I have an AM4378 Custom.
I have an error message during the boot.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
Pls let me know how to fix this problem.
I attached the boot log file below.
CPU : AM437X-GP rev 1.2 Model: TI AM437x GP EVM DRAM: 2 GiB PMIC: TPS65218 NAND: 512 MiB MMC: OMAP SD/MMC: 0 Loading Environment from FAT... *** Warning - bad CRC, using default environment Net: Warning: ethernet@4a100000 using MAC address from ROM eth0: ethernet@4a100000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 ** Unable to read file boot.scr ** 848 bytes read in 1 ms (828.1 KiB/s) Loaded env from uEnv.txt Importing environment from mmc0 ... switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 4293120 bytes read in 217 ms (18.9 MiB/s) 52345 bytes read in 4 ms (12.5 MiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 8fff0000, end 8ffffc78 ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.19.59-g5f8c1c6121 (kihan21@ubuntu) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #10 [ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: TI AM437x GP EVM [ 0.000000] Memory policy: Data cache writeback [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 48 MiB at 0xfcc00000 [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] AM437x ES1.2 (sgx neon) [ 0.000000] random: get_random_bytes called from start_kernel+0xa0/0x420 with crng_init=0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 522559 [ 0.000000] Kernel command line: console=ttyO0,115200n8 video=HDMI-A-1:800x600 root=PARTUUID=8fa8f7a9-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 2015660K/2097148K available (8192K kernel code, 318K rwdata, 2708K rodata, 1024K init, 254K bss, 32336K reserved, 49152K cma-reserved, 1261) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (9184 kB) [ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB) [ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 319 kB) [ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 255 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] Tasks RCU enabled. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] L2C: platform modifies aux control register: 0x0e030000 -> 0x3e430000 [ 0.000000] L2C: DT/platform modifies aux control register: 0x0e030000 -> 0x3e430000 [ 0.000000] L2C-310 enabling early BRESP for Cortex-A9 [ 0.000000] OMAP L2C310: ROM does not support power control setting [ 0.000000] L2C-310 dynamic clock gating disabled, standby mode disabled [ 0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB [ 0.000000] L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x4e430000 [ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz [ 0.000013] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns [ 0.000029] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000037] OMAP clocksource: timer1 at 24000000 Hz [ 0.000401] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns [ 0.000410] OMAP clocksource: 32k_counter at 32768 Hz [ 0.000779] Console: colour dummy device 80x30 [ 0.000807] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0' [ 0.000813] This ensures that you still see kernel messages. Please [ 0.000817] update your kernel commandline. [ 0.000858] Calibrating delay loop... 1987.37 BogoMIPS (lpj=9936896) [ 0.060177] pid_max: default: 32768 minimum: 301 [ 0.060356] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.060380] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.061109] CPU: Testing write buffer coherency: ok [ 0.061162] CPU0: Spectre v2: using BPIALL workaround [ 0.061987] Setting up static identity map for 0x80100000 - 0x80100060 [ 0.062125] rcu: Hierarchical SRCU implementation. [ 0.062444] EFI services will not be available. [ 0.063483] devtmpfs: initialized [ 0.072281] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 