There is only a maximum case temperature mentioned in the datasheet, what is the maximum junction temperature value ?
Swadish,
Maximum case temperature is the rating provided as it can be measured accurately. There is no way to measure the junction temperature accurately. Also, for multi-core devices, the temperature in the die will not be uniform. You can use the THETA-JC value and the maximum current from the power estimation tool to calculate an estimate of the maximum junction temperature. It will only be a few degrees C above the case temperature assuming the heat is being dissipated through the lid.
Tom
