DRA77P: OV2775 Usecase Demo
Part Number: DRA77P
Other Parts Discussed in Thread: INA226
Hi Everyone,
I have a requirement of bringing up the OV2775 camera sensor on J7_EVM using RTOS for which we have ported the camera configurations of J6 vision SDK package to the pdk rtos j7 package but still not able to capture anything there. So, to figure out the delta missing during the porting of camera configuration from J6 vision SDK, We want to test the OV2775 camera interface on J6 + fusion kit.
So, Could anyone please help me if any RTOS based usecases available in J6 vision SDK package to verify OV2775 camera with also the details of build steps.
    After installing the vision SDK, follow the steps mentioned in the below document for building & running the demo use-case
    file_path :vision_sdk/docs/UserGuides/VisionSDK_UserGuide_TDA3xx.pdf
    Run any one of the ISS capture use-cases to test "OV2775" camera sensor.
    By default "OV10635" camera sensor is enabled, so in order to change the camera source, please enter the key 's' then select camera source settings then choose the "OV2775" sensor as a camera source.
    Gaviraju
    file:///Y:/ADAS/vision_sdk/docs/UserGuides/VisionSDK_UserGuide_TDA3xx.pdf
    Thank you so much Gaviraju for the quick response. It helped me a lot. Thanks again.
  • Hi Gaviraju,
    I am able to generate the following images at the below specified path by following the build steps of user guide. Could you please confirm me whether this is the image which I need to run on one of the cores to select the OV2775 camera use-case application.
    \vision_sdk\binaries\$(MAKEAPPNAME)\$(MAKECONFIG)\vision_sdk\bin\tda3xx-evm
    vision_sdk_arp32_1_release.xearp32F
    vision_sdk_c66xdsp_1_release.xe66
    vision_sdk_c66xdsp_2_release.xe66
    vision_sdk_ipu1_0_release.xem4
    vision_sdk_ipu1_1_release.xem4
  • Sri Rama,
    I would suggest to follow TDA3x user guide to run these demos..
    Rgds,
    Brijesh
  • Brijesh,
    I have the followed the steps specified in the user guide to generated the following images. But after loading and running them in the same order on different cores as per user guide I see my application hangs in ipc_start(Please check the below screenshot). Can you update me if we need to follow any separate procedure.
    Please try the following method.
    1) make -s -j depend
    2) make -s -j
    3) make -s appimage
    4) make -s sbl
    5) Copy appimage & MLO into the SD card (This should be bootable partition)
    6) Make sure the board in SD boot mode then power on the EVM & run your use-case.
    Gaviraju
  • Hi Gaviraju,
    I have followed all the steps specified above to boot from SD card.
    These are the options selected after it boots, Choosen 's' to opt system settings for selecting the below display and capture settings
    Display Settings(Step 1)
    HDMI 1080P60-------> Selected Option '3'
    Capture Settings(Step 2)
    OV2775 Sensor 1080p30 - TIDA001130-------> Selected Option 'e'
    Vision SDK Usecases(Step 3)
    ISS Usecases, (TDA3x ONLY)-------> Selected Option '5'
    ISS Usecases, (TDA3x ONLY)(Step 4)
    1CH ISS capture + ISS ISP + ISS LDC+VTNF + Display-------> Selected Option '1'
    But it is hanging in Heap memory allocation in LOCAL_DDR. You can check the same in the below full log. Currently I am using
    3.8 vision sdk.
     TDA2Px SBL Boot
     DPLL Configuration Completed
     Clock Domain Configuration Completed
     Module Enable Configuration Completed
     TI EVM PAD Config Completed
     TDA2Px DDR Configuration
     DDR Config Completed
     App Image Download Begins
     SD Boot - file open completed successfully
     MPU CPU0 Image Load Completed
     IPU1 CPU0 Image Load Completed
     IPU1 CPU1 Image Load Completed
     IPU2 CPU0 and CPU1 Image Load Completed
     DSP1 Image Load Completed
     DSP2 Image Load Completed
     EVE1 Image Load Completed
     EVE2 Image Load Completed
     App Image Download Completed
     Putting MPU CPU1 in Off mode
     EVE MMU configuration completed
     PMCCNTR counts once every 64 clock cycles, multiple by 64 to get actual CPU cycles
     SBL Initial Config Cycles - 99854  (8.52 ms)
     SOC Init Cycles - 336386  (28.70 ms)
     DDR Config Clock Cycles - 178443  (15.22 ms)
     App Image Load Cycles - 439912065  (37539.16 ms)
     Slave Core Bootup Cycles - 255384  (21.79 ms)
     SBL Boot-up Cycles - 440783670  (37613.53 ms)
     Time at which SBL started IPU1_0 - 625437  (19086.82 ms)
     Jumping to MPU CPU0 App
    [IPU1-0]     19.082047 s:  ***** IPU1_0 Firmware build time 14:44:17 Aug  5 2020
    [IPU1-0]     19.082230 s:  *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
    [IPU1-0]     19.153236 s:  SYSTEM: Notify register to [IPU1-1] line 0, event 15...
    [IPU1-0]     19.153419 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
    [IPU1-0]     19.153510 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
    [IPU1-0]     19.153632 s:  SYSTEM: Notify register to [DSP2] line 0, event 15...
    [IPU1-0]     19.153724 s:  SYSTEM: Notify register to [EVE1] line 0, event 15...
    [IPU1-0]     19.153846 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
    [IPU1-0]     19.153937 s:  SYSTEM: Notify register to [HOST] line 0, event 15...
    [IPU1-0]     19.155676 s:  *** UTILS: CPU MHz = 20 Mhz ***
    [IPU1-0]     19.155828 s:  SYSTEM: System Common Init in progress !!!
    [IPU1-0]     19.167998 s:  UTILS: CIO: Init Done !!!
    [IPU1-0]     19.168120 s:  SYSTEM: IPC init in progress !!!
    [IPU1-0]     19.168181 s:  SYSTEM: Notify init done !!!
