AM5748: Issue with compiling for envtools
Part Number: AM5748
Other Parts Discussed in Thread: PCF8575, TPS65090, TPS65910
Hi all,
I am using ti-processor-sdk-linux-am57xx-evm-05.00.00.15 for my am5748 custom board development. The u-boot version is  u-boot-2018.01+gitAUTOINC+131dc82830-g131dc82830 but I am not able to compile envtools to get fw_setenv and fw_saveenv command I am getting the error as below,
CHK include/config/uboot.release
CHK include/generated/version_autogenerated.h
CHK include/generated/timestamp_autogenerated.h
UPD include/generated/timestamp_autogenerated.h
HOSTCC tools/env/crc32.o
In file included from tools/env/crc32.c:1:0:
tools/env/../../lib/crc32.c:12:10: fatal error: arpa/inet.h: No such file or directory
#include <arpa/inet.h>
compilation terminated.
make[1]: *** [tools/env/crc32.o] Error 1
make: *** [envtools] Error 2
Please help me to compile this.
Thank you
Deepak H M
  • Deepak,
    Can you let me know the configs that you are enabling?
    - Keerthy
  • Hi Keerthy,
    Thanks for your replay, please find the configs as below
    # Automatically generated file; DO NOT EDIT.
    # U-Boot 2018.01 Configuration
    CONFIG_CREATE_ARCH_SYMLINK=y
    # CONFIG_ARC is not set
    CONFIG_ARM=y
    # CONFIG_M68K is not set
    # CONFIG_MICROBLAZE is not set
    # CONFIG_MIPS is not set
    # CONFIG_NDS32 is not set
    # CONFIG_NIOS2 is not set
    # CONFIG_PPC is not set
    # CONFIG_SANDBOX is not set
    # CONFIG_SH is not set
    # CONFIG_X86 is not set
    # CONFIG_XTENSA is not set
    CONFIG_SYS_ARCH="arm"
    CONFIG_SYS_CPU="armv7"
    CONFIG_SYS_SOC="omap5"
    CONFIG_SYS_VENDOR="ti"
    CONFIG_SYS_BOARD="am57xx"
    CONFIG_SYS_CONFIG_NAME="am57xx_evm"
    # ARM architecture
    CONFIG_HAS_VBAR=y
    CONFIG_HAS_THUMB2=y
    CONFIG_ARM_ASM_UNIFIED=y
    CONFIG_ARM_ERRATA_798870=y
    CONFIG_CPU_V7=y
    CONFIG_SYS_ARM_ARCH=7
    CONFIG_SYS_CACHE_SHIFT_6=y
    CONFIG_SYS_CACHELINE_SIZE=64
    # CONFIG_ARM_SMCCC is not set
    # CONFIG_SEMIHOSTING is not set
    CONFIG_SYS_THUMB_BUILD=y
    CONFIG_SPL_SYS_THUMB_BUILD=y
    # CONFIG_SYS_L2CACHE_OFF is not set
    # CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK is not set
    # CONFIG_ARM_CORTEX_CPU_IS_UP is not set
    CONFIG_USE_ARCH_MEMCPY=y
    CONFIG_SPL_USE_ARCH_MEMCPY=y
    CONFIG_USE_ARCH_MEMSET=y
    CONFIG_SPL_USE_ARCH_MEMSET=y
    # CONFIG_ARM64_SUPPORT_AARCH32 is not set
    # CONFIG_ARCH_AT91 is not set
    # CONFIG_TARGET_EDB93XX is not set
    # CONFIG_TARGET_ASPENITE is not set
    # CONFIG_TARGET_GPLUGD is not set
    # CONFIG_ARCH_DAVINCI is not set
    # CONFIG_KIRKWOOD is not set
    # CONFIG_ARCH_MVEBU is not set
    # CONFIG_TARGET_DEVKIT3250 is not set
    # CONFIG_TARGET_WORK_92105 is not set
    # CONFIG_TARGET_APF27 is not set
    # CONFIG_TARGET_APX4DEVKIT is not set
    # CONFIG_TARGET_XFI3 is not set
    # CONFIG_TARGET_M28EVK is not set
    # CONFIG_TARGET_MX23EVK is not set
    # CONFIG_TARGET_MX28EVK is not set
    # CONFIG_TARGET_MX23_OLINUXINO is not set
    # CONFIG_TARGET_BG0900 is not set
    # CONFIG_TARGET_SANSA_FUZE_PLUS is not set
    # CONFIG_TARGET_SC_SPS_1 is not set
    # CONFIG_ORION5X is not set
    # CONFIG_TARGET_SPEAR300 is not set
    # CONFIG_TARGET_SPEAR310 is not set
    # CONFIG_TARGET_SPEAR320 is not set
    # CONFIG_TARGET_SPEAR600 is not set
    # CONFIG_TARGET_STV0991 is not set
    # CONFIG_TARGET_X600 is not set
    # CONFIG_TARGET_IMX31_PHYCORE is not set
    # CONFIG_TARGET_IMX31_PHYCORE_EET is not set
    # CONFIG_TARGET_MX31ADS is not set
    # CONFIG_TARGET_MX31PDK is not set
    # CONFIG_TARGET_WOODBURN is not set
    # CONFIG_TARGET_WOODBURN_SD is not set
    # CONFIG_TARGET_FLEA3 is not set
    # CONFIG_TARGET_MX35PDK is not set
    # CONFIG_ARCH_BCM283X is not set
    # CONFIG_TARGET_VEXPRESS_CA15_TC2 is not set
    # CONFIG_TARGET_VEXPRESS_CA5X2 is not set
    # CONFIG_TARGET_VEXPRESS_CA9X4 is not set
    # CONFIG_TARGET_BCM23550_W1D is not set
    # CONFIG_TARGET_BCM28155_AP is not set
    # CONFIG_TARGET_BCMCYGNUS is not set
    # CONFIG_TARGET_BCMNSP is not set
    # CONFIG_TARGET_BCMNS2 is not set
    # CONFIG_ARCH_EXYNOS is not set
    # CONFIG_ARCH_S5PC1XX is not set
    # CONFIG_ARCH_HIGHBANK is not set
    # CONFIG_ARCH_INTEGRATOR is not set
    # CONFIG_ARCH_KEYSTONE is not set
    CONFIG_ARCH_OMAP2PLUS=y