0.072640] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.072662] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.075831] pinctrl core: initialized pinctrl subsystem [ 0.076486] DMI not present or invalid. [ 0.076906] NET: Registered protocol family 16 [ 0.078542] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.149742] cpuidle: using governor ladder [ 0.149777] cpuidle: using governor menu [ 0.156430] OMAP GPIO hardware version 0.1 [ 0.165005] No ATAGs? [ 0.165028] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers. [ 0.165042] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.177354] edma 49000000.edma: TI EDMA DMA engine driver [ 0.181117] SCSI subsystem initialized [ 0.181610] media: Linux media interface: v0.10 [ 0.181649] videodev: Linux video capture interface: v2.00 [ 0.181751] pps_core: LinuxPPS API ver. 1 registered [ 0.181759] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.181782] PTP clock support registered [ 0.181813] EDAC MC: Ver: 3.0.0 [ 0.182715] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400 [ 0.183309] Advanced Linux Sound Architecture Driver Initialized. [ 0.184343] clocksource: Switched to clocksource timer1 [ 0.191390] NET: Registered protocol family 2 [ 0.192074] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes) [ 0.192107] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 0.192166] TCP bind hash table entries: 8192 (order: 3, 32768 bytes) [ 0.192239] TCP: Hash tables configured (established 8192 bind 8192) [ 0.192422] UDP hash table entries: 512 (order: 1, 8192 bytes) [ 0.192445] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes) [ 0.192577] NET: Registered protocol family 1 [ 0.193097] RPC: Registered named UNIX socket transport module. [ 0.193109] RPC: Registered udp transport module. [ 0.193114] RPC: Registered tcp transport module. [ 0.193120] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.194974] Initialise system trusted keyrings [ 0.195203] workingset: timestamp_bits=14 max_order=19 bucket_order=5 [ 0.198926] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.199572] NFS: Registering the id_resolver key type [ 0.199603] Key type id_resolver registered [ 0.199610] Key type id_legacy registered [ 0.199648] ntfs: driver 2.1.32 [Flags: R/O]. [ 0.201636] Key type asymmetric registered [ 0.201651] Asymmetric key parser 'x509' registered [ 0.201712] bounce: pool size: 64 pages [ 0.201770] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.201781] io scheduler noop registered [ 0.201787] io scheduler deadline registered [ 0.201994] io scheduler cfq registered (default) [ 0.202004] io scheduler mq-deadline registered [ 0.202010] io scheduler kyber registered [ 0.204631] pinctrl-single 44e10800.pinmux: 199 pins, size 796 [ 0.207703] pwm-backlight backlight: backlight supply power not found, using dummy regulator [ 0.207796] pwm-backlight backlight: Linked as a consumer to regulator.0 [ 0.247065] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.249875] omap8250 44e09000.serial: No clock speed specified: using default: 48000000 [ 0.250534] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 31, base_baud = 3000000) is a 8250 [ 0.940734] console [ttyS0] enabled [ 0.944850] omap8250 481a6000.serial: No clock speed specified: using default: 48000000 [ 0.953531] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 32, base_baud = 3000000) is a 8250 [ 0.964459] omap_rng 48310000.rng: Random Number Generator ver. 20 [ 0.971852] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator [ 0.981342] random: fast init done [ 0.984995] random: crng init done [ 0.989082] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0 [ 0.996029] omapdss_dss 4832a000.dss: Dropping the link to regulator.0 [ 