Hi Expert,
we are trying NFS boot on TDA4 EVM with latest PSDKLA7.0. but the nfs filesystem can not be mounted.
below is the console log. I also attached this file.
Could you please give us suggestions?
U-Boot SPL 2020.01-gf9b0d030d3 (Jun 17 2020 - 15:08:08 +0000)
SYSFW ABI: 3.0 (firmware rev 0x0014 '20.04.1-v2020.04a (Terrific Lla')
Trying to boot from MMC2
Loading Environment from MMC... *** Warning - No MMC card found, using default environment
** File not found /lib/firmware/j7-main-r5f0_0-fw **
** File not found /lib/firmware/j7-mcu-r5f0_0-fw **
Starting ATF on ARM64 core...
NOTICE: BL31: v2.3():07.00.00.005-dirty
NOTICE: BL31: Built : 14:33:55, Jun 17 2020
U-Boot SPL 2020.01-gf9b0d030d3 (Jun 17 2020 - 14:34:25 +0000)
Detected: J7X-BASE-CPB rev E3
Detected: J7X-GESI-EXP rev E3
Detected: J7X-VSC8514-ETH rev E2
U-Boot 2020.01-gf9b0d030d3 (Jun 17 2020 - 14:34:25 +0000)
SoC: J721E SR1.0
Model: Texas Instruments K3 J721E SoC
Board: J721EX-PM2-SOM rev E7
DRAM: 4 GiB
not found for dev hbmc-mux
Flash: 0 Bytes
MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1
Loading Environment from MMC... OK
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Net: eth0: ethernet@046000000
Hit any key to stop autoboot: 0
=> setenv serverip 192.168.0.101
=> setenv ipaddr 192.168.0.102
=> setenv bootargs 'console=ttyS2,115200n8 root=/dev/nfs rw nfsroot=192.168.0.101:/home/felix/ti/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/targetNFS nolock ip=192.168.0.102:192.168.0.101:192.168.0
.101 nfsrootdebug'
=> setenv bootcmd 'tftp 0x80000000 Image-j7-evm.bin;tftp 0x890000000 k3-j721e-common-proc-board.dtb;booti 0x80000000 - 0x890000000'
=> boot
link up on port 1, speed 1000, full duplex
Using ethernet@046000000 device
TFTP from server 192.168.0.101; our IP address is 192.168.0.102
Filename 'Image-j7-evm.bin'.
Load address: 0x80000000
Loading: #################################################################
6.4 MiB/s
done
Bytes transferred = 16654344 (fe2008 hex)
Filename 'k3-j721e-common-proc-board.dtb'.
Load address: 0x890000000
3.4 MiB/s
done
Bytes transferred = 89857 (15f01 hex)
## Flattened Device Tree blob at 890000000
Booting using the fdt blob at 0x890000000
Loading Device Tree to 00000000fdea1000, end 00000000fdeb9f00 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 5.4.40-g66cf445b76 (oe-user@oe-host) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 SMP PREEMPT Wed Jun 17 14:28:47 UTC
2020
[ 0.000000] Machine model: Texas Instruments K3 J721E SoC
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@fb000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@fb100000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 512 MiB at 0x00000000c0000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 2 pages/cpu s48408 r8192 d74472 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] Built 1 zonelists, mobility grouping off. Total pages: 47825
[ 0.000000] Kernel command line: console=ttyS2,115200n8 root=/dev/nfs rw nfsroot=192.168.0.101:/home/felix/ti/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/targetNFS nolock ip=192.168.0.102:192.168
.0.101:192.168.0.101 nfsrootdebug vers=4
[ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0xbbff0000-0xbfff0000] (64MB)
[ 0.000000] Memory: 3354112K/3063808K available (9534K kernel code, 776K rwdata, 3840K rodata, 1728K init, 695K bss, 18446744073708737024K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008c00c0000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c00d0000
[ 0.000000] random: get_random_bytes called from start_kernel+0x2b8/0x438 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.000161] Console: colour dummy device 80x25
[ 0.000180] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.000185] pid_max: default: 32768 minimum: 301
[ 0.000221] LSM: Security Framework initializing
[ 0.000250] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[ 0.000262] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[ 0.023982] ASID allocator initialised with 32768 entries
[ 0.031979] rcu: Hierarchical SRCU implementation.
[ 0.040025] Platform MSI: gic-its@1820000 domain created
[ 0.040119] PCI/MSI: /interconnect@100000/interrupt-controller@1800000/gic-its@1820000 domain created
[ 0.047994] smp: Bringing up secondary CPUs ...
[ 0.080319] Detected PIPT I-cache on CPU1
[ 0.080336] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.080346] GICv3: CPU1: using allocated LPI pending table @0x00000008c00e0000
[ 0.080366] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.080403] smp: Brought up 1 node, 2 CPUs
[ 0.080408] SMP: Total of 2 processors activated.
[ 0.080412] CPU features: detected: 32-bit EL0 Support
[ 0.080415] CPU features: detected: CRC32 instructions
[ 0.086358] CPU: All CPU(s) started at EL2
[ 0.086372] alternatives: patching kernel code
[ 0.086770] devtmpfs: initialized
[ 0.090830] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.090837] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[ 0.091233] pinctrl core: initialized pinctrl subsystem
[ 0.091574] NET: Registered protocol family 16
[ 0.093954] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.094221] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.103018] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[ 0.103023] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[ 0.103026] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.104743] cryptd: max_cpu_qlen set to 1000
[ 0.107369] vsys_3v3: supplied by evm_12v0
[ 0.107457] vsys_5v0: supplied by evm_12v0
[ 0.107818] iommu: Default domain type: Translated
[ 0.107940] SCSI subsystem initialized
[ 0.108190] mc: Linux media interface: v0.10
[ 0.108200] videodev: Linux video capture interface: v2.00
[ 0.108210] pps_core: LinuxPPS API ver. 1 registered
[ 0.108212] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.108218] PTP clock support registered
[ 0.108226] EDAC MC: Ver: 3.0.0
[ 0.108694] FPGA manager framework
[ 0.108721] Advanced Linux Sound Architecture Driver Initialized.