    # CONFIG_ARCH_MESON is not set
    # CONFIG_ARCH_MX25 is not set
    # CONFIG_ARCH_MX7ULP is not set
    # CONFIG_ARCH_MX7 is not set
    # CONFIG_ARCH_MX6 is not set
    CONFIG_SPL_LDSCRIPT="arch/arm/mach-omap2/u-boot-spl.lds"
    # CONFIG_ARCH_MX5 is not set
    # CONFIG_ARCH_QEMU is not set
    # CONFIG_ARCH_RMOBILE is not set
    # CONFIG_TARGET_S32V234EVB is not set
    # CONFIG_ARCH_SNAPDRAGON is not set
    # CONFIG_ARCH_SOCFPGA is not set
    # CONFIG_ARCH_SUNXI is not set
    # CONFIG_TARGET_TS4600 is not set
    # CONFIG_ARCH_VF610 is not set
    # CONFIG_ARCH_ZYNQ is not set
    # CONFIG_ARCH_ZYNQMP is not set
    # CONFIG_TEGRA is not set
    # CONFIG_TARGET_VEXPRESS64_AEMV8A is not set
    # CONFIG_TARGET_VEXPRESS64_BASE_FVP is not set
    # CONFIG_TARGET_VEXPRESS64_BASE_FVP_DRAM is not set
    # CONFIG_TARGET_VEXPRESS64_JUNO is not set
    # CONFIG_TARGET_LS2080A_EMU is not set
    # CONFIG_TARGET_LS2080A_SIMU is not set
    # CONFIG_TARGET_LS1088AQDS is not set
    # CONFIG_TARGET_LS2080AQDS is not set
    # CONFIG_TARGET_LS2080ARDB is not set
    # CONFIG_TARGET_LS2081ARDB is not set
    # CONFIG_TARGET_HIKEY is not set
    # CONFIG_TARGET_POPLAR is not set
    # CONFIG_TARGET_LS1012AQDS is not set
    # CONFIG_TARGET_LS1012ARDB is not set
    # CONFIG_TARGET_LS1012AFRDM is not set
    # CONFIG_TARGET_LS1088ARDB is not set
    # CONFIG_TARGET_LS1021AQDS is not set
    # CONFIG_TARGET_LS1021ATWR is not set
    # CONFIG_TARGET_LS1021AIOT is not set
    # CONFIG_TARGET_LS1043AQDS is not set
    # CONFIG_TARGET_LS1043ARDB is not set
    # CONFIG_TARGET_LS1046AQDS is not set
    # CONFIG_TARGET_LS1046ARDB is not set
    # CONFIG_TARGET_H2200 is not set
    # CONFIG_TARGET_ZIPITZ2 is not set
    # CONFIG_TARGET_COLIBRI_PXA270 is not set
    # CONFIG_ARCH_UNIPHIER is not set
    # CONFIG_STM32 is not set
    # CONFIG_ARCH_STI is not set
    # CONFIG_ARCH_ROCKCHIP is not set
    # CONFIG_TARGET_THUNDERX_88XX is not set
    # CONFIG_ARCH_ASPEED is not set
    # CONFIG_TI_SECURE_DEVICE is not set
    CONFIG_SYS_TEXT_BASE=0x80800000
    CONFIG_TI_I2C_BOARD_DETECT=y
    CONFIG_EEPROM_BUS_ADDRESS=0
    CONFIG_EEPROM_CHIP_ADDRESS=0x50
    CONFIG_TI_COMMON_CMD_OPTIONS=y
    CONFIG_SPL_GPIO_SUPPORT=y
    CONFIG_SPL_LIBCOMMON_SUPPORT=y
    CONFIG_SPL_LIBGENERIC_SUPPORT=y
    CONFIG_SYS_MALLOC_F_LEN=0x2000
    # CONFIG_OMAP34XX is not set
    # CONFIG_OMAP44XX is not set
    CONFIG_OMAP54XX=y
    # CONFIG_TI814X is not set
    # CONFIG_TI816X is not set
    # CONFIG_AM43XX is not set
    # CONFIG_AM33XX is not set
    CONFIG_SYS_MPUCLK=500
    CONFIG_DRA7XX=y
    # CONFIG_TARGET_CL_SOM_AM57X is not set
    # CONFIG_TARGET_CM_T54 is not set
    # CONFIG_TARGET_OMAP5_UEVM is not set
    # CONFIG_TARGET_DRA7XX_EVM is not set
    CONFIG_TARGET_AM57XX_EVM=y
    CONFIG_OMAP_PLATFORM_RESET_TIME_MAX_USEC=31219
    # Voltage Domain OPP selections
    CONFIG_DRA7_MPU_OPP_NOM=y
    # CONFIG_DRA7_DSPEVE_OPP_NOM is not set
    # CONFIG_DRA7_DSPEVE_OPP_OD is not set
    CONFIG_DRA7_DSPEVE_OPP_HIGH=y
    # CONFIG_DRA7_IVA_OPP_NOM is not set
    # CONFIG_DRA7_IVA_OPP_OD is not set
    CONFIG_DRA7_IVA_OPP_HIGH=y
    # CONFIG_DRA7_GPU_OPP_NOM is not set
    # CONFIG_DRA7_GPU_OPP_OD is not set
    CONFIG_DRA7_GPU_OPP_HIGH=y
    CONFIG_CONS_INDEX=3
    CONFIG_SPL_MMC_SUPPORT=y
    CONFIG_SPL_SERIAL_SUPPORT=y
    # CONFIG_SPL_DRIVERS_MISC_SUPPORT is not set
    CONFIG_SPL_LIBDISK_SUPPORT=y
    # CONFIG_SPL_NAND_SUPPORT is not set
    CONFIG_SPL_SPI_FLASH_SUPPORT=y
    CONFIG_SPL_SPI_SUPPORT=y
    # CONFIG_SPL_WATCHDOG_SUPPORT is not set
    CONFIG_IDENT_STRING=""
    CONFIG_SPL_STACK_R_ADDR=0x82000000
    CONFIG_SPL_FAT_SUPPORT=y
    CONFIG_ARMV7_LPAE=y
    # CONFIG_CMD_DEKBLOB is not set
    # CONFIG_CMD_HDMIDETECT is not set
    # ARM debug
    # CONFIG_DEBUG_LL is not set
    CONFIG_DEFAULT_DEVICE_TREE="am572x-idk"
    CONFIG_SMBIOS_PRODUCT_NAME="am57xx"
    # CONFIG_DEBUG_UART is not set
    # CONFIG_AHCI is not set
    # General setup
    CONFIG_LOCALVERSION=""
    CONFIG_LOCALVERSION_AUTO=y
    CONFIG_CC_OPTIMIZE_FOR_SIZE=y
    # CONFIG_DISTRO_DEFAULTS is not set
    CONFIG_SYS_MALLOC_F=y
    CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000
    CONFIG_TPL_SYS_MALLOC_F_LEN=0x2000
    CONFIG_EXPERT=y
    CONFIG_SYS_MALLOC_CLEAR_ON_INIT=y
    # CONFIG_TOOLS_DEBUG is not set