    [IPU1-0]     19.169981 s:  SYSTEM: MsgQ init done !!!
    [IPU1-0]     19.170987 s:  SYSTEM: Work Queue init done !!!
    [IPU1-0]     19.171140 s:  SYSTEM: IPC init DONE !!!
    [IPU1-0]     19.175074 s:  SYSTEM: System Common Init Done !!!
    [IPU1-0]     19.175166 s:  SYSTEM: System Init in progress !!!
    [IPU1-0]     19.175227 s:  SYSTEM: BSP Common Init in progress !!!
    [IPU1-0]     19.175349 s:  SYSTEM: BSP Common Init Done !!!
    [IPU1-0]     19.175440 s:  SYSTEM: BSP Platform Init in progress !!!
    [IPU1-0]     19.175593 s:  SYSTEM: BSP Platform Init Done !!!
    [IPU1-0]     19.175654 s:  SYSTEM: FVID2 Init in progress !!!
    [IPU1-0]     19.175806 s:  SYSTEM: FVID2 Init Done !!!
    [IPU1-0]     19.175898 s:  SYSTEM: VPS Init in progress !!!
    [IPU1-0]     19.175989 s:  SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0xa0000000 -> 0x80000000]
    [IPU1-0]     19.179741 s: *** VPDMA Firmware Loading... ***
    [IPU1-0]     19.179863 s: VPDMA Firmware Address = 0x9fd1b5c0
    [IPU1-0]     19.179954 s: VPDMA Load Address     = 0x4897d004
    [IPU1-0]     19.180076 s: VPDMA Firmware Version = 0x4d0001b8
    [IPU1-0]     19.180137 s: VPDMA List Busy Status = 0x00000000
    [IPU1-0]     19.180229 s: *** VPDMA Firmware Load Success ***
    [IPU1-0]     19.180656 s: *** VPDMA Firmware Loading... ***
    [IPU1-0]     19.180747 s: VPDMA Firmware Address = 0x9fd1b5c0
    [IPU1-0]     19.180839 s: VPDMA Load Address     = 0x4899d004
    [IPU1-0]     19.180961 s: VPDMA Firmware Version = 0x4d0001b8
    [IPU1-0]     19.181052 s: VPDMA List Busy Status = 0x00000000
    [IPU1-0]     19.181144 s: *** VPDMA Firmware Load Success ***
    [IPU1-0]     19.181571 s: *** VPDMA Firmware Loading... ***
    [IPU1-0]     19.181693 s: VPDMA Firmware Address = 0x9fd1b5c0
    [IPU1-0]     19.181784 s: VPDMA Load Address     = 0x489dd004
    [IPU1-0]     19.181876 s: VPDMA Firmware Version = 0x4d0001b8
    [IPU1-0]     19.181967 s: VPDMA List Busy Status = 0x00000000
    [IPU1-0]     19.182059 s: *** VPDMA Firmware Load Success ***
    [IPU1-0]     19.258463 s:  SYSTEM: VPS Init Done !!!
    [IPU1-0]     19.259379 s:  UTILS: DMA: HWI Create for INT34 !!!
    [IPU1-0]     19.259592 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
    [IPU1-0]     19.259714 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254232 B (248 KB)
    [IPU1-0]     19.259867 s:  SYSTEM: Heap = SR_OCMC              @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
    [IPU1-0]     19.260050 s:  SYSTEM: Heap = SR_DDR_CACHED        @ 0x88583000, Total size = 368037888 B (350 MB), Free size = 368037888 B (350 MB)
    [IPU1-0]     19.260294 s:  SYSTEM: Heap = SR_DDR_NON_CACHED    @ 0xbfc00000, Total size = 127872 B (0 MB), Free size = 106368 B (0 MB)
    [IPU1-0]     19.260477 s:  SYSTEM: Initializing Links !!!
    [IPU1-0]     19.563319 s:  SYSTEM: Initializing Links ... DONE !!!
    [IPU1-0]     19.613310 s:  BOARD: Board Init in progress !!!
    [IPU1-0]     19.613707 s:  BOARD: Board Init Done !!!
    [IPU1-0]     19.627645 s:
    [IPU1-0]     19.627706 s:  Vision SDK Version    : [REL_VISION_SDK_03_08_00_00]
    [IPU1-0]     19.627767 s:  FVID2 Version         : [FVID_02_01_00_01]
    [IPU1-0]     19.627859 s:  BSP Version           : [PDK_01_10_04__xx]
    [IPU1-0]     19.627920 s:  Platform              : [EVM]
    [IPU1-0]     19.627981 s:  SOC                   : [TDA2PX]
    [IPU1-0]     19.628042 s:  SOC Revision          : [ES1.0]
    [IPU1-0]     19.628103 s:  Board Detected        : [Vision]
    [IPU1-0]     19.634600 s:  EEPROM Base Board Name: [DRA76/7xP,TDA2P]
    [IPU1-0]     19.634661 s:  Base Board Revision   : [REV A]
    [IPU1-0]     19.636003 s:  Daughter Card Revision: [REV D]
    [IPU1-0]     19.636064 s:
    [IPU1-0]     19.639754 s:  SYSTEM: UART: INTERRUPT Mode is Selected
    [IPU1-1]     19.097968 s:  ***** IPU1_1 Firmware build time 14:41:20 Aug  5 2020
    [IPU1-1]     19.098151 s:  *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
    [IPU1-1]     19.155371 s:  SYSTEM: Notify register to [IPU1-0] line 0, event 15...
    [IPU1-1]     19.155584 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
    [IPU1-1]     19.155706 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
    [IPU1-1]     19.155859 s:  SYSTEM: Notify register to [DSP2] line 0, event 15...
    [IPU1-1]     19.155981 s:  SYSTEM: Notify register to [EVE1] line 0, event 15...
    [IPU1-1]     19.156133 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
    [IPU1-1]     19.156225 s:  SYSTEM: Notify register to [HOST] line 0, event 15...
