Hi Forum;
We are working on custom board which based on AM572x Evaluation Module. There is some hardware difference from AM572x Evaluation Module. The biggest difference we have 1 GB DDR3L RAM (2x512MiB) only on EMIF1. After linux loaded,we verified DDR3s with Memtester. The relevant board.c file have been configured. Device tree files have been configured both in u-boot and linux. Other interfaces except HDMI seem to work properly.
Boot Option: SD Card
Debug Option: UART3 (with TERATERM)
Linux Version: 4.19.79-g77dfab56c6
SDK Version: v06.03
Rootfs: tisdk-rootfs-image-am57xx-evm
We disabled ipu1 and ipu2 because they gave crash errors. The crash message is:
- remoteproc remoteproc0: crash detected in 55020000.ipu: type watchdog
Because of that remotproc error, we disabled ipu1 and ipu2.
Maybe we think it may be misuse in lisa maps. Our lisa map configuration is:
static const struct dmm_lisa_map_regs AM572x_DDR3L_532MHz_TI_AM5728_PIJET_dmm_regs = {
//.dmm_lisa_map_0 = 0x00000000,
//.dmm_lisa_map_1 = 0x00000000,
.dmm_lisa_map_2 = 0x80600100,
.dmm_lisa_map_3 = 0xff020100,
.is_ma_present = 0x1};
After u-boot, before the kernel we are sending these boot arguments;
- setenv bootargs console=ttyS2,115200 root=/dev/mmcblk0p2 rw rootwait rootfs=ext4 video=mxcfb0:dev=hdmi,1280x800M@60,if=RGB24
Our kernel output:
Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.19.79-g77dfab56c6 (oe-user@oe-host) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 SMP PREEMPT Sun Jan 5 02:56:25 UTC 2020 [ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [ 0.000000] OF: fdt: Machine model: TI AM5728 PIJET [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB [ 0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB [ 0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatible id shared-dma-pool [ 0.000000] cma: Reserved 24 MiB at 0x00000000be400000 [ 0.000000] OMAP4: Map 0x00000000bfd00000 to (ptrval) for dram barrier [ 0.000000] Hit pending asynchronous external abort (FSR=0x00001211) during first unmask, this is most likely caused by a firmware/bootloader bug. [ 0.000000] DRA752 ES2.0 [ 0.000000] random: get_random_bytes called from start_kernel+0xb4/0x470 with crng_init=0 [ 0.000000] percpu: Embedded 15 pages/cpu s32396 r8192 d20852 u61440 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 210496 [ 0.000000] Kernel command line: console=ttyS2,115200 root=/dev/mmcblk0p2 rw rootwait rootfs=ext4 [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 724672K/848896K available (10240K kernel code, 335K rwdata, 2800K rodata, 2048K init, 269K bss, 25920K reserved, 98304K cma-reserved, 234496K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (12256 kB) [ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (2048 kB) [ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 336 kB) [ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 270 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] Tasks RCU enabled. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] OMAP clockevent source: timer1 at 32786 Hz [ 0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns [ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns [ 0.000018] Switching to timer-based delay loop, resolution 162ns [ 0.000293] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns [ 0.000303] OMAP clocksource: 32k_counter at 32768 Hz [ 0.000732] Console: colour dummy device 80x30 [ 0.000780] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475) [ 0.000798] pid_max: default: 32768 minimum: 301 [ 0.000924] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000940] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001520] CPU: Testing write buffer coherency: ok [ 0.001559] CPU0: Spectre v2: using ICIALLU workaround [ 0.001788] /cpus/cpu@0 missing clock-frequency property [ 0.001808] /cpus/cpu@1 missing clock-frequency property [ 0.001821] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.059918] Setting up static identity map for 0x80200000 - 0x80200060 [ 0.079927] rcu: Hierarchical SRCU implementation. [ 0.100121] EFI services will not be available. [ 0.119984] smp: Bringing up secondary CPUs ... [ 0.200308] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.200313] CPU1: Spectre v2: using ICIALLU workaround [ 0.200435] smp: Brought up 1 node, 2 CPUs [ 0.200448] SMP: Total of 2 processors activated (24.59 BogoMIPS). [ 0.200457] CPU: All CPU(s) started in HYP mode. [ 0.200464] CPU: Virtualization extensions available. [ 0.200955] devtmpfs: initialized [ 0.217369] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0 [ 0.217635] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.217654] futex hash table entries: 512 (order: 3, 32768 bytes) [ 0.219404] pinctrl core: initialized pinctrl subsystem [ 0.219936] DMI not present or invalid. [ 0.220257] NET: Registered protocol family 16 [ 0.221391] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.222343] omap_hwmod: l3_main_2 using broken dt data from ocp [ 0.324146] wkupaon_cm:clk:0068:0: failed to disable [ 0.423686] cpuidle: using governor ladder [ 0.423721] cpuidle: using governor menu [ 0.433920] OMAP GPIO hardware version 0.1 [ 0.458708] No ATAGs? [ 0.458784] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.458798] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.459639] OMAP DMA hardware revision 0.0 [ 0.471141] edma 43300000.edma: memcpy is disabled [ 0.474600] edma 43300000.edma: TI EDMA DMA engine driver [ 0.481798] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported) [ 0.485430] omap-iommu 40d01000.mmu: 40d01000.mmu registered [ 0.485606] omap-iommu 40d02000.mmu: 40d02000.mmu registered [ 0.485863] omap-iommu 58882000.mmu: 58882000.mmu registered [ 0.486101] omap-iommu 55082000.mmu: 55082000.mmu registered [ 0.486476] omap-iommu 41501000.mmu: 41501000.mmu registered [ 0.486665] omap-iommu 41502000.mmu: 41502000.mmu registered [ 0.486986] iommu: Adding device 40800000.dsp to group 0 [ 0.487212] iommu: Adding device 41000000.dsp to group 3 [ 0.488414] SCSI subsystem initialized [ 0.489472] palmas 0-0058: Irq flag is 0x00000008 [ 0.517802] palmas 0-0058: Muxing GPIO 2b, PWM 0, LED 0 [ 0.519367] SMPS12: supplied by regulator-dummy [ 0.520968] SMPS3: supplied by regulator-dummy [ 0.522531] SMPS45: supplied by regulator-dummy [ 0.524251] SMPS6: supplied by regulator-dummy [ 0.525570] SMPS7: supplied by regulator-dummy [ 0.526884] SMPS8: supplied by regulator-dummy [ 0.528077] SMPS9: supplied by regulator-dummy [ 0.528723] LDO1: supplied by regulator-dummy [ 0.529078] random: fast init done [ 0.541228] LDO2: supplied by regulator-dummy [ 0.551100] LDO3: supplied by regulator-dummy [ 0.561113] LDO4: supplied by regulator-dummy [ 0.571134] LDO5: supplied by regulator-dummy [ 0.571793] LDO6: supplied by regulator-dummy [ 0.572441] LDO7: supplied by regulator-dummy [ 0.573091] LDO8: supplied by regulator-dummy [ 0.573759] LDO9: supplied by regulator-dummy [ 0.581160] LDOLN: supplied by regulator-dummy [ 0.591174] LDOUSB: supplied by regulator-dummy [ 0.603071] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz [ 0.603686] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz [ 0.604061] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz [ 0.604441] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz [ 0.604620] media: Linux media interface: v0.10 [ 0.604658] videodev: Linux video capture interface: v2.00 [ 0.604733] pps_core: LinuxPPS API ver. 1 registered [ 0.604743] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.604763] PTP clock support registered [ 0.604793] EDAC MC: Ver: 3.0.0 [ 0.605585] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400 [ 0.605837] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400 [ 0.620783] Advanced Linux Sound Architecture Driver Initialized. [ 0.621581] clocksource: Switched to clocksource arch_sys_counter [ 0.630334] NET: Registered protocol family 2 [ 0.630941] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes) [ 0.630971] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 0.631034] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 0.631161] TCP: Hash tables configured (established 8192 bind 8192) [ 0.631244] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.631279] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.631410] NET: Registered protocol family 1 [ 0.651871] RPC: Registered named UNIX socket transport module. [ 0.651882] RPC: Registered udp transport module. [ 0.651890] RPC: Registered tcp transport module. [ 0.651899] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.652914] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 0.653105] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available [ 0.654079] Initialise system trusted keyrings [ 0.654224] workingset: timestamp_bits=14 max_order=18 bucket_order=4 [ 0.659459] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.659952] NFS: Registering the id_resolver key type [ 0.659974] Key type id_resolver registered [ 0.659983] Key type id_legacy registered [ 0.660024] ntfs: driver 2.1.32 [Flags: R/O]. [ 0.661751] Key type asymmetric registered [ 0.661763] Asymmetric key parser 'x509' registered [ 0.661815] bounce: pool size: 64 pages [ 0.661849] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.661860] io scheduler noop registered [ 0.661869] io scheduler deadline registered [ 0.661967] io scheduler cfq registered (default) [ 0.661978] io scheduler mq-deadline registered [ 0.661987] io scheduler kyber registered [ 0.667662] pinctrl-single 4a003400.pinmux: 282 pins, size 1128 [ 0.674828] vdd_3v3: supplied by regen1 [ 0.675061] aic_dvdd_fixed: supplied by vdd_3v3 [ 0.675127] vtt_fixed: supplied by smps3 [ 0.723047] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.726631] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 43, base_baud = 3000000) is a 8250 [ 0.727604] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 44, base_baud = 3000000) is a 8250 [ 1.693176] console [ttyS2] enabled [ 1.697601] 48422000.serial: ttyS7 at MMIO 0x48422000 (irq = 45, base_baud = 3000000) is a 8250 [ 1.707291] 4ae2b000.serial: ttyS9 at MMIO 0x4ae2b000 (irq = 46, base_baud = 3000000) is a 8250 [ 1.718122] omap_rng 48090000.rng: Random Number Generator ver. 20 [ 1.718332] hwrng: no data available [ 1.728114] omapdss_dss 58000000.dss: Linked as a consumer to regulator.20 [ 1.735162] DSS: OMAP DSS rev 6.1 [ 1.741367] omapdss_hdmi5 58040000.encoder: Linked as a consumer to regulator.14 [ 1.748896] omapdss_hdmi5 58040000.encoder: Dropping the link to regulator.14 [ 1.769014] brd: module loaded [ 1.778727] loop: module loaded [ 1.786044] libphy: Fixed MDIO Bus: probed [ 1.851613] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000 [ 1.859310] libphy: 48485000.mdio: probed [ 1.875892] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver Micrel KSZ9031 Gigabit PHY [ 1.886121] cpsw 48484000.ethernet: Detected MACID = fc:69:47:f0:92:16 [ 1.892761] cpsw 48484000.ethernet: initialized cpsw ale version 1.4 [ 1.899145] cpsw 48484000.ethernet: ALE Table size 1024 [ 1.904450] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies) [ 1.912960] i2c /dev entries driver [ 1.919767] gpio-fan gpio_fan: GPIO fan initialized [ 1.925830] tmp102 0-0048: initialized [ 1.932558] cpu cpu0: Linked as a consumer to regulator.4 [ 1.938065] cpu cpu0: Linked as a consumer to regulator.27 [ 1.945238] sdhci: Secure Digital Host Controller Interface driver [ 1.951446] sdhci: Copyright(c) Pierre Ossman [ 1.956434] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.963197] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22) [ 1.972052] sdhci-omap 4809c000.mmc: Got CD GPIO [ 1.976852] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.26 [ 1.983891] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.11 [ 1.990757] sdhci-omap 4809c000.mmc: Dropping the link to regulator.11 [ 1.997390] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.1 [ 2.004311] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.11 [ 2.011244] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_3_3v mode [ 2.044304] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA [ 2.052258] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.1 [ 2.059097] sdhci-omap 480b4000.mmc: Dropping the link to regulator.1 [ 2.065741] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.1 [ 2.098660] mmc1: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA [ 2.105903] mmc0: host does not support reading read-only switch, assuming write-enable [ 2.113983] ledtrig-cpu: registered to indicate activity on CPUs [ 2.120048] mmc0: Problem switching card into high-speed mode! [ 2.126085] mmc0: new SDHC card at address 0001 [ 2.132514] mmcblk0: mmc0:0001 SD08G 7.52 GiB [ 2.138246] NET: Registered protocol family 10 [ 2.143377] Segment Routing with IPv6 [ 2.147098] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 2.153323] mmcblk0: p1 p2 [ 2.153711] NET: Registered protocol family 17 [ 2.161039] Key type dns_resolver registered [ 2.165591] Registering SWP/SWPB emulation handler [ 2.170484] omap_voltage_late_init: Voltage driver support not added [ 2.176940] Power Management for TI OMAP4+ devices. [ 2.183003] Loading compiled-in X.509 certificates [ 2.189597] mmc1: new DDR MMC card at address 0001 [ 2.205252] mmcblk1: mmc1:0001 Q2J55L 7.09 GiB [ 2.210389] mmcblk1boot0: mmc1:0001 Q2J55L partition 1 16.0 MiB [ 2.216886] mmcblk1boot1: mmc1:0001 Q2J55L partition 2 16.0 MiB [ 2.223116] dmm 4e000000.dmm: workaround for errata i878 in use [ 2.223213] mmcblk1rpmb: mmc1:0001 Q2J55L partition 3 4.00 MiB, chardev (244:0) [ 2.236760] dmm 4e000000.dmm: initialized all PAT entries [ 2.243295] omapdss_hdmi5 58040000.encoder: Linked as a consumer to regulator.14 [ 2.250791] omapdss_hdmi5 58040000.encoder: Dropping the link to regulator.14 [ 2.259291] omapdss_hdmi5 58040000.encoder: Linked as a consumer to regulator.14 [ 2.267091] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops) [ 2.275102] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops) [ 2.283819] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 2.290459] [drm] No driver support for vblank timestamp query. [ 2.296429] [drm] Cannot find any crtc or sizes [ 2.301672] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 0 [ 2.309228] hctosys: unable to open rtc device (rtc0) [ 2.314837] ALSA device list: [ 2.317814] No soundcards found. [ 2.322534] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem [ 2.346454] EXT4-fs (mmcblk0p2): warning: mounting fs with errors, running e2fsck is recommended [ 2.380558] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 2.388754] VFS: Mounted root (ext3 filesystem) on device 179:2. [ 2.410754] devtmpfs: mounted [ 2.414881] Freeing unused kernel memory: 2048K [ 2.419558] Run /sbin/init as init process [ 3.129911] systemd[1]: System time before build time, advancing clock. [ 3.173365] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid) [ 3.195088] systemd[1]: Detected architecture arm. Welcome to Arago 2019.11! [ 3.242886] systemd[1]: Set hostname to <am57xx-evm>. [ 3.371658] [drm] Cannot find any crtc or sizes [ 3.560823] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling. [ 3.578084] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.) [ 3.898655] random: systemd: uninitialized urandom read (16 bytes read) [ 3.905872] systemd[1]: Listening on initctl Compatibility Named Pipe. [ OK ] Listening on initctl Compatibility Named Pipe. [ 3.941741] random: systemd: uninitialized urandom read (16 bytes read) [ 3.951263] systemd[1]: Created slice system-getty.slice. [ OK ] Created slice system-getty.slice. [ 3.982344] random: systemd: uninitialized urandom read (16 bytes read) [ 3.989428] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 4.032508] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ 4.071833] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Forward Password Requests to Wall Directory Watch. [ OK ] Reached target Paths. [ OK ] Created slice system-serial\x2dgetty.slice. [ OK ] Listening on udev Control Socket. [ OK ] Listening on Journal Socket (/dev/log). [ OK ] Reached target Remote File Systems. [ OK ] Created slice User and Session Slice. [ OK ] Reached target Slices. [ OK ] Listening on udev Kernel Socket. [ OK ] Listening on Process Core Dump Socket. [ OK ] Reached target Swap. [ OK ] Listening on Journal Socket. Mounting POSIX Message Queue File System... Starting Journal Service... Starting Load Kernel Modules... [ 4.633271] cmemk: loading out-of-tree module taints kernel. [ 4.639862] CMEMK module: reference Linux version 4.19.79 Starting udev Coldplug all Devices... [ 4.649151] allocated heap buffer 0x40500000 of size 0x100000 [ 4.661313] cmemk initialized Mounting Kernel Debug File System... Mounting Temporary Directory (/tmp)... [ 4.740721] cryptodev: driver 1.9 loaded. [ OK ] Started Hardware RNG Entropy Gatherer Daemon. [ 4.789106] random: crng init done [ 4.792580] random: 7 urandom warning(s) missed due to ratelimiting Starting Remount Root and Kernel File Systems... [ OK ] Started Journal Service. [ 4.834134] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [ 4.851176] usbcore: registered new interface driver usbfs [ 4.857594] usbcore: registered new interface driver hub [[ 4.865879] usbcore: registered new device driver usb OK ] Mounted POSIX Message Queue File System. [ 4.896200] usbcore: registered new interface driver ftdi_sio [ 4.902055] usbserial: USB Serial support registered for FTDI USB Serial Device [ OK ] Mounted Kernel Debug File System. [ OK ] Started Load Kernel Modules. [ OK ] Mounted Temporary Directory (/tmp). [ OK ] Started Remount Root and Kernel File Systems. Starting Create Static Device Nodes in /dev... Starting Apply Kernel Variables... Mounting Kernel Configuration File System... Starting Flush Journal to Persistent Storage... [ OK ] Started Apply Kernel Variables. [ OK ] Started Create Static Device Nodes in /dev. [ OK ] Mounted Kernel Configuration File System. [ 5.239384] systemd-journald[93]: Received request to flush runtime journal from PID 1 [ OK ] Reached target Local File Systems (Pre). [ OK ] Reached target Containers. Mounting /var/volatile... Mounting /media/ram... Starting udev Kernel Device Manager... [ OK ] Started udev Coldplug all Devices. [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Mounted /var/volatile. [ OK ] Mounted /media/ram. Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... [ OK ] Started udev Kernel Device Manager. [ OK ] Started Load/Save Random Seed. [ OK ] Started Create Volatile Files and Directories. Starting Network Time Synchronization... Starting Update UTMP about System Boot/Shutdown... Starting Network Service... [ 5.792064] omap-rproc 40800000.dsp: ignoring dependency for device, assuming no driver [ 5.800241] omap-rproc 40800000.dsp: ignoring dependency for device, assuming no driver [ OK ] Started Update UTMP about System Boot/Shutdown. [ 5.917878] omap-rproc 40800000.dsp: assigned reserved memory node dsp1-memory@99000000 [ 5.982397] remoteproc remoteproc0: 40800000.dsp is available [ OK ] Found device /dev/ttyS2. [ 6.029415] omap-rproc 41000000.dsp: ignoring dependency for device, assuming no driver [ OK ] Started Network Service. Starting Wait for Network to be Configured... Starting Network Name Resolution... [ 6.141795] omap-rproc 41000000.dsp: ignoring dependency for device, assuming no driver [ 6.194061] omap-rproc 41000000.dsp: assigned reserved memory node dsp2-memory@9f000000 [ 6.227030] remoteproc remoteproc1: 41000000.dsp is available [ 6.308597] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: rtc core: registered 48070000.i2c:tps659038@58:tps659038_rtc as rtc1 [ 6.443463] rtc-ds1307 2-006f: registered as rtc0 [ 6.504152] omap_rtc 48838000.rtc: registered as rtc2 [ 6.517232] Driver for 1-wire Dallas network protocol. [ 6.523477] at24 0-0050: 4096 byte 24c32 EEPROM, writable, 1 bytes/write [ 6.641602] omap_hdq 480b2000.1w: OMAP HDQ Hardware Rev 0.:. Driver in Interrupt mode [ 6.862240] w1_master_driver w1_bus_master1: Attaching one wire slave 01.000000000000 crc 3d [ 6.878977] w1_master_driver w1_bus_master1: Family 1 for 01.000000000000.3d is not registered. [ OK ] Started Network Time Synchronization. [ OK ] Started Network Name Resolution. [ OK ] Reached target Network. [ OK ] Reached target Host and Network Name Lookups. [ 7.165178] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2 [ 7.172017] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3 [ 7.180772] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ OK ] Reached target System Time Synchronized. [ 7.191656] omap-des 480a5000.des: will run requests pump with realtime priority [ OK ] Reached target System Initialization. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Started Daily Cleanup of Temporary Directories. [ 7.483179] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3 [ 7.489142] omap-aes 4b500000.aes: will run requests pump with realtime priority [ 7.498653] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3 [ 7.505257] omap-aes 4b700000.aes: will run requests pump with realtime priority [ 7.665537] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin [ 7.690565] [drm] Initialized pvr 1.17.4948957 20110701 for 56000000.gpu on minor 1 [ OK ] Listening on D-Bus System Message Bus Socket. [ 7.901757] vpe 489d0000.vpe: Device registered as /dev/video0 [ OK ] Listening on RPCbind Server Activation Socket. [ 8.092916] ahci 4a140000.sata: controller can't do 64bit DMA, forcing 32bit [ 8.111031] ahci 4a140000.sata: forcing port_map 0x0 -> 0x1 [ 8.129701] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode [ 8.141244] ahci 4a140000.sata: flags: ncq sntf pm led clo only pmp pio slum part ccc apst [ 8.171132] scsi host0: ahci [ 8.174510] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 83 [ OK ] Listening on dropbear.socket. [ OK ] Reached target Sockets. [ OK ] Reached target Basic System. Starting Lightning Fast Webserver With Light System Requirements... [ 8.430990] omap-hdmi-audio omap-hdmi-audio.0.auto: snd-soc-dummy-dai <-> 58040000.encoder mapping ok Starting rc.pvr.service... [ 8.456364] omap-hdmi-audio omap-hdmi-audio.0.auto: ASoC: no DMI vendor name! Starting TI MultiCore Tools Daemon... [ 8.515887] ata1: SATA link down (SStatus 0 SControl 300) [ OK ] Started Periodic Command Scheduler. Starting Enable and configure wl18xx bluetooth stack... [ OK ] Started Redis In-Memory Data Store. Starting Permit User Sessions... Starting Avahi mDNS/DNS-SD Stack... Starting Print notice about GPLv3 packages... Starting RPC Bind Service... [ OK ] Started Job spooling tools. [ OK ] Started Daily rotation of log files. [ OK ] Reached target Timers. [ OK ] Started D-Bus System Message Bus. Starting Simple Network Management Protocol (SNMP) Daemon.... Starting Login Service... Starting Reboot and dump vmcore via kexec... Starting TI IPC Daemon... [ OK ] Started Permit User Sessions. [ OK ] Started Serial Getty on ttyS2. [ OK ] Started Getty on tty1. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... [ 9.989788] remoteproc remoteproc0: powering up 40800000.dsp [ 9.995501] remoteproc remoteproc0: Booting fw image dra7-dsp1-fw.xe66, size 20483260 [ 10.008798] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0 [ 10.014723] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0 [ 10.043240] net eth0: initializing cpsw version 1.15 (0) [ 10.064393] virtio_rpmsg_bus virtio0: rpmsg host is online [ 10.071141] remoteproc remoteproc0: registered virtio0 (type 7) [ 10.086232] remoteproc remoteproc0: remote processor 40800000.dsp is now up [ 10.172241] Micrel KSZ9031 Gigabit PHY 48485000.mdio:01: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=48485000.mdio:01, irq=POLL) [ 10.189978] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 10.525470] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ] [ 11.033664] remoteproc remoteproc1: powering up 41000000.dsp [ 11.045200] remoteproc remoteproc1: Booting fw image dra7-dsp2-fw.xe66, size 20483260 [ 11.071009] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0 [ 11.076972] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0 [ 11.189062] virtio_rpmsg_bus virtio1: rpmsg host is online [ 11.198745] remoteproc remoteproc1: registered virtio1 (type 7) [ 11.220937] remoteproc remoteproc1: remote processor 41000000.dsp is now up [ OK ] Started Login Service. [ OK ] Started Lightning Fast Webserver With Light System Requirements. [ OK ] Started rc.pvr.service. [ OK ] Started TI MultiCore Tools Daemon. [ OK ] Started Enable and configure wl18xx bluetooth stack. [ OK ] Started RPC Bind Service. [ OK ] Started Reboot and dump vmcore via kexec. [ OK ] Started TI IPC Daemon. [ OK ] Started Synchronize System and HW clocks. [ 12.180408] EXT4-fs error (device mmcblk0p2): ext4_mb_generate_buddy:747: group 32, block bitmap and bg descriptor inconsistent: 3388 vs 3387 free clusters [ 12.550402] EXT4-fs error (device mmcblk0p2): ext4_mb_generate_buddy:747: group 51, block bitmap and bg descriptor inconsistent: 3978 vs 3979 free clusters [ 12.589549] EXT4-fs error (device mmcblk0p2): ext4_mb_generate_buddy:747: group 52, block bitmap and bg descriptor inconsistent: 5415 vs 5414 free clusters [ 12.644780] dwc3 48890000.usb: Failed to get clk 'ref': -2 [ 12.655280] dwc3 488d0000.usb: Failed to get clk 'ref': -2 [ 12.676118] OF: graph: no port node found in /ocp/ocp2scp@4a080000/phy@4a085000 [ 12.698550] remoteproc remoteproc2: 4b234000.pru is available [ 12.716508] pru-rproc 4b234000.pru: PRU rproc node pru@4b234000 probed successfully [ 12.725794] remoteproc remoteproc3: 4b238000.pru is available [ 12.731645] pru-rproc 4b238000.pru: PRU rproc node pru@4b238000 probed successfully [ 12.740080] remoteproc remoteproc4: 4b2b4000.pru is available [ 12.745974] pru-rproc 4b2b4000.pru: PRU rproc node pru@4b2b4000 probed successfully [ 12.754555] remoteproc remoteproc5: 4b2b8000.pru is available [ 12.760444] pru-rproc 4b2b8000.pru: PRU rproc node pru@4b2b8000 probed successfully [ 12.855229] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 12.861514] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1 [ 12.870958] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010 [ 12.882793] xhci-hcd xhci-hcd.1.auto: irq 177, io mem 0x48890000 [ 12.889168] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [ 12.898256] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 12.905759] usb usb1: Product: xHCI Host Controller [ 12.910658] usb usb1: Manufacturer: Linux 4.19.79-g77dfab56c6 xhci-hcd [ 12.917676] usb usb1: SerialNumber: xhci-hcd.1.auto [ 12.923368] hub 1-0:1.0: USB hub found [ 12.927188] hub 1-0:1.0: 1 port detected [ 12.931440] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 12.938678] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2 [ 12.946974] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed [ 12.954144] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 12.962750] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19 [ 12.971064] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 12.978792] usb usb2: Product: xHCI Host Controller [ 12.983970] usb usb2: Manufacturer: Linux 4.19.79-g77dfab56c6 xhci-hcd [ 12.990530] usb usb2: SerialNumber: xhci-hcd.1.auto [ 12.996265] hub 2-0:1.0: USB hub found [ 13.000058] hub 2-0:1.0: 1 port detected [ OK ] Started Simple Network Management Protocol (SNMP) Daemon.. _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org am57xx-evm ttyS2 Arago 2019.11 am57xx-evm ttyS2 am57xx-evm login: *************************************************************** *************************************************************** NOTICE: This file system contains the following GPLv3 packages: autoconf bash-dev bash bc binutils-dev binutils bison-dev bison cifs-utils cpio cpp-symlinks cpp dosfstools elfutils-dev elfutils findutils g++-symlinks g++ gawk gcc-symlinks gcc gdb gdbc6x gdbserver gettext glmark2 gstreamer1.0-libav gzip hidapi libasm1 libbfd libcairo-perf-utils libdw1 libelf1 libgdbm-compat4 libgdbm-dev libgdbm6 libgettextlib libgettextsrc libgmp10 libidn2-0 libmavconn libmpc3 libmpfr6 libreadline-dev libreadline7 libunistring2 m4-dev m4 make mavlink mavros-extras mavros-msgs mavros nettle parted pdm-anomaly-detection socketcan-interface swig-dev swig which If you do not wish to distribute GPLv3 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** ***************************************************************
Our u-boot am57xx_evm_config file:
CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_OMAP54XX=y CONFIG_TARGET_AM57XX_EVM=y CONFIG_DRA7_DSPEVE_OPP_HIGH=y CONFIG_DRA7_IVA_OPP_HIGH=y CONFIG_DRA7_GPU_OPP_HIGH=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_ARMV7_LPAE=y CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL_LOAD_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="androidboot.serialno=${serial#} console=ttyS2,115200 androidboot.console=ttyS2 androidboot.hardware=beagle_x15board" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DMA=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_OS_BOOT=y CONFIG_SPL_DM_RESET=y CONFIG_SPL_REMOTEPROC=y CONFIG_SPL_SPI_LOAD=y CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_CMD_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_PMIC is not set CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am5728-custom" CONFIG_OF_LIST="am5728-custom" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_DWC_AHCI=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_FASTBOOT_BUF_SIZE=0x2F000000 CONFIG_FASTBOOT_USB_DEV=1 CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=1 CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_MISC=y CONFIG_FS_LOADER=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_DRIVER_TI_CPSW=y CONFIG_PHY=y CONFIG_PIPE3_PHY=y CONFIG_OMAP_USB2_PHY=y CONFIG_DM_PMIC=y CONFIG_PMIC_PALMAS=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_PALMAS=y CONFIG_REMOTEPROC_TI_IPU=y CONFIG_DM_RESET=y CONFIG_RESET_DRA7=y CONFIG_DM_SCSI=y CONFIG_DM_SERIAL=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_TI_QSPI=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GADGET=y CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_CLK=y CONFIG_CLK_CDCE9XX=y
Our linux tisdk_am57xx-evm_defconfig file:
4643.tisdk_am57xx-evm_defconfig.txt
After loading linux kernel, when we plug-in HDMI cable to screen on our custom board, we regularly get errors on Teraterm console. I attached related teraterm output file which only includes hdmi errors.
