Hi All,
We are developing arm-dsp application using k2hk device, the system is not behaving as expected and crashing,
In the processor SDK, we are observing some memory mismatch in the following configuration,
- Device tree
dsp-common-mpm-memory@820000000 {
compatible = "ti,keystone-dsp-mem-pool";
reg = <0x8 0x20000000 0x0 0x10000000>;no-map;status = "okay";}; - mpm_config.json
"name": "local-ddr",
"globaladdr": "0x90000000",
"length": "0x30000000",
"devicename": "/dev/dspmem"
}, - DSP repo memory map is DSP source code
DDR_IPC a0000000 0b000000 00000000 0b000000 RW X
the above three configuration is fine? if not than as wihich address we can configure for all?
Snehal