1.005447] panel-simple display: display supply power not found, using dummy regulator [ 1.013566] panel-simple display: Linked as a consumer to regulator.0 [ 1.030600] brd: module loaded [ 1.041842] loop: module loaded [ 1.047810] libphy: Fixed MDIO Bus: probed [ 1.124400] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000 [ 1.132100] davinci_mdio 4a101000.mdio: detected phy mask fffffffe [ 1.139347] libphy: 4a101000.mdio: probed [ 1.143389] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver Micrel KSZ9031 Gigabit PHY [ 1.153934] cpsw 4a100000.ethernet: Detected MACID = 34:b1:f7:3d:b9:84 [ 1.160682] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4 [ 1.167139] cpsw 4a100000.ethernet: ALE Table size 1024 [ 1.172419] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies) [ 1.180901] i2c /dev entries driver [ 1.186309] cpuidle: enable-method property 'ti,am4372' found operations [ 1.193449] sdhci: Secure Digital Host Controller Interface driver [ 1.199752] sdhci: Copyright(c) Pierre Ossman [ 1.205488] omap_hsmmc 47810000.mmc: Linked as a consumer to regulator.2 [ 1.237390] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.243932] ledtrig-cpu: registered to indicate activity on CPUs [ 1.254921] NET: Registered protocol family 10 [ 1.260638] Segment Routing with IPv6 [ 1.264540] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 1.271199] NET: Registered protocol family 17 [ 1.276159] Key type dns_resolver registered [ 1.280740] omap_voltage_late_init: Voltage driver support not added [ 1.288045] Loading compiled-in X.509 certificates [ 1.302990] GPIO line 119 (SelEMMCorNAND) hogged as output/low [ 1.309717] GPIO line 136 (SelLCDorHDMI) hogged as output/high [ 1.316249] omap-gpmc 50000000.gpmc: GPMC revision 6.0 [ 1.321418] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000 [ 1.328859] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xdc [ 1.335295] nand: Micron MT29F4G08ABAEAWP [ 1.339324] nand: 512 MiB, SLC, erase size: 256 KiB, page size: 4096, OOB size: 224 [ 1.347094] Using OMAP_ECC_BCH16_CODE_HW ECC scheme [ 1.352092] 10 fixed-partitions partitions found on MTD device omap2-nand.0 [ 1.359105] Creating 10 MTD partitions on "omap2-nand.0": [ 1.364542] 0x000000000000-0x000000040000 : "NAND.SPL" [ 1.370621] 0x000000040000-0x000000080000 : "NAND.SPL.backup1" [ 1.377279] 0x000000080000-0x0000000c0000 : "NAND.SPL.backup2" [ 1.383820] 0x0000000c0000-0x000000100000 : "NAND.SPL.backup3" [ 1.390424] 0x000000100000-0x000000180000 : "NAND.u-boot-spl-os" [ 1.397273] 0x000000180000-0x000000280000 : "NAND.u-boot" [ 1.403499] 0x000000280000-0x0000002c0000 : "NAND.u-boot-env" [ 1.410010] 0x0000002c0000-0x000000300000 : "NAND.u-boot-env.backup1" [ 1.417239] 0x000000300000-0x000000a00000 : "NAND.kernel" [ 1.424243] 0x000000a00000-0x000020000000 : "NAND.file-system" [ 1.540060] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 100 kHz [ 1.547270] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 100 kHz [ 1.553403] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator [ 1.562820] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0 [ 1.569745] DSS: OMAP DSS rev 2.0 [ 1.574040] omapdss_dss 4832a000.dss: bound 4832a400.dispc (ops dispc_component_ops) [ 1.582331] omapdrm omapdrm.0: DMM not available, disable DMM support [ 1.589104] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 1.595782] [drm] No driver support for vblank timestamp query. [ 1.664183] Console: switching to colour frame buffer device 100x30 [ 1.687320] omapdrm omapdrm.0: fb0: omapdrm frame buffer device [ 1.693982] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 0 [ 1.701658] cpu cpu0: Linked as a consumer to regulator.5 [ 1.707209] cpu cpu0: Dropping the link to regulator.5 [ 1.712539] cpu cpu0: Linked