root@am57xx-evm:~# [ 100.811223] omapdss error: HDMI I2C Master Error [ 100.820558] [drm] Enabling DMM ywrap scrolling [ 100.826144] Console: switching to colour frame buffer device 128x48 [ 100.832528] omapdrm omapdrm.0: fb0: omapdrm frame buffer device [ 100.840691] omapdss error: HDMI I2C Master Error [ 101.011104] ------------[ cut here ]------------ [ 101.015772] WARNING: CPU: 0 PID: 0 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380 [ 101.024947] 44000000.ocp:L3 Custom Error: MASTER GPU_P1 TARGET DMM_P1 (Read): Data Access in User mode during Functional access [ 101.036472] Modules linked in: xhci_plat_hcd xhci_hcd pru_rproc irq_pruss_intc dwc3 udc_core pruss snd_soc_omap_hdmi ahci_platform libahci_platform pvrsrvkm(O) ti_vpe libahci pruss_soc_bus ti_sc omap_aes_driver libata omap_wdt ti_csc omap_sham omap_des phy_omap_usb2 ti_vpdma des_generic omap_hdq at24 wire crypto_engine dwc3_omap rtc_omap omap_crypto rtc_ds1307 rtc_palmas omap_remoteproc virtio_rpmsg_bus remoteproc sch_fq_codel uio_module_drv(O) uio ftdi_sio usbserial usbcore usb_common jailhouse(O) gdbserverproxy(O) cryptodev(O) cmemk(O) [ 101.084490] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G O 4.19.79-g77dfab56c6 #1 [ 101.092964] Hardware name: Generic DRA74X (Flattened Device Tree) [ 101.099082] Backtrace: [ 101.101550] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 101.109156] r7:c0dfdbb4 r6:60030193 r5:00000000 r4:c12506dc [ 101.114849] [<c020cd54>] (show_stack) from [<c0a12ee0>] (dump_stack+0x90/0xa4) [ 101.122108] [<c0a12e50>] (dump_stack) from [<c022e098>] (__warn+0xdc/0xf8) [ 101.129014] r7:c0dfdbb4 r6:00000009 r5:00000000 r4:c1201cbc [ 101.134701] [<c022dfbc>] (__warn) from [<c022dcdc>] (warn_slowpath_fmt+0x50/0x6c) [ 101.142219] r9:ef1ca9c0 r8:f0880264 r7:c0dfdae0 r6:c0dfdfac r5:c0dfdb84 r4:c1204c48 [ 101.150000] [<c022dc90>] (warn_slowpath_fmt) from [<c0566554>] (l3_interrupt_handler+0x330/0x380) [ 101.158910] r3:ef21d400 r2:c0dfdb84 [ 101.162501] r5:00000002 r4:80080003 [ 101.166101] [<c0566224>] (l3_interrupt_handler) from [<c02895e8>] (__handle_irq_event_percpu+0x68/0x140) [ 101.175625] r10:c12522f8 r9:ef219f00 r8:00000017 r7:c1201de8 r6:00000000 r5:ef219f68 [ 101.183487] r4:ef21d8c0 [ 101.186036] [<c0289580>] (__handle_irq_event_percpu) from [<c02896f4>] (handle_irq_event_percpu+0x34/0x88) [ 101.195734] r10:c10684f0 r9:c1200000 r8:ef00c000 r7:00000001 r6:ef219f00 r5:ef219f68 [ 101.203596] r4:c1204c48 [ 101.206145] [<c02896c0>] (handle_irq_event_percpu) from [<c0289788>] (handle_irq_event+0x40/0x64) [ 101.215056] r6:c120a434 r5:ef219f68 r4:ef219f00 [ 101.219698] [<c0289748>] (handle_irq_event) from [<c028d4d8>] (handle_fasteoi_irq+0xc0/0x168) [ 101.228259] r7:00000001 r6:c120a434 r5:ef219f68 r4:ef219f00 [ 101.233947] [<c028d418>] (handle_fasteoi_irq) from [<c02887e4>] (generic_handle_irq+0x2c/0x3c) [ 101.242596] r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc [ 101.248284] [<c02887b8>] (generic_handle_irq) from [<c0288e48>] (__handle_domain_irq+0x64/0xbc) [ 101.257024] [<c0288de4>] (__handle_domain_irq) from [<c0564890>] (gic_handle_irq+0x44/0x80) [ 101.265413] r9:c1200000 r8:fa213000 r7:c1201eb0 r6:fa212000 r5:fa21200c r4:c1205104 [ 101.273193] [<c056484c>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c) [ 101.280707] Exception stack(0xc1201eb0 to 0xc1201ef8) [ 101.285780] 1ea0: 00000000 0001d834 ef67650c c0222150 [ 101.293996] 1ec0: ffffe000 c1204c7c c1204cc4 00000001 00000000 00000000 c10684f0 c1201f0c [ 101.302209] 1ee0: c1201eec c1201f00 c0221de4 c0208e94 a0030013 ffffffff [ 101.308854] r9:c1200000 r8:00000000 r7:c1201ee4 r6:ffffffff r5:a0030013 r4:c0208e94 [ 101.316643] [<c0208e6c>] (arch_cpu_idle) from [<c0a2cecc>] (default_idle_call+0x30/0x34) [ 101.324773] [<c0a2ce9c>] (default_idle_call) from [<c025a890>] (do_idle+0x204/0x2ac) [ 101.332554] [<c025a68c>] (do_idle) from [<c025ac24>] (cpu_startup_entry+0x20/0x24) [ 101.340158] r10:c104ba38 r9:c1253e00 r8:ffffffff r7:c1253e00 r6:00000000 r5:00000002 [ 101.348020] r4:000000c7 [ 101.350567] [<c025ac04>] (cpu_startup_entry) from [<c0a27174>] (rest_init+0xd0/0xd4) [ 101.358349] [<c0a270a4>] (rest_init) from [<c1000dfc>] (start_kernel+0x448/0x470) [ 101.365862] r5:00000000 r4:c1253e58 [ 101.369455] [<c10009b4>] (start_kernel) from [<00000000>] ( (null)) [ 101.375834] ---[ end trace 45d8c963d0be86df ]--- [ 101.380524] ------------[ cut here ]------------ [ 101.385171] WARNING: CPU: 0 PID: 0 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380 [ 101.391423] omapdrm omapdrm.0: atomic complete timeout (pipe 0)! [ 101.394343] 44000000.ocp:L3 Custom Error: MASTER BB2D TARGET DMM_P2 (Read): Data Access in User mode during Functional access [ 101.394347] Modules linked in: xhci_plat_hcd xhci_hcd pru_rproc irq_pruss_intc dwc3 [ 101.400562] ------------[ cut here ]------------ [ 101.411748] udc_core [ 101.419443] WARNING: CPU: 1 PID: 112 at drivers/gpu/drm/omapdrm/omap_crtc.c:400 omap_crtc_arm_event+0x50/0x54 [ 101.424064] pruss [ 101.426341] Modules linked in: [ 101.436292] snd_soc_omap_hdmi [ 101.438306] xhci_plat_hcd [ 101.441366] ahci_platform [ 101.444427] xhci_hcd [ 101.447139] libahci_platform [ 101.449852] pru_rproc [ 101.452128] pvrsrvkm(O) [ 101.455101] irq_pruss_intc [ 101.457463] ti_vpe [ 101.460000] dwc3 [ 101.462798] libahci [ 101.464900] udc_core [ 101.466828] pruss_soc_bus [ 101.469016] pruss [ 101.471291] ti_sc [ 101.474003] snd_soc_omap_hdmi [ 101.476017] omap_aes_driver [ 101.478032] ahci_platform [ 101.481093] libata [ 101.483978] libahci_platform [ 101.486690] omap_wdt [ 101.488791] pvrsrvkm(O) [ 101.491764] ti_csc [ 101.494039] ti_vpe [ 101.496576] omap_sham [ 101.498678] libahci [ 101.500778] omap_des [ 101.503141] pruss_soc_bus [ 101.505328] phy_omap_usb2 [ 101.507603] ti_sc [ 101.510314] ti_vpdma [ 101.513026] omap_aes_driver [ 101.515041] des_generic [ 101.517316] libata [ 101.520202] omap_hdq [ 101.522740] omap_wdt [ 101.524841] at24 [ 101.527117] ti_csc [ 101.529393] wire [ 101.531320] omap_sham [ 101.533422] crypto_engine [ 101.535349] omap_des [ 101.537711] dwc3_omap [ 101.540423] phy_omap_usb2 [ 101.542697] rtc_omap [ 101.545061] ti_vpdma [ 101.547772] omap_crypto [ 101.550049] des_generic [ 101.552323] rtc_ds1307 [ 101.554860] omap_hdq [ 101.557398] rtc_palmas [ 101.559848] at24 [ 101.562124] omap_remoteproc [ 101.564574] wire [ 101.566501] virtio_rpmsg_bus [ 101.569387] crypto_engine [ 101.571313] remoteproc [ 101.574287] dwc3_omap [ 101.576999] sch_fq_codel [ 101.579449] rtc_omap [ 101.581812] uio_module_drv(O) [ 101.584436] omap_crypto [ 101.586713] uio [ 101.589773] rtc_ds1307 [ 101.592310] ftdi_sio [ 101.594150] rtc_palmas [ 101.596599] usbserial [ 101.598875] omap_remoteproc [ 101.601325] usbcore [ 101.603687] virtio_rpmsg_bus [ 101.606573] usb_common [ 101.608761] remoteproc [ 101.611734] jailhouse(O) [ 101.614184] sch_fq_codel [ 101.616634] gdbserverproxy(O) [ 101.619259] uio_module_drv(O) [ 101.621882] cryptodev(O) [ 101.624943] uio [ 101.628004] cmemk(O) [ 101.630628] ftdi_sio [ 101.634742] usbserial [ 101.637021] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W O 4.19.79-g77dfab56c6 #1 [ 101.637025] usbcore [ 101.639390] Hardware name: Generic DRA74X (Flattened Device Tree) [ 101.647856] usb_common [ 101.650045] Backtrace: [ 101.656158] jailhouse(O) [ 101.661059] gdbserverproxy(O) [ 101.663689] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 101.663694] cryptodev(O) [ 101.666757] r7:c0dfdbb4 r6:60030193 r5:00000000 r4:c12506dc [ 101.674350] cmemk(O) [ 101.676981] [<c020cd54>] (show_stack) from [<c0a12ee0>] (dump_stack+0x90/0xa4) [ 101.684933] [<c0a12e50>] (dump_stack) from [<c022e098>] (__warn+0xdc/0xf8) [ 101.699074] r7:c0dfdbb4 r6:00000009 r5:00000000 r4:c1201bac [ 101.704761] [<c022dfbc>] (__warn) from [<c022dcdc>] (warn_slowpath_fmt+0x50/0x6c) [ 101.712277] r9:ef1ca9c0 r8:f0881364 r7:c0dfdae0 r6:c0dfdfb4 r5:c0dfdb84 r4:c1204c48 [ 101.720059] [<c022dc90>] (warn_slowpath_fmt) from [<c0566554>] (l3_interrupt_handler+0x330/0x380) [ 101.728968] r3:ef21d400 r2:c0dfdb84 [ 101.732558] r5:00000002 r4:80080003 [ 101.736154] [<c0566224>] (l3_interrupt_handler) from [<c02895e8>] (__handle_irq_event_percpu+0x68/0x140) [ 101.745677] r10:c12522f8 r9:ef219f00 r8:00000017 r7:c1201cd8 r6:00000000 r5:ef219f68 [ 101.753540] r4:ef21d8c0 [ 101.756089] [<c0289580>] (__handle_irq_event_percpu) from [<c02896f4>] (handle_irq_event_percpu+0x34/0x88) [ 101.765785] r10:c10684f0 r9:c1200000 r8:ef00c000 r7:00000001 r6:ef219f00 r5:ef219f68 [ 101.773647] r4:c1204c48 [ 101.776195] [<c02896c0>] (handle_irq_event_percpu) from [<c0289788>] (handle_irq_event+0x40/0x64) [ 101.785105] r6:c120a434 r5:ef219f68 r4:ef219f00 [ 101.789745] [<c0289748>] (handle_irq_event) from [<c028d4d8>] (handle_fasteoi_irq+0xc0/0x168) [ 101.798307] r7:00000001 r6:c120a434 r5:ef219f68 r4:ef219f00 [ 101.803994] [<c028d418>] (handle_fasteoi_irq) from [<c02887e4>] (generic_handle_irq+0x2c/0x3c) [ 101.812642] r7:00000001 r6:c1201eb0 r5:00000000 r4:c1068cfc [ 101.818329] [<c02887b8>] (generic_handle_irq) from [<c0288e48>] (__handle_domain_irq+0x64/0xbc) [ 101.827069] [<c0288de4>] (__handle_domain_irq) from [<c0564890>] (gic_handle_irq+0x44/0x80) [ 101.835459] r9:c1200000 r8:fa213000 r7:c1201da0 r6:fa212000 r5:fa21200c r4:c1205104 [ 101.843239] [<c056484c>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c) [ 101.850752] Exception stack(0xc1201da0 to 0xc1201de8) [ 101.855827] 1da0: 2e610000 00000000 2e610000 c1068d40 00000282 00000000 00000000 00000001 [ 101.864042] 1dc0: ef00c000 c1200000 c10684f0 c1201e4c 00200102 c1201df0 00200102 c02020e0 [ 101.872254] 1de0: 60030113 ffffffff [ 101.875759] r9:c1200000 r8:ef00c000 r7:c1201dd4 r6:ffffffff r5:60030113 r4:c02020e0 [ 101.883543] [<c0202038>] (__do_softirq) from [<c0232edc>] (irq_exit+0xd4/0x110) [ 101.890885] r10:c10684f0 r9:c1200000 r8:ef00c000 r7:00000001 r6:00000000 r5:00000000 [ 101.898746] r4:c1068cfc [ 101.901294] [<c0232e08>] (irq_exit) from [<c0288e4c>] (__handle_domain_irq+0x68/0xbc) [ 101.909161] [<c0288de4>] (__handle_domain_irq) from [<c0564890>] (gic_handle_irq+0x44/0x80) [ 