    # CONFIG_PHYS_64BIT is not set
    # Boot images
    CONFIG_ANDROID_BOOT_IMAGE=y
    CONFIG_FIT=y
    CONFIG_FIT_ENABLE_SHA256_SUPPORT=y
    # CONFIG_FIT_SIGNATURE is not set
    # CONFIG_FIT_VERBOSE is not set
    # CONFIG_FIT_BEST_MATCH is not set
    CONFIG_SPL_FIT=y
    # CONFIG_SPL_FIT_SIGNATURE is not set
    CONFIG_SPL_LOAD_FIT=y
    # CONFIG_SPL_FIT_IMAGE_POST_PROCESS is not set
    CONFIG_SPL_FIT_SOURCE=""
    CONFIG_SPL_FIT_GENERATOR=""
    CONFIG_OF_BOARD_SETUP=y
    # CONFIG_OF_SYSTEM_SETUP is not set
    # CONFIG_OF_STDOUT_VIA_ALIAS is not set
    CONFIG_SYS_EXTRA_OPTIONS=""
    CONFIG_ARCH_FIXUP_FDT_MEMORY=y
    # API
    # CONFIG_API is not set
    # Boot timing
    # CONFIG_BOOTSTAGE is not set
    CONFIG_BOOTSTAGE_RECORD_COUNT=30
    CONFIG_SPL_BOOTSTAGE_RECORD_COUNT=5
    CONFIG_BOOTSTAGE_STASH_ADDR=0
    CONFIG_BOOTSTAGE_STASH_SIZE=0x1000
    # Boot media
    # CONFIG_NAND_BOOT is not set
    # CONFIG_ONENAND_BOOT is not set
    CONFIG_QSPI_BOOT=y
    # CONFIG_SATA_BOOT is not set
    # CONFIG_SD_BOOT is not set
    CONFIG_SPI_BOOT=y
    CONFIG_BOOTDELAY=2
    CONFIG_USE_BOOTARGS=y
    CONFIG_BOOTARGS="androidboot.serialno=${serial#} console=ttyS2,115200 androidboot.console=ttyS2 androidboot.hardware=am57xevmboard"
    # CONFIG_USE_BOOTCOMMAND is not set
    # Console
    # CONFIG_CONSOLE_RECORD is not set
    CONFIG_LOGLEVEL=4
    CONFIG_SPL_LOGLEVEL=4
    # CONFIG_SILENT_CONSOLE is not set
    # CONFIG_PRE_CONSOLE_BUFFER is not set
    # CONFIG_CONSOLE_MUX is not set
    # CONFIG_SYS_CONSOLE_IS_IN_ENV is not set
    # CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE is not set
    # CONFIG_SYS_CONSOLE_ENV_OVERWRITE is not set
    CONFIG_SYS_CONSOLE_INFO_QUIET=y
    # CONFIG_SYS_STDIO_DEREGISTER is not set
    # Logging
    # CONFIG_LOG is not set
    # CONFIG_SPL_LOG is not set
    CONFIG_DEFAULT_FDT_FILE=""
    CONFIG_VERSION_VARIABLE=y
    CONFIG_BOARD_LATE_INIT=y
    CONFIG_DISPLAY_CPUINFO=y
    CONFIG_DISPLAY_BOARDINFO=y
    # Start-up hooks
    # CONFIG_ARCH_EARLY_INIT_R is not set
    # CONFIG_ARCH_MISC_INIT is not set
    CONFIG_BOARD_EARLY_INIT_F=y
    # Security support
    CONFIG_HASH=y
    # SPL / TPL
    CONFIG_SUPPORT_SPL=y
    CONFIG_SPL=y
    CONFIG_SPL_BOARD_INIT=y
    # CONFIG_SPL_BOOTROM_SUPPORT is not set
    CONFIG_SPL_RAW_IMAGE_SUPPORT=y
    CONFIG_SPL_LEGACY_IMAGE_SUPPORT=y
    CONFIG_SPL_SYS_MALLOC_SIMPLE=y
    # CONFIG_TPL_SYS_MALLOC_SIMPLE is not set
    CONFIG_SPL_STACK_R=y
    CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x100000
    CONFIG_SPL_SEPARATE_BSS=y
    CONFIG_SPL_DISPLAY_PRINT=y
    CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y
    CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300
    # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION is not set
    CONFIG_SPL_CRC32_SUPPORT=y
    # CONFIG_SPL_MD5_SUPPORT is not set
    # CONFIG_SPL_SHA1_SUPPORT is not set
    # CONFIG_SPL_SHA256_SUPPORT is not set
    # CONFIG_SPL_FIT_IMAGE_TINY is not set
    # CONFIG_SPL_CPU_SUPPORT is not set
    # CONFIG_SPL_CRYPTO_SUPPORT is not set
    # CONFIG_SPL_HASH_SUPPORT is not set
    CONFIG_SPL_DMA_SUPPORT=y
    CONFIG_SPL_ENV_SUPPORT=y
    # CONFIG_SPL_SAVEENV is not set
    # CONFIG_SPL_ETH_SUPPORT is not set
    CONFIG_SPL_EXT_SUPPORT=y
    # CONFIG_SPL_FPGA_SUPPORT is not set
    CONFIG_SPL_I2C_SUPPORT=y
    # CONFIG_SPL_MMC_WRITE is not set
    # CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT is not set
    # CONFIG_SPL_MTD_SUPPORT is not set
    # CONFIG_SPL_MUSB_NEW_SUPPORT is not set
    # CONFIG_SPL_NET_SUPPORT is not set
    # CONFIG_SPL_NO_CPU_SUPPORT is not set
    # CONFIG_SPL_NOR_SUPPORT is not set
    # CONFIG_SPL_XIP_SUPPORT is not set
    # CONFIG_SPL_ONENAND_SUPPORT is not set
    CONFIG_SPL_OS_BOOT=y
    # CONFIG_SPL_PCI_SUPPORT is not set
    # CONFIG_SPL_PCH_SUPPORT is not set
    # CONFIG_SPL_POST_MEM_SUPPORT is not set
    CONFIG_SPL_POWER_SUPPORT=y
    # CONFIG_SPL_RAM_SUPPORT is not set
    # CONFIG_SPL_RTC_SUPPORT is not set
    # CONFIG_SPL_SATA_SUPPORT is not set
    CONFIG_SPL_THERMAL=y
    # CONFIG_SPL_USB_HOST_SUPPORT is not set
    # CONFIG_SPL_USB_GADGET_SUPPORT is not set
    # CONFIG_SPL_YMODEM_SUPPORT is not set
    # Command line interface
    CONFIG_CMDLINE=y
    CONFIG_HUSH_PARSER=y
    CONFIG_SYS_PROMPT="=> "
    # Autoboot options