as a consumer to regulator.5 [ 1.719306] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22) [ 1.728186] omap_hsmmc 48060000.mmc: Got CD GPIO [ 1.733264] omap_hsmmc 48060000.mmc: Linked as a consumer to regulator.1 [ 1.766228] hctosys: unable to open rtc device (rtc0) [ 1.772822] vmmcwl_fixed: disabling [ 1.776523] ALSA device list: [ 1.779653] No soundcards found. [ 1.785098] Waiting for root device PARTUUID=8fa8f7a9-02... [ 1.847605] mmc1: host does not support reading read-only switch, assuming write-enable [ 1.861509] mmc1: new high speed SDHC card at address aaaa [ 1.868337] mmcblk1: mmc1:aaaa SU04G 3.69 GiB [ 1.876961] mmcblk1: p1 p2 [ 2.000794] EXT4-fs (mmcblk1p2): recovery complete [ 2.010095] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ 2.018411] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 2.028307] devtmpfs: mounted [ 2.033124] Freeing unused kernel memory: 1024K [ 2.037883] Run /sbin/init as init process [ 2.367802] systemd[1]: System time before build time, advancing clock. [ 2.412595] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ) [ 2.435229] systemd[1]: Detected architecture arm. Welcome to Arago 2019.07! [ 2.478091] systemd[1]: Set hostname to <am437x-evm>. [ 2.782041] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not suppo. [ 2.799422] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.) [ 3.193303] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 3.225210] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 3.255381] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 3.289306] systemd[1]: Created slice system-getty.slice. [ OK ] Created slice system-getty.slice. [ 3.326384] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ OK ] Listening on Journal Socket. Mounting POSIX Message Queue File System... Mounting Kernel Debug File System... Starting Load Kernel Modules... [ OK ] Started Hardware RNG Entropy Gatherer Daemon. Starting Remount Root and Kernel File Systems... [ OK ] Created slice system-serial\x2dgetty.slice. [ 3.589228] cmemk: disagrees about version of symbol module_layout [ 3.599550] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null) Starting Journal Service... [ OK ] Reached target Swap. [ 3.631044] cryptodev: disagrees about version of symbol module_layout Starting Create list of required st��…ce nodes for the current kernel... [ 3.659881] usb_common: disagrees about version of symbol module_layout [ 3.683116] usb_common: disagrees about version of symbol module_layout [ OK ] Listening on Network Service Netlink Socket. [ 3.711229] uio: disagrees about version of symbol module_layout [ OK ] Listening on initctl Compatibility Named Pipe. [ OK ] Created slice User and Session Slice. [ OK ] Reached target Slices. [ OK ] Started Forward Password Requests to Wall Directory Watch. [ OK ] Reached target Paths. Mounting Temporary Directory (/tmp)... [ OK ] Listening on Process Core Dump Socket. [ OK ] Listening on udev Control Socket. Starting udev Coldplug all Devices... [ OK ] Started Journal Service. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Kernel Debug File System. [FAILED] Failed to start Load Kernel Modules. See 'systemctl status systemd-modules-load.service' for details. [ OK ] Started Remount Root and Kernel File Systems. [ OK ] Started Create list of required sta��…vice nodes for the current kernel. [ OK ] Mounted Temporary Directory (/tmp). Starting Create Static Device Nodes in /dev... Starting Apply Kernel Variables... Mounting Kernel Configuration File System... Starting Flush Journal to Persistent Storage... [ 4.499702] sch_fq_codel: disagrees about version of symbol module_layout [ OK ] Started Create Static Device Nodes in /dev. [ OK ] Started Apply Kernel Variables. [ OK ] Mounted Kernel Configuration File System. [ 4.635354] systemd-journald[80]: Received request to flush runtime journal from PID 1 [ OK ] Reached target Local File Systems (Pre). Mounting /var/volatile... Mounting /media/ram... [ OK ] Reached target Containers. Starting udev Kernel Device Manager... [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Mounted /var/volatile. [ OK ] Mounted /media/ram. Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... [ OK ] Started udev Kernel Device Manager. [ OK ] Started Load/Save Random Seed. [ OK ] Started Create Volatile Files and Directories. Starting Network Service... Starting Network Time Synchronization... Starting Update UTMP about System Boot/Shutdown... [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Started Network Service. Starting Network Name Resolution... Starting Wait for Network to be Configured... [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Time Synchronized. [ 6.471054] ti_am335x_tscadc: disagrees about version of symbol module_layout [ 6.478613] omap_wdt: disagrees about version of symbol module_layout [ 6.496767] rtc_omap: disagrees about version of symbol module_layout [ 6.503651] rtc_omap: disagrees about version of symbol module_layout [ OK ] Started udev Coldplug all Devices. [ OK ] Reached target System Initialization. [ OK ] Listening on RPCbind Server Activation Socket[ 6.647032] phy_omap_usb2: disagrees about version of symbol module_layout . [ 6.657057] remoteproc: disagrees about version of symbol module_layout [ 6.664728] phy_omap_usb2: disagrees about version of symbol module_layout [ 6.679017] ti_am335x_tscadc: disagrees about version of symbol module_layout [ 6.721867] omap_wdt: disagrees about version of symbol module_layout [ OK ] Listening on dropbear.socket. [ 6.813948] rtc_omap: disagrees about version of symbol module_layout [ 6.845683] phy_omap_usb2: disagrees about version of symbol module_layout [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ 6.887580] phy_omap_usb2: disagrees about version of symbol module_layout [ OK ] Started Daily rotation of log files. [ 6.917801] remoteproc: disagrees about version of symbol module_layout [ 6.925556] rtc_omap: disagrees about version of symbol module_layout [ 6.968255] remoteproc: disagrees about version of symbol module_layout Starting Reboot and dump vmcore via kexec... [ OK ] Listening on D-Bus System Message Bus Socket. [ OK ] Reached target Sockets. [ 7.103657] v4l2_fwnode: disagrees about version of symbol module_layout [ OK ] Reached target Basic System. Starting uim-sysfs.service... [ 7.210892] remoteproc: disagrees about version of symbol module_layout [ 7.295523] v4l2_fwnode: disagrees about version of symbol module_layout [ 7.324646] pixcir_i2c_ts: disagrees about version of symbol module_layout [ 7.334587] snd_soc_tlv320aic3x: disagrees about version of symbol module_layout [ OK ] Started D-Bus System Message Bus. [ 7.445860] v4l2_fwnode: disagrees about version of symbol module_layout [ 7.529350] v4l2_fwnode: disagrees about version of symbol module_layout [ 7.583969] pixcir_i2c_ts: disagrees about version of symbol module_layout [ 7.617588] snd_soc_tlv320aic3x: disagrees about version of symbol module_layout [ 7.639487] can_dev: disagrees about version of symbol module_layout [ 7.647583] can_dev: disagrees about version of symbol module_layout [ 7.710921] can_dev: disagrees about version of symbol module_layout [ 7.720887] can_dev: disagrees about version of symbol module_layout [ OK ] Started Job spooling tools. [ 7.814136] v4l2_fwnode: disagrees about version of symbol module_layout [ 7.828457] v4l2_fwnode: disagrees about version of symbol module_layout [ 7.854687] dwc3_omap: disagrees about version of symbol module_layout [ 7.929878] can_dev: disagrees about version of symbol module_layout Starting RPC Bind Service... [ 7.961967] dwc3_omap: disagrees about version of symbol module_layout [ 7.983738] can_dev: disagrees about version of symbol module_layout [ 8.037188] dwc3_omap: disagrees about version of symbol module_layout Starting Print notice about GPLv3 packages... [ 8.072788] v4l2_fwnode: disagrees about version of symbol module_layout [ 8.109138] v4l2_fwnode: disagrees about version of symbol module_layout [ 8.121029] can_dev: disagrees about version of symbol module_layout Starting Login Service... [ 8.148519] can_dev: disagrees about version of symbol module_layout [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target Timers. [ 8.270090] dwc3_omap: disagrees about version of symbol module_layout [ OK ] Started Periodic Command Scheduler. [ OK ] Started Network Name Resolution. [ OK ] Started Reboot and dump vmcore via kexec. [ OK ] Started RPC Bind Service. [ 8.693994] ti_emif_sram: disagrees about version of symbol module_layout [ 8.709425] omap_crypto: disagrees about version of symbol module_layout [ 8.719737] omap_crypto: disagrees about version of symbol module_layout [ 8.726812] omap_sham: disagrees about version of symbol module_layout [ 8.743077] pruss_soc_bus: disagrees about version of symbol module_layout [ OK ] Found device /dev/ttyS0. [ 8.832609] omap_crypto: disagrees about version of symbol module_layout [ 8.877411] omap_sham: disagrees about version of symbol module_layout [ 8.889786] pruss_soc_bus: disagrees about version of symbol module_layout [ 8.946844] omap_crypto: disagrees about version of symbol module_layout [ 8.969030] ti_emif_sram: disagrees about version of symbol module_layout Starting Avahi mDNS/DNS-SD Stack... [ OK ] Reached target Network. Starting Permit User Sessions... Starting Enable and configure wl18xx bluetooth stack... Starting Simple Network Management Protocol (SNMP) Daemon.... Starting Lightning Fast Webserver With Light System Requirements... [ OK ] Started Redis In-Memory Data Store. [ OK ] Reached target Host and Network Name Lookups. [ OK ] Started NFS status monitor for NFSv2/3 locking.. [ OK ] Started Permit User Sessions. [ OK ] Started Lightning Fast Webserver With Light System Requirements. [ OK ] Started Avahi mDNS/DNS-SD Stack. [ 11.033682] pvrsrvkm: disagrees about version of symbol module_layout [ 11.313801] pvrsrvkm: disagrees about version of symbol module_layout [ 11.386935] net eth0: initializing cpsw version 1.15 (0) [ 11.619319] Micrel KSZ9031 Gigabit PHY 4a101000.mdio:00: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL) [ 11.708730] matrix_keymap: disagrees about version of symbol module_layout [ 11.861863] matrix_keymap: disagrees about version of symbol module_layout [ 11.898287] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 11.980103] ti_emif_sram: disagrees about version of symbol module_layout [ 12.058700] snd_soc_simple_card_utils: disagrees about version of symbol module_layout [ 12.123397] ti_emif_sram: disagrees about version of symbol module_layout [ OK ] Started Enable and configure wl18xx bluetooth stack. [ 12.348419] snd_soc_simple_card_utils: disagrees about version of symbol module_layout [ 13.926337] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 14.045035] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ OK ] Started Simple Network Management Protocol (SNMP) Daemon.. [ OK ] Started uim-sysfs.service. *************************************************************** *************************************************************** NOTICE: This file system contains the following GPLv3 packages: autoconf bash-dev bash bc binutils cifs-utils cpio cpp-symlinks cpp dosfstools elfutils findutils g++-symlinks g++ gawk gcc-symlinks