    [IPU1-1]     19.158207 s:  SYSTEM: System Common Init in progress !!!
    [IPU1-1]     19.159336 s:  UTILS: CIO: Init Done !!!
    [IPU1-1]     19.159458 s:  SYSTEM: IPC init in progress !!!
    [IPU1-1]     19.159519 s:  SYSTEM: Notify init done !!!
    [IPU1-1]     19.161349 s:  SYSTEM: MsgQ init done !!!
    [IPU1-1]     19.162111 s:  SYSTEM: Work Queue init done !!!
    [IPU1-1]     19.162172 s:  SYSTEM: IPC init DONE !!!
    [IPU1-1]     19.165863 s:  SYSTEM: System Common Init Done !!!
    [IPU1-1]     19.165954 s:  SYSTEM: System IPU1_1 Init in progress !!!
    [IPU1-1]     19.166809 s:  UTILS: DMA: HWI Create for INT25 !!!
    [IPU1-1]     19.167022 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
    [IPU1-1]     19.167114 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 655360 B (640 KB), Free size = 647600 B (632 KB)
    [IPU1-1]     19.167327 s:  SYSTEM: Initializing Links !!!
    [IPU1-1]     19.277465 s:  UTILS: PRF: ##### Cannot allocate Object for SYNC1 ####
    [IPU1-1]     19.280485 s:  UTILS: PRF: ##### Cannot allocate Object for SYNC2 ####
    [IPU1-1]     19.283383 s:  UTILS: PRF: ##### Cannot allocate Object for SYNC3 ####
    [IPU1-1]     19.286616 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM0 ####
    [IPU1-1]     19.289635 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM1 ####
    [IPU1-1]     19.292716 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM2 ####
    [IPU1-1]     19.295979 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM3 ####
    [IPU1-1]     19.298969 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM4 ####
    [IPU1-1]     19.302324 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM5 ####
    [IPU1-1]     19.305526 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM6 ####
    [IPU1-1]     19.308698 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM7 ####
    [IPU1-1]     19.308820 s:  SYSTEM: Initializing Links ... DONE !!!
    [IPU1-1]     19.308881 s:  SYSTEM: System IPU1_1 Init Done !!!
    [HOST  ]     19.147959 s:  ***** A15_0 Firmware build time 12:19:50 Aug  5 2020
    [HOST  ]     19.147989 s:  *** SYSTEM: CPU Frequency <ORG = 750000000 Hz>, <NEW = 1500000000 Hz>
    [HOST  ]     19.154090 s:  SYSTEM: Notify register to [IPU1-0] line 0, event 15...
    [HOST  ]     19.154120 s:  SYSTEM: Notify register to [IPU1-1] line 0, event 15...
    [HOST  ]     19.154120 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
    [HOST  ]     19.154120 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
    [HOST  ]     19.154120 s:  SYSTEM: Notify register to [DSP2] line 0, event 15...
    [HOST  ]     19.154151 s:  SYSTEM: Notify register to [EVE1] line 0, event 15...
    [HOST  ]     19.154151 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
    [HOST  ]     19.156042 s:  SYSTEM: System Common Init in progress !!!
    [HOST  ]     19.156072 s:  SYSTEM: IPC init in progress !!!
    [HOST  ]     19.156103 s:  SYSTEM: Notify init done !!!
    [HOST  ]     19.156133 s:  SYSTEM: MsgQ init done !!!
    [HOST  ]     19.156133 s:  SYSTEM: Work Queue init done !!!
    [HOST  ]     19.156133 s:  SYSTEM: IPC init DONE !!!
    [HOST  ]     19.156591 s:  SYSTEM: System Common Init Done !!!
    [HOST  ]     19.156591 s:  SYSTEM: System A15 Init in progress !!!
    [HOST  ]     19.156713 s:  UTILS: DMA: HWI Create for INT66 !!!
    [HOST  ]     19.156713 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
    [HOST  ]     19.156713 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 6291456 B (6144 KB), Free size = 6248624 B (6102 KB)
    [HOST  ]     19.156743 s:  SYSTEM: Initializing Links !!!
    [HOST  ]     19.158299 s:  UTILS: PRF: ##### Cannot allocate Object for SYNC1 ####
    [HOST  ]     19.158329 s:  UTILS: PRF: ##### Cannot allocate Object for SYNC2 ####
    [HOST  ]     19.158390 s:  UTILS: PRF: ##### Cannot allocate Object for SYNC3 ####
    [HOST  ]     19.158421 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM0 ####
    [HOST  ]     19.158482 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM1 ####
    [HOST  ]     19.158512 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM2 ####
    [HOST  ]     19.158573 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM3 ####
    [HOST  ]     19.158604 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM4 ####
    [HOST  ]     19.158665 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM5 ####
    [HOST  ]     19.158695 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM6 ####
    [HOST  ]     19.158756 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM7 ####
    [HOST  ]     19.158756 s:  SYSTEM: Initializing Links ... DONE !!!
    [HOST  ]     19.158787 s:  SYSTEM: System A15 Init Done !!!
    [HOST  ]     19.454431 s:  NSP GMAC: PHY 2 Found on MAC Port 0
    [HOST  ]     19.456780 s:  NSP GMAC: PHY 3 Found on MAC Port 1
    [DSP1  ]     19.124473 s:  ***** DSP1 Firmware build time 14:37:05 Aug  5 2020
    [DSP1  ]     19.124534 s:  *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 850000000 Hz>
    [DSP1  ]     19.157567 s:  SYSTEM: Notify register to [IPU1-0] line 0, event 15...
    [DSP1  ]     19.157628 s:  SYSTEM: Notify register to [IPU1-1] line 0, event 15...
    [DSP1  ]     19.157658 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
    [DSP1  ]     19.157689 s:  SYSTEM: Notify register to [DSP2] line 0, event 15...
    [DSP1  ]     19.157689 s:  SYSTEM: Notify register to [EVE1] line 0, event 15...