101.917549] r9:c1200000 r8:fa213000 r7:c1201eb0 r6:fa212000 r5:fa21200c r4:c1205104 [ 101.925329] [<c056484c>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c) [ 101.932842] Exception stack(0xc1201eb0 to 0xc1201ef8) [ 101.937915] 1ea0: 00000000 0001d834 ef67650c c0222150 [ 101.946130] 1ec0: ffffe000 c1204c7c c1204cc4 00000001 00000000 00000000 c10684f0 c1201f0c [ 101.954343] 1ee0: c1201eec c1201f00 c0221de4 c0208e94 a0030013 ffffffff [ 101.960988] r9:c1200000 r8:00000000 r7:c1201ee4 r6:ffffffff r5:a0030013 r4:c0208e94 [ 101.968771] [<c0208e6c>] (arch_cpu_idle) from [<c0a2cecc>] (default_idle_call+0x30/0x34) [ 101.976900] [<c0a2ce9c>] (default_idle_call) from [<c025a890>] (do_idle+0x204/0x2ac) [ 101.984680] [<c025a68c>] (do_idle) from [<c025ac24>] (cpu_startup_entry+0x20/0x24) [ 101.992284] r10:c104ba38 r9:c1253e00 r8:ffffffff r7:c1253e00 r6:00000000 r5:00000002 [ 102.000146] r4:000000c7 [ 102.002693] [<c025ac04>] (cpu_startup_entry) from [<c0a27174>] (rest_init+0xd0/0xd4) [ 102.010473] [<c0a270a4>] (rest_init) from [<c1000dfc>] (start_kernel+0x448/0x470) [ 102.017988] r5:00000000 r4:c1253e58 [ 102.021580] [<c10009b4>] (start_kernel) from [<00000000>] ( (null)) [ 102.027959] ---[ end trace 45d8c963d0be86e0 ]--- [ 102.027964] CPU: 1 PID: 112 Comm: kworker/u4:2 Tainted: G W O 4.19.79-g77dfab56c6 #1 [ 102.027969] Hardware name: Generic DRA74X (Flattened Device Tree) [ 102.032643] ------------[ cut here ]------------ [ 102.041510] Workqueue: events_unbound commit_work [ 102.047626] WARNING: CPU: 0 PID: 0 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380 [ 102.056971] 44000000.ocp:L3 Custom Error: MASTER DSS TARGET DMM_P1 (Read): Data Access in User mode during Functional access [ 102.066132] Backtrace: [ 102.077389] Modules linked in: [ 102.079844] xhci_plat_hcd [ 102.082910] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 102.082914] xhci_hcd [ 102.085630] r7:c0e1dd44 r6:20060093 r5:00000000 r4:c12506dc [ 102.093223] pru_rproc [ 102.095507] [<c020cd54>] (show_stack) from [<c0a12ee0>] (dump_stack+0x90/0xa4) [ 102.101176] irq_pruss_intc [ 102.103546] [<c0a12e50>] (dump_stack) from [<c022e098>] (__warn+0xdc/0xf8) [ 102.110787] dwc3 [ 102.113587] r7:c0e1dd44 r6:00000009 r5:00000000 r4:00000000 [ 102.120483] udc_core [ 102.122416] [<c022dfbc>] (__warn) from [<c022e0fc>] (warn_slowpath_null+0x48/0x50) [ 102.128087] pruss [ 102.130366] r9:ee502c00 r8:ee502c00 r7:ed6a0f00 r6:c0699644 r5:00000190 r4:c0e1dd44 [ 102.137958] snd_soc_omap_hdmi [ 102.139978] [<c022e0b4>] (warn_slowpath_null) from [<c0699644>] (omap_crtc_arm_event+0x50/0x54) [ 102.147742] ahci_platform [ 102.150803] r6:ed972600 r5:c1204c48 r4:eeaab400 [ 102.159531] libahci_platform [ 102.162249] [<c06995f4>] (omap_crtc_arm_event) from [<c0699cc0>] (omap_crtc_atomic_flush+0x358/0x380) [ 102.166873] pvrsrvkm(O) [ 102.169848] r5:c1204c48 r4:eeaab400 [ 102.179099] ti_vpe [ 102.181651] [<c0699968>] (omap_crtc_atomic_flush) from [<c064a680>] (drm_atomic_helper_commit_planes+0x224/0x298) [ 102.185220] libahci [ 102.187325] r9:ee4e8000 r8:00000000 r7:ed6a0f00 r6:ee503a00 r5:dff839c0 r4:00000001 [ 102.197619] pruss_soc_bus [ 102.199815] [<c064a45c>] (drm_atomic_helper_commit_planes) from [<c0697c04>] (omap_atomic_commit_tail+0x6c/0xc8) [ 102.207577] ti_sc [ 102.210293] r10:00000000 r9:dff839f0 r8:00000000 r7:ef005000 r6:ee502c00 r5:eeaaa800 [ 102.220501] omap_aes_driver [ 102.222517] r4:dff839c0 [ 102.230373] libata [ 102.233265] [<c0697b98>] (omap_atomic_commit_tail) from [<c064ebf4>] (commit_tail+0x48/0x74) [ 102.235796] omap_wdt [ 102.237900] r7:ef005000 r6:ef006200 r5:c0c5d9f4 r4:dff839c0 [ 102.246365] ti_csc [ 102.248646] [<c064ebac>] (commit_tail) from [<c064ec34>] (commit_work+0x14/0x18) [ 102.254317] omap_sham [ 102.256419] r5:ee3a6680 r4:dff839ec [ 102.263840] omap_des [ 102.266210] [<c064ec20>] (commit_work) from [<c02463f8>] (process_one_work+0x1f4/0x404) [ 102.269788] phy_omap_usb2 [ 102.272070] [<c0246204>] (process_one_work) from [<c02471b8>] (worker_thread+0x58/0x568) [ 102.280096] ti_vpdma [ 102.282811] r10:ef006200 r9:c1203d00 r8:ef006218 r7:00000088 r6:ef006200 r5:ee3a6694 [ 102.290927] des_generic [ 102.293203] r4:ee3a6680 [ 102.301058] omap_hdq [ 102.303604] [<c0247160>] (worker_thread) from [<c024c698>] (kthread+0x160/0x168) [ 102.306133] at24 [ 102.308413] r10:ee48be74 r9:c0247160 r8:ee3a6680 r7:ed8ea000 r6:00000000 r5:ee3a5f40 [ 102.315831] wire [ 102.317757] r4:ee30a280 [ 102.325614] crypto_engine [ 102.327547] [<c024c538>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c) [ 102.330077] dwc3_omap [ 102.332791] Exception stack(0xed8ebfb0 to 0xed8ebff8) [ 102.340035] rtc_omap [ 102.342399] bfa0: 00000000 00000000 00000000 00000000 [ 102.347464] omap_crypto [ 102.349742] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 102.357945] rtc_ds1307 [ 102.360483] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 102.368688] rtc_palmas [ 102.371142] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c538 [ 102.377774] omap_remoteproc [ 102.380225] r4:ee3a5f40 [ 102.388081] virtio_rpmsg_bus [ 102.390969] ---[ end trace 45d8c963d0be86e1 ]--- [ 102.393504] remoteproc sch_fq_codel uio_module_drv(O) uio ftdi_sio usbserial usbcore usb_common jailhouse(O) gdbserverproxy(O) cryptodev(O) cmemk(O) [ 102.401753] omap_i2c 48070000.i2c: controller timed out [ 102.414604] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W O 4.19.79-g77dfab56c6 #1 [ 102.414609] Hardware name: Generic DRA74X (Flattened Device Tree) [ 102.414612] Backtrace: [ 102.436899] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 102.444503] r7:c0dfdbb4 r6:60030193 r5:00000000 r4:c12506dc [ 102.450193] [<c020cd54>] (show_stack) from [<c0a12ee0>] (dump_stack+0x90/0xa4) [ 102.457452] [<c0a12e50>] (dump_stack) from [<c022e098>] (__warn+0xdc/0xf8) [ 102.464358] r7:c0dfdbb4 r6:00000009 r5:00000000 r4:c1201bac [ 102.470044] [<c022dfbc>] (__warn) from [<c022dcdc>] (warn_slowpath_fmt+0x50/0x6c) [ 102.477561] r9:ef1ca9c0 r8:f0880264 r7:c0dfdae0 r6:c0e21504 r5:c0dfdb84 r4:c1204c48 [ 102.485343] [<c022dc90>] (warn_slowpath_fmt) from [<c0566554>] (l3_interrupt_handler+0x330/0x380) [ 102.494253] r3:ef21d400 r2:c0dfdb84 [ 102.497842] r5:00000002 r4:80080003 [ 102.501438] [<c0566224>] (l3_interrupt_handler) from [<c02895e8>] (__handle_irq_event_percpu+0x68/0x140) [ 102.510961] r10:c12522f8 r9:ef219f00 r8:00000017 r7:c1201cd8 r6:00000000 r5:ef219f68 [ 102.518822] r4:ef21d8c0 [ 102.521371] [<c0289580>] (__handle_irq_event_percpu) from [<c02896f4>] (handle_irq_event_percpu+0x34/0x88) [ 102.531068] r10:c10684f0 r9:c1200000 r8:ef00c000 r7:00000001 r6:ef219f00 r5:ef219f68 [ 102.538930] r4:c1204c48 [ 102.541479] [<c02896c0>] (handle_irq_event_percpu) from [<c0289788>] (handle_irq_event+0x40/0x64) [ 102.550390] r6:c120a434 r5:ef219f68 r4:ef219f00 [ 102.555031] [<c0289748>] (handle_irq_event) from [<c028d4d8>] (handle_fasteoi_irq+0xc0/0x168) [ 102.563593] r7:00000001 r6:c120a434 r5:ef219f68 r4:ef219f00 [ 102.569280] [<c028d418>] (handle_fasteoi_irq) from [<c02887e4>] (generic_handle_irq+0x2c/0x3c) [ 102.577928] r7:00000001 r6:c1201eb0 r5:00000000 r4:c1068cfc [ 102.583616] [<c02887b8>] (generic_handle_irq) from [<c0288e48>] (__handle_domain_irq+0x64/0xbc) [ 102.592355] [<c0288de4>] (__handle_domain_irq) from [<c0564890>] (gic_handle_irq+0x44/0x80) [ 102.600744] r9:c1200000 r8:fa213000 r7:c1201da0 r6:fa212000 r5:fa21200c r4:c1205104 [ 102.608525] [<c056484c>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c) [ 102.616039] Exception stack(0xc1201da0 to 0xc1201de8) [ 102.621115] 1da0: 2e610000 00000000 2e610000 c1068d40 00000282 00000000 00000000 00000001 [ 102.629329] 1dc0: ef00c000 c1200000 c10684f0 c1201e4c 00200102 c1201df0 00200102 c02020e0 [ 102.637540] 1de0: 60030113 ffffffff [ 102.641045] r9:c1200000 r8:ef00c000 r7:c1201dd4 r6:ffffffff r5:60030113 r4:c02020e0 [ 102.648826] [<c0202038>] (__do_softirq) from [<c0232edc>] (irq_exit+0xd4/0x110) [ 102.656170] r10:c10684f0 r9:c1200000 r8:ef00c000 r7:00000001 r6:00000000 r5:00000000 [ 102.664031] r4:c1068cfc [ 102.666579] [<c0232e08>] (irq_exit) from [<c0288e4c>] (__handle_domain_irq+0x68/0xbc) [ 102.674447] [<c0288de4>] (__handle_domain_irq) from [<c0564890>] (gic_handle_irq+0x44/0x80) [ 102.682836] r9:c1200000 r8:fa213000 r7:c1201eb0 r6:fa212000 r5:fa21200c r4:c1205104 [ 102.690616] [<c056484c>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c) [ 102.698130] Exception stack(0xc1201eb0 to 0xc1201ef8) [ 102.703203] 1ea0: 00000000 0001d834 ef67650c c0222150 [ 102.711417] 1ec0: ffffe000 c1204c7c c1204cc4 00000001 00000000 00000000 c10684f0 c1201f0c [ 102.719631] 1ee0: c1201eec c1201f00 c0221de4 c0208e94 a0030013 ffffffff [ 102.726277] r9:c1200000 r8:00000000 r7:c1201ee4 r6:ffffffff r5:a0030013 r4:c0208e94 [ 102.734060] [<c0208e6c>] (arch_cpu_idle) from [<c0a2cecc>] (default_idle_call+0x30/0x34) [ 102.742189] [<c0a2ce9c>] (default_idle_call) from [<c025a890>] (do_idle+0x204/0x2ac) [ 102.749968] [<c025a68c>] (do_idle) from [<c025ac24>] (cpu_startup_entry+0x20/0x24) [ 102.757572] r10:c104ba38 r9:c1253e00 r8:ffffffff r7:c1253e00 r6:00000000 r5:00000002 [ 102.765433] r4:000000c7 [ 102.767979] [<c025ac04>] (cpu_startup_entry) from [<c0a27174>] (rest_init+0xd0/0xd4) [ 102.775761] [<c0a270a4>] (rest_init) from [<c1000dfc>] (start_kernel+0x448/0x470) [ 102.783276] r5:00000000 r4:c1253e58 [ 102.786868] [<c10009b4>] (start_kernel) from [<00000000>] ( (null)) [ 102.793247] ---[ end trace 45d8c963d0be86e2 ]--- [ 102.797920] ------------[ cut here ]------------ [ 102.801697] omapdrm omapdrm.0: atomic complete timeout (pipe 0)! [ 102.802564] WARNING: CPU: 0 PID: 0 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380 [ 102.802575] 44000000.ocp:L3 Custom Error: MASTER DSS TARGET DMM_P1 (Read): Data Access in User mode during Functional access [ 102.829024] Modules linked in: xhci_plat_hcd xhci_hcd pru_rproc irq_pruss_intc dwc3 udc_core pruss snd_soc_omap_hdmi ahci_platform libahci_platform pvrsrvkm(O) ti_vpe libahci pruss_soc_bus ti_sc omap_aes_driver libata omap_wdt ti_csc omap_sham omap_des phy_omap_usb2 ti_vpdma des_generic omap_hdq at24 wire crypto_engine dwc3_omap