Hello Community,
There are different modes of HSR like H, T, U and N as per standard
What are this mode, If i change mode H to T , what will happen ?
Please let me know how to test different modes of HSR ?
Pankaj
Hello Community,
Pankaj
Hi Pankaj,
See the definitions of the HSR modes below:
HSR_MODE H: HSR-tagged forwarding – in this mode, the DANH shall insert the HSR tag on behalf of its host and forward the ring traffic, except for frames sent by the node itself. Duplicate frames and frames where the node is the unicast destination shall not be forwarded
HSR_MODE_N: No forwarding – in this mode, the node shall behave like mode H with the exception that it shall not forward ring traffic from port to port. This mode only alters the switch decision in the receiving task
HSR_MODE_T: Transparent forwarding – in this mode the DANH shall remove the HSR tag before forwarding the frame to the other port and send a frame from the host to both ports, untagged and without discarding duplicates.
HSR_MODE_U: Unicast Forwarding – in this mode, the node shall behave as in Mode H, except that it shall forward unicast traffic for which it is the destination as it does for multicast.
You may refer to above definition to configure the mode and analyze the network traces.
Garrett