    [DSP1  ]     19.157719 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
    [DSP1  ]     19.157750 s:  SYSTEM: Notify register to [HOST] line 0, event 15...
    [DSP1  ]     19.157902 s:  *** UTILS: CPU MHz = 20 Mhz ***
    [DSP1  ]     19.157933 s:  SYSTEM: System Common Init in progress !!!
    [DSP1  ]     19.158085 s:  UTILS: CIO: Init Done !!!
    [DSP1  ]     19.158116 s:  SYSTEM: IPC init in progress !!!
    [DSP1  ]     19.158146 s:  SYSTEM: Notify init done !!!
    [DSP1  ]     19.158268 s:  SYSTEM: MsgQ init done !!!
    [DSP1  ]     19.158360 s:  SYSTEM: Work Queue init done !!!
    [DSP1  ]     19.158390 s:  SYSTEM: IPC init DONE !!!
    [DSP1  ]     19.158939 s:  SYSTEM: System Common Init Done !!!
    [DSP1  ]     19.158970 s:  SYSTEM: System DSP Init in progress !!!
    [DSP1  ]     19.159122 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
    [DSP1  ]     19.159153 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
    [DSP1  ]     19.159183 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516616 B (504 KB)
    [DSP1  ]     19.159214 s:  SYSTEM: Initializing Links !!!
    [DSP1  ]     19.165710 s:  SYSTEM: Initializing Links ... DONE !!!
    [DSP1  ]     19.165771 s: lz4CompDecomp Init
    [DSP1  ]     19.165771 s:  SYSTEM: System DSP Init Done !!!
    [DSP1  ]     19.576038 s:  SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!!
    [DSP1  ]     19.576069 s:  SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!!
    [DSP2  ]     19.124473 s: ***** DSP2 Firmware build time 14:39:37 Aug  5 2020
    [DSP2  ]     19.124534 s:  *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 850000000 Hz>
    [DSP2  ]     19.158726 s:  SYSTEM: Notify register to [IPU1-0] line 0, event 15...
    [DSP2  ]     19.158787 s:  SYSTEM: Notify register to [IPU1-1] line 0, event 15...
    [DSP2  ]     19.158817 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
    [DSP2  ]     19.158817 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
    [DSP2  ]     19.158848 s:  SYSTEM: Notify register to [EVE1] line 0, event 15...
    [DSP2  ]     19.158878 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
    [DSP2  ]     19.158878 s:  SYSTEM: Notify register to [HOST] line 0, event 15...
    [DSP2  ]     19.159031 s:  *** UTILS: CPU MHz = 20 Mhz ***
    [DSP2  ]     19.159061 s:  SYSTEM: System Common Init in progress !!!
    [DSP2  ]     19.159214 s:  UTILS: CIO: Init Done !!!
    [DSP2  ]     19.159244 s:  SYSTEM: IPC init in progress !!!
    [DSP2  ]     19.159244 s:  SYSTEM: Notify init done !!!
    [DSP2  ]     19.159366 s:  SYSTEM: MsgQ init done !!!
    [DSP2  ]     19.159458 s:  SYSTEM: Work Queue init done !!!
    [DSP2  ]     19.159488 s:  SYSTEM: IPC init DONE !!!
    [DSP2  ]     19.160007 s:  SYSTEM: System Common Init Done !!!
    [DSP2  ]     19.160068 s:  SYSTEM: System DSP Init in progress !!!
    [DSP2  ]     19.160220 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
    [DSP2  ]     19.160251 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
    [DSP2  ]     19.160281 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516616 B (504 KB)
    [DSP2  ]     19.160312 s:  SYSTEM: Initializing Links !!!
    [DSP2  ]     19.166809 s:  SYSTEM: Initializing Links ... DONE !!!
    [DSP2  ]     19.166839 s: lz4CompDecomp Init
    [DSP2  ]     19.166839 s:  SYSTEM: System DSP Init Done !!!
    [DSP2  ]     19.578051 s:  SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!!
    [DSP2  ]     19.578051 s:  SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!!
    [EVE1  ]     19.094125 s:  ***** EVE Firmware build time 14:33:33 Aug  5 2020
    [EVE1  ]     19.095772 s:  *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 325000000 Hz>
    [EVE1  ]     19.161013 s:  SYSTEM: Notify register to [IPU1-0] line 0, event 15...
    [EVE1  ]     19.162569 s:  SYSTEM: Notify register to [IPU1-1] line 0, event 15...
    [EVE1  ]     19.163941 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
    [EVE1  ]     19.165283 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
    [EVE1  ]     19.166564 s:  SYSTEM: Notify register to [DSP2] line 0, event 15...
    [EVE1  ]     19.167846 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
    [EVE1  ]     19.169066 s:  SYSTEM: Notify register to [HOST] line 0, event 15...
    [EVE1  ]     19.171506 s:  SYSTEM: System Common Init in progress !!!
    [EVE1  ]     19.173519 s:  UTILS: CIO: Init Done !!!
    [EVE1  ]     19.174403 s:  SYSTEM: IPC init in progress !!!
    [EVE1  ]     19.175288 s:  SYSTEM: Notify init done !!!
    [EVE1  ]     19.177423 s:  SYSTEM: MsgQ init done !!!
    [EVE1  ]     19.178856 s:  SYSTEM: Work Queue init done !!!
    [EVE1  ]     19.179741 s:  SYSTEM: IPC init DONE !!!
    [EVE1  ]     19.191911 s:  SYSTEM: System Common Init Done !!!
    [EVE1  ]     19.192856 s:  SYSTEM: System EVE Init in progress !!!
    [EVE1  ]     19.194259 s:  UTILS: DMA: HWI Create for INT8 !!!
    [EVE1  ]     19.195388 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
    [EVE1  ]     19.196577 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
    [EVE1  ]     19.198682 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254408 B (248 KB)
    [EVE1  ]     19.200695 s:  SYSTEM: Initializing Links !!!
    [EVE1  ]     19.281858 s:  SYSTEM: Initializing Links ... DONE !!!
