Other Parts Discussed in Thread: BEAGLEBOARD-X15, TLV320AIC3104, TPIC2810, TLV320AIC3106
hi everyone
we designed our custom board with AM5728 and it has interface with audio codec TLV320AIC3104.
We refer to am57xx-beagle-x15-common.dtsi to modify the device tree file
/* * Copyright (C) 2015-2016 Texas Instruments Incorporated - http://www.ti.com/ * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as * published by the Free Software Foundation. */ #include "am57xx-industrial-grade.dtsi" / { aliases { rtc0 = &mcp_rtc; rtc1 = &tps659038_rtc; rtc2 = &rtc; display0 = &hdmi0; display1 = &lcd0; sound0 = &hdmi; sound1 = &sound0; }; chosen { stdout-path = &uart3; }; vmain: fixedregulator-vmain { compatible = "regulator-fixed"; regulator-name = "VMAIN"; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; regulator-always-on; regulator-boot-on; }; v3_3d: fixedregulator-v3_3d { compatible = "regulator-fixed"; regulator-name = "V3_3D"; vin-supply = <&smps9_reg>; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-always-on; regulator-boot-on; }; vdd_3v3: fixedregulator-vdd_3v3 { compatible = "regulator-fixed"; regulator-name = "vdd_3v3"; vin-supply = <®en1>; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-always-on; regulator-boot-on; }; aic_dvdd: fixedregulator-aic_dvdd { compatible = "regulator-fixed"; regulator-name = "aic_dvdd_fixed"; vin-supply = <&v3_3d>; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-always-on; regulator-boot-on; }; vtt_fixed: fixedregulator-vtt { /* TPS51200 */ compatible = "regulator-fixed"; regulator-name = "vtt_fixed"; vin-supply = <&v3_3d>; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-always-on; regulator-boot-on; }; src_clk_x1: src_clk_x1 { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <20000000>; }; leds-iio { status = "disabled"; compatible = "gpio-leds"; led-out0 { label = "out0"; gpios = <&tpic2810 0 GPIO_ACTIVE_HIGH>; default-state = "off"; }; led-out1 { label = "out1"; gpios = <&tpic2810 1 GPIO_ACTIVE_HIGH>; default-state = "off"; }; led-out2 { label = "out2"; gpios = <&tpic2810 2 GPIO_ACTIVE_HIGH>; default-state = "off"; }; led-out3 { label = "out3"; gpios = <&tpic2810 3 GPIO_ACTIVE_HIGH>; default-state = "off"; }; led-out4 { label = "out4"; gpios = <&tpic2810 4 GPIO_ACTIVE_HIGH>; default-state = "off"; }; led-out5 { label = "out5"; gpios = <&tpic2810 5 GPIO_ACTIVE_HIGH>; default-state = "off"; }; led-out6 { label = "out6"; gpios = <&tpic2810 6 GPIO_ACTIVE_HIGH>; default-state = "off"; }; led-out7 { label = "out7"; gpios = <&tpic2810 7 GPIO_ACTIVE_HIGH>; default-state = "off"; }; }; lcd0: display { compatible = "osddisplays,osd070t1718-19ts", "panel-dpi"; label = "lcd"; enable-gpios = <&gpio2 5 GPIO_ACTIVE_HIGH>; panel-timing { clock-frequency = <33000000>; hactive = <800>; vactive = <480>; hfront-porch = <210>; hback-porch = <16>; hsync-len = <30>; vback-porch = <10>; vfront-porch = <22>; vsync-len = <13>; hsync-active = <0>; vsync-active = <0>; de-active = <1>; pixelclk-active = <1>; }; port { lcd_in: endpoint { remote-endpoint = <&dpi_out>; }; }; }; hdmi0: connector@0 { compatible = "hdmi-connector"; label = "hdmi"; type = "a"; port { hdmi_connector_in: endpoint { remote-endpoint = <&tpd12s015_out>; }; }; }; tpd12s015: encoder@0 { compatible = "ti,tpd12s016", "ti,tpd12s015"; gpios = <0>, /* optional CT_CP_HPD */ <0>, /* optional LS_OE */ <&gpio7 12 GPIO_ACTIVE_HIGH>; /* HPD */ ports { #address-cells = <1>; #size-cells = <0>; port@0 { reg = <0>; tpd12s015_in: endpoint@0 { remote-endpoint = <&hdmi_out>; }; }; port@1 { reg = <1>; tpd12s015_out: endpoint@0 { remote-endpoint = <&hdmi_connector_in>; }; }; }; }; src_clk_x1: src_clk_x1 { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <20000000>; }; sound0: sound@0 { compatible = "simple-audio-card"; simple-audio-card,name = "BeagleBoard-X15"; simple-audio-card,widgets = "Line", "Line Out", "Line", "Line In"; simple-audio-card,routing = "Line Out", "LLOUT", "Line Out", "RLOUT", "MIC2L", "Line In", "MIC2R", "Line In"; simple-audio-card,format = "dsp_b"; simple-audio-card,bitclock-master = <&sound0_master>; simple-audio-card,frame-master = <&sound0_master>; simple-audio-card,bitclock-inversion; simple-audio-card,cpu { sound-dai = <&mcasp3>; }; sound0_master: simple-audio-card,codec { sound-dai = <&tlv320aic3104>; system-clock-frequency = <24500000>; //clocks = <&clkout2_clk>; }; }; }; &dra7_pmx_core { dcan1_pins_default: dcan1_pins_default { pinctrl-single,pins = < DRA7XX_CORE_IOPAD(0x37d0, PIN_OUTPUT_PULLUP | MUX_MODE0) /* dcan1_tx */ DRA7XX_CORE_IOPAD(0x37d4, PIN_INPUT_PULLUP | MUX_MODE0) /* dcan1_rx */ >; }; dcan1_pins_sleep: dcan1_pins_sleep { pinctrl-single,pins = < DRA7XX_CORE_IOPAD(0x37d0, MUX_MODE15 | PULL_UP) /* dcan1_tx.off */ DRA7XX_CORE_IOPAD(0x37d4, MUX_MODE15 | PULL_UP) /* dcan1_rx.off */ >; }; i2c1_pins_default: i2c1_pins_default { pinctrl-single,pins = < DRA7XX_CORE_IOPAD(0x3800, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c1_sda.sda */ DRA7XX_CORE_IOPAD(0x3804, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c1_scl.scl */ >; }; i2c4_pins_default: i2c4_pins_default { pinctrl-single,pins = < DRA7XX_CORE_IOPAD(0x3440, PIN_INPUT_PULLUP | MUX_MODE7) /* gpmc_a0.i2c4_scl */ DRA7XX_CORE_IOPAD(0x3444, PIN_INPUT_PULLUP | MUX_MODE7) /* gpmc_a1.i2c4_sda */ >; }; i2c5_pins_default: i2c5_pins_default { pinctrl-single,pins = < DRA7XX_CORE_IOPAD(0x3450, PIN_INPUT_PULLUP | MUX_MODE7) /* gpmc_a4.i2c4_scl */ DRA7XX_CORE_IOPAD(0x3454, PIN_INPUT_PULLUP | MUX_MODE7) /* gpmc_a5.i2c4_sda */ >; }; spi2_pins: spi2_pins { pinctrl-single,pins = < DRA7XX_CORE_IOPAD(0x37c0, (INPUT_EN | MUX_MODE0)) /* spi2_sclk.spi2_sclk (A26) */ DRA7XX_CORE_IOPAD(0x37c4, (INPUT_EN | MUX_MODE0)) /* spi2_d1.spi2_d1 (B22) */ DRA7XX_CORE_IOPAD(0x37c8, (INPUT_EN | MUX_MODE0)) /* spi2_d0.spi2_d0 (G17) */ DRA7XX_CORE_IOPAD(0x37cc, (PIN_OUTPUT_PULLUP | MUX_MODE0)) /* spi2_cs0.spi2_cs0 (B24) */ DRA7XX_CORE_IOPAD(0x37b4, (PIN_OUTPUT_PULLUP | MUX_MODE3)) /* spi1_cs1.spi2_cs1 (A22) */ >; }; uart1_pins_default: uart1_pins_default { pinctrl-single,pins = < DRA7XX_CORE_IOPAD(0x37e0, PIN_INPUT_PULLUP | MUX_MODE0) /* uart1_rxd.uart1_rxd */ DRA7XX_CORE_IOPAD(0x37e4, PIN_INPUT_PULLUP | MUX_MODE0) /* uart1_txd.uart1_txd */ >; }; uart2_pins_default: uart2_pins_default { pinctrl-single,pins = < 0x3f0 (PIN_INPUT_PULLUP | MUX_MODE4) /* uart2_rxd.uart2_rxd */ 0x3f4 (PIN_INPUT_PULLUP | MUX_MODE4) /* uart2_txd.uart2_txd */ >; }; uart9_pins_default: uart9_pins_default { pinctrl-single,pins = < DRA7XX_CORE_IOPAD(0x3560, PIN_INPUT_PULLUP | MUX_MODE7) /* vin2a_hsync0.uart9_rxd */ DRA7XX_CORE_IOPAD(0x3564, PIN_INPUT_PULLUP | MUX_MODE7) /* vin2a_vsync0.uart9_txd */ >; }; gpio2_pins_default: gpio2_pins_default { pinctrl-single,pins = < DRA7XX_CORE_IOPAD(0x34dc, (PIN_INPUT_PULLUP | MUX_MODE14)) /* vin1a_clk0.gpio2_30 (AG8) */ >; }; gpio3_pins_default: gpio3_pins_default { pinctrl-single,pins = < DRA7XX_CORE_IOPAD(0x354c, PIN_INPUT_PULLUP | MUX_MODE14) /* vin1a_d22.gpio3_26 */ DRA7XX_CORE_IOPAD(0x3550, PIN_INPUT_PULLUP | MUX_MODE14) /* vin1a_d23.gpio3_27 */ DRA7XX_CORE_IOPAD(0x3528, (PIN_INPUT_PULLUP | MUX_MODE14)) /* vin1a_d13.gpio3_17 (AF6) */ DRA7XX_CORE_IOPAD(0x350c, (PIN_INPUT_PULLUP | MUX_MODE14)) /* vin1a_d6.gpio3_10 (AG6) */ DRA7XX_CORE_IOPAD(0x352c, (PIN_INPUT_PULLUP | MUX_MODE14)) /* vin1a_d14.gpio3_18 (AF3) */ >; }; gpio4_pins_default: gpio4_pins_default { pinctrl-single,pins = < DRA7XX_CORE_IOPAD(0x3578, (PIN_INPUT_PULLUP | MUX_MODE14)) /* vin2a_d4.gpio4_5 (D2) */ >; }; gpio5_pins_default: gpio5_pins_default { pinctrl-single,pins = < DRA7XX_CORE_IOPAD(0x3644, PIN_INPUT_PULLUP | MUX_MODE14) /* RMII_MHZ_50_CLK.gpio5_17 */ >; }; gpio6_pins_default: gpio6_pins_default { pinctrl-single,pins = < DRA7XX_CORE_IOPAD(0x3684, PIN_INPUT_PULLUP | MUX_MODE14) /* usb2_drvvbus.gpio6_13 */ >; }; gpio7_pins_default: gpio7_pins_default { pinctrl-single,pins = < DRA7XX_CORE_IOPAD(0x37ec, (PIN_OUTPUT_PULLDOWN | MUX_MODE14)) /* uart1_rtsn.gpio7_25 (C27) */ DRA7XX_CORE_IOPAD(0x37b0, (PIN_INPUT_PULLUP | MUX_MODE14)) /* spi1_cs0.gpio7_10 (A24) */ >; }; ads7846_pins: ads7846_pins { pinctrl-single,pins = < DRA7XX_CORE_IOPAD(0x3548, (PIN_INPUT_PULLUP | MUX_MODE14)) /* vin1a_d21.gpio3_25 */ >; }; am572x_idk_audio_pins: am572x_idk_audio_pins { pinctrl-single,pins = < DRA7XX_CORE_IOPAD(0x3724, (PIN_INPUT_PULLDOWN | MUX_MODE0)) /* mcasp3_aclkx */ DRA7XX_CORE_IOPAD(0x3728, (PIN_INPUT_PULLDOWN | MUX_MODE0)) /* mcasp3_fsx */ DRA7XX_CORE_IOPAD(0x372C, (PIN_INPUT_PULLDOWN | MUX_MODE0)) /* mcasp3_axr0 */ DRA7XX_CORE_IOPAD(0x3730, (PIN_OUTPUT_PULLDOWN | MUX_MODE0)) /* mcasp3_axr1 */ >; }; }; &i2c1 { status = "okay"; clock-frequency = <400000>; pinctrl-names = "default"; pinctrl-0 = <&i2c1_pins_default>; tps659038: tps659038@58 { compatible = "ti,tps659038"; reg = <0x58>; /* interrupts-extended = <&gpio6 16 IRQ_TYPE_LEVEL_HIGH &dra7_pmx_core 0x418>; */ #interrupt-cells = <2>; interrupt-controller; ti,system-power-controller; ti,palmas-override-powerhold; tps659038_pmic { compatible = "ti,tps659038-pmic"; smps12-in-supply = <&vmain>; smps3-in-supply = <&vmain>; smps45-in-supply = <&vmain>; smps6-in-supply = <&vmain>; smps7-in-supply = <&vmain>; smps8-in-supply = <&vmain>; smps9-in-supply = <&vmain>; ldo1-in-supply = <&vmain>; ldo2-in-supply = <&vmain>; ldo3-in-supply = <&vmain>; ldo4-in-supply = <&vmain>; ldo9-in-supply = <&vmain>; ldoln-in-supply = <&vmain>; ldousb-in-supply = <&vmain>; ldortc-in-supply = <&vmain>; regulators { smps12_reg: smps12 { /* VDD_MPU */ regulator-name = "smps12"; regulator-min-microvolt = <850000>; regulator-max-microvolt = <1250000>; regulator-always-on; regulator-boot-on; }; smps3_reg: smps3 { /* VDD_DDR EMIF1 EMIF2 */ regulator-name = "smps3"; regulator-min-microvolt = <1350000>; regulator-max-microvolt = <1350000>; regulator-always-on; regulator-boot-on; }; smps45_reg: smps45 { /* VDD_DSPEVE on AM572 */ /* VDD_IVA + VDD_DSP on AM571 */ regulator-name = "smps45"; regulator-min-microvolt = <850000>; regulator-max-microvolt = <1060000>; regulator-always-on; regulator-boot-on; }; smps6_reg: smps6 { /* VDD_GPU */ regulator-name = "smps6"; regulator-min-microvolt = <850000>; regulator-max-microvolt = <1060000>; regulator-always-on; regulator-boot-on; }; smps7_reg: smps7 { /* VDD_CORE */ regulator-name = "smps7"; regulator-min-microvolt = <850000>; regulator-max-microvolt = <1150000>; regulator-always-on; regulator-boot-on; }; smps8_reg: smps8 { /* 5728 - VDD_IVAHD */ /* 5718 - N.C. test point */ regulator-name = "smps8"; regulator-min-microvolt = <1060000>; regulator-max-microvolt = <1060000>; regulator-always-on; regulator-boot-on; }; smps9_reg: smps9 { /* VDD_3_3D */ regulator-name = "smps9"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-always-on; regulator-boot-on; }; ldo1_reg: ldo1 { /* VDDSHV8 - VSDMMC */ /* NOTE: on rev 1.3a, data supply */ regulator-name = "ldo1"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <3300000>; regulator-boot-on; regulator-always-on; }; ldo2_reg: ldo2 { /* VDDSH18V */ regulator-name = "ldo2"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-always-on; regulator-boot-on; }; ldo3_reg: ldo3 { /* R1.3a 572x V1_8PHY_LDO3: USB, SATA */ regulator-name = "ldo3"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-always-on; regulator-boot-on; }; ldo4_reg: ldo4 { /* R1.3a 572x V1_8PHY_LDO4: PCIE, HDMI*/ regulator-name = "ldo4"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-always-on; regulator-boot-on; }; /* LDO5-8 unused */ ldo9_reg: ldo9 { /* VDD_RTC */ regulator-name = "ldo9"; regulator-min-microvolt = <1050000>; regulator-max-microvolt = <1050000>; regulator-always-on; regulator-boot-on; }; ldoln_reg: ldoln { /* VDDA_1V8_PLL */ regulator-name = "ldoln"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-always-on; regulator-boot-on; }; ldousb_reg: ldousb { /* VDDA_3V_USB: VDDA_USBHS33 */ regulator-name = "ldousb"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-always-on; regulator-boot-on; }; ldortc_reg: ldortc { /* VDDA_RTC */ regulator-name = "ldortc"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-always-on; regulator-boot-on; }; regen1: regen1 { /* VDD_3V3_ON */ regulator-name = "regen1"; regulator-boot-on; regulator-always-on; }; regen2: regen2 { /* Needed for PMIC internal resource */ regulator-name = "regen2"; regulator-boot-on; regulator-always-on; }; }; }; tps659038_rtc: tps659038_rtc { compatible = "ti,palmas-rtc"; interrupt-parent = <&tps659038>; interrupts = <8 IRQ_TYPE_EDGE_FALLING>; wakeup-source; }; tps659038_pwr_button: tps659038_pwr_button { compatible = "ti,palmas-pwrbutton"; interrupt-parent = <&tps659038>; interrupts = <1 IRQ_TYPE_EDGE_FALLING>; wakeup-source; ti,palmas-long-press-seconds = <12>; }; tps659038_gpio: tps659038_gpio { compatible = "ti,palmas-gpio"; gpio-controller; #gpio-cells = <2>; }; extcon_usb2: tps659038_usb { compatible = "ti,palmas-usb-vid"; ti,enable-vbus-detection; ti,enable-id-detection; /* ID & VBUS s provided in board dts */ }; }; tc358778: tc358778@0e { compatible = "toshiba,tc358778", "toshiba,tc358768"; reg = <0x0e>; status = "disabled"; clocks = <&src_clk_x1>; clock-names = "refclk"; ports { #address-cells = <1>; #size-cells = <0>; port@0 { reg = <0>; tc358778_in: endpoint { remote-endpoint = <&dpi_out>; data-lines = <24>; }; }; port@1 { reg = <1>; tc358778_out: endpoint { /* * lanes and remote-endpoint defined per * panel. */ }; }; }; }; tpic2810: tpic2810@60 { compatible = "ti,tpic2810"; reg = <0x60>; gpio-controller; #gpio-cells = <2>; }; ov2659: ov2659@30 { compatible = "ovti,ov2659"; reg = <0x30>; clocks = <&src_clk_x1>; clock-names = "xvclk"; pwrdn-gpios = <&gpio6 14 GPIO_ACTIVE_LOW>; port { ov2659_1: endpoint { hsync-active = <1>; vsync-active = <1>; pclk-sample = <1>; link-frequencies = /bits/ 64 <70000000>; }; }; }; tlv320aic3104: tlv320aic3104@18 { #sound-dai-cells = <0>; compatible = "ti,tlv320aic3104"; reg = <0x18>; status = "okay"; AVDD-supply = <&v3_3d>; IOVDD-supply = <&v3_3d>; DRVDD-supply = <&v3_3d>; DVDD-supply = <&aic_dvdd>; }; }; &i2c4 { status = "okay"; clock-frequency = <400000>; pinctrl-names = "default"; pinctrl-0 = <&i2c4_pins_default>; tmp102: tmp102@49 { compatible = "ti,tmp102"; reg = <0x49>; interrupt-parent = <&gpio3>; interrupts = <13 IRQ_TYPE_LEVEL_LOW>; #thermal-sensor-cells = <1>; }; eeprom@52 { compatible = "24c02"; reg = <0x52>; pagesize = <16>; }; mcp_rtc: rtc@6f { compatible = "microchip,mcp7941x"; reg = <0x6f>; interrupts-extended = <&crossbar_mpu GIC_SPI 2 IRQ_TYPE_EDGE_RISING>, <&dra7_pmx_core 0x424>; interrupt-names = "irq", "wakeup"; wakeup-source; }; }; &i2c5 { status = "okay"; clock-frequency = <400000>; pinctrl-names = "default"; pinctrl-0 = <&i2c5_pins_default>; eeprom@54 { compatible = "24c02"; reg = <0x54>; pagesize = <256>; }; }; &mcspi2 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&spi2_pins>; ti,pindir-d0-out-d1-in; ads7846@0 { pinctrl-names = "default"; pinctrl-0 = <&ads7846_pins>; compatible = "ti,ads7846"; reg = <0>; /* CS0 */ spi-max-frequency = <1500000>; interrupt-parent = <&gpio3>; interrupts = <25 0>; /* gpio3_25 */ pendown-gpio = <&gpio3 25 0>; ti,x-min = /bits/ 16 <0x0>; ti,x-max = /bits/ 16 <0x0fff>; ti,y-min = /bits/ 16 <0x0>; ti,y-max = /bits/ 16 <0x0fff>; ti,x-plate-ohms = /bits/ 16 <180>; ti,pressure-max = /bits/ 16 <255>; ti,debounce-max = /bits/ 16 <10>; ti,debounce-tol = /bits/ 16 <30>; ti,debounce-rep = /bits/ 16 <1>; ti,settle-delay-usec = /bits/ 16 <150>; ti,keep-vref-on = <1>; linux,wakeup; }; ad5724r@0 { compatible = "adi,ad5724r"; reg = <1>; /* CS1 */ spi-cpha; /* SPI_MODE_1 */ spi-max-frequency = <1500000>; }; }; &mcspi3 { status = "okay"; ti,pindir-d0-out-d1-in; sn65hvs882: sn65hvs882@0 { compatible = "pisosr-gpio"; gpio-controller; #gpio-cells = <2>; reg = <0>; spi-max-frequency = <1000000>; spi-cpol; }; }; &uart1 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&uart1_pins_default>; interrupts-extended = <&crossbar_mpu GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, <&dra7_pmx_core 0x3e0>; }; &uart2 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&uart2_pins_default>; }; &uart3 { status = "okay"; interrupts-extended = <&crossbar_mpu GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH &dra7_pmx_core 0x248>; }; &uart9 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&uart9_pins_default>; }; &gpio2 { pinctrl-names = "default"; pinctrl-0 = <&gpio2_pins_default>; status = "okay"; }; &gpio3 { pinctrl-names = "default"; pinctrl-0 = <&gpio3_pins_default>; status = "okay"; }; &gpio4 { pinctrl-names = "default"; pinctrl-0 = <&gpio4_pins_default>; status = "okay"; }; &gpio5 { pinctrl-names = "default"; pinctrl-0 = <&gpio5_pins_default>; status = "okay"; }; &gpio6 { pinctrl-names = "default"; pinctrl-0 = <&gpio6_pins_default>; status = "okay"; }; /* gpio7_25 use to select the spi2 bus connect to vport(low) or dac(high) */ &gpio7 { pinctrl-names = "default"; pinctrl-0 = <&gpio7_pins_default>; status = "okay"; }; &rtc { status = "okay"; ext-clk-src; }; &mac { status = "okay"; dual_emac; }; &cpsw_emac0 { phy_id = <&davinci_mdio>, <0>; phy-mode = "rgmii"; dual_emac_res_vlan = <1>; }; &cpsw_emac1 { phy_id = <&davinci_mdio>, <1>; phy-mode = "rgmii"; dual_emac_res_vlan = <2>; }; &usb2_phy1 { phy-supply = <&ldousb_reg>; }; &usb2_phy2 { phy-supply = <&ldousb_reg>; }; &usb1 { dr_mode = "host"; }; &usb2 { dr_mode = "host"; }; &mmc1 { status = "okay"; vmmc-supply = <&v3_3d>; vmmc_aux-supply = <&ldo1_reg>; bus-width = <4>; cd-gpios = <&gpio6 27 0>; /* gpio 219 */ }; &mmc2 { status = "okay"; vmmc-supply = <&v3_3d>; bus-width = <8>; ti,non-removable; max-frequency = <96000000>; no-1-8-v; /delete-property/ mmc-hs200-1_8v; }; &dcan1 { status = "okay"; pinctrl-names = "default", "sleep", "active"; pinctrl-0 = <&dcan1_pins_sleep>; pinctrl-1 = <&dcan1_pins_sleep>; pinctrl-2 = <&dcan1_pins_default>; }; &qspi { status = "okay"; spi-max-frequency = <76800000>; m25p80@0 { compatible = "s25fl256s1", "jedec,spi-nor"; spi-max-frequency = <76800000>; reg = <0>; spi-tx-bus-width = <1>; spi-rx-bus-width = <4>; #address-cells = <1>; #size-cells = <1>; /* MTD partition table. * The ROM checks the first four physical blocks * for a valid file to boot and the flash here is * 64KiB block size. */ partition@0 { label = "QSPI.SPL"; reg = <0x00000000 0x000020000>; }; partition@1 { label = "QSPI.SPL.backup1"; reg = <0x00020000 0x00020000>; }; partition@2 { label = "QSPI.u-boot"; reg = <0x00040000 0x00100000>; }; partition@3 { label = "QSPI.u-boot-spl-os"; reg = <0x00140000 0x00080000>; }; partition@4 { label = "QSPI.u-boot-env"; reg = <0x001C0000 0x00010000>; }; partition@5 { label = "QSPI.u-boot-env.backup1"; reg = <0x001D0000 0x00010000>; }; partition@6 { label = "QSPI.kernel"; reg = <0x001E0000 0x080000>; }; partition@7 { label = "QSPI.user-data"; reg = <0x009E0000 0x1620000>; }; }; }; &hdmi { status = "okay"; /* * XXX: Support AM572x-Rev 1.2a. this is wrong for AM571x-rev 1.3a, * AM572x-Rev1.3a - but thanks to always-on, they work. * TODO: SWITCH TO LDO4 once rev 1.2a is deprecated * (on rev 1.3a availability) */ vdda-supply = <&ldo3_reg>; port { hdmi_out: endpoint { remote-endpoint = <&tpd12s015_in>; }; }; }; &dss { status = "okay"; vdda_video-supply = <&ldoln_reg>; ports { #address-cells = <1>; #size-cells = <0>; port@0 { reg = <0>; dpi_out: endpoint { remote-endpoint = <&lcd_in>; data-lines = <24>; }; }; }; }; &bb2d { status = "okay"; }; &mcasp3 { pinctrl-names = "default"; pinctrl-0 = <&am572x_idk_audio_pins>; #sound-dai-cells = <0>; assigned-clocks = <&mcasp3_ahclkx_mux>; assigned-clock-parents = <&sys_clkin2>; status = "okay"; op-mode = <0>; /* MCASP_IIS_MODE */ tdm-slots = <2>; /* 4 serializers */ serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */ 1 2 0 0 >; tx-num-evt = <32>; rx-num-evt = <32>; }; &mailbox3 { status = "okay"; mbox_pru1_0: mbox_pru1_0 { status = "okay"; }; mbox_pru1_1: mbox_pru1_1 { status = "okay"; }; }; &mailbox4 { status = "okay"; mbox_pru2_0: mbox_pru2_0 { status = "okay"; }; mbox_pru2_1: mbox_pru2_1 { status = "okay"; }; }; &pruss_soc_bus1 { status = "okay"; pruss1: pruss@4b200000 { status = "okay"; pru1_0: pru@4b234000 { interrupt-parent = <&pruss1_intc>; interrupts = <16>, <17>; interrupt-names = "vring", "kick"; status = "okay"; }; pru1_1: pru@4b238000 { interrupt-parent = <&pruss1_intc>; interrupts = <18>, <19>; interrupt-names = "vring", "kick"; status = "okay"; }; }; }; &pruss_soc_bus2 { status = "okay"; pruss2: pruss@4b280000 { status = "okay"; pru2_0: pru@4b2b4000 { interrupt-parent = <&pruss2_intc>; interrupts = <16>, <17>; interrupt-names = "vring", "kick"; status = "okay"; }; pru2_1: pru@4b2b8000 { interrupt-parent = <&pruss2_intc>; interrupts = <18>, <19>; interrupt-names = "vring", "kick"; status = "okay"; }; }; };
aliases {
rtc0 = &mcp_rtc;
rtc2 = &rtc;
display0 = &hdmi0;
display1 = &lcd0;
sound0 = &hdmi;
sound1 = &sound0;
regulator-boot-on;
vin-supply = <&vdd_3v3>;
regulator-boot-on;
sound0: sound@0 {
"Line", "Line Out",
"Line", "Line In";
"MIC2L", "Line In",
"MIC2R", "Line In";
&i2c1 {
status = "okay";
tps659038: tps659038@58 { ... };
tc358778: tc358778@0e { ... };
tpic2810: tpic2810@60 { ... };
ov2659: ov2659@30 { ... };
reg = <0x18>;
status = "okay";
AVDD-supply = <&vdd_3v3>;
IOVDD-supply = <&vdd_3v3>;
DRVDD-supply = <&vdd_3v3>;
&mcasp3 {
status = "okay";
tdm-slots = <2>;
/* 4 serializers */
1 2 0 0
tx-num-evt = <32>;
rx-num-evt = <32>;
But not working.
root@am57xx-evm:~# dmesg | grep sound
[ 2.975879] No soundcards found.
[ 11.788933] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound@0[0]'
[ 11.806844] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound@0[0]'
[ 11.829823] asoc-simple-card sound@0: tlv320aic3x-hifi <-> 48468000.mcasp mapping ok
root@am57xx-evm:~# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: H58040000encode [HDMI 58040000.encoder], device 0: HDMI 58040000.encoder snd-soc-dummy-dai-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: BeagleBoardX15 [BeagleBoard-X15], device 0: davinci-mcasp.0-tlv320aic3x-hifi tlv320aic3x-hifi-0 []
Subdevices: 1/1
root@am57xx-evm:~# arecord -l
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
Does this mean that there is something wrong with the device tree configuration, and if so, how should I modify it?
Kindly help.