[ 0.109023] clocksource: Switched to clocksource arch_sys_counter
[ 0.109076] VFS: Disk quotas dquot_6.6.0
[ 0.109118] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[ 0.111081] thermal_sys: Registered thermal governor 'step_wise'
[ 0.111083] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.111244] NET: Registered protocol family 2
[ 0.111443] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[ 0.111489] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[ 0.111592] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[ 0.111809] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.111861] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[ 0.111903] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[ 0.111991] NET: Registered protocol family 1
[ 0.112240] RPC: Registered named UNIX socket transport module.
[ 0.112244] RPC: Registered udp transport module.
[ 0.112246] RPC: Registered tcp transport module.
[ 0.112248] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.112253] PCI: CLS 0 bytes, default 64
[ 0.112502] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.115990] Initialise system trusted keyrings
[ 0.116051] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[ 0.118039] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.118247] NFS: Registering the id_resolver key type
[ 0.118255] Key type id_resolver registered
[ 0.118258] Key type id_legacy registered
[ 0.118263] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.118339] 9p: Installing v9fs 9p2000 file system support
[ 0.125312] Key type asymmetric registered
[ 0.125315] Asymmetric key parser 'x509' registered
[ 0.125333] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.125336] io scheduler mq-deadline registered
[ 0.125339] io scheduler kyber registered
[ 0.126364] pinctrl-single 4301c000.pinmux: 94 pins, size 376
[ 0.126554] pinctrl-single 11c000.pinmux: 173 pins, size 692
[ 0.126897] pinctrl-single a40000.timesync_router: 512 pins, size 2048
[ 0.129036] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.129067] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.129166] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.129173] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[ 0.129292] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.129300] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[ 0.129387] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.129394] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[ 0.129489] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[ 0.129497] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[ 0.129637] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[ 0.129645] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[ 0.131094] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.136209] brd: module loaded
[ 0.138947] loop: module loaded
[ 0.140251] libphy: Fixed MDIO Bus: probed
[ 0.140429] tun: Universal TUN/TAP device driver, 1.6
[ 0.140668] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 0.140671] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.140688] sky2: driver version 1.30
[ 0.141175] VFIO - User Level meta-driver version: 0.3
[ 0.141489] i2c /dev entries driver
[ 0.141981] sdhci: Secure Digital Host Controller Interface driver
[ 0.141983] sdhci: Copyright(c) Pierre Ossman
[ 0.142172] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.142631] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.143206] optee: probing for conduit method from DT.
[ 0.143218] optee: revision 3.8 (199fca17)
[ 0.143487] optee: initialized driver
[ 0.144163] NET: Registered protocol family 17
[ 0.144222] 9pnet: Installing 9P2000 support
[ 0.144241] Key type dns_resolver registered
[ 0.144388] registered taskstats version 1
[ 0.144390] Loading compiled-in X.509 certificates
[ 0.148213] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.148301] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.149717] ti-sci 44083000.dmsc: ABI: 3.0 (firmware rev 0x0014 '20.04.1-v2020.04a (Terrific Lla')
[ 0.165323] random: fast init done
[ 0.192755] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 0.194126] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[ 0.194385] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.194654] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[ 0.194962] pca953x 3-0020: 3-0020 supply vcc not found, using dummy regulator
[ 0.217535] pca953x 3-0022: 3-0022 supply vcc not found, using dummy regulator
[ 0.218213] GPIO line 481 (MCASP/TRACE_MUX_S0) hogged as output/low
[ 0.218404] GPIO line 482 (MCASP/TRACE_MUX_S1) hogged as output/high
[ 0.218742] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 0.219136] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[ 0.219411] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz
[ 0.219741] pca953x 6-0020: 6-0020 supply vcc not found, using dummy regulator
[ 0.241379] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[ 0.241648] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[ 0.241903] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[ 0.242209] pca953x 9-0020: 9-0020 supply vcc not found, using dummy regulator
[ 0.265324] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
[ 0.265929] ti-sci-intr interconnect@100000:interconnect@28380000:interrupt-controller2: Interrupt Router 137 domain created
[ 0.266027] ti-sci-intr interconnect@100000:interrupt-controller0: Interrupt Router 131 domain created
[ 0.266120] ti-sci-intr interconnect@100000:navss@30000000:interrupt-controller1: Interrupt Router 213 domain created
[ 0.266281] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 0.274106] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
[ 1.275267] j721e-pcie 2900000.pcie: host bridge /interconnect@100000/pcie@2900000 ranges:
[ 1.275291] j721e-pcie 2900000.pcie: IO 0x10001000..0x10010fff -> 0x10001000
[ 1.275302] j721e-pcie 2900000.pcie: MEM 0x10011000..0x17ffffff -> 0x10011000
[ 1.275407] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
[ 1.275412] pci_bus 0000:00: root bus resource [bus 00-0f]
[ 1.275416] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[ 1.275419] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
[ 1.275435] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[ 1.275454] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 1.275458] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 1.275479] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
[ 1.275484] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[ 1.275496] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
[ 1.275502] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
[ 1.275546] pci 0000:00:00.0: supports D1
[ 1.275549] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 1.275554] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
[ 1.275565] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x208 may corrupt adjacent RW1C bits
[ 1.275574] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
[ 1.275578] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
[ 1.275592] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x210 may corrupt adjacent RW1C bits
[ 1.275597] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x210 may corrupt adjacent RW1C bits
[ 1.277179] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.278637] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01
[ 1.278651] pci 0000:00:00.0: BAR 7: assigned [mem 0x10400000-0x113fffff 64bit]
[ 1.278656] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.278816] pcieport 0000:00:00.0: PME: Signaling with IRQ 40
[ 1.278969] pcieport 0000:00:00.0: AER: enabled with IRQ 40
[ 2.281372] j721e-pcie 2910000.pcie: host bridge /interconnect@100000/pcie@2910000 ranges:
[ 2.281389] j721e-pcie 2910000.pcie: IO 0x18001000..0x18010fff -> 0x18001000
[ 2.281398] j721e-pcie 2910000.pcie: MEM 0x18011000..0x1fffffff -> 0x18011000
[ 2.281461] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
[ 2.281465] pci_bus 0001:00: root bus resource [bus 00-0f]
[ 2.281469] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[ 2.281472] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
[ 2.281485] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
[ 2.281550] pci 0001:00:00.0: supports D1
[ 2.281553] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
[ 2.283071] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.284519] pci_bus 0001:01: busn_res: [bus 01-0f] end is updated to 01
[ 2.284528] pci 0001:00:00.0: PCI bridge to [bus 01]
[ 2.284669] pcieport 0001:00:00.0: PME: Signaling with IRQ 43
[ 2.284771] pcieport 0001:00:00.0: AER: enabled with IRQ 43
[ 3.286927] j721e-pcie 2920000.pcie: host bridge /interconnect@100000/pcie@2920000 ranges:
[ 3.286943] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x00001000
[ 3.286952] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x00011000
[ 3.287014] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
[ 3.287018] pci_bus 0002:00: root bus resource [bus 00-0f]
[ 3.287022] pci_bus 0002:00: root bus resource [io 0x20000-0x2ffff] (bus address [0x1000-0x10fff])
[ 3.287026] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
[ 3.287039] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
[ 3.287103] pci 0002:00:00.0: supports D1
[ 3.287106] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
[ 3.288599] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.290061] pci_bus 0002:01: busn_res: [bus 01-0f] end is updated to 01
[ 3.290069] pci 0002:00:00.0: PCI bridge to [bus 01]
[ 3.290203] pcieport 0002:00:00.0: PME: Signaling with IRQ 46
[ 3.290314] pcieport 0002:00:00.0: AER: enabled with IRQ 46
[ 3.290938] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[ 3.290942] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 3.290945] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 3.292281] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[ 3.292286] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 3.292289] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 3.292477] omap8250 40a00000.serial: PM domain pd:149 will not be powered off
[ 3.292602] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 7, base_baud = 6000000) is a 8250
[ 3.292944] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 19, base_baud = 3000000) is a 8250
[ 5.196973] printk: console [ttyS2] enabled
[ 5.201472] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 20, base_baud = 3000000) is a 8250
[ 5.210296] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 21, base_baud = 3000000) is a 8250
[ 5.219034] arm-smmu-v3 36600000.smmu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 5.228122] arm-smmu-v3 36600000.smmu: allocated 524288 entries for cmdq
[ 5.236667] arm-smmu-v3 36600000.smmu: allocated 524288 entries for evtq
[ 5.244040] arm-smmu-v3 36600000.smmu: msi_domain absent - falling back to wired irqs
[ 5.253616] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 5.264126] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[ 5.274279] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[ 5.284517] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[ 5.295283] scsi host0: ufshcd
[ 5.302014] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[ 5.317267] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
[ 5.341226] cadence-qspi 47040000.spi: Cadence QSPI NOR probe failed -517
[ 5.348753] cadence-qspi 47050000.spi: mt25qu512a (65536 Kbytes)
[ 5.359918] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
[ 5.371583] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
[ 5.382813] scsi 0:0:0:49488: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[ 5.391535] scsi 0:0:0:49476: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[ 5.400198] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
[ 5.413237] cadence-qspi 47050000.spi: Cadence QSPI NOR probe failed -517
[ 5.457026] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 5.464669] libphy: 46000f00.mdio: probed
[ 5.469675] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 5.477938] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[ 5.489372] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
[ 5.497906] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 5.506413] mmc0: CQHCI version 5.10
[ 5.544758] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
[ 5.553357] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 5.559946] davinci_gpio 42110000.gpio: IRQ index 4 not found
[ 5.565693] davinci_gpio 42110000.gpio: IRQ not populated, err = -6
[ 5.575488] vdd_mmc1: supplied by vsys_3v3
[ 5.580063] pca953x 4-0020: 4-0020 supply vcc not found, using dummy regulator
[ 5.609563] GPIO line 284 (DP0_PWR_SW_EN) hogged as output/high
[ 5.616079] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 5.622913] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 5.629765] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[ 5.636597] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[ 5.643399] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[ 5.652948] ti-udma 285c0000.dma-controller: Channels: 24 (tchan: 12, rchan: 12, gp-rflow: 8)
[ 5.663301] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[ 5.675762] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[ 5.684199] cadence-qspi 47050000.spi: mt25qu512a (65536 Kbytes)
[ 5.699220] mmc0: Command Queue Engine enabled
[ 5.703660] mmc0: new HS400 MMC card at address 0001
[ 5.712860] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[ 5.717512] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[ 5.723534] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[ 5.729451] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 5.737120] libphy: 46000f00.mdio: probed
[ 5.741141] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (240:0)
[ 5.749343] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 5.757621] mmcblk0: p1 p2
[ 5.760700] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[ 5.773304] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 5.780394] pps pps0: new PPS source ptp1
[ 5.784524] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1
[ 5.793469] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 57.4
[ 5.800763] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 5.807652] mmc1: CQHCI version 5.10
[ 5.842032] mmc1: SDHCI controller on 4fb0000.sdhci [4fb0000.sdhci] using ADMA 64-bit
[ 5.850156] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 5.862037] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 5.869393] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 5.876714] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 5.884027] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[ 5.891935] hctosys: unable to open rtc device (rtc0)
[ 5.904716] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
[ 5.917129] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
[ 7.273877] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
[ 7.280702] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
[ 7.290805] mmcblk1: p1 p2
[ 10.017862] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 10.049026] IP-Config: Guessing netmask 255.255.255.0
[ 10.054065] IP-Config: Complete:
[ 10.057284] device=eth0, hwaddr=50:51:a9:fc:8d:d2, ipaddr=192.168.0.102, mask=255.255.255.0, gw=192.168.0.101
[ 10.067608] host=192.168.0.102, domain=, nis-domain=(none)
[ 10.073512] bootserver=192.168.0.101, rootserver=192.168.0.101, rootpath=
[ 10.095766] ALSA device list:
[ 10.098728] No soundcards found.