    CONFIG_AUTOBOOT=y
    # CONFIG_AUTOBOOT_KEYED is not set
    # FASTBOOT
    CONFIG_FASTBOOT=y
    CONFIG_USB_FUNCTION_FASTBOOT=y
    CONFIG_CMD_FASTBOOT=y
    CONFIG_FASTBOOT_BUF_ADDR=0x82000000
    CONFIG_FASTBOOT_BUF_SIZE=0x2F000000
    CONFIG_FASTBOOT_USB_DEV=1
    CONFIG_FASTBOOT_FLASH=y
    CONFIG_FASTBOOT_FLASH_MMC=y
    CONFIG_FASTBOOT_FLASH_MMC_DEV=1
    CONFIG_FASTBOOT_GPT_NAME="gpt"
    CONFIG_FASTBOOT_MBR_NAME="mbr"
    # Commands
    # Info commands
    CONFIG_CMD_BDI=y
    # CONFIG_CMD_CONFIG is not set
    CONFIG_CMD_CONSOLE=y
    # CONFIG_CMD_CPU is not set
    # CONFIG_CMD_LICENSE is not set
    # Boot commands
    CONFIG_CMD_BOOTD=y
    CONFIG_CMD_BOOTM=y
    CONFIG_CMD_BOOTZ=y
    CONFIG_CMD_BOOTEFI=y
    CONFIG_CMD_BOOTEFI_HELLO_COMPILE=y
    # CONFIG_CMD_BOOTEFI_HELLO is not set
    # CONFIG_CMD_BOOTEFI_SELFTEST is not set
    # CONFIG_CMD_BOOTMENU is not set
    CONFIG_CMD_ELF=y
    CONFIG_CMD_FDT=y
    CONFIG_CMD_GO=y
    CONFIG_CMD_RUN=y
    CONFIG_CMD_IMI=y
    # CONFIG_CMD_IMLS is not set
    CONFIG_CMD_XIMG=y
    # CONFIG_CMD_POWEROFF is not set
    CONFIG_CMD_SPL=y
    CONFIG_CMD_SPL_NAND_OFS=0
    CONFIG_CMD_SPL_WRITE_SIZE=0x2000
    # CONFIG_CMD_THOR_DOWNLOAD is not set
    # CONFIG_CMD_ZBOOT is not set
    # Environment commands
    CONFIG_CMD_ASKENV=y
    CONFIG_CMD_EXPORTENV=y
    CONFIG_CMD_IMPORTENV=y
    CONFIG_CMD_EDITENV=y
    # CONFIG_CMD_GREPENV is not set
    CONFIG_CMD_SAVEENV=y
    CONFIG_CMD_ENV_EXISTS=y
    # CONFIG_CMD_ENV_CALLBACK is not set
    # CONFIG_CMD_ENV_FLAGS is not set
    # Memory commands
    CONFIG_CMD_CRC32=y
    # CONFIG_CRC32_VERIFY is not set
    CONFIG_CMD_EEPROM=y
    # CONFIG_CMD_EEPROM_LAYOUT is not set
    # CONFIG_LOOPW is not set
    # CONFIG_CMD_MD5SUM is not set
    # CONFIG_CMD_MEMINFO is not set
    CONFIG_CMD_MEMORY=y
    # CONFIG_CMD_MEMTEST is not set
    # CONFIG_CMD_MX_CYCLIC is not set
    # CONFIG_CMD_SHA1SUM is not set
    # CONFIG_CMD_STRINGS is not set
    # Compression commands
    # CONFIG_CMD_LZMADEC is not set
    # CONFIG_CMD_UNZIP is not set
    # CONFIG_CMD_ZIP is not set
    # Device access commands
    # CONFIG_CMD_ARMFLASH is not set
    # CONFIG_CMD_CLK is not set
    # CONFIG_CMD_DEMO is not set
    CONFIG_CMD_DFU=y
    CONFIG_CMD_DM=y
    # CONFIG_CMD_FDC is not set
    # CONFIG_CMD_FLASH is not set
    CONFIG_CMD_FPGA=y
    # CONFIG_CMD_FPGA_LOADBP is not set
    # CONFIG_CMD_FPGA_LOADFS is not set
    # CONFIG_CMD_FPGA_LOADMK is not set
    # CONFIG_CMD_FPGA_LOADP is not set
    # CONFIG_CMD_FPGAD is not set
    # CONFIG_CMD_FUSE is not set
    CONFIG_CMD_GPIO=y
    CONFIG_CMD_GPT=y
    CONFIG_RANDOM_UUID=y
    # CONFIG_CMD_GPT_RENAME is not set
    # CONFIG_CMD_IDE is not set
    # CONFIG_CMD_IO is not set
    # CONFIG_CMD_IOTRACE is not set
    CONFIG_CMD_I2C=y
    CONFIG_CMD_LOADB=y
    CONFIG_CMD_LOADS=y
    CONFIG_CMD_MMC=y
    # CONFIG_CMD_NAND is not set
    # CONFIG_CMD_MMC_SPI is not set
    # CONFIG_CMD_ONENAND is not set
    CONFIG_CMD_PART=y
    # CONFIG_CMD_PCI is not set
    # CONFIG_CMD_PCMCIA is not set
    # CONFIG_CMD_READ is not set
    # CONFIG_CMD_SATA is not set
    # CONFIG_CMD_SAVES is not set
    # CONFIG_CMD_SDRAM is not set
    CONFIG_CMD_SF=y
    # CONFIG_CMD_SF_TEST is not set
    CONFIG_CMD_SPI=y
    # CONFIG_CMD_TSI148 is not set
    # CONFIG_CMD_UNIVERSE is not set
    CONFIG_CMD_USB=y
    # CONFIG_CMD_USB_SDP is not set
    # CONFIG_CMD_USB_MASS_STORAGE is not set
    # Shell scripting commands
    CONFIG_CMD_ECHO=y
    CONFIG_CMD_ITEST=y
    CONFIG_CMD_SOURCE=y
    # CONFIG_CMD_SETEXPR is not set
    # Network commands
    CONFIG_CMD_NET=y
    # CONFIG_CMD_TFTPPUT is not set
    # CONFIG_CMD_TFTPSRV is not set
    # CONFIG_CMD_RARP is not set
    CONFIG_CMD_DHCP=y
    # CONFIG_CMD_PXE is not set
    CONFIG_CMD_NFS=y
    CONFIG_CMD_MII=y
    CONFIG_CMD_PING=y
    # CONFIG_CMD_CDP is not set
    # CONFIG_CMD_SNTP is not set
    # CONFIG_CMD_DNS is not set
    # CONFIG_CMD_LINK_LOCAL is not set
    # CONFIG_CMD_ETHSW is not set
    # Misc commands
    # CONFIG_CMD_BSP is not set
    # CONFIG_CMD_BKOPS_ENABLE is not set
    # CONFIG_CMD_CACHE is not set
    # CONFIG_CMD_DISPLAY is not set
    # CONFIG_CMD_LED is not set
    # CONFIG_CMD_DATE is not set
    CONFIG_CMD_TIME=y
    # CONFIG_CMD_GETTIME is not set
    CONFIG_CMD_MISC=y