rtc_omap omap_crypto rtc_ds1307 rtc_palmas omap_remoteproc virtio_rpmsg_bus remoteproc sch_fq_codel uio_module_drv(O) uio ftdi_sio usbserial usbcore usb_common jailhouse(O) gdbserverproxy(O) cryptodev(O) cmemk(O) [ 102.877036] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W O 4.19.79-g77dfab56c6 #1 [ 102.885509] Hardware name: Generic DRA74X (Flattened Device Tree) [ 102.891626] Backtrace: [ 102.894091] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 102.901695] r7:c0dfdbb4 r6:60030193 r5:00000000 r4:c12506dc [ 102.907381] [<c020cd54>] (show_stack) from [<c0a12ee0>] (dump_stack+0x90/0xa4) [ 102.914638] [<c0a12e50>] (dump_stack) from [<c022e098>] (__warn+0xdc/0xf8) [ 102.921545] r7:c0dfdbb4 r6:00000009 r5:00000000 r4:c1201bac [ 102.927231] [<c022dfbc>] (__warn) from [<c022dcdc>] (warn_slowpath_fmt+0x50/0x6c) [ 102.934748] r9:ef1ca9c0 r8:f0880264 r7:c0dfdae0 r6:c0e21504 r5:c0dfdb84 r4:c1204c48 [ 102.942529] [<c022dc90>] (warn_slowpath_fmt) from [<c0566554>] (l3_interrupt_handler+0x330/0x380) [ 102.951438] r3:ef21d400 r2:c0dfdb84 [ 102.955027] r5:00000002 r4:80080003 [ 102.958623] [<c0566224>] (l3_interrupt_handler) from [<c02895e8>] (__handle_irq_event_percpu+0x68/0x140) [ 102.968145] r10:c12522f8 r9:ef219f00 r8:00000017 r7:c1201cd8 r6:00000000 r5:ef219f68 [ 102.976008] r4:ef21d8c0 [ 102.978558] [<c0289580>] (__handle_irq_event_percpu) from [<c02896f4>] (handle_irq_event_percpu+0x34/0x88) [ 102.988256] r10:c10684f0 r9:c1200000 r8:ef00c000 r7:00000001 r6:ef219f00 r5:ef219f68 [ 102.996117] r4:c1204c48 [ 102.998665] [<c02896c0>] (handle_irq_event_percpu) from [<c0289788>] (handle_irq_event+0x40/0x64) [ 103.007576] r6:c120a434 r5:ef219f68 r4:ef219f00 [ 103.012217] [<c0289748>] (handle_irq_event) from [<c028d4d8>] (handle_fasteoi_irq+0xc0/0x168) [ 103.020779] r7:00000001 r6:c120a434 r5:ef219f68 r4:ef219f00 [ 103.026465] [<c028d418>] (handle_fasteoi_irq) from [<c02887e4>] (generic_handle_irq+0x2c/0x3c) [ 103.035114] r7:00000001 r6:c1201eb0 r5:00000000 r4:c1068cfc [ 103.040802] [<c02887b8>] (generic_handle_irq) from [<c0288e48>] (__handle_domain_irq+0x64/0xbc) [ 103.049541] [<c0288de4>] (__handle_domain_irq) from [<c0564890>] (gic_handle_irq+0x44/0x80) [ 103.057930] r9:c1200000 r8:fa213000 r7:c1201da0 r6:fa212000 r5:fa21200c r4:c1205104 [ 103.065710] [<c056484c>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c) [ 103.073223] Exception stack(0xc1201da0 to 0xc1201de8) [ 103.078299] 1da0: 2e610000 00000000 2e610000 c1068d40 00000282 00000000 00000000 00000001 [ 103.086514] 1dc0: ef00c000 c1200000 c10684f0 c1201e4c 00200102 c1201df0 00200102 c02020e0 [ 103.094725] 1de0: 60030113 ffffffff [ 103.098231] r9:c1200000 r8:ef00c000 r7:c1201dd4 r6:ffffffff r5:60030113 r4:c02020e0 [ 103.106012] [<c0202038>] (__do_softirq) from [<c0232edc>] (irq_exit+0xd4/0x110) [ 103.113354] r10:c10684f0 r9:c1200000 r8:ef00c000 r7:00000001 r6:00000000 r5:00000000 [ 103.121217] r4:c1068cfc [ 103.123764] [<c0232e08>] (irq_exit) from [<c0288e4c>] (__handle_domain_irq+0x68/0xbc) [ 103.131632] [<c0288de4>] (__handle_domain_irq) from [<c0564890>] (gic_handle_irq+0x44/0x80) [ 103.140021] r9:c1200000 r8:fa213000 r7:c1201eb0 r6:fa212000 r5:fa21200c r4:c1205104 [ 103.147801] [<c056484c>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c) [ 103.155314] Exception stack(0xc1201eb0 to 0xc1201ef8) [ 103.160387] 1ea0: 00000000 0001d834 ef67650c c0222150 [ 103.168602] 1ec0: ffffe000 c1204c7c c1204cc4 00000001 00000000 00000000 c10684f0 c1201f0c [ 103.176816] 1ee0: c1201eec c1201f00 c0221de4 c0208e94 a0030013 ffffffff [ 103.183460] r9:c1200000 r8:00000000 r7:c1201ee4 r6:ffffffff r5:a0030013 r4:c0208e94 [ 103.191242] [<c0208e6c>] (arch_cpu_idle) from [<c0a2cecc>] (default_idle_call+0x30/0x34) [ 103.199371] [<c0a2ce9c>] (default_idle_call) from [<c025a890>] (do_idle+0x204/0x2ac) [ 103.207152] [<c025a68c>] (do_idle) from [<c025ac24>] (cpu_startup_entry+0x20/0x24) [ 103.214756] r10:c104ba38 r9:c1253e00 r8:ffffffff r7:c1253e00 r6:00000000 r5:00000002 [ 103.222618] r4:000000c7 [ 103.225166] [<c025ac04>] (cpu_startup_entry) from [<c0a27174>] (rest_init+0xd0/0xd4) [ 103.232946] [<c0a270a4>] (rest_init) from [<c1000dfc>] (start_kernel+0x448/0x470) [ 103.240461] r5:00000000 r4:c1253e58 [ 103.244053] [<c10009b4>] (start_kernel) from [<00000000>] ( (null)) [ 103.250433] ---[ end trace 45d8c963d0be86e3 ]--- [ 103.255093] ------------[ cut here ]------------ [ 103.259735] WARNING: CPU: 0 PID: 0 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380 [ 103.268908] 44000000.ocp:L3 Custom Error: MASTER DSS TARGET DMM_P1 (Read): Data Access in User mode during Functional access [ 103.280170] Modules linked in: xhci_plat_hcd xhci_hcd pru_rproc irq_pruss_intc dwc3 udc_core pruss snd_soc_omap_hdmi ahci_platform libahci_platform pvrsrvkm(O) ti_vpe libahci pruss_soc_bus ti_sc omap_aes_driver libata omap_wdt ti_csc omap_sham omap_des phy_omap_usb2 ti_vpdma des_generic omap_hdq at24 wire crypto_engine dwc3_omap rtc_omap omap_crypto rtc_ds1307 rtc_palmas omap_remoteproc virtio_rpmsg_bus remoteproc sch_fq_codel uio_module_drv(O) uio ftdi_sio usbserial usbcore usb_common jailhouse(O) gdbserverproxy(O) cryptodev(O) cmemk(O) [ 103.328173] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W O 4.19.79-g77dfab56c6 #1 [ 103.336646] Hardware name: Generic DRA74X (Flattened Device Tree) [ 103.342762] Backtrace: [ 103.345227] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 103.352832] r7:c0dfdbb4 r6:60030193 r5:00000000 r4:c12506dc [ 103.358519] [<c020cd54>] (show_stack) from [<c0a12ee0>] (dump_stack+0x90/0xa4) [ 103.365777] [<c0a12e50>] (dump_stack) from [<c022e098>] (__warn+0xdc/0xf8) [ 103.372682] r7:c0dfdbb4 r6:00000009 r5:00000000 r4:c1201bac [ 103.378368] [<c022dfbc>] (__warn) from [<c022dcdc>] (warn_slowpath_fmt+0x50/0x6c) [ 103.385885] r9:ef1ca9c0 r8:f0880264 r7:c0dfdae0 r6:c0e21504 r5:c0dfdb84 r4:c1204c48 [ 103.393666] [<c022dc90>] (warn_slowpath_fmt) from [<c0566554>] (l3_interrupt_handler+0x330/0x380) [ 103.402577] r3:ef21d400 r2:c0dfdb84 [ 103.406166] r5:00000002 r4:80080003 [ 103.409762] [<c0566224>] (l3_interrupt_handler) from [<c02895e8>] (__handle_irq_event_percpu+0x68/0x140) [ 103.419286] r10:c12522f8 r9:ef219f00 r8:00000017 r7:c1201cd8 r6:00000000 r5:ef219f68 [ 103.427148] r4:ef21d8c0 [ 103.429697] [<c0289580>] (__handle_irq_event_percpu) from [<c02896f4>] (handle_irq_event_percpu+0x34/0x88) [ 103.439395] r10:c10684f0 r9:c1200000 r8:ef00c000 r7:00000001 r6:ef219f00 r5:ef219f68 [ 103.447257] r4:c1204c48 [ 103.449806] [<c02896c0>] (handle_irq_event_percpu) from [<c0289788>] (handle_irq_event+0x40/0x64) [ 103.458716] r6:c120a434 r5:ef219f68 r4:ef219f00 [ 103.463357] [<c0289748>] (handle_irq_event) from [<c028d4d8>] (handle_fasteoi_irq+0xc0/0x168) [ 103.471919] r7:00000001 r6:c120a434 r5:ef219f68 r4:ef219f00 [ 103.477605] [<c028d418>] (handle_fasteoi_irq) from [<c02887e4>] (generic_handle_irq+0x2c/0x3c) [ 103.486255] r7:00000001 r6:c1201eb0 r5:00000000 r4:c1068cfc [ 103.491943] [<c02887b8>] (generic_handle_irq) from [<c0288e48>] (__handle_domain_irq+0x64/0xbc) [ 103.500684] [<c0288de4>] (__handle_domain_irq) from [<c0564890>] (gic_handle_irq+0x44/0x80) [ 103.509072] r9:c1200000 r8:fa213000 r7:c1201da0 r6:fa212000 r5:fa21200c r4:c1205104 [ 103.516851] [<c056484c>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c) [ 103.524364] Exception stack(0xc1201da0 to 0xc1201de8) [ 103.529439] 1da0: 2e610000 00000000 2e610000 c1068d40 00000282 00000000 00000000 00000001 [ 103.537653] 1dc0: ef00c000 c1200000 c10684f0 c1201e4c 00200102 c1201df0 00200102 c02020e0 [ 103.545864] 1de0: 60030113 ffffffff [ 103.549369] r9:c1200000 r8:ef00c000 r7:c1201dd4 r6:ffffffff r5:60030113 r4:c02020e0 [ 103.557150] [<c0202038>] (__do_softirq) from [<c0232edc>] (irq_exit+0xd4/0x110) [ 103.564492] r10:c10684f0 r9:c1200000 r8:ef00c000 r7:00000001 r6:00000000 r5:00000000 [ 103.572354] r4:c1068cfc [ 103.574901] [<c0232e08>] (irq_exit) from [<c0288e4c>] (__handle_domain_irq+0x68/0xbc) [ 103.582768] [<c0288de4>] (__handle_domain_irq) from [<c0564890>] (gic_handle_irq+0x44/0x80) [ 103.591157] r9:c1200000 r8:fa213000 r7:c1201eb0 r6:fa212000 r5:fa21200c r4:c1205104 [ 103.598936] [<c056484c>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c) [ 103.606450] Exception stack(0xc1201eb0 to 0xc1201ef8) [ 103.611524] 1ea0: 00000000 0001d834 ef67650c c0222150 [ 103.619737] 1ec0: ffffe000 c1204c7c c1204cc4 00000001 00000000 00000000 c10684f0 c1201f0c [ 103.627951] 1ee0: c1201eec c1201f00 c0221de4 c0208e94 a0030013 ffffffff [ 103.634597] r9:c1200000 r8:00000000 r7:c1201ee4 r6:ffffffff r5:a0030013 r4:c0208e94 [ 103.642378] [<c0208e6c>] (arch_cpu_idle) from [<c0a2cecc>] (default_idle_call+0x30/0x34) [ 103.650508] [<c0a2ce9c>] (default_idle_call) from [<c025a890>] (do_idle+0x204/0x2ac) [ 103.658289] [<c025a68c>] (do_idle) from [<c025ac24>] (cpu_startup_entry+0x20/0x24) [ 103.665893] r10:c104ba38 r9:c1253e00 r8:ffffffff r7:c1253e00 r6:00000000 r5:00000002 [ 103.673754] r4:000000c7 [ 103.676301] [<c025ac04>] (cpu_startup_entry) from [<c0a27174>] (rest_init+0xd0/0xd4) [ 103.684081] [<c0a270a4>] (rest_init) from [<c1000dfc>] (start_kernel+0x448/0x470) [ 103.691594] r5:00000000 r4:c1253e58 [ 103.695186] [<c10009b4>] (start_kernel) from [<00000000>] ( (null)) [ 103.701564] ---[ end trace 45d8c963d0be86e4 ]--- [ 103.706230] ------------[ cut here ]------------ [ 103.710874] WARNING: CPU: 0 PID: 0 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380 [ 103.720047] 44000000.ocp:L3 Custom Error: MASTER DSS TARGET DMM_P1 (Read): Data Access in User mode during Functional access [ 103.731309] Modules linked in: xhci_plat_hcd xhci_hcd pru_rproc irq_pruss_intc dwc3 udc_core pruss snd_soc_omap_hdmi ahci_platform libahci_platform pvrsrvkm(O) ti_vpe libahci pruss_soc_bus ti_sc omap_aes_driver libata omap_wdt ti_csc omap_sham omap_des phy_omap_usb2 ti_vpdma des_generic omap_hdq at24 wire crypto_engine dwc3_omap rtc_omap omap_crypto rtc_ds1307 rtc_palmas omap_remoteproc virtio_rpmsg_bus remoteproc sch_fq_codel uio_module_drv(O) uio ftdi_sio usbserial usbcore usb_common jailhouse(O) gdbserverproxy(O) cryptodev(O) cmemk(O) [ 103.779315] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W