DRA72XEVM: While running the application getting 6 printk messages dropped virtio_rpmsg_bus virtio0: channel rpmsg-proto::51:ffffffff already exist
Prodigy 50 points
Part Number: DRA72XEVM
We are running the application on the custom board having TDA2xx SoC and Vision SDK 3.0.7
The usecase is as below:
Capture -> VPE -> Display_Video
For few minutes initially the display is coming properly. However, after some time the display is not visible and below log messages appear continuously.
[2020-07-28 03:38:02.901] pid=7484, Node Opened
 ** 6 printk messages dropped ** virtio_rpmsg_bus virtio0: channel rpmsg-proto::51:ffffffff already exist
[2020-07-28 03:38:48.184] ** 7 printk messages dropped ** virtio_rpmsg_bus virtio0: channel rpmsg-prïto::51:ffffffff already exist
[2020-07-28 03:38:48.202] ** 6 printk messages dropped ** virtio_rpmsg_bus virtio0: channel rpmsg-proto::51:ffffffff already exist
[2020-07-28 03:38:48.213] ** 2 printk messages dropped ** virtio_rpmsg_bus virtio0: channel rpmsg-proto::51:ffffffff already exist
[2020-07-28 03:38:48.213] ** 8 printk messages dropped ** virtio_rpmsg_bus virtio0: channel rpmsg-proto::51:ffffffff already exist
[2020-07-28 03:38:48.213] ** 8 printk messages dropped ** virtio_rpmsg_bus virtio0: channel rpmsg-proto::51:fffæffff already exist
[2020-07-28 03:38:48.228] ** 8 printk messages dropped ** virtio_rpmsg_bus virtio0: channel rpmsg/proto::51:ffffffff already exist
[2020-07-28 03:38:48.249] ** 8 printk messages dropped ** virtio_rpmsg_bus virtio0: channel rpmsg-proto::51:ffffffff already exist
[2020-07-28 03:38:48.249] ** 8 printk messages dropped ** virtio_rpmsg_bus virtio0: channel rpmsg-proto::51:ffæfffff already exist
[2020-07-28 03:38:48.264] ** 7 printk messages dropped ** virtio_rpmsg_bus virtio0: channel rpmsg-proto::51:ffffffff already exist
[2020-07-28 03:38:48.288] ** 8 printk messages dropped ** virtio_rpmsg_bus virtio0: channel rpmsg-proto::51:ffffffff already exist
[2020-07-28 03:38:48.304] ** 8 printk messages dropped ** virtio_rpmsg_bus virtio0: channel rpmsg-proto::51:ffffffff already exist
[2020-07-28 03:38:48.304] j* 7 printk messages dropped ** virtio_rpmsg_bus virtio0: channel rpmsg-proto::51:ffffffff already exist
[2020-07-28 03:38:48.319] ** 8 printk messages dropped ** virtio_rpmsg_bus virtio0: channel rpmsg-proto::51:ffffffff already exist
[2020-07-28 03:38:48.337] ** 8 printk meósages dropped ** virtio_rpmsg_bus virtio0: channel rpmsg-proto::51:ffffffff already exist
[2020-07-28 03:38:48.349] ** 8 printk messages dropped ** virtio_rpmsg_bus virtio0: channel rpmsg-proto::51:ffffffff already exist
[2020-07-28 03:38:48.349] ** 7 printk messages dropped ** virtio_rpmsg_bus virtio0: channel rpmsg-proto::51:ffffffff already exist
[2020-07-28 03:38:48.373] ** 8 printk messagew dropped ** virtio_rpmsg_bus virtio0: channel rpmsg-proto::51:ffffffff already exist
[2020-07-28 03:38:48.386] ** 8 printk messages dsopped ** virtio_rpmsg_bus virtio0: channel rpmsg-proto::51:ffffffff already exist
[2020-07-28 03:38:48.397] *. 8 printk messages dropped ** virtio_rpmsg_bus virtio0: channel rpmsg-proto::51:ffffffff already exist
[2020-07-28 03:38:48.397] ** 7 printk messages dropped ** virtio_rpmsg_bus virtio0: channel rpmsg-proto::51:ffffffff already exist
[2020-07-28 03:38:48.397] ** 8 printk messages dropped ** virtio_rpmsg_bus virtio0: channel rpmsg-proto::51:ffffffff already exist
[2020-07-28 06:15:24.498] ** 8 printk messages dropped ** systemd-journald[17509]: /dev/kmsg buffer overrun, some messages lost.
Could you pls help to resolve.
Raghavan
    Please share the complete log with statistics.
    The same issue observed in the EVM board?
    Gaviraju
  • In reply to Gaviraju Doddabettahalli Bettegowda:
    Hi Gaviraju,
    Thanks for the quick response.
    We have been testing entire solution on custom board since long time the evaluation board does not meet all our required features.
    However, based on your suggestion I will remove the integrated code and test the TI code and provide you logs.
    Meanwhile, if you could provide some information on the reason for this kind of log message because after this log statements the entire system is going to out of memory and system stops working. If you could provide reason for this behaviour of vision sdk, I will meanwhile keep debugging....
    Raghavan