    # CONFIG_CMD_TIMER is not set
    # CONFIG_CMD_QFW is not set
    # CONFIG_CMD_TERMINAL is not set
    # CONFIG_CMD_UUID is not set
    # TI specific command line interface
    CONFIG_CMD_DDR3=y
    # Power commands
    # CONFIG_CMD_PMIC is not set
    CONFIG_CMD_REGULATOR=y
    # Security commands
    # CONFIG_CMD_AES is not set
    # CONFIG_CMD_BLOB is not set
    # CONFIG_CMD_HASH is not set
    # Firmware commands
    # Filesystem commands
    # CONFIG_CMD_BTRFS is not set
    CONFIG_CMD_EXT2=y
    CONFIG_CMD_EXT4=y
    CONFIG_CMD_EXT4_WRITE=y
    CONFIG_CMD_FAT=y
    CONFIG_CMD_FS_GENERIC=y
    # CONFIG_CMD_FS_UUID is not set
    # CONFIG_CMD_JFFS2 is not set
    # CONFIG_CMD_MTDPARTS is not set
    # CONFIG_CMD_REISER is not set
    CONFIG_CMD_SCSI=y
    # CONFIG_CMD_ZFS is not set
    # Debug commands
    # CONFIG_CMD_BEDBUG is not set
    # CONFIG_CMD_DIAG is not set
    # CONFIG_CMD_KGDB is not set
    # CONFIG_CMD_LOG is not set
    # CONFIG_CMD_TRACE is not set
    # CONFIG_CMD_UBI is not set
    # Partition Types
    CONFIG_PARTITIONS=y
    # CONFIG_MAC_PARTITION is not set
    # CONFIG_SPL_MAC_PARTITION is not set
    CONFIG_DOS_PARTITION=y
    CONFIG_SPL_DOS_PARTITION=y
    CONFIG_ISO_PARTITION=y
    CONFIG_SPL_ISO_PARTITION=y
    # CONFIG_AMIGA_PARTITION is not set
    # CONFIG_SPL_AMIGA_PARTITION is not set
    CONFIG_EFI_PARTITION=y
    CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=128
    CONFIG_EFI_PARTITION_ENTRIES_OFF=0
    CONFIG_SPL_EFI_PARTITION=y
    CONFIG_PARTITION_UUIDS=y
    CONFIG_SPL_PARTITION_UUIDS=y
    # CONFIG_PARTITION_TYPE_GUID is not set
    CONFIG_SUPPORT_OF_CONTROL=y
    CONFIG_DTC=y
    # Device Tree Control
    CONFIG_OF_CONTROL=y
    # CONFIG_OF_BOARD_FIXUP is not set
    CONFIG_SPL_OF_CONTROL=y
    # CONFIG_OF_LIVE is not set
    CONFIG_OF_SEPARATE=y
    # CONFIG_OF_EMBED is not set
    # CONFIG_OF_BOARD is not set
    CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am57xx-beagle-x15-revc am572x-idk am571x-idk am574x-idk"
    # CONFIG_MULTI_DTB_FIT is not set
    # CONFIG_SPL_MULTI_DTB_FIT is not set
    CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clocks clock-names interrupt-parent"
    # CONFIG_SPL_OF_PLATDATA is not set
    CONFIG_MKIMAGE_DTC_PATH="dtc"
    # Environment
    # CONFIG_ENV_IS_NOWHERE is not set
    # CONFIG_ENV_IS_IN_EEPROM is not set
    # CONFIG_ENV_IS_IN_FAT is not set
    # CONFIG_ENV_IS_IN_FLASH is not set
    # CONFIG_ENV_IS_IN_MMC is not set
    # CONFIG_ENV_IS_IN_NAND is not set
    # CONFIG_ENV_IS_IN_NVRAM is not set
    # CONFIG_ENV_IS_IN_ONENAND is not set
    # CONFIG_ENV_IS_IN_REMOTE is not set
    CONFIG_ENV_IS_IN_SPI_FLASH=y
    # CONFIG_ENV_IS_IN_UBI is not set
    CONFIG_NET=y
    # CONFIG_NET_RANDOM_ETHADDR is not set
    # CONFIG_NETCONSOLE is not set
    CONFIG_NET_TFTP_VARS=y
    CONFIG_BOOTP_PXE_CLIENTARCH=0x15
    CONFIG_BOOTP_VCI_STRING="U-Boot.armv7"
    # Device Drivers
    # Generic Driver Options
    CONFIG_DM=y
    CONFIG_SPL_DM=y
    CONFIG_DM_WARN=y
    # CONFIG_DM_DEBUG is not set
    CONFIG_DM_DEVICE_REMOVE=y
    CONFIG_DM_STDIO=y
    CONFIG_DM_SEQ_ALIAS=y
    CONFIG_SPL_DM_SEQ_ALIAS=y
    CONFIG_REGMAP=y
    CONFIG_SPL_REGMAP=y
    CONFIG_SYSCON=y
    CONFIG_SPL_SYSCON=y
    # CONFIG_DEVRES is not set
    CONFIG_SIMPLE_BUS=y
    CONFIG_SPL_SIMPLE_BUS=y
    CONFIG_OF_TRANSLATE=y
    CONFIG_SPL_OF_TRANSLATE=y
    CONFIG_DM_DEV_READ_INLINE=y
    # CONFIG_ADC is not set
    # CONFIG_ADC_EXYNOS is not set
    # CONFIG_ADC_SANDBOX is not set
    # CONFIG_SARADC_ROCKCHIP is not set
    # CONFIG_SATA is not set
    CONFIG_LIBATA=y
    CONFIG_SCSI_AHCI=y
    # SATA/SCSI device support
    # CONFIG_DWC_AHSATA is not set
    # CONFIG_FSL_SATA is not set
    # CONFIG_MVSATA_IDE is not set
    # CONFIG_SATA_MV is not set
    # CONFIG_SATA_SIL is not set
    # CONFIG_SATA_SIL3114 is not set
    # CONFIG_BLK is not set
    # CONFIG_BLOCK_CACHE is not set
    # CONFIG_IDE is not set
    # Boot count support
    # CONFIG_BOOTCOUNT is not set
    # Clock
    # CONFIG_CLK is not set
    # CONFIG_CPU is not set
    # Hardware crypto devices
    # CONFIG_FSL_CAAM is not set
    # CONFIG_SYS_FSL_SEC_BE is not set
    # CONFIG_SYS_FSL_SEC_LE is not set
    # Demo for driver model
    # CONFIG_DM_DEMO is not set
    # DFU support
    CONFIG_USB_FUNCTION_DFU=y