gcc gdb gdbserver gettext glmark2 gstreamer1.0-libav gzip hidapi libbfd libdw1 libelf1 libgdbm-compat4 libgdbm-dev libgdbm6 libgettextlib libgettextsrc libgmp10 libidn2-0 libmavconn libmpc3 libmpfr6 libreadline-dev libreadline7 libunistring2 m4-dev m4 make mavlink mavros-extras mavros-msgs mavros nettle pdm-anomaly-detection socketcan-interface which If you do not wish to distribute GPLv3 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** [ OK ] Started Print notice about GPLv3 packages. [ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ OK ] Created slice system-systemd\x2dfsck.slice. Starting File System Check on /dev/mmcblk1p1... Starting Rotate log files... [ OK ] Created slice system-systemd\x2dbacklight.slice. Starting Load/Save Screen Backlight��…ightness of backlight:backlight... Starting rc.pvr.service... [ OK ] Stopped Redis In-Memory Data Store. [ OK ] Started Redis In-Memory Data Store. [ OK ] Started Serial Getty on ttyS0. [ 23.625988] pvrsrvkm: disagrees about version of symbol module_layout [ OK ] Started Getty on tty1. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... [ OK ] Started Load/Save Screen Backlight Brightness of backlight:backlight. [FAILED] Failed to start Synchronize System and HW clocks. See 'systemctl status sync-clocks.service' for details. [ OK ] Started File System Check on /dev/mmcblk1p1. [ OK ] Stopped Redis In-Memory Data Store. [ OK ] Started Redis In-Memory Data Store. Mounting /run/media/mmcblk1p1... [ OK ] Started Login Service. [ OK ] Mounted /run/media/mmcblk1p1. [ OK ] Stopped Redis In-Memory Data Store. [ OK ] Started Redis In-Memory Data Store. [ OK ] Started Rotate log files. [ OK ] Stopped Redis In-Memory Data Store. [ OK ] Started Redis In-Memory Data Store. [ OK ] Stopped Redis In-Memory Data Store. [ OK ] Started Redis In-Memory Data Store. [ OK ] Stopped Redis In-Memory Data Store. [FAILED] Failed to start Redis In-Memory Data Store. [ 25.827526] pvrsrvkm: disagrees about version of symbol module_layout See 'systemctl status redis.service' for details. [ OK ] Started rc.pvr.service. Starting weston.service... [ OK ] Started Wait for Network to be Configured. [ OK ] Reached target Network is Online. [ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf. [ 27.956908] xfrm_algo: disagrees about version of symbol module_layout [ 28.222710] xfrm_algo: disagrees about version of symbol module_layout _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org am437x-evm ttyS0 Arago 2019.07 am437x-evm ttyS0 am437x-evm login:
root@am437x-evm:~# lsmod
Module Size Used by
xfrm_user 32768 2
xfrm4_tunnel 16384 0
ipcomp 16384 0
xfrm_ipcomp 16384 1 ipcomp
esp4 20480 0
ah4 16384 0
af_key 36864 0
xfrm_algo 16384 5 xfrm_user,esp4,ah4,af_key,xfrm_ipcomp
xhci_plat_hcd 16384 0
xhci_hcd 147456 1 xhci_plat_hcd
pru_rproc 24576 0
irq_pruss_intc 16384 1 pru_rproc
pruss 16384 1 pru_rproc
dwc3 73728 0
udc_core 28672 1 dwc3
ti_am335x_adc 20480 0
snd_soc_simple_card 16384 0
snd_soc_simple_card_utils 16384 1 snd_soc_simple_card
pm33xx 16384 0
matrix_keypad 16384 0
matrix_keymap 16384 1 matrix_keypad
pruss_soc_bus 16384 0
omap_des 20480 0
omap_aes_driver 24576 0
des_generic 28672 1 omap_des
crypto_engine 16384 2 omap_des,omap_aes_driver
omap_sham 28672 0
omap_crypto 16384 2 omap_des,omap_aes_driver
ti_emif_sram 16384 1 pm33xx
dwc3_omap 16384 0
am437x_vpfe 36864 0
c_can_platform 16384 0
c_can 20480 1 c_can_platform
can_dev 28672 1 c_can
pixcir_i2c_ts 16384 0
snd_soc_tlv320aic3x 57344 1
ov2659 16384 2
v4l2_fwnode 20480 2 am437x_vpfe,ov2659
wkup_m3_ipc 16384 1 pm33xx
phy_omap_usb2 16384 3
rtc_omap 20480 2
wkup_m3_rproc 16384 1
omap_wdt 16384 0
ti_am335x_tscadc 16384 1 ti_am335x_adc
remoteproc 49152 3 pru_rproc,wkup_m3_rproc,wkup_m3_ipc
sch_fq_codel 20480 2