    [EVE1  ]     19.282864 s:  SYSTEM: System EVE Init Done !!!
    [EVE2  ]     19.097663 s:  ***** EVE Firmware build time 14:34:48 Aug  5 2020
    [EVE2  ]     19.099249 s:  *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 325000000 Hz>
    [EVE2  ]     19.161044 s:  SYSTEM: Notify register to [IPU1-0] line 0, event 15...
    [EVE2  ]     19.162569 s:  SYSTEM: Notify register to [IPU1-1] line 0, event 15...
    [EVE2  ]     19.163941 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
    [EVE2  ]     19.165283 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
    [EVE2  ]     19.166595 s:  SYSTEM: Notify register to [DSP2] line 0, event 15...
    [EVE2  ]     19.167846 s:  SYSTEM: Notify register to [EVE1] line 0, event 15...
    [EVE2  ]     19.169096 s:  SYSTEM: Notify register to [HOST] line 0, event 15...
    [EVE2  ]     19.171536 s:  SYSTEM: System Common Init in progress !!!
    [EVE2  ]     19.173519 s:  UTILS: CIO: Init Done !!!
    [EVE2  ]     19.174403 s:  SYSTEM: IPC init in progress !!!
    [EVE2  ]     19.175288 s:  SYSTEM: Notify init done !!!
    [EVE2  ]     19.177423 s:  SYSTEM: MsgQ init done !!!
    [EVE2  ]     19.178856 s:  SYSTEM: Work Queue init done !!!
    [EVE2  ]     19.179771 s:  SYSTEM: IPC init DONE !!!
    [EVE2  ]     19.191941 s:  SYSTEM: System Common Init Done !!!
    [EVE2  ]     19.192856 s:  SYSTEM: System EVE Init in progress !!!
    [EVE2  ]     19.194259 s:  UTILS: DMA: HWI Create for INT8 !!!
    [EVE2  ]     19.195388 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
    [EVE2  ]     19.196577 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
    [EVE2  ]     19.198682 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254408 B (248 KB)
    [EVE2  ]     19.200695 s:  SYSTEM: Initializing Links !!!
    [EVE2  ]     19.281827 s:  SYSTEM: Initializing Links ... DONE !!!
    [EVE2  ]     19.282834 s:  SYSTEM: System EVE Init Done !!!
    [IPU2  ]     19.079820 s:  ***** IPU2 Firmware build time 14:48:18 Aug  5 2020
    [IPU2  ]     19.080034 s:  *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
    [IPU2  ]     19.156499 s:  SYSTEM: Notify register to [IPU1-0] line 0, event 15...
    [IPU2  ]     19.156652 s:  SYSTEM: Notify register to [IPU1-1] line 0, event 15...
    [IPU2  ]     19.156774 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
    [IPU2  ]     19.156896 s:  SYSTEM: Notify register to [DSP2] line 0, event 15...
    [IPU2  ]     19.157018 s:  SYSTEM: Notify register to [EVE1] line 0, event 15...
    [IPU2  ]     19.157140 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
    [IPU2  ]     19.157262 s:  SYSTEM: Notify register to [HOST] line 0, event 15...
    [IPU2  ]     19.159946 s:  SYSTEM: System Common Init in progress !!!
    [IPU2  ]     19.161135 s:  UTILS: CIO: Init Done !!!
    [IPU2  ]     19.161227 s:  SYSTEM: IPC init in progress !!!
    [IPU2  ]     19.161379 s:  SYSTEM: Notify init done !!!
    [IPU2  ]     19.163179 s:  SYSTEM: MsgQ init done !!!
    [IPU2  ]     19.163941 s:  SYSTEM: Work Queue init done !!!
    [IPU2  ]     19.164033 s:  SYSTEM: IPC init DONE !!!
    [IPU2  ]     19.169188 s:  SYSTEM: System Common Init Done !!!
    [IPU2  ]     19.169340 s:  SYSTEM: System IPU2 Init in progress !!!
    [IPU2  ]     19.170103 s:  UTILS: DMA: HWI Create for INT25 !!!
    [IPU2  ]     19.170377 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
    [IPU2  ]     19.170469 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254336 B (248 KB)
    [IPU2  ]     19.170682 s:  SYSTEM: Initializing Links !!!
    [IPU2  ]     19.274751 s:  UTILS: PRF: ##### Cannot allocate Object for SYNC1 ####
    [IPU2  ]     19.277557 s:  UTILS: PRF: ##### Cannot allocate Object for SYNC2 ####
    [IPU2  ]     19.280363 s:  UTILS: PRF: ##### Cannot allocate Object for SYNC3 ####
    [IPU2  ]     19.283200 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM0 ####
    [IPU2  ]     19.286097 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM1 ####
    [IPU2  ]     19.288995 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM2 ####
    [IPU2  ]     19.291862 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM3 ####
    [IPU2  ]     19.294759 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM4 ####
    [IPU2  ]     19.297657 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM5 ####
    [IPU2  ]     19.300555 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM6 ####
    [IPU2  ]     19.303513 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM7 ####
    [IPU2  ]     19.303635 s:  SYSTEM: Initializing Links ... DONE !!!
    [IPU2  ]     19.303696 s:  SYSTEM: System IPU2 Init Done !!!