O 4.19.79-g77dfab56c6 #1 [ 103.787787] Hardware name: Generic DRA74X (Flattened Device Tree) [ 103.793903] Backtrace: [ 103.796367] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 103.803971] r7:c0dfdbb4 r6:60030193 r5:00000000 r4:c12506dc [ 103.809658] [<c020cd54>] (show_stack) from [<c0a12ee0>] (dump_stack+0x90/0xa4) [ 103.816915] [<c0a12e50>] (dump_stack) from [<c022e098>] (__warn+0xdc/0xf8) [ 103.823821] r7:c0dfdbb4 r6:00000009 r5:00000000 r4:c1201bac [ 103.829507] [<c022dfbc>] (__warn) from [<c022dcdc>] (warn_slowpath_fmt+0x50/0x6c) [ 103.837025] r9:ef1ca9c0 r8:f0880264 r7:c0dfdae0 r6:c0e21504 r5:c0dfdb84 r4:c1204c48 [ 103.844806] [<c022dc90>] (warn_slowpath_fmt) from [<c0566554>] (l3_interrupt_handler+0x330/0x380) [ 103.853715] r3:ef21d400 r2:c0dfdb84 [ 103.857305] r5:00000002 r4:80080003 [ 103.860901] [<c0566224>] (l3_interrupt_handler) from [<c02895e8>] (__handle_irq_event_percpu+0x68/0x140) [ 103.870424] r10:c12522f8 r9:ef219f00 r8:00000017 r7:c1201cd8 r6:00000000 r5:ef219f68 [ 103.878286] r4:ef21d8c0 [ 103.880835] [<c0289580>] (__handle_irq_event_percpu) from [<c02896f4>] (handle_irq_event_percpu+0x34/0x88) [ 103.890532] r10:c10684f0 r9:c1200000 r8:ef00c000 r7:00000001 r6:ef219f00 r5:ef219f68 [ 103.898394] r4:c1204c48 [ 103.900943] [<c02896c0>] (handle_irq_event_percpu) from [<c0289788>] (handle_irq_event+0x40/0x64) [ 103.909853] r6:c120a434 r5:ef219f68 r4:ef219f00 [ 103.914494] [<c0289748>] (handle_irq_event) from [<c028d4d8>] (handle_fasteoi_irq+0xc0/0x168) [ 103.923055] r7:00000001 r6:c120a434 r5:ef219f68 r4:ef219f00 [ 103.928742] [<c028d418>] (handle_fasteoi_irq) from [<c02887e4>] (generic_handle_irq+0x2c/0x3c) [ 103.937391] r7:00000001 r6:c1201eb0 r5:00000000 r4:c1068cfc [ 103.943078] [<c02887b8>] (generic_handle_irq) from [<c0288e48>] (__handle_domain_irq+0x64/0xbc) [ 103.951818] [<c0288de4>] (__handle_domain_irq) from [<c0564890>] (gic_handle_irq+0x44/0x80) [ 103.960207] r9:c1200000 r8:fa213000 r7:c1201da0 r6:fa212000 r5:fa21200c r4:c1205104 [ 103.967987] [<c056484c>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c) [ 103.975501] Exception stack(0xc1201da0 to 0xc1201de8) [ 103.980575] 1da0: 2e610000 00000000 2e610000 c1068d40 00000282 00000000 00000000 00000001 [ 103.988790] 1dc0: ef00c000 c1200000 c10684f0 c1201e4c 00200102 c1201df0 00200102 c02020e0 [ 103.997001] 1de0: 60030113 ffffffff [ 104.000506] r9:c1200000 r8:ef00c000 r7:c1201dd4 r6:ffffffff r5:60030113 r4:c02020e0 [ 104.008287] [<c0202038>] (__do_softirq) from [<c0232edc>] (irq_exit+0xd4/0x110) [ 104.015629] r10:c10684f0 r9:c1200000 r8:ef00c000 r7:00000001 r6:00000000 r5:00000000 [ 104.023491] r4:c1068cfc [ 104.026038] [<c0232e08>] (irq_exit) from [<c0288e4c>] (__handle_domain_irq+0x68/0xbc) [ 104.033906] [<c0288de4>] (__handle_domain_irq) from [<c0564890>] (gic_handle_irq+0x44/0x80) [ 104.042295] r9:c1200000 r8:fa213000 r7:c1201eb0 r6:fa212000 r5:fa21200c r4:c1205104 [ 104.050075] [<c056484c>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c) [ 104.057588] Exception stack(0xc1201eb0 to 0xc1201ef8) [ 104.062661] 1ea0: 00000000 0001d834 ef67650c c0222150 [ 104.070876] 1ec0: ffffe000 c1204c7c c1204cc4 00000001 00000000 00000000 c10684f0 c1201f0c [ 104.079089] 1ee0: c1201eec c1201f00 c0221de4 c0208e94 a0030013 ffffffff [ 104.085734] r9:c1200000 r8:00000000 r7:c1201ee4 r6:ffffffff r5:a0030013 r4:c0208e94 [ 104.093517] [<c0208e6c>] (arch_cpu_idle) from [<c0a2cecc>] (default_idle_call+0x30/0x34) [ 104.101647] [<c0a2ce9c>] (default_idle_call) from [<c025a890>] (do_idle+0x204/0x2ac) [ 104.109426] [<c025a68c>] (do_idle) from [<c025ac24>] (cpu_startup_entry+0x20/0x24) [ 104.117031] r10:c104ba38 r9:c1253e00 r8:ffffffff r7:c1253e00 r6:00000000 r5:00000002 [ 104.124893] r4:000000c7 [ 104.127440] [<c025ac04>] (cpu_startup_entry) from [<c0a27174>] (rest_init+0xd0/0xd4) [ 104.135220] [<c0a270a4>] (rest_init) from [<c1000dfc>] (start_kernel+0x448/0x470) [ 104.142735] r5:00000000 r4:c1253e58 [ 104.146326] [<c10009b4>] (start_kernel) from [<00000000>] ( (null)) [ 104.152705] ---[ end trace 45d8c963d0be86e5 ]--- [ 104.157365] ------------[ cut here ]------------ [ 104.162009] WARNING: CPU: 0 PID: 0 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380 [ 104.171181] 44000000.ocp:L3 Custom Error: MASTER DSS TARGET DMM_P1 (Read): Data Access in User mode during Functional access [ 104.182443] Modules linked in: xhci_plat_hcd xhci_hcd pru_rproc irq_pruss_intc dwc3 udc_core pruss snd_soc_omap_hdmi ahci_platform libahci_platform pvrsrvkm(O) ti_vpe libahci pruss_soc_bus ti_sc omap_aes_driver libata omap_wdt ti_csc omap_sham omap_des phy_omap_usb2 ti_vpdma des_generic omap_hdq at24 wire crypto_engine dwc3_omap rtc_omap omap_crypto rtc_ds1307 rtc_palmas omap_remoteproc virtio_rpmsg_bus remoteproc sch_fq_codel uio_module_drv(O) uio ftdi_sio usbserial usbcore usb_common jailhouse(O) gdbserverproxy(O) cryptodev(O) cmemk(O) [ 104.230448] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W O 4.19.79-g77dfab56c6 #1 [ 104.238921] Hardware name: Generic DRA74X (Flattened Device Tree) [ 104.245039] Backtrace: [ 104.247503] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 104.255107] r7:c0dfdbb4 r6:60030193 r5:00000000 r4:c12506dc [ 104.260793] [<c020cd54>] (show_stack) from [<c0a12ee0>] (dump_stack+0x90/0xa4) [ 104.268050] [<c0a12e50>] (dump_stack) from [<c022e098>] (__warn+0xdc/0xf8) [ 104.274955] r7:c0dfdbb4 r6:00000009 r5:00000000 r4:c1201bac [ 104.280642] [<c022dfbc>] (__warn) from [<c022dcdc>] (warn_slowpath_fmt+0x50/0x6c) [ 104.288160] r9:ef1ca9c0 r8:f0880264 r7:c0dfdae0 r6:c0e21504 r5:c0dfdb84 r4:c1204c48 [ 104.295940] [<c022dc90>] (warn_slowpath_fmt) from [<c0566554>] (l3_interrupt_handler+0x330/0x380) [ 104.304849] r3:ef21d400 r2:c0dfdb84 [ 104.308439] r5:00000002 r4:80080003 [ 104.312034] [<c0566224>] (l3_interrupt_handler) from [<c02895e8>] (__handle_irq_event_percpu+0x68/0x140) [ 104.321557] r10:c12522f8 r9:ef219f00 r8:00000017 r7:c1201cd8 r6:00000000 r5:ef219f68 [ 104.329419] r4:ef21d8c0 [ 104.331968] [<c0289580>] (__handle_irq_event_percpu) from [<c02896f4>] (handle_irq_event_percpu+0x34/0x88) [ 104.341665] r10:c10684f0 r9:c1200000 r8:ef00c000 r7:00000001 r6:ef219f00 r5:ef219f68 [ 104.349527] r4:c1204c48 [ 104.352075] [<c02896c0>] (handle_irq_event_percpu) from [<c0289788>] (handle_irq_event+0x40/0x64) [ 104.360985] r6:c120a434 r5:ef219f68 r4:ef219f00 [ 104.365626] [<c0289748>] (handle_irq_event) from [<c028d4d8>] (handle_fasteoi_irq+0xc0/0x168) [ 104.374188] r7:00000001 r6:c120a434 r5:ef219f68 r4:ef219f00 [ 104.379875] [<c028d418>] (handle_fasteoi_irq) from [<c02887e4>] (generic_handle_irq+0x2c/0x3c) [ 104.388524] r7:00000001 r6:c1201eb0 r5:00000000 r4:c1068cfc [ 104.394212] [<c02887b8>] (generic_handle_irq) from [<c0288e48>] (__handle_domain_irq+0x64/0xbc) [ 104.402952] [<c0288de4>] (__handle_domain_irq) from [<c0564890>] (gic_handle_irq+0x44/0x80) [ 104.411341] r9:c1200000 r8:fa213000 r7:c1201da0 r6:fa212000 r5:fa21200c r4:c1205104 [ 104.419120] [<c056484c>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c) [ 104.426634] Exception stack(0xc1201da0 to 0xc1201de8) [ 104.431709] 1da0: 2e610000 00000000 2e610000 c1068d40 00000282 00000000 00000000 00000001 [ 104.439923] 1dc0: ef00c000 c1200000 c10684f0 c1201e4c 00200102 c1201df0 00200102 c02020e0 [ 104.448134] 1de0: 60030113 ffffffff [ 104.451639] r9:c1200000 r8:ef00c000 r7:c1201dd4 r6:ffffffff r5:60030113 r4:c02020e0 [ 104.459420] [<c0202038>] (__do_softirq) from [<c0232edc>] (irq_exit+0xd4/0x110) [ 104.466763] r10:c10684f0 r9:c1200000 r8:ef00c000 r7:00000001 r6:00000000 r5:00000000 [ 104.474625] r4:c1068cfc [ 104.477172] [<c0232e08>] (irq_exit) from [<c0288e4c>] (__handle_domain_irq+0x68/0xbc) [ 104.485040] [<c0288de4>] (__handle_domain_irq) from [<c0564890>] (gic_handle_irq+0x44/0x80) [ 104.493429] r9:c1200000 r8:fa213000 r7:c1201eb0 r6:fa212000 r5:fa21200c r4:c1205104 [ 104.501208] [<c056484c>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c) [ 104.508722] Exception stack(0xc1201eb0 to 0xc1201ef8) [ 104.513796] 1ea0: 00000000 0001d834 ef67650c c0222150 [ 104.522009] 1ec0: ffffe000 c1204c7c c1204cc4 00000001 00000000 00000000 c10684f0 c1201f0c [ 104.530222] 1ee0: c1201eec c1201f00 c0221de4 c0208e94 a0030013 ffffffff [ 104.536867] r9:c1200000 r8:00000000 r7:c1201ee4 r6:ffffffff r5:a0030013 r4:c0208e94 [ 104.544648] [<c0208e6c>] (arch_cpu_idle) from [<c0a2cecc>] (default_idle_call+0x30/0x34) [ 104.552778] [<c0a2ce9c>] (default_idle_call) from [<c025a890>] (do_idle+0x204/0x2ac) [ 104.560557] [<c025a68c>] (do_idle) from [<c025ac24>] (cpu_startup_entry+0x20/0x24) [ 104.568161] r10:c104ba38 r9:c1253e00 r8:ffffffff r7:c1253e00 r6:00000000 r5:00000002 [ 104.576022] r4:000000c7 [ 104.578568] [<c025ac04>] (cpu_startup_entry) from [<c0a27174>] (rest_init+0xd0/0xd4) [ 104.586349] [<c0a270a4>] (rest_init) from [<c1000dfc>] (start_kernel+0x448/0x470) [ 104.593863] r5:00000000 r4:c1253e58 [ 104.597454] [<c10009b4>] (start_kernel) from [<00000000>] ( (null)) [ 104.603835] ---[ end trace 45d8c963d0be86e6 ]--- [ 104.608493] ------------[ cut here ]------------ [ 104.611662] omap_i2c 48070000.i2c: controller timed out [ 104.613134] WARNING: CPU: 0 PID: 0 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380 [ 104.613144] 44000000.ocp:L3 Custom Error: MASTER DSS TARGET DMM_P1 (Read): Data Access in User mode during Functional access [ 104.638808] Modules linked in: xhci_plat_hcd xhci_hcd pru_rproc irq_pruss_intc dwc3 udc_core pruss snd_soc_omap_hdmi ahci_platform libahci_platform pvrsrvkm(O) ti_vpe libahci pruss_soc_bus ti_sc omap_aes_driver libata omap_wdt ti_csc omap_sham omap_des phy_omap_usb2 ti_vpdma des_generic omap_hdq at24 wire crypto_engine dwc3_omap rtc_omap omap_crypto rtc_ds1307 rtc_palmas omap_remoteproc virtio_rpmsg_bus remoteproc sch_fq_codel uio_module_drv(O) uio ftdi_sio usbserial usbcore usb_common jailhouse(O) gdbserverproxy(O) cryptodev(O) cmemk(O) [ 104.686814] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W O 4.19.79-g77dfab56c6 #1 [ 104.695287] Hardware name: Generic DRA74X (Flattened Device Tree) [ 104.701403] Backtrace: [ 104.703868] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 