• Resolved
CCS/TMDSIDK572: Code Composer Studo on linux
Genius 4695 points
Part Number: TMDSIDK572
I'm reading and doing procedure in following URL.
1.In new connection window, after I specified ssh.shells, "Next" button is not active and  I can't proceed to next step.
   Are there any possible reasons why?
   Could you tell me advice where to check configurations?
2.Is it possible to debug the behavior of DSP, IPU, other peripheral etc. in this way?
U-SK
  • Guru 331555 points
    U-SK
    I assume you are using a later version of CCS than the one in the document (6.1). You are likely running into the below issue:
    https://bugs.eclipse.org/bugs/show_bug.cgi?id=472774
    RSE is not developed from the CCS team but by the Eclipse community.
    U-SK
    RSE is for communication a remote system (in this case, embedded Linux) to browse the file system, transfer files, etc. Check the Eclipse documentation for more information on RSE:
    https://help.eclipse.org/2020-09/index.jsp?topic=%2Forg.eclipse.rse.doc.user%2Fgettingstarted%2Fg_start.html
    ki
    Did you read the CCS Forum Guidelines & FAQ? If not, PLEASE read it. If you haven't read it in awhile, please read it again to see if any updates were made.
    Having CCS problems? Check out the CCS Troubleshooting Guide
    Looking for CCS Training/Documentation? Check out the CCS Resources page
    Curious about the status of a bug and know the tracking ID? Track it via the public bug tracking portal
    NOTE: When a bug is filed and a tracking ID is provided, the thread may then be suggested as "TI Thinks Resolved". Why? Please read the first FAQ of the CCS Forum Guidelines & FAQ
  • Genius 4695 points
    In reply to Ki:
    Hi ki,
    Thank you for your reply.
    I will try using CCSv6.1.1.
    Regarding debug, I understand debug of application running on A15 is possible according to following.
    I would like to know whether debug is possible with the application running on DSP/IPU or the application using some peripheral driver.
    In code composer studio on linux, can we compile following project?
     -application running on DSP/IPU
       -application using some peripherals(USB, timer, SPI, etc)
    U-SK
    In reply to U-SK:
    U-SK
    GDB debug would get linux application level debug visibility. For the above, you'd want CCS low-level JTAG debug. See the below presentation for more details:
    https://dev.ti.com/tirex/explore/node?node=AFh9r0YTTAqSBoDhP3BjRQ__FUz-xrs__LATEST
    U-SK
    I would assume so. However any details is beyond my area of expertise.
    ki
    In reply to Ki:
    Hi ki,
    I understand.
    U-SK
    In reply to Ki:
    Ki
    I was able to experiment with the workaround (last comment in the link) and it appears to have worked for me with CCS 10.1.1. I installed the TM Terminal and TM Terminal RSE add-in packages like below (under 'Help -> Install New Software'):
    Once installed, I then was able to open a terminal with the context menu on the RSE connection:
    This is the functionality that was missing.
    Hope this helps
    ki
