When the Linux is loaded after couple of minutes I see this message.
[ 268.626084] omap-mailbox 48840000.mailbox: Try increasing MBOX_TX_QUEUE_LEN
[ 268.633088] omap-rproc 58820000.ipu: PM mbox_send_message failed: -105
What can be a reason and how to resolve it?
This is my boot_log:
[ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.19.94-gbe5389fd85 (root@Pc) (gcc version 8.4.0 (Ubuntu/Linaro 8.4.0-1ubuntu1~18.04)) #7 SMP PREEMPT Fri Oct 16 14:30:44 EET 2020 [ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [ 0.000000] OF: fdt: Machine model: TI AM5748 IDK [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB [ 0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB [ 0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009d000000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB [ 0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatible id shared-dma-pool [ 0.000000] cma: Reserved 24 MiB at 0x00000000fd400000 [ 0.000000] OMAP4: Map 0x00000000fed00000 to (ptrval) for dram barrier [ 0.000000] Hit pending asynchronous external abort (FSR=0x00000211) during first unmask, this is most likely caused by a firmware/bootloader bug. [ 0.000000] On node 0 totalpages: 412672 [ 0.000000] DMA zone: 1152 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 122624 pages, LIFO batch:31 [ 0.000000] HighMem zone: 290048 pages, LIFO batch:63 [ 0.000000] DRA762 ES1.0 [ 0.000000] random: get_random_bytes called from start_kernel+0xb4/0x470 with crng_init=0 [ 0.000000] percpu: Embedded