    [IPU1-0]     20.673214 s:  UTILS_PRCM_STATS: INA226 Setup Failed. Check if INA226 is connected on I2C3 Lines
    [IPU1-0]     20.678551 s:  QSPI Init Started
    [IPU1-0]     20.678826 s:  MID - 1
    [IPU1-0]     20.678887 s:  DID - 18
    [IPU1-0]     20.678917 s:  QSPI Init Completed Sucessfully
    [IPU1-0]     20.694869 s:
    [IPU1-0]     20.694930 s:  Current System Settings,
    [IPU1-0]     20.694991 s:  ========================
    [IPU1-0]     20.695022 s:  Display Type   : HDMI 1920x1080 @ 60fps
    [IPU1-0]     20.695113 s:  Capture Source : Sensor OV10635 1280x720  @ 30fps - VIP, YUV422
    [IPU1-0]     20.695174 s:  My IP address for interface 1 : 0.0.0.0
    [IPU1-0]     20.695235 s:  My IP address for interface 2 : 0.0.0.0
    [IPU1-0]     20.695357 s:  ISS Settings   : LDC=[OFF] VTNF=[OFF] WDR=[OFF]
    [IPU1-0]     20.695449 s:
    [IPU1-0]     20.695479 s:  ============
    [IPU1-0]     20.695510 s:  Usecase Menu
    [IPU1-0]     20.695571 s:  ============
    [IPU1-0]     20.695601 s:
    [IPU1-0]
    [IPU1-0]  Vision SDK Usecases,
    [IPU1-0]  --------------------
    [IPU1-0]  1: Single Camera Usecases
    [IPU1-0]  2: Multi-Camera LVDS Usecases
    [IPU1-0]  3: AVB RX Usecases, (TDA2x & TDA2Ex ONLY)
    [IPU1-0]  4: Dual Display Usecases, (TDA2x EVM ONLY)
    [IPU1-0]  5: ISS Usecases, (TDA3x ONLY)
    [IPU1-0]  6: TDA2x Stereo Usecases
    [IPU1-0]  7: Network RX/TX Usecases
    [IPU1-0]  9: RADAR Usecases
    [IPU1-0]  a: Miscellaneous test's
    [IPU1-0]  f: TIDL Usecase
    [IPU1-0]  g: Camera Radar Combo Usecases
    [IPU1-0]
    [IPU1-0]  s: System Settings
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]  Enter Choice:
    [IPU1-0]
    [HOST  ]     24.158329 s:  NETWORK_CTRL: Starting Server (port=5000) !!!
    [HOST  ]     24.158329 s:  NETWORK_CTRL: Starting Server ... DONE (port=5000) !!!
    [IPU1-0]     37.159061 s:
    [IPU1-0]     37.159122 s:
    [IPU1-0]
    [IPU1-0]  ===============
    [IPU1-0]  System Settings
    [IPU1-0]
    [IPU1-0]  1: Display Settings
    [IPU1-0]  2: Capture Settings
    [IPU1-0]  3: ISS Settings (TDA3x ONLY)
    [IPU1-0]  4: Enable Charging via USB2 Port (TDA2x EVM ONLY)
    [IPU1-0]  5: Print PRCM Statistics
    [IPU1-0]  6: Show Memory/CPU/DDR BW usage
    [IPU1-0]  7: Calibration Settings
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]     37.159397 s:
    [IPU1-0]     39.580064 s:
    [IPU1-0]
    [IPU1-0]  ================
    [IPU1-0]  Display Settings
    [IPU1-0]
    [IPU1-0]  1: LCD  7-inch 800x480@60fps
    [IPU1-0]  2: LCD  10-inch 1280x720@60fps
    [IPU1-0]  3: HDMI 1080P60
    [IPU1-0]  4: HDMI 720P60
    [IPU1-0]  5: SDTV NTSC
    [IPU1-0]  6: SDTV PAL
    [IPU1-0]  7: HDMI XGA TDM mode (TDA3x ONLY)
    [IPU1-0]  8: LCD  10-inch 1920x1200@60fps
    [IPU1-0]  9: HDMI WXGA mode (TDA3x ONLY)
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]     39.580369 s:
    [IPU1-0]     44.426554 s:
    [IPU1-0]     44.426615 s:  Current System Settings,
    [IPU1-0]     44.426645 s:  ========================
    [IPU1-0]     44.426706 s:  Display Type   : HDMI 1920x1080 @ 60fps
    [IPU1-0]     44.426767 s:  Capture Source : Sensor OV10635 1280x720  @ 30fps - VIP, YUV422
    [IPU1-0]     44.426859 s:  My IP address for interface 1 : 0.0.0.0
    [IPU1-0]     44.426920 s:  My IP address for interface 2 : 0.0.0.0
    [IPU1-0]     44.427042 s:  ISS Settings   : LDC=[OFF] VTNF=[OFF] WDR=[OFF]
    [IPU1-0]     44.427133 s:
    [IPU1-0]     44.427164 s:  ============
    [IPU1-0]     44.427194 s:  Usecase Menu
    [IPU1-0]     44.427255 s:  ============
    [IPU1-0]     44.427316 s:
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]     53.319252 s:
    [IPU1-0]     53.319313 s:
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]     53.319587 s:
    [IPU1-0]     60.955285 s:
    [IPU1-0]
    [IPU1-0]  Capture Source
    [IPU1-0]
    [IPU1-0]  1: OV10635 Sensor 720P30
    [IPU1-0]  2: HDMI Capture 1080P60 (Not Supported in TDA2x/TDA2Ex Multi-serdes board)
    [IPU1-0]  3: OV10640 Sensor 720P30 - CSI2 (TDA3x ONLY)
    [IPU1-0]  4: OV10640 Sensor 720P30 - Parallel (TDA3x ONLY)
    [IPU1-0]  5: AR0132  Sensor 720P60 - Parallel (TDA3x ONLY)
    [IPU1-0]  6: AR0140  Sensor 720P60 - Parallel (TDA3x ONLY)
    [IPU1-0]  7: IMX224  Sensor 1280x960 - CSI2 (TDA3x ONLY)
    [IPU1-0]  8: AR0140  Sensor for SV - TIDA00262 (TDA3x ONLY)
    [IPU1-0]  9: OV10640 Sensor for SV - IMI (TDA3x ONLY)