uio 20480 0
ftdi_sio 40960 0
usbserial 36864 1 ftdi_sio
usbcore 217088 4 ftdi_sio,usbserial,xhci_plat_hcd,xhci_hcd
usb_common 16384 3 udc_core,usbcore,dwc3
root@am437x-evm:~# journalctl | grep modules
Oct 19 16:13:45 am437x-evm systemd-modules-load[72]: Failed to insert 'cmemk': Exec format error
Oct 19 16:13:45 am437x-evm systemd-modules-load[72]: Failed to insert 'cryptodev': Exec format error
Oct 19 16:13:45 am437x-evm systemd-modules-load[72]: Failed to insert 'usbserial': Exec format error
Oct 19 16:13:45 am437x-evm systemd-modules-load[72]: Failed to insert 'ftdi_sio': Exec format error
Oct 19 16:13:45 am437x-evm systemd-modules-load[72]: Failed to insert 'uio_module_drv': Exec format error
Oct 19 16:13:45 am437x-evm systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
Oct 19 16:13:45 am437x-evm systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
root@am437x-evm:~# uname -r
4.19.59-g5f8c1c6121
root@am437x-evm:~# modinfo cmemk
filename: /lib/modules/4.19.59-g5f8c1c6121/extra/cmemk.ko
license: GPL
srcversion: CA4057FB85EBE5FF1AD93F2
depends:
vermagic: 4.19.59-g5f8c1c6121 preempt mod_unload modversions ARMv7 p2v8
root@am437x-evm:~# modinfo cryptodev
filename: /lib/modules/4.19.59-g5f8c1c6121/extra/cryptodev.ko
license: GPL
description: CryptoDev driver
author: Nikos Mavrogiannopoulos <nmav@gnutls.org>
srcversion: DE8256F6C394DF31333BE0A
depends:
parm: cryptodev_verbosity:0: normal, 1: verbose, 2: debug (int)
root@am437x-evm:~# modinfo usbserial
filename: /lib/modules/4.19.59-g5f8c1c6121/kernel/drivers/usb/serial/usbserial.ko
license: GPL v2
description: USB Serial Driver core
author: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
srcversion: 65F41F1C01D915715063557
depends: usbcore
intree: Y
root@am437x-evm:~# modinfo uio_module_drv
filename: /lib/modules/4.19.59-g5f8c1c6121/extra/uio_module_drv.ko
alias: platform:uio_module_drv
description: User-space driver for a generic module
license: GPL v2
author: Sam Nelson
srcversion: 5E972E7D9BDD9CCD670A6A2
alias: of:N*T*Cti,uio-module-drvC*
depends: uio
SDK Version is processor-sdk-linux-am437x-evm-06.01.00.08 and reference design is AM437x GP-EVM.
And I upgraded SDK version to 06.03.00.106 and rebuilt kernel & modules.
Below is build script file.
export PATH=$PATH:/home/kihan21/ti/ti-processor-sdk-linux-am437x-evm-06.03.00.106/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/
export ARCH=arm
export CROSS_COMPILE=arm-linux-gnueabihf-
export INSTALL_MOD_PATH=/home/kihan21/ti/ti-processor-sdk-linux-am437x-evm-06.03.00.106/targetNFS
make mrproper
make tisdk_am437x-evm_defconfig
make menuconfig
make am437x-evm_debug_defconfig
echo "=================================zImage===================================="
make zImage
cp arch/arm/boot/zImage ../../targetNFS/boot/
AM4378 Custom Board rebuild boot-log.txt
Apr 19 02:08:04 am437x-evm systemd-modules-load[79]: Failed to insert 'cmemk': Exec format error
Apr 19 02:08:04 am437x-evm systemd-modules-load[79]: Failed to insert 'cryptodev': Exec format error
Apr 19 02:08:04 am437x-evm systemd-modules-load[79]: Inserted module 'usbserial'
Apr 19 02:08:04 am437x-evm systemd-modules-load[79]: Inserted module 'ftdi_sio'
Apr 19 02:08:03 am437x-evm systemd-modules-load[79]: Failed to insert 'uio_module_drv': Exec format error
root@am437x-evm:~# uname -a
Linux am437x-evm 4.19.94+ #1 PREEMPT Fri Jul 24 22:21:32 KST 2020 armv7l GNU/Linux
root@am437x-evm:/lib/modules/4.19.94+/extra# modinfo uio_module_drv.ko
filename: /lib/modules/4.19.94+/extra/uio_module_drv.ko
license: GPL v2
author: Sam Nelson
depends: uio
vermagic: 4.19.94-gbe5389fd85 preempt mod_unload modversions ARMv7 p2v8
cmemk, cryptodev, uio_module_drv were not build and intalled.
Pls let me know how to build these modules.
Thanks, kiha.