[ 109.539505] VFS: Unable to mount root fs via NFS, trying floppy.
[ 109.545667] VFS: Cannot open root device "nfs" or unknown-block(2,0): error -6
[ 109.552875] Please append a correct "root=" boot option; here are the available partitions:
[ 109.561216] 0100 4096 ram0
[ 109.561217] (driver?)
[ 109.567302] 0101 4096 ram1
[ 109.567303] (driver?)
[ 109.573389] 0102 4096 ram2
[ 109.573389] (driver?)
[ 109.579472] 0103 4096 ram3
[ 109.579473] (driver?)
[ 109.585558] 0104 4096 ram4
[ 109.585559] (driver?)
[ 109.591641] 0105 4096 ram5
[ 109.591642] (driver?)
[ 109.597727] 0106 4096 ram6
[ 109.597728] (driver?)
[ 109.603811] 0107 4096 ram7
[ 109.603811] (driver?)
[ 109.609898] 0108 4096 ram8
[ 109.609899] (driver?)
[ 109.615981] 0109 4096 ram9
[ 109.615982] (driver?)
[ 109.622067] 010a 4096 ram10
[ 109.622067] (driver?)
[ 109.628236] 010b 4096 ram11
[ 109.628237] (driver?)
[ 109.634409] 010c 4096 ram12
[ 109.634409] (driver?)
[ 109.640579] 010d 4096 ram13
[ 109.640579] (driver?)
[ 109.646751] 010e 4096 ram14
[ 109.646751] (driver?)
[ 109.652920] 010f 4096 ram15
[ 109.652921] (driver?)
[ 109.659097] 1f00 65536 mtdblock0
[ 109.659097] (driver?)
[ 109.665616] 1f01 65536 mtdblock1
[ 109.665617] (driver?)
[ 109.672134] b300 15540224 mmcblk0
[ 109.672135] driver: mmcblk
[ 109.678917] b301 63488 mmcblk0p1 9215d7c1-01
[ 109.678918]
[ 109.685698] b302 15475712 mmcblk0p2 9215d7c1-02
[ 109.685698]
[ 109.692476] b360 15558144 mmcblk1
[ 109.692476] driver: mmcblk
[ 109.699254] b361 131072 mmcblk1p1 1774cca5-01
[ 109.699255]
[ 109.706034] b362 15426048 mmcblk1p2 1774cca5-02
[ 109.706035]
[ 109.712813] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
[ 109.721054] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.40-g66cf445b76 #1
[ 109.727995] Hardware name: Texas Instruments K3 J721E SoC (DT)
[ 109.733808] Call trace:
[ 109.736245] dump_backtrace+0x0/0x140
[ 109.739892] show_stack+0x14/0x20
[ 109.743195] dump_stack+0xb4/0xf8
[ 109.746496] panic+0x158/0x324
[ 109.749538] mount_block_root+0x1d8/0x28c
[ 109.753532] mount_root+0x124/0x158
[ 109.757005] prepare_namespace+0x15c/0x1c0
[ 109.761086] kernel_init_freeable+0x210/0x22c
[ 109.765427] kernel_init+0x10/0xfc
[ 109.768814] ret_from_fork+0x10/0x18
[ 109.772376] SMP: stopping secondary CPUs
[ 109.776285] Kernel Offset: disabled
[ 109.779758] CPU features: 0x0002,20006008
[ 109.783751] Memory Limit: none
[ 109.786794] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0) ]---
U-Boot SPL 2020.01-gf9b0d030d3 (Jun 17 2020 - 15:08:08 +0000) SYSFW ABI: 3.0 (firmware rev 0x0014 '20.04.1-v2020.04a (Terrific Lla') Trying to boot from MMC2 Loading Environment from MMC... *** Warning - No MMC card found, using default environment ** File not found /lib/firmware/j7-main-r5f0_0-fw ** ** File not found /lib/firmware/j7-mcu-r5f0_0-fw ** Starting ATF on ARM64 core... NOTICE: BL31: v2.3():07.00.00.005-dirty NOTICE: BL31: Built : 14:33:55, Jun 17 2020 U-Boot SPL 2020.01-gf9b0d030d3 (Jun 17 2020 - 14:34:25 +0000) SYSFW ABI: 3.0 (firmware rev 0x0014 '20.04.1-v2020.04a (Terrific Lla') Detected: J7X-BASE-CPB rev E3 Detected: J7X-GESI-EXP rev E3 Detected: J7X-VSC8514-ETH rev E2 Trying to boot from MMC2 U-Boot 2020.01-gf9b0d030d3 (Jun 17 2020 - 14:34:25 +0000) SoC: J721E SR1.0 Model: Texas Instruments K3 J721E SoC Board: J721EX-PM2-SOM rev E7 DRAM: 4 GiB not found for dev hbmc-mux Flash: 0 Bytes MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1 Loading Environment from MMC... OK In: serial@2800000 Out: serial@2800000 Err: serial@2800000 Detected: J7X-BASE-CPB rev E3 Detected: J7X-GESI-EXP rev E3 Detected: J7X-VSC8514-ETH rev E2 Net: eth0: ethernet@046000000 Hit any key to stop autoboot: 0 => => setenv serverip 192.168.0.101 => setenv ipaddr 192.168.0.102 => setenv bootargs 'console=ttyS2,115200n8 root=/dev/nfs rw nfsroot=192.168.0.101:/home/felix/ti/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/targetNFS nolock ip=192.168.0.102:192.168.0.101:192.168.0 .101 nfsrootdebug' => setenv bootcmd 'tftp 0x80000000 Image-j7-evm.bin;tftp 0x890000000 k3-j721e-common-proc-board.dtb;booti 0x80000000 - 0x890000000' => boot link up on port 1, speed 1000, full duplex Using ethernet@046000000 device TFTP from server 192.168.0.101; our IP address is 192.168.0.102 Filename 'Image-j7-evm.bin'. Load address: 0x80000000 Loading: ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ### 6.4 MiB/s done Bytes transferred = 16654344 (fe2008 hex) link up on port 1, speed 1000, full duplex Using ethernet@046000000 device TFTP from server 192.168.0.101; our IP address is 192.168.0.102 Filename 'k3-j721e-common-proc-board.dtb'. Load address: 0x890000000 Loading: ################## 3.4 MiB/s done Bytes transferred = 89857 (15f01 hex) ## Flattened Device Tree blob at 890000000 Booting using the fdt blob at 0x890000000 Loading Device Tree to 00000000fdea1000, end 00000000fdeb9f00 ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 5.4.40-g66cf445b76 (oe-user@oe-host) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 SMP PREEMPT Wed Jun 17 14:28:47 UTC 2020 [ 0.000000] Machine model: Texas Instruments K3 J721E SoC [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@fb000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@fb100000, compatible id shared-dma-pool [ 0.000000] cma: Reserved 512 MiB at 0x00000000c0000000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.0 [ 0.000000] percpu: Embedded 2 pages/cpu s48408 r8192 