    # CONFIG_DFU_TFTP is not set
    CONFIG_DFU_MMC=y
    # CONFIG_DFU_NAND is not set
    CONFIG_DFU_RAM=y
    # CONFIG_DFU_SF is not set
    # DMA Support
    # CONFIG_DMA is not set
    # CONFIG_TI_EDMA3 is not set
    # FPGA support
    # CONFIG_FPGA_ALTERA is not set
    # CONFIG_FPGA_SOCFPGA is not set
    # CONFIG_FPGA_XILINX is not set
    # GPIO Support
    CONFIG_DM_GPIO=y
    # CONFIG_ALTERA_PIO is not set
    # CONFIG_DWAPB_GPIO is not set
    # CONFIG_AT91_GPIO is not set
    # CONFIG_ATMEL_PIO4 is not set
    # CONFIG_INTEL_BROADWELL_GPIO is not set
    # CONFIG_INTEL_ICH6_GPIO is not set
    # CONFIG_IMX_RGPIO2P is not set
    # CONFIG_HSDK_CREG_GPIO is not set
    # CONFIG_LPC32XX_GPIO is not set
    # CONFIG_MSM_GPIO is not set
    CONFIG_OMAP_GPIO=y
    # CONFIG_CMD_PCA953X is not set
    # CONFIG_PCF8575_GPIO is not set
    # CONFIG_ROCKCHIP_GPIO is not set
    # CONFIG_CMD_TCA642X is not set
    # CONFIG_TEGRA_GPIO is not set
    # CONFIG_TEGRA186_GPIO is not set
    # CONFIG_VYBRID_GPIO is not set
    # CONFIG_DM_74X164 is not set
    # CONFIG_DM_PCA953X is not set
    # CONFIG_MPC85XX_GPIO is not set
    # I2C support
    CONFIG_DM_I2C=y
    # CONFIG_DM_I2C_COMPAT is not set
    # CONFIG_I2C_SET_DEFAULT_BUS_NUM is not set
    # CONFIG_DM_I2C_GPIO is not set
    # CONFIG_SYS_I2C_FSL is not set
    # CONFIG_SYS_I2C_DW is not set
    # CONFIG_SYS_I2C_INTEL is not set
    # CONFIG_SYS_I2C_IMX_LPI2C is not set
    CONFIG_SYS_I2C_OMAP24XX=y
    # CONFIG_SYS_I2C_ROCKCHIP is not set
    # CONFIG_SYS_I2C_MVTWSI is not set
    CONFIG_SYS_I2C_BUS_MAX=5
    # CONFIG_I2C_MUX is not set
    # CONFIG_DM_KEYBOARD is not set
    # CONFIG_CROS_EC_KEYB is not set
    # LED Support
    # CONFIG_LED is not set
    # CONFIG_SPL_LED is not set
    # CONFIG_LED_STATUS is not set
    # Mailbox Controller Support
    # CONFIG_DM_MAILBOX is not set
    # Memory Controller drivers
    # Multifunction device drivers
    CONFIG_MISC=y
    # CONFIG_ALTERA_SYSID is not set
    # CONFIG_ATSHA204A is not set
    # CONFIG_ROCKCHIP_EFUSE is not set
    # CONFIG_CROS_EC is not set
    # CONFIG_DS4510 is not set
    # CONFIG_FSL_SEC_MON is not set
    # CONFIG_MXC_OCOTP is not set
    # CONFIG_NUVOTON_NCT6102D is not set
    # CONFIG_PWRSEQ is not set
    # CONFIG_PCA9551_LED is not set
    # CONFIG_WINBOND_W83627 is not set
    # CONFIG_I2C_EEPROM is not set
    # CONFIG_SPL_I2C_EEPROM is not set
    # MMC Host controller Support
    CONFIG_MMC=y
    CONFIG_MMC_WRITE=y
    # CONFIG_MMC_BROKEN_CD is not set
    CONFIG_DM_MMC=y
    CONFIG_SPL_DM_MMC=y
    # CONFIG_ARM_PL180_MMCI is not set
    CONFIG_MMC_QUIRKS=y
    CONFIG_MMC_HW_PARTITIONING=y
    CONFIG_MMC_IO_VOLTAGE=y
    # CONFIG_SPL_MMC_IO_VOLTAGE is not set
    CONFIG_MMC_UHS_SUPPORT=y
    # CONFIG_MMC_HS200_SUPPORT is not set
    # CONFIG_SPL_MMC_HS200_SUPPORT is not set
    CONFIG_MMC_VERBOSE=y
    # CONFIG_SPL_MMC_TINY is not set
    # CONFIG_MMC_DW is not set
    # CONFIG_MMC_MXC is not set
    # CONFIG_MMC_MXS is not set
    # CONFIG_MMC_PCI is not set
    CONFIG_MMC_OMAP_HS=y
    # CONFIG_MMC_SDHCI is not set
    # CONFIG_FTSDC010 is not set
    # MTD Support
    # CONFIG_MTD is not set
    # CONFIG_MTD_NOR_FLASH is not set
    # CONFIG_NAND is not set
    # SPI Flash Support
    CONFIG_DM_SPI_FLASH=y
    CONFIG_SPI_FLASH=y
    CONFIG_SPI_FLASH_BAR=y
    # CONFIG_SF_DUAL_FLASH is not set
    # CONFIG_SPI_FLASH_ATMEL is not set
    # CONFIG_SPI_FLASH_EON is not set
    # CONFIG_SPI_FLASH_GIGADEVICE is not set
    # CONFIG_SPI_FLASH_MACRONIX is not set
    CONFIG_SPI_FLASH_SPANSION=y
    # CONFIG_SPI_FLASH_STMICRO is not set
    # CONFIG_SPI_FLASH_SST is not set
    # CONFIG_SPI_FLASH_WINBOND is not set
    CONFIG_SPI_FLASH_USE_4K_SECTORS=y
    # CONFIG_SPI_FLASH_DATAFLASH is not set
    # CONFIG_SPI_FLASH_MTD is not set
    # UBI support
    # CONFIG_MTD_UBI is not set
    # CONFIG_BITBANGMII is not set
    # CONFIG_MV88E6352_SWITCH is not set
    CONFIG_PHYLIB=y
    # CONFIG_MV88E61XX_SWITCH is not set
    # CONFIG_PHYLIB_10G is not set
    # CONFIG_PHY_AQUANTIA is not set
    # CONFIG_PHY_ATHEROS is not set
    # CONFIG_PHY_BROADCOM is not set
    # CONFIG_PHY_CORTINA is not set
    # CONFIG_PHY_DAVICOM is not set
    # CONFIG_PHY_ET1011C is not set
    # CONFIG_PHY_LXT is not set
    # CONFIG_PHY_MARVELL is not set
    # CONFIG_PHY_MESON_GXL is not set
