TMDSEVM6678 EVM.
Tom
Tom,
I am connecting 3 devices on the same TSIP with the rate of 16MHz so it need to be open drain.
do you have recommendation for that?
Erez.
Erez,
I would need to understand more about the other devices connected to the TSIP data lines. What are the characteristics of the other inputs and outputs? Also, how is the output drive control managed with them? Is the connected data bus a TDM stream where timeslots are assigned and driven by more than one driver? What is the maximum data rate?
Tom
Hi Tom,
Due company propriety i would like to go on separate thread, private with this subject.
can we?
Erez.
Erez,
Please contact your TI FAE or TSR. They should be able to forward your email contact so that we can review information that must remain confidential.
Tom
Tom,
unfortunately i did not manage to contact with FAE. can you advise contact?
Erez.
Erez,
I cannot post contact information on E2E. You will need to contact your FAE or TSR directly, perhaps through your parts procurement team.
Tom