d74472 u131072 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: EL2 vector hardening [ 0.000000] Built 1 zonelists, mobility grouping off. Total pages: 47825 [ 0.000000] Kernel command line: console=ttyS2,115200n8 root=/dev/nfs rw nfsroot=192.168.0.101:/home/felix/ti/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/targetNFS nolock ip=192.168.0.102:192.168 .0.101:192.168.0.101 nfsrootdebug vers=4 [ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0xbbff0000-0xbfff0000] (64MB) [ 0.000000] Memory: 3354112K/3063808K available (9534K kernel code, 776K rwdata, 3840K rodata, 1728K init, 695K bss, 18446744073708737024K reserved, 524288K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: no VLPI support, no direct LPI support [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000008c00c0000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c00d0000 [ 0.000000] random: get_random_bytes called from start_kernel+0x2b8/0x438 with crng_init=0 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.000161] Console: colour dummy device 80x25 [ 0.000180] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.000185] pid_max: default: 32768 minimum: 301 [ 0.000221] LSM: Security Framework initializing [ 0.000250] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear) [ 0.000262] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear) [ 0.023982] ASID allocator initialised with 32768 entries [ 0.031979] rcu: Hierarchical SRCU implementation. [ 0.040025] Platform MSI: gic-its@1820000 domain created [ 0.040119] PCI/MSI: /interconnect@100000/interrupt-controller@1800000/gic-its@1820000 domain created [ 0.047994] smp: Bringing up secondary CPUs ... [ 0.080319] Detected PIPT I-cache on CPU1 [ 0.080336] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.080346] GICv3: CPU1: using allocated LPI pending table @0x00000008c00e0000 [ 0.080366] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.080403] smp: Brought up 1 node, 2 CPUs [ 0.080408] SMP: Total of 2 processors activated. [ 0.080412] CPU features: detected: 32-bit EL0 Support [ 0.080415] CPU features: detected: CRC32 instructions [ 0.086358] CPU: All CPU(s) started at EL2 [ 0.086372] alternatives: patching kernel code [ 0.086770] devtmpfs: initialized [ 0.090830] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.090837] futex hash table entries: 512 (order: -1, 32768 bytes, linear) [ 0.091233] pinctrl core: initialized pinctrl subsystem [ 0.091574] NET: Registered protocol family 16 [ 0.093954] DMA: preallocated 256 KiB pool for atomic allocations [ 0.094221] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.103018] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages [ 0.103023] HugeTLB registered 512 MiB page size, pre-allocated 0 pages [ 0.103026] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.104743] cryptd: max_cpu_qlen set to 1000 [ 0.107369] vsys_3v3: supplied by evm_12v0 [ 0.107457] vsys_5v0: supplied by evm_12v0 [ 0.107818] iommu: Default domain type: Translated [ 0.107940] SCSI subsystem initialized [ 0.108190] mc: Linux media interface: v0.10 [ 0.108200] videodev: Linux video capture interface: v2.00 [ 0.108210] pps_core: LinuxPPS API ver. 1 registered [ 0.108212] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.108218] PTP clock support registered [ 0.108226] EDAC MC: Ver: 3.0.0 [ 0.108694] FPGA manager framework [ 0.108721] Advanced Linux Sound Architecture Driver Initialized. [ 0.109023] clocksource: Switched to clocksource arch_sys_counter [ 0.109076] VFS: Disk quotas dquot_6.6.0 [ 0.109118] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes) [ 0.111081] thermal_sys: Registered thermal governor 'step_wise' [ 0.111083] thermal_sys: Registered thermal governor 'power_allocator' [ 0.111244] NET: Registered protocol family 2 [ 0.111443] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear) [ 0.111489] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear) [ 0.111592] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear) [ 0.111809] TCP: Hash tables configured (established 32768 bind 32768) [ 0.111861] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear) [ 0.111903] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear) [ 0.111991] NET: Registered protocol family 1 [ 0.112240] RPC: Registered named UNIX socket transport module. [ 0.112244] RPC: Registered udp transport module. [ 0.112246] RPC: Registered tcp transport module. [ 0.112248] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.112253] PCI: CLS 0 bytes, default 64 [ 0.112502] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 0.115990] Initialise system trusted keyrings [ 0.116051] workingset: timestamp_bits=46 max_order=16 bucket_order=0 [ 0.118039] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.118247] NFS: Registering the id_resolver key type [ 0.118255] Key type id_resolver registered [ 0.118258] Key type id_legacy registered [ 0.118263] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.118339] 9p: Installing v9fs 9p2000 file system support [ 0.125312] Key type asymmetric registered [ 0.125315] Asymmetric key parser 'x509' registered [ 0.125333] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 0.125336] io scheduler mq-deadline registered [ 0.125339] io scheduler kyber registered [ 0.126364] pinctrl-single 4301c000.pinmux: 94 pins, size 376 [ 0.126554] pinctrl-single 11c000.pinmux: 173 pins, size 692 [ 0.126897] pinctrl-single