    [IPU1-0]  a: OV10635 Sensor for Mosaic Display - SAT0088/OV10635 (TDA2PX, TDA2EX & TDA3x)
    [IPU1-0]  b: OV2775 Sensor 1080p30 (TDA3x ONLY)
    [IPU1-0]  c: AR143 MARS Camera (TDA3x ONLY)
    [IPU1-0]  d: Skip Sensor configuration
    [IPU1-0]  e: OV2775 Sensor 1080p30 - TIDA001130
    [IPU1-0]  f: IMX390 Sensor 1080p30 - D3
    [IPU1-0]  g: OV10640 Sensor + OV490 ISP - IMI
    [IPU1-0]  h: AR0233 RCCB UB953 - MARS
    [IPU1-0]  i: OV2311 UB953 - Leopard Imaging
    [IPU1-0]  j: AR0239 RGBIR UB953 - MARS
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]     60.956261 s:
    [IPU1-0]     82.908650 s:  TIDA1130 Sensor is Selected
    [IPU1-0]     82.908924 s:
    [IPU1-0]     82.908955 s:  Current System Settings,
    [IPU1-0]     82.909046 s:  ========================
    [IPU1-0]     82.909107 s:  Display Type   : HDMI 1920x1080 @ 60fps
    [IPU1-0]     82.909168 s:  Capture Source : Sensor OV10635 1280x720  @ 30fps - VIP, YUV422
    [IPU1-0]     82.909260 s:  My IP address for interface 1 : 0.0.0.0
    [IPU1-0]     82.909321 s:  My IP address for interface 2 : 0.0.0.0
    [IPU1-0]     82.909412 s:  ISS Settings   : LDC=[OFF] VTNF=[OFF] WDR=[OFF]
    [IPU1-0]     82.909473 s:
    [IPU1-0]     82.909504 s:  ============
    [IPU1-0]     82.909565 s:  Usecase Menu
    [IPU1-0]     82.909595 s:  ============
    [IPU1-0]     82.909656 s:
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]     89.215335 s:
    [IPU1-0]     89.215488 s:
    [IPU1-0]
    [IPU1-0]  ISS Usecases (TDA3x ONLY)
    [IPU1-0]  ---------------------------
    [IPU1-0]  1: 1CH ISS capture + ISS ISP + ISS LDC+VTNF + Display
    [IPU1-0]  2: 4CH ISS capture + ISS ISP + Simcop + Surround View (DSP1) +  Display
    [IPU1-0]  4: 3D SRV 4CH ISS capture + ISS ISP + DeWarp + Synthesis (DSP1) + Display
    [IPU1-0]  5: Surround View Calibration
    [IPU1-0]  6: 3D + 2D SRV 4CH ISS capture + ISS ISP + DeWarp + Synthesis (DSP1) + Display
    [IPU1-0]  c: 4 Channel (2 ch per CSI2 Inst) ISS Capture (OV2775 Sensor) Display
    [IPU1-0]  d: 1 Channel Capture + RGBIR +ISP + Display
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]     92.826724 s:
    [IPU1-0]     92.826785 s:  Entered Chains_issIspSimcop_Display
    [IPU1-0]     94.587750 s:  ISSCAPTURE: Create in progress !!!
    [IPU1-0]     94.589184 s:  UTILS: DMA: Allocated CH (TCC) = 48 (48)
    [IPU1-0]     94.589336 s:  UTILS: DMA: 0 of 1: Allocated PaRAM = 48 (0x63304800)
    [IPU1-0]     94.589611 s:  ISSCAPTURE: Create Done !!!
    [IPU1-0]     94.589733 s:  ISSM2MISP: Create in progress !!!
    [IPU1-0]     94.590770 s:  UTILS: DMA: Allocated CH (TCC) = 49 (49)
    [IPU1-0]     94.590892 s:  UTILS: DMA: 0 of 1: Allocated PaRAM = 49 (0x63304820)
    [IPU1-0]     94.594979 s:  ISSM2MISP: Memory requirement is 14268288 bytes.
    [IPU1-0]     94.595101 s:  ISSM2MISP: Memory provided by user is 15305088 bytes.
    [IPU1-0]     94.595193 s:  ISSM2MISP: Unused Memory is 1036800 bytes.
    [IPU1-0]     94.595254 s:  ISSM2MISP: Create Done !!!
    [IPU1-0]     94.595437 s:  ALGORITHM: Create in progress (algId = 6) !!!
    [IPU1-0]     94.596016 s:  ALGORITHM: Create Done (algId = 6) !!!
    [IPU1-0]     94.596504 s:  ISS Resizer: Create in progress !!!
    [IPU1-0]     94.601537 s:  ISS RESIZER: Create Done !!!
    [IPU1-0]     94.601689 s:  DISPLAY: Create in progress !!!
    [IPU1-0]     94.602238 s:  DISPLAY: Create Done !!!
    [IPU1-0]     94.602421 s:  ALGORITHM: Create in progress (algId = 3) !!!
    [IPU1-0]     94.620386 s:  ALG_ISS_AEWB: Memory requirement is 886716 bytes.
    [IPU1-0]     94.620508 s:  ALG_ISS_AEWB: Memory provided by user is 917504 bytes.
    [IPU1-0]     94.620600 s:  ALG_ISS_AEWB: Unused Memory is 30788 bytes.
    [IPU1-0]     94.620661 s:  ALGORITHM: Create Done (algId = 3) !!!
    [IPU1-0]     94.620844 s:  ISSM2MSIMCOP: Create in progress !!!
    [IPU1-0]     94.621820 s:  UTILS: DMA: Allocated CH (TCC) = 50 (50)
    [IPU1-0]     94.621942 s:  UTILS: DMA: 0 of 1: Allocated PaRAM = 50 (0x63304840)
    [IPU1-0]     94.623467 s:  ISSM2MSIMCOP: Create Done !!!
    [IPU1-0]     94.623619 s:  DISPLAY: Create in progress !!!
    [IPU1-0]     94.624168 s:  DISPLAY: Create Done !!!
    [IPU1-0]     94.624778 s:  GRPXSRC: Create in progress !!!
    [IPU1-0]     96.161440 s:  GRPXSRC: Create Done !!!
    [IPU1-0]     96.161898 s:  DISPLAY: Create in progress !!!