104.711471] r7:c0dfdbb4 r6:60030193 r5:00000000 r4:c12506dc [ 104.717161] [<c020cd54>] (show_stack) from [<c0a12ee0>] (dump_stack+0x90/0xa4) [ 104.724418] [<c0a12e50>] (dump_stack) from [<c022e098>] (__warn+0xdc/0xf8) [ 104.731324] r7:c0dfdbb4 r6:00000009 r5:00000000 r4:c1201bac [ 104.737010] [<c022dfbc>] (__warn) from [<c022dcdc>] (warn_slowpath_fmt+0x50/0x6c) [ 104.744527] r9:ef1ca9c0 r8:f0880264 r7:c0dfdae0 r6:c0e21504 r5:c0dfdb84 r4:c1204c48 [ 104.752308] [<c022dc90>] (warn_slowpath_fmt) from [<c0566554>] (l3_interrupt_handler+0x330/0x380) [ 104.761218] r3:ef21d400 r2:c0dfdb84 [ 104.764807] r5:00000002 r4:80080003 [ 104.768404] [<c0566224>] (l3_interrupt_handler) from [<c02895e8>] (__handle_irq_event_percpu+0x68/0x140) [ 104.777926] r10:c12522f8 r9:ef219f00 r8:00000017 r7:c1201cd8 r6:00000000 r5:ef219f68 [ 104.785788] r4:ef21d8c0 [ 104.788337] [<c0289580>] (__handle_irq_event_percpu) from [<c02896f4>] (handle_irq_event_percpu+0x34/0x88) [ 104.798035] r10:c10684f0 r9:c1200000 r8:ef00c000 r7:00000001 r6:ef219f00 r5:ef219f68 [ 104.805897] r4:c1204c48 [ 104.808445] [<c02896c0>] (handle_irq_event_percpu) from [<c0289788>] (handle_irq_event+0x40/0x64) [ 104.817356] r6:c120a434 r5:ef219f68 r4:ef219f00 [ 104.821996] [<c0289748>] (handle_irq_event) from [<c028d4d8>] (handle_fasteoi_irq+0xc0/0x168) [ 104.830559] r7:00000001 r6:c120a434 r5:ef219f68 r4:ef219f00 [ 104.836246] [<c028d418>] (handle_fasteoi_irq) from [<c02887e4>] (generic_handle_irq+0x2c/0x3c) [ 104.844895] r7:00000001 r6:c1201eb0 r5:00000000 r4:c1068cfc [ 104.850582] [<c02887b8>] (generic_handle_irq) from [<c0288e48>] (__handle_domain_irq+0x64/0xbc) [ 104.859322] [<c0288de4>] (__handle_domain_irq) from [<c0564890>] (gic_handle_irq+0x44/0x80) [ 104.867710] r9:c1200000 r8:fa213000 r7:c1201da0 r6:fa212000 r5:fa21200c r4:c1205104 [ 104.875490] [<c056484c>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c) [ 104.883004] Exception stack(0xc1201da0 to 0xc1201de8) [ 104.888080] 1da0: 2e610000 00000000 2e610000 c1068d40 00000282 00000000 00000000 00000001 [ 104.896294] 1dc0: ef00c000 c1200000 c10684f0 c1201e4c 00200102 c1201df0 00200102 c02020e0 [ 104.904507] 1de0: 60030113 ffffffff [ 104.908011] r9:c1200000 r8:ef00c000 r7:c1201dd4 r6:ffffffff r5:60030113 r4:c02020e0 [ 104.915792] [<c0202038>] (__do_softirq) from [<c0232edc>] (irq_exit+0xd4/0x110) [ 104.923134] r10:c10684f0 r9:c1200000 r8:ef00c000 r7:00000001 r6:00000000 r5:00000000 [ 104.930995] r4:c1068cfc [ 104.933542] [<c0232e08>] (irq_exit) from [<c0288e4c>] (__handle_domain_irq+0x68/0xbc) [ 104.941409] [<c0288de4>] (__handle_domain_irq) from [<c0564890>] (gic_handle_irq+0x44/0x80) [ 104.949798] r9:c1200000 r8:fa213000 r7:c1201eb0 r6:fa212000 r5:fa21200c r4:c1205104 [ 104.957579] [<c056484c>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c) [ 104.965092] Exception stack(0xc1201eb0 to 0xc1201ef8) [ 104.970165] 1ea0: 00000000 0001d834 ef67650c c0222150 [ 104.978379] 1ec0: ffffe000 c1204c7c c1204cc4 00000001 00000000 00000000 c10684f0 c1201f0c [ 104.986592] 1ee0: c1201eec c1201f00 c0221de4 c0208e94 a0030013 ffffffff [ 104.993236] r9:c1200000 r8:00000000 r7:c1201ee4 r6:ffffffff r5:a0030013 r4:c0208e94 [ 105.001017] [<c0208e6c>] (arch_cpu_idle) from [<c0a2cecc>] (default_idle_call+0x30/0x34) [ 105.009146] [<c0a2ce9c>] (default_idle_call) from [<c025a890>] (do_idle+0x204/0x2ac) [ 105.016927] [<c025a68c>] (do_idle) from [<c025ac24>] (cpu_startup_entry+0x20/0x24) [ 105.024530] r10:c104ba38 r9:c1253e00 r8:ffffffff r7:c1253e00 r6:00000000 r5:00000002 [ 105.032392] r4:000000c7 [ 105.034939] [<c025ac04>] (cpu_startup_entry) from [<c0a27174>] (rest_init+0xd0/0xd4) [ 105.042718] [<c0a270a4>] (rest_init) from [<c1000dfc>] (start_kernel+0x448/0x470) [ 105.050233] r5:00000000 r4:c1253e58 [ 105.053824] [<c10009b4>] (start_kernel) from [<00000000>] ( (null)) [ 105.060204] ---[ end trace 45d8c963d0be86e7 ]--- [ 105.064868] ------------[ cut here ]------------ [ 105.069511] WARNING: CPU: 0 PID: 0 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380 [ 105.071668] thermal thermal_zone5: failed to read out thermal zone (-110) [ 105.078685] 44000000.ocp:L3 Custom Error: MASTER DSS TARGET DMM_P1 (Read): Data Access in User mode during Functional access [ 105.096755] Modules linked in: xhci_plat_hcd xhci_hcd pru_rproc irq_pruss_intc dwc3 udc_core pruss snd_soc_omap_hdmi ahci_platform libahci_platform pvrsrvkm(O) ti_vpe libahci pruss_soc_bus ti_sc omap_aes_driver libata omap_wdt ti_csc omap_sham omap_des phy_omap_usb2 ti_vpdma des_generic omap_hdq at24 wire crypto_engine dwc3_omap rtc_omap omap_crypto rtc_ds1307 rtc_palmas omap_remoteproc virtio_rpmsg_bus remoteproc sch_fq_codel uio_module_drv(O) uio ftdi_sio usbserial usbcore usb_common jailhouse(O) gdbserverproxy(O) cryptodev(O) cmemk(O) [ 105.144759] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W O 4.19.79-g77dfab56c6 #1 [ 105.153232] Hardware name: Generic DRA74X (Flattened Device Tree) [ 105.159350] Backtrace: [ 105.161816] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 105.169418] r7:c0dfdbb4 r6:60030193 r5:00000000 r4:c12506dc [ 105.175107] [<c020cd54>] (show_stack) from [<c0a12ee0>] (dump_stack+0x90/0xa4) [ 105.182363] [<c0a12e50>] (dump_stack) from [<c022e098>] (__warn+0xdc/0xf8) [ 105.189268] r7:c0dfdbb4 r6:00000009 r5:00000000 r4:c1201bac [ 105.194955] [<c022dfbc>] (__warn) from [<c022dcdc>] (warn_slowpath_fmt+0x50/0x6c) [ 105.202473] r9:ef1ca9c0 r8:f0880264 r7:c0dfdae0 r6:c0e21504 r5:c0dfdb84 r4:c1204c48 [ 105.210253] [<c022dc90>] (warn_slowpath_fmt) from [<c0566554>] (l3_interrupt_handler+0x330/0x380) [ 105.219163] r3:ef21d400 r2:c0dfdb84 [ 105.222753] r5:00000002 r4:80080003 [ 105.226350] [<c0566224>] (l3_interrupt_handler) from [<c02895e8>] (__handle_irq_event_percpu+0x68/0x140) [ 105.235873] r10:c12522f8 r9:ef219f00 r8:00000017 r7:c1201cd8 r6:00000000 r5:ef219f68 [ 105.243735] r4:ef21d8c0 [ 105.246284] [<c0289580>] (__handle_irq_event_percpu) from [<c02896f4>] (handle_irq_event_percpu+0x34/0x88) [ 105.255981] r10:c10684f0 r9:c1200000 r8:ef00c000 r7:00000001 r6:ef219f00 r5:ef219f68 [ 105.263842] r4:c1204c48 [ 105.266391] [<c02896c0>] (handle_irq_event_percpu) from [<c0289788>] (handle_irq_event+0x40/0x64) [ 105.275301] r6:c120a434 r5:ef219f68 r4:ef219f00 [ 105.279942] [<c0289748>] (handle_irq_event) from [<c028d4d8>] (handle_fasteoi_irq+0xc0/0x168) [ 105.288505] r7:00000001 r6:c120a434 r5:ef219f68 r4:ef219f00 [ 105.294191] [<c028d418>] (handle_fasteoi_irq) from [<c02887e4>] (generic_handle_irq+0x2c/0x3c) [ 105.302841] r7:00000001 r6:c1201eb0 r5:00000000 r4:c1068cfc [ 105.308529] [<c02887b8>] (generic_handle_irq) from [<c0288e48>] (__handle_domain_irq+0x64/0xbc) [ 105.317268] [<c0288de4>] (__handle_domain_irq) from [<c0564890>] (gic_handle_irq+0x44/0x80) [ 105.325657] r9:c1200000 r8:fa213000 r7:c1201da0 r6:fa212000 r5:fa21200c r4:c1205104 [ 105.333437] [<c056484c>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c) [ 105.340951] Exception stack(0xc1201da0 to 0xc1201de8) [ 105.346027] 1da0: 2e610000 00000000 2e610000 c1068d40 00000282 00000000 00000000 00000001 [ 105.354241] 1dc0: ef00c000 c1200000 c10684f0 c1201e4c 00200102 c1201df0 00200102 c02020e0 [ 105.362453] 1de0: 60030113 ffffffff [ 105.365959] r9:c1200000 r8:ef00c000 r7:c1201dd4 r6:ffffffff r5:60030113 r4:c02020e0 [ 105.373739] [<c0202038>] (__do_softirq) from [<c0232edc>] (irq_exit+0xd4/0x110) [ 105.381082] r10:c10684f0 r9:c1200000 r8:ef00c000 r7:00000001 r6:00000000 r5:00000000 [ 105.388944] r4:c1068cfc [ 105.391492] [<c0232e08>] (irq_exit) from [<c0288e4c>] (__handle_domain_irq+0x68/0xbc) [ 105.399360] [<c0288de4>] (__handle_domain_irq) from [<c0564890>] (gic_handle_irq+0x44/0x80) [ 105.407750] r9:c1200000 r8:fa213000 r7:c1201eb0 r6:fa212000 r5:fa21200c r4:c1205104 [ 105.415529] [<c056484c>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c) [ 105.423042] Exception stack(0xc1201eb0 to 0xc1201ef8) [ 105.428117] 1ea0: 00000000 0001d834 ef67650c c0222150 [ 105.436331] 1ec0: ffffe000 c1204c7c c1204cc4 00000001 00000000 00000000 c10684f0 c1201f0c [ 105.444544] 1ee0: c1201eec c1201f00 c0221de4 c0208e94 a0030013 ffffffff [ 105.451189] r9:c1200000 r8:00000000 r7:c1201ee4 r6:ffffffff r5:a0030013 r4:c0208e94 [ 105.458970] [<c0208e6c>] (arch_cpu_idle) from [<c0a2cecc>] (default_idle_call+0x30/0x34) [ 105.467099] [<c0a2ce9c>] (default_idle_call) from [<c025a890>] (do_idle+0x204/0x2ac) [ 105.474879] [<c025a68c>] (do_idle) from [<c025ac24>] (cpu_startup_entry+0x20/0x24) [ 105.482483] r10:c104ba38 r9:c1253e00 r8:ffffffff r7:c1253e00 r6:00000000 r5:00000002 [ 105.490345] r4:000000c7 [ 105.492891] [<c025ac04>] (cpu_startup_entry) from [<c0a27174>] (rest_init+0xd0/0xd4) [ 105.500673] [<c0a270a4>] (rest_init) from [<c1000dfc>] (start_kernel+0x448/0x470) [ 105.508187] r5:00000000 r4:c1253e58 [ 105.511778] [<c10009b4>] (start_kernel) from [<00000000>] ( (null)) [ 105.518158] ---[ end trace 45d8c963d0be86e8 ]--- [ 105.522819] ------------[ cut here ]---------
omapdss error: HDMI I2C Master Error 44000000.ocp:L3 Custom Error: MASTER GPU_P1 TARGET DMM_P1 (Read): Data Access in User mode during Functional access 44000000.ocp:L3 Custom Error: MASTER BB2D TARGET DMM_P2 (Read): Data Access in User mode during Functional access 44000000.ocp:L3 Custom Error: MASTER DSS TARGET DMM_P1 (Read): Data Access in User mode during Functional access 44000000.ocp:L3 Custom Error: MASTER DSS TARGET DMM_P1 (Read): Data Access in User mode during Functional access 44000000.ocp:L3 Custom Error: MASTER DSS TARGET DMM_P1 (Read): Data Access in User mode during Functional access 44000000.ocp:L3 Custom Error: MASTER DSS TARGET DMM_P1 (Read): Data Access in User mode during Functional access 44000000.ocp:L3 Custom Error: MASTER DSS TARGET DMM_P1 (Read): Data Access in User mode during Functional access 44000000.ocp:L3 Custom Error: MASTER DSS TARGET DMM_P1 (Read): Data Access in User mode during Functional access 44000000.ocp:L3 Custom Error: MASTER DSS TARGET DMM_P1 (Read): Data Access in User mode during Functional access
Our hdmi screen photos shared below:
If you can give any solution for solve this problem, we will be glad.
Thank you.