    CONFIG_PHY_MICREL=y
    CONFIG_PHY_MICREL_KSZ90X1=y
    # CONFIG_PHY_MICREL_KSZ8XXX is not set
    # CONFIG_PHY_MSCC is not set
    # CONFIG_PHY_NATSEMI is not set
    # CONFIG_PHY_REALTEK is not set
    # CONFIG_PHY_SMSC is not set
    # CONFIG_PHY_TERANETICS is not set
    # CONFIG_PHY_TI is not set
    # CONFIG_PHY_VITESSE is not set
    # CONFIG_PHY_XILINX is not set
    # CONFIG_PHY_FIXED is not set
    CONFIG_DM_ETH=y
    CONFIG_NETDEVICES=y
    CONFIG_PHY_GIGE=y
    # CONFIG_ALTERA_TSE is not set
    # CONFIG_BCM_SF2_ETH is not set
    # CONFIG_DWC_ETH_QOS is not set
    # CONFIG_E1000 is not set
    # CONFIG_ETH_DESIGNWARE is not set
    # CONFIG_ETHOC is not set
    # CONFIG_FTMAC100 is not set
    # CONFIG_MACB is not set
    # CONFIG_RGMII is not set
    # CONFIG_RTL8139 is not set
    # CONFIG_RTL8169 is not set
    # CONFIG_SMC911X is not set
    # CONFIG_SUN7I_GMAC is not set
    # CONFIG_SUN4I_EMAC is not set
    # CONFIG_SUN8I_EMAC is not set
    # CONFIG_PCI is not set
    # PHY Subsystem
    CONFIG_PHY=y
    # CONFIG_SPL_PHY is not set
    # CONFIG_NOP_PHY is not set
    CONFIG_PIPE3_PHY=y
    CONFIG_OMAP_USB2_PHY=y
    # CONFIG_MVEBU_COMPHY_SUPPORT is not set
    # Pin controllers
    # CONFIG_PINCTRL is not set
    # CONFIG_SPL_PINCTRL is not set
    # Power
    # Power Domain Support
    # CONFIG_POWER_DOMAIN is not set
    CONFIG_DM_PMIC=y
    CONFIG_PMIC_CHILDREN=y
    CONFIG_SPL_PMIC_CHILDREN=y
    # CONFIG_PMIC_ACT8846 is not set
    # CONFIG_PMIC_AS3722 is not set
    # CONFIG_DM_PMIC_PFUZE100 is not set
    # CONFIG_DM_PMIC_MAX77686 is not set
    # CONFIG_DM_PMIC_MAX8998 is not set
    # CONFIG_PMIC_MAX8997 is not set
    # CONFIG_PMIC_PM8916 is not set
    # CONFIG_PMIC_RK8XX is not set
    # CONFIG_PMIC_S2MPS11 is not set
    # CONFIG_DM_PMIC_SANDBOX is not set
    # CONFIG_PMIC_S5M8767 is not set
    # CONFIG_PMIC_RN5T567 is not set
    # CONFIG_PMIC_TPS65090 is not set
    CONFIG_PMIC_PALMAS=y
    # CONFIG_PMIC_LP873X is not set
    # CONFIG_PMIC_LP87565 is not set
    # CONFIG_POWER_MC34VR500 is not set
    # CONFIG_DM_PMIC_TPS65910 is not set
    CONFIG_DM_REGULATOR=y
    # CONFIG_SPL_DM_REGULATOR is not set
    # CONFIG_REGULATOR_PWM is not set
    # CONFIG_DM_REGULATOR_FIXED is not set
    # CONFIG_DM_REGULATOR_GPIO is not set
    CONFIG_DM_REGULATOR_PALMAS=y
    CONFIG_DM_REGULATOR_PBIAS=y
    # CONFIG_DM_PWM is not set
    # CONFIG_PWM_SANDBOX is not set
    # CONFIG_RAM is not set
    # Remote Processor drivers
    # Reset Controller Support
    # CONFIG_DM_RESET is not set
    # Real Time Clock
    # CONFIG_DM_RTC is not set
    # CONFIG_RTC_S35392A is not set
    CONFIG_SCSI=y
    # Serial drivers
    CONFIG_BAUDRATE=115200
    CONFIG_REQUIRE_SERIAL_CONSOLE=y
    CONFIG_SERIAL_PRESENT=y
    CONFIG_SPL_SERIAL_PRESENT=y
    CONFIG_DM_SERIAL=y
    # CONFIG_SERIAL_RX_BUFFER is not set
    CONFIG_SPL_DM_SERIAL=y
    # CONFIG_TPL_DM_SERIAL is not set
    # CONFIG_DEBUG_UART_SKIP_INIT is not set
    # CONFIG_ALTERA_JTAG_UART is not set
    # CONFIG_ALTERA_UART is not set
    # CONFIG_ATMEL_USART is not set
    # CONFIG_FSL_LPUART is not set
    # CONFIG_MVEBU_A3700_UART is not set
    # CONFIG_NULLDEV_SERIAL is not set
    CONFIG_SYS_NS16550=y
    # CONFIG_MSM_SERIAL is not set
    # CONFIG_PXA_SERIAL is not set
    # Sound support
    # CONFIG_SOUND is not set
    # SPI Support
    CONFIG_DM_SPI=y
    # CONFIG_ALTERA_SPI is not set
    # CONFIG_CADENCE_QSPI is not set
    # CONFIG_DESIGNWARE_SPI is not set
    # CONFIG_EXYNOS_SPI is not set
    # CONFIG_FSL_DSPI is not set
    # CONFIG_ICH_SPI is not set
    # CONFIG_MVEBU_A3700_SPI is not set
    # CONFIG_ROCKCHIP_SPI is not set
    # CONFIG_TEGRA114_SPI is not set
    # CONFIG_TEGRA20_SFLASH is not set
    # CONFIG_TEGRA20_SLINK is not set
    # CONFIG_TEGRA210_QSPI is not set
    # CONFIG_XILINX_SPI is not set
    # CONFIG_SOFT_SPI is not set
    # CONFIG_FSL_ESPI is not set
    # CONFIG_FSL_QSPI is not set
    # CONFIG_ATCSPI200_SPI is not set
    CONFIG_TI_QSPI=y
    # CONFIG_OMAP3_SPI is not set
    # SPMI support
    # CONFIG_SPMI is not set
    # System reset device drivers
    # CONFIG_SYSRESET is not set
    # CONFIG_SYSRESET_SYSCON is not set
    # CONFIG_SYSRESET_WATCHDOG is not set
    CONFIG_DM_THERMAL=y
    CONFIG_TI_DRA7_THERMAL=y
    # Timer Support