    [IPU1-0]     96.162447 s:  DISPLAY: Create Done !!!
    [IPU1-0]     96.162752 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022
    [IPU1-0]     96.162874 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 243936 B (238 KB)
    [IPU1-0]     96.163026 s:  SYSTEM: Heap = SR_OCMC              @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
    [IPU1-0]     96.163179 s:  SYSTEM: Heap = SR_DDR_CACHED        @ 0x88583000, Total size = 368037888 B (350 MB), Free size = 314142208 B (299 MB)
    [IPU1-0]     96.163392 s:  SYSTEM: Heap = SR_DDR_NON_CACHED    @ 0xbfc00000, Total size = 127872 B (0 MB), Free size = 106368 B (0 MB)
    [IPU1-0]     96.170194 s:  QSPI Read Started, please wait!
    [IPU1-0]     96.170438 s:  QSPI Read Completed Sucessfully
    [IPU1-0]     96.172268 s:  CHAINS: DCC Tag ID check failed for QSPI
    [IPU1-0]     96.172451 s:  CHAINS: Using DCC Profile from Driver
    [IPU1-0]     96.183309 s:  *** UTILS: CPU KHz = 20000 Khz ***
    [IPU1-0]     96.183919 s:
    [IPU1-0]     96.184194 s:  i2cMdSubmitChan: i2c4 transfer to slave address 0x3d failed
    [IPU1-0]     96.184316 s: src/bsp_deviceI2c.c @ Line 580:
    [IPU1-0]     96.184682 s:  I2C4: DEV 0x3d: WR 0x0c = 0x0f ... ERROR !!!
    [IPU1-0]     96.184773 s: src/bsp_deviceI2c.c @ Line 602:
    [IPU1-0]     96.184865 s:  I2C4: Error timeout 1 ms!!!
    [IPU1-0]     96.184926 s: Could not configure deserializer !!!
    [IPU1-0]     96.184987 s: configDeserializer failed!!!
    [IPU1-0]     96.185048 s: Power ON failed!!!
    [IPU1-0]     96.185109 s:  Assertion @ Line: 388 in C:/ti/VISION_SDK/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/apps/src/rtos/iss/src/common/app_util_iss.c: status == 0 : failed !!!
    [IPU1-0]     96.185872 s:  Assertion @ Line: 388 in C:/ti/VISION_SDK/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/apps/src/rtos/iss/src/common/app_util_iss.c: status == 0 : failed !!!
    [IPU1-1]     96.164094 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [IPU1-1]     96.164246 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 655360 B (640 KB), Free size = 645280 B (630 KB)
    [HOST  ]     96.164795 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [HOST  ]     96.164795 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 6291456 B (6144 KB), Free size = 6247792 B (6101 KB)
    [DSP1  ]     96.165009 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [DSP1  ]     96.165039 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
    [DSP1  ]     96.165070 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516416 B (504 KB)
    [DSP2  ]     96.165314 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [DSP2  ]     96.165344 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
    [DSP2  ]     96.165375 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516416 B (504 KB)
    [EVE1  ]     96.166015 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [EVE1  ]     96.166290 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
    [EVE1  ]     96.166748 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254248 B (248 KB)
    [EVE2  ]     96.167907 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [EVE2  ]     96.168151 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
    [EVE2  ]     96.168639 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254248 B (248 KB)
    [IPU2  ]     96.169676 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [IPU2  ]     96.169828 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 252016 B (246 KB)
    Please ignore the steps suggested in the previous post because there is no SD boot in TDA3xx.
    1) Are you flashing all images to the corresponding core?
    2) After flashing the images, please free run all core.
    Gaviraju
  • Gaviraju,
    Currently I am booting it of TDA2Px, Will this work(SD boot) on TDA2Px?
    Yes, It will support SD boot.
    Please follow the TDA2px user-guide instruction instead of TDA3x user-guide.
    file:///C:/PROCESSOR_SDK_VISION_03_08_00_00/vision_sdk/docs/UserGuides/VisionSDK_UserGuide_TDA2px.pdf
    Gaviraju
    Yeah, I check the user guide also but they didn't specified any other details apart form the build commands to generate appimage and MLO.
    The below error noticed from the log
    This is related to camera sensor error, so
    1) Make sure the camera is connected properly.
    2) There are two camera sensor "OV2775" & "OV2775-TIDA1130", which one is connected to the board?
    Gaviraju
  • Hi Gaviraju,
    I am connecting OV2775-TIDA1130 to fusion1 board csi0 port.
  • Hi Sri-Ram,
    I am bit confused. Are you trying to bringup this camera on J6+ or on J7?
    The thread discussion seems to be for J6+, but the question is for J7.
    Are you first trying to bring it up on J6+?
    On the I2c error, it seems it is not able to communicate with UB960, write to address 0x3d is failing. So is fusion board powered on? There is a separate 12V power cable that goes from J6+ to fusion board. Please refer to user guide for more details.
    Rgds,
    Brijesh
  • Hi Brijesh,
    I want to bring-up the camera interface(OV2775 TIDA-1130) on J7 for which I pull out the OV2775 iss sensor configurations from Vision SDK and integrated with FPD device library of J7and able to verify the read write access of the OV2775 camera sensor using Fusion1 interfaced with J7, But even after the read write access verification I could not able to capture any camera data(Using J7 IMX390 camera capture driver example where IMX390 configurations are replaced with OV2775 sensor configurations).
    Currently I am using vision_sdk_03_08. So, to check for any porting misses I want to try verifying the OV2775 TIDA-1130 on J6(i.e; TDA2Px), Able to build and boot from SD card the below is the complete log, At the end of the log you can see deserilizer register configuration failing. We are supplying power from the J6 board. You can check the below attached images for power status of fusion1 and hardware setup.
    TDA2Px SBL Boot
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
  • Hi Brijesh,
    TDA2Px SBL Boot
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]
    [IPU1-0]  x: Exit
    [IPU1-0]
    [IPU1-0]