a40000.timesync_router: 512 pins, size 2048 [ 0.129036] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.129067] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.129166] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.129173] debugfs: Directory '31010000.pat' with parent 'regmap' already present! [ 0.129292] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.129300] debugfs: Directory '31011000.pat' with parent 'regmap' already present! [ 0.129387] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.129394] debugfs: Directory '31012000.pat' with parent 'regmap' already present! [ 0.129489] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages [ 0.129497] debugfs: Directory '31013000.pat' with parent 'regmap' already present! [ 0.129637] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages [ 0.129645] debugfs: Directory '31014000.pat' with parent 'regmap' already present! [ 0.131094] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.136209] brd: module loaded [ 0.138947] loop: module loaded [ 0.140251] libphy: Fixed MDIO Bus: probed [ 0.140429] tun: Universal TUN/TAP device driver, 1.6 [ 0.140668] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k [ 0.140671] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.140688] sky2: driver version 1.30 [ 0.141175] VFIO - User Level meta-driver version: 0.3 [ 0.141489] i2c /dev entries driver [ 0.141981] sdhci: Secure Digital Host Controller Interface driver [ 0.141983] sdhci: Copyright(c) Pierre Ossman [ 0.142172] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.142631] ledtrig-cpu: registered to indicate activity on CPUs [ 0.143206] optee: probing for conduit method from DT. [ 0.143218] optee: revision 3.8 (199fca17) [ 0.143487] optee: initialized driver [ 0.144163] NET: Registered protocol family 17 [ 0.144222] 9pnet: Installing 9P2000 support [ 0.144241] Key type dns_resolver registered [ 0.144388] registered taskstats version 1 [ 0.144390] Loading compiled-in X.509 certificates [ 0.148213] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.148301] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.149717] ti-sci 44083000.dmsc: ABI: 3.0 (firmware rev 0x0014 '20.04.1-v2020.04a (Terrific Lla') [ 0.165323] random: fast init done [ 0.192755] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 0.194126] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz [ 0.194385] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz [ 0.194654] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz [ 0.194962] pca953x 3-0020: 3-0020 supply vcc not found, using dummy regulator [ 0.217535] pca953x 3-0022: 3-0022 supply vcc not found, using dummy regulator [ 0.218213] GPIO line 481 (MCASP/TRACE_MUX_S0) hogged as output/low [ 0.218404] GPIO line 482 (MCASP/TRACE_MUX_S1) hogged as output/high [ 0.218742] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz [ 0.219136] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz [ 0.219411] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz [ 0.219741] pca953x 6-0020: 6-0020 supply vcc not found, using dummy regulator [ 0.241379] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz [ 0.241648] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz [ 0.241903] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz [ 0.242209] pca953x 9-0020: 9-0020 supply vcc not found, using dummy regulator [ 0.265324] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz [ 0.265929] ti-sci-intr interconnect@100000:interconnect@28380000:interrupt-controller2: Interrupt Router 137 domain created [ 0.266027] ti-sci-intr interconnect@100000:interrupt-controller0: Interrupt Router 131 domain created [ 0.266120] ti-sci-intr interconnect@100000:navss@30000000:interrupt-controller1: Interrupt Router 213 domain created [ 0.266281] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created [ 0.274106] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps [ 1.275267] j721e-pcie 2900000.pcie: host bridge /interconnect@100000/pcie@2900000 ranges: [ 1.275291] j721e-pcie 2900000.pcie: IO 0x10001000..0x10010fff -> 0x10001000 [ 1.275302] j721e-pcie 2900000.pcie: MEM 0x10011000..0x17ffffff -> 0x10011000 [ 1.275407] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00 [ 1.275412] pci_bus 0000:00: root bus resource [bus 00-0f] [ 1.275416] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff]) [ 1.275419] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff] [ 1.275435] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400 [ 1.275454] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 1.275458] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 1.275479] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits [ 1.275484] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits [ 1.275496] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits [ 1.275502] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits [ 1.275546] pci 0000:00:00.0: supports D1 [ 1.275549] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 1.275554] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits [ 1.275565] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x208 may corrupt adjacent RW1C bits [ 1.275574] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit] [ 1.275578] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs) [ 1.275592] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x210 may corrupt adjacent RW1C bits [ 1.275597] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x210 