    # CONFIG_TIMER is not set
    # TPM support
    CONFIG_USB=y
    CONFIG_DM_USB=y
    # USB Host Controller Drivers
    CONFIG_USB_HOST=y
    CONFIG_USB_XHCI_HCD=y
    CONFIG_USB_XHCI_DWC3=y
    # CONFIG_USB_XHCI_PCI is not set
    CONFIG_USB_XHCI_DRA7XX_INDEX=0
    CONFIG_USB_DM_XHCI_OMAP=y
    # CONFIG_USB_XHCI_FSL is not set
    # CONFIG_USB_EHCI_HCD is not set
    # CONFIG_USB_OHCI_HCD is not set
    # CONFIG_USB_UHCI_HCD is not set
    # CONFIG_USB_DWC2 is not set
    CONFIG_USB_DWC3=y
    # CONFIG_USB_DWC3_HOST is not set
    CONFIG_USB_DWC3_GADGET=y
    # Platform Glue Driver Support
    CONFIG_USB_DWC3_OMAP=y
    # PHY Subsystem
    CONFIG_USB_DWC3_PHY_OMAP=y
    # CONFIG_USB_DWC3_PHY_SAMSUNG is not set
    # MUSB Controller Driver
    # CONFIG_USB_MUSB_HOST is not set
    # CONFIG_USB_MUSB_GADGET is not set
    # CONFIG_USB_MUSB_TI is not set
    # ULPI drivers
    # USB peripherals
    CONFIG_USB_STORAGE=y
    # CONFIG_USB_KEYBOARD is not set
    CONFIG_USB_GADGET=y
    CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments"
    CONFIG_USB_GADGET_VENDOR_NUM=0x0451
    CONFIG_USB_GADGET_PRODUCT_NUM=0xd022
    # CONFIG_USB_GADGET_ATMEL_USBA is not set
    # CONFIG_USB_GADGET_BCM_UDC_OTG_PHY is not set
    # CONFIG_USB_GADGET_DWC2_OTG is not set
    # CONFIG_CI_UDC is not set
    CONFIG_USB_GADGET_VBUS_DRAW=2
    CONFIG_USB_GADGET_DUALSPEED=y
    CONFIG_USB_GADGET_DOWNLOAD=y
    # CONFIG_USB_FUNCTION_SDP is not set
    # CONFIG_USB_ETHER is not set
    # CONFIG_USB_HOST_ETHER is not set
    # Graphics support
    # CONFIG_DM_VIDEO is not set
    # CONFIG_SYS_WHITE_ON_BLACK is not set
    # CONFIG_NO_FB_CLEAR is not set
    # TrueType Fonts
    # CONFIG_VIDEO_VESA is not set
    # CONFIG_VIDEO_LCD_ANX9804 is not set
    # CONFIG_VIDEO_LCD_SSD2828 is not set
    # CONFIG_VIDEO_MVEBU is not set
    # CONFIG_I2C_EDID is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_VIDEO_TEGRA20 is not set
    # CONFIG_VIDEO_BRIDGE is not set
    # CONFIG_VIDEO is not set
    # CONFIG_LCD is not set
    # CONFIG_VIDEO_SIMPLE is not set
    # CONFIG_VIDEO_DT_SIMPLEFB is not set
    # Watchdog Timer Support
    # CONFIG_BCM2835_WDT is not set
    # CONFIG_OMAP_WATCHDOG is not set
    # CONFIG_ULP_WATCHDOG is not set
    # CONFIG_WDT is not set
    # CONFIG_PHYS_TO_BUS is not set
    # File systems
    # CONFIG_FS_BTRFS is not set
    # CONFIG_FS_CBFS is not set
    CONFIG_FS_FAT=y
    CONFIG_FAT_WRITE=y
    CONFIG_FS_FAT_MAX_CLUSTSIZE=65536
    # CONFIG_FS_JFFS2 is not set
    # CONFIG_FS_CRAMFS is not set
    # CONFIG_YAFFS2 is not set
    # Library routines
    # CONFIG_BCH is not set
    # CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED is not set
    # CONFIG_DYNAMIC_CRC_TABLE is not set
    CONFIG_HAVE_PRIVATE_LIBGCC=y
    CONFIG_USE_PRIVATE_LIBGCC=y
    CONFIG_SYS_HZ=1000
    # CONFIG_USE_TINY_PRINTF is not set
    # CONFIG_PANIC_HANG is not set
    CONFIG_REGEX=y
    # CONFIG_LIB_RAND is not set
    # CONFIG_SPL_TINY_MEMSET is not set
    # CONFIG_TPL_TINY_MEMSET is not set
    # CONFIG_BITREVERSE is not set
    # CONFIG_CMD_DHRYSTONE is not set
    # Security support
    # CONFIG_AES is not set
    # CONFIG_RSA is not set
    # CONFIG_TPM is not set
    # Hashing Support
    CONFIG_SHA1=y
    CONFIG_SHA256=y
    # CONFIG_SHA_HW_ACCEL is not set
    CONFIG_MD5=y
    # Compression Support
    # CONFIG_LZ4 is not set
    # CONFIG_LZMA is not set
    # CONFIG_LZO is not set
    # CONFIG_SPL_LZO is not set
    # CONFIG_SPL_GZIP is not set
    # CONFIG_ERRNO_STR is not set
    CONFIG_OF_LIBFDT=y
    CONFIG_OF_LIBFDT_OVERLAY=y
    CONFIG_SPL_OF_LIBFDT=y
    # CONFIG_FDT_FIXUP_PARTITIONS is not set
    # System tables
    CONFIG_GENERATE_SMBIOS_TABLE=y
    CONFIG_SMBIOS_MANUFACTURER="ti"
    CONFIG_EFI_LOADER=y
    # CONFIG_UNIT_TEST is not set
    Thank you
    Deepak
  • Deepak,
    Apologies for not getting back on this earlier. Can you consider migrating to latest release?
    http://software-dl.ti.com/processor-sdk-linux/esd/AM57X/latest/index_FDS.html
    Keerthy
  • Hi keerthy,
    Thanks for your reply, this issue is with tool chain which comes with sdk. I downloaded seperately from the website now I am able to compile them. I was about to replay you sorry for the delay from my side. And your help means a lot for me.
    Thank you
    Deepak H M
