I was trying to execute reboot command on Linux A72 side.
It gets stuck and will not perform reboot.
Need inputs, what might be causing this behavior.
After executing reboot, attaching the end logs, we have waited for more than 30 minutes and system will not restart.
[ OK ] Stopped target Swap.
[ OK ] Reached target Shutdown.
[ OK ] Reached target Final Step.
Starting Reboot...
[ 247.393330] watchdog: watchdog0: nowayout prevents watchdog being stopped!
[ 247.400221] watchdog: watchdog0: nowayout prevents watchdog being stopped!
[ 247.407122] watchdog: watchdog0: watchdog did not stop!
[ 247.415619] systemd-shutdow: 23 output lines suppressed due to ratelimiting
[ 247.452332] systemd-shutdown[1]: Syncing filesystems and block devices.
[ 247.467115] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[ 247.478177] systemd-journald[153]: Received SIGTERM from PID 1 (systemd-shutdow).
[ 247.501471] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[ 247.511501] systemd-shutdown[1]: Hardware watchdog 'K3 RTI Watchdog', version 0
[ 247.519642] systemd-shutdown[1]: Unmounting file systems.
[ 247.526376] [1115]: Remounting '/' read-only in with options '(null)'.
[ 247.684563] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 247.690595] systemd-shutdown[1]: All filesystems unmounted.
[ 247.696164] systemd-shutdown[1]: Deactivating swaps.
[ 247.701185] systemd-shutdown[1]: All swaps deactivated.
[ 247.706407] systemd-shutdown[1]: Detaching loop devices.
[ 247.713086] systemd-shutdown[1]: All loop devices detached.
[ 247.729712] reboot: Restarting system
-------------------Nothing happens after this----------------------------------------
