Hi
Im using TQ's MBa57xx card and for the i need to change pinmux from tose used in TI's idk. With the manuals https://www.ti.com/lit/an/sprac44a/sprac44a.pdf and http://software-dl.ti.com/processor-sdk-rtos/esd/docs/latest/rtos/index_board.html
Hi
Hi
For some reason the forum did only posti small part of the guestion so here is the rest:
with the manuals mentioned (later one used thought waybackmachine as your sit has been down since 17.9.2020) i got information that i need to change four files on the folder ..\ti\pdk_am57xx_1_0_17\packages\ti\board\src and rebuild the project. Anyhow i have not been able to find instructions for the rebuilding itself.
I using TQ's TQMa57xx board and it uses different pinmux compared to idkAM574x and therefore i need to change that.
Id like to use the examples which can be build with the pdk. Is there any changes i need to make to those after compiling the new board support library or should they work with new pinmux just after compiling the new libruary replacing the idkAM574x library.
Best regards
Tommi Mehtonen
Hi Tommi,
I think you should try to explain your question again.
Karthik