may corrupt adjacent RW1C bits [ 1.277179] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 1.278637] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01 [ 1.278651] pci 0000:00:00.0: BAR 7: assigned [mem 0x10400000-0x113fffff 64bit] [ 1.278656] pci 0000:00:00.0: PCI bridge to [bus 01] [ 1.278816] pcieport 0000:00:00.0: PME: Signaling with IRQ 40 [ 1.278969] pcieport 0000:00:00.0: AER: enabled with IRQ 40 [ 2.281372] j721e-pcie 2910000.pcie: host bridge /interconnect@100000/pcie@2910000 ranges: [ 2.281389] j721e-pcie 2910000.pcie: IO 0x18001000..0x18010fff -> 0x18001000 [ 2.281398] j721e-pcie 2910000.pcie: MEM 0x18011000..0x1fffffff -> 0x18011000 [ 2.281461] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00 [ 2.281465] pci_bus 0001:00: root bus resource [bus 00-0f] [ 2.281469] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x18001000-0x18010fff]) [ 2.281472] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff] [ 2.281485] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400 [ 2.281550] pci 0001:00:00.0: supports D1 [ 2.281553] pci 0001:00:00.0: PME# supported from D0 D1 D3hot [ 2.283071] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.284519] pci_bus 0001:01: busn_res: [bus 01-0f] end is updated to 01 [ 2.284528] pci 0001:00:00.0: PCI bridge to [bus 01] [ 2.284669] pcieport 0001:00:00.0: PME: Signaling with IRQ 43 [ 2.284771] pcieport 0001:00:00.0: AER: enabled with IRQ 43 [ 3.286927] j721e-pcie 2920000.pcie: host bridge /interconnect@100000/pcie@2920000 ranges: [ 3.286943] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x00001000 [ 3.286952] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x00011000 [ 3.287014] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00 [ 3.287018] pci_bus 0002:00: root bus resource [bus 00-0f] [ 3.287022] pci_bus 0002:00: root bus resource [io 0x20000-0x2ffff] (bus address [0x1000-0x10fff]) [ 3.287026] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff]) [ 3.287039] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400 [ 3.287103] pci 0002:00:00.0: supports D1 [ 3.287106] pci 0002:00:00.0: PME# supported from D0 D1 D3hot [ 3.288599] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 3.290061] pci_bus 0002:01: busn_res: [bus 01-0f] end is updated to 01 [ 3.290069] pci 0002:00:00.0: PCI bridge to [bus 01] [ 3.290203] pcieport 0002:00:00.0: PME: Signaling with IRQ 46 [ 3.290314] pcieport 0002:00:00.0: AER: enabled with IRQ 46 [ 3.290938] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235 [ 3.290942] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 3.290945] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 3.292281] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211 [ 3.292286] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 3.292289] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 3.292477] omap8250 40a00000.serial: PM domain pd:149 will not be powered off [ 3.292602] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 7, base_baud = 6000000) is a 8250 [ 3.292944] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 19, base_baud = 3000000) is a 8250 [ 5.196973] printk: console [ttyS2] enabled [ 5.201472] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 20, base_baud = 3000000) is a 8250 [ 5.210296] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 21, base_baud = 3000000) is a 8250 [ 5.219034] arm-smmu-v3 36600000.smmu: ias 48-bit, oas 48-bit (features 0x00001faf) [ 5.228122] arm-smmu-v3 36600000.smmu: allocated 524288 entries for cmdq [ 5.236667] arm-smmu-v3 36600000.smmu: allocated 524288 entries for evtq [ 5.244040] arm-smmu-v3 36600000.smmu: msi_domain absent - falling back to wired irqs [ 5.253616] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled [ 5.264126] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled [ 5.274279] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled [ 5.284517] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled [ 5.295283] scsi host0: ufshcd [ 5.302014] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes) [ 5.317267] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0 [ 5.341226] cadence-qspi 47040000.spi: Cadence QSPI NOR probe failed -517 [ 5.348753] cadence-qspi 47050000.spi: mt25qu512a (65536 Kbytes) [ 5.359918] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2 [ 5.371583] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0 [ 5.382813] scsi 0:0:0:49488: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6 [ 5.391535] scsi 0:0:0:49476: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6 [ 5.400198] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found [ 5.413237] cadence-qspi 47050000.spi: Cadence QSPI NOR probe failed -517 [ 5.457026] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 5.464669] libphy: 46000f00.mdio: probed [ 5.469675] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 5.477938] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 [ 5.489372] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517 [ 5.497906] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0 [ 5.506413] mmc0: CQHCI version 5.10 [ 5.544758] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit [ 5.553357] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 5.559946] davinci_gpio 42110000.gpio: IRQ index 4 not found [ 5.565693] davinci_gpio 42110000.gpio: IRQ not populated, err = -6 [ 5.575488] vdd_mmc1: supplied by vsys_3v3 [ 5.580063] pca953x 4-0020: 4-0020 supply vcc not found, using dummy regulator [ 5.609563] GPIO line 284 (DP0_PWR_SW_EN) hogged as output/high [ 5.616079] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100 [ 5.622913] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100 [ 5.629765] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100 [ 5.636597] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100 [ 5.643399] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100 [ 5.652948] ti-udma 285c0000.dma-controller: Channels: 24 (tchan: 12, rchan: 12, gp-rflow: 8) [ 5.663301] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16) [ 5.675762] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes) [ 5.684199] cadence-qspi 47050000.spi: mt25qu512a (65536 Kbytes) [ 5.699220] mmc0: Command Queue Engine enabled [ 5.703660] mmc0: new HS400 MMC card at address 0001 [ 5.712860] mmcblk0: mmc0:0001 S0J56X 14.8 GiB [ 5.717512] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB [ 5.723534] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB [ 5.729451] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 5.737120] libphy: 46000f00.mdio: probed [ 5.741141] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (240:0) [ 5.749343] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 5.757621] mmcblk0: p1 p2 [ 5.760700] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 [ 5.773304] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 5.780394] pps pps0: new PPS source ptp1 [ 5.784524] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1 [ 5.793469] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 57.4 [ 5.800763] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 5.807652] mmc1: CQHCI version 5.10 [ 5.842032] mmc1: SDHCI controller on 4fb0000.sdhci [4fb0000.sdhci] using ADMA 64-bit [ 5.850156] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 5.862037] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present! [ 5.869393] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present! [ 5.876714] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present! [ 5.884027] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present! [ 5.891935] hctosys: unable to open rtc device (rtc0) [ 5.904716] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL) [ 5.917129] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down [ 7.273877] mmc1: new ultra high speed DDR50 SDHC card at address aaaa [ 7.280702] mmcblk1: mmc1:aaaa SC16G 14.8 GiB [ 7.290805] mmcblk1: p1 p2 [ 10.017862] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off [ 10.049026] IP-Config: Guessing netmask 255.255.255.0 [ 10.054065] IP-Config: Complete: [ 10.057284] device=eth0, hwaddr=50:51:a9:fc:8d:d2, ipaddr=192.168.0.102, mask=255.255.255.0, gw=192.168.0.101 [ 10.067608] host=192.168.0.102, domain=, nis-domain=(none) [ 10.073512] bootserver=192.168.0.101, rootserver=192.168.0.101, rootpath= [ 10.095766] ALSA device list: [ 10.098728] No soundcards found. [ 109.539505] VFS: Unable to mount root fs via NFS, trying floppy. [ 109.545667] VFS: Cannot open root device "nfs" or unknown-block(2,0): error -6 [ 109.552875] Please append a correct "root=" boot option; here are the available partitions: [ 109.561216] 0100 4096 ram0 [ 109.561217] (driver?) [ 109.567302] 0101 4096 ram1 [ 109.567303] (driver?) [ 109.573389] 0102 4096 ram2 [ 109.573389] (driver?) [ 109.579472] 0103 4096 ram3 [ 109.579473] (driver?) [ 109.585558] 0104 4096 ram4 [ 109.585559] (driver?) [ 109.591641] 0105 4096 ram5 [ 109.591642] (driver?) [ 109.597727] 0106 4096 ram6 [ 109.597728] (driver?) [ 109.603811] 0107 4096 ram7 [ 109.603811] (driver?) [ 109.609898] 0108 4096 ram8 [ 109.609899] (driver?) [ 109.615981] 0109 4096 ram9 [ 109.615982] (driver?) [ 109.622067] 010a 4096 ram10 [ 109.622067] (driver?) [ 109.628236] 010b 4096 ram11 [ 109.628237] (driver?) [ 109.634409] 010c 4096 ram12 [ 109.634409] (driver?) [ 109.640579] 010d 4096 ram13 [ 109.640579] (driver?) [ 109.646751] 010e 4096 ram14 [ 109.646751] (driver?) [ 109.652920] 010f 4096 ram15 [ 109.652921] (driver?) [ 109.659097] 1f00 65536 mtdblock0 [ 109.659097] (driver?) [ 109.665616] 1f01 65536 mtdblock1 [ 109.665617] (driver?) [ 109.672134] b300 15540224 mmcblk0 [ 109.672135] driver: mmcblk [ 109.678917] b301 63488 mmcblk0p1 9215d7c1-01 [ 109.678918] [ 109.685698] b302 15475712 mmcblk0p2 9215d7c1-02 [ 109.685698] [ 109.692476] b360 15558144 mmcblk1 [ 109.692476] driver: mmcblk [ 109.699254] b361 131072 mmcblk1p1 1774cca5-01 [ 109.699255] [ 109.706034] b362 15426048 mmcblk1p2 1774cca5-02 [ 109.706035] [ 109.712813] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0) [ 109.721054] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.40-g66cf445b76 #1 [ 109.727995] Hardware name: Texas Instruments K3 J721E SoC (DT) [ 109.733808] Call trace: [ 109.736245] dump_backtrace+0x0/0x140 [ 109.739892] show_stack+0x14/0x20 [ 109.743195] dump_stack+0xb4/0xf8 [ 109.746496] panic+0x158/0x324 [ 109.749538] mount_block_root+0x1d8/0x28c [ 109.753532] mount_root+0x124/0x158 [ 109.757005] prepare_namespace+0x15c/0x1c0 [ 109.761086] kernel_init_freeable+0x210/0x22c [ 109.765427] kernel_init+0x10/0xfc [ 109.768814] ret_from_fork+0x10/0x18 [ 109.772376] SMP: stopping secondary CPUs [ 109.776285] Kernel Offset: disabled [ 109.779758] CPU features: 0x0002,20006008 [ 109.783751] Memory Limit: none [ 109.786794] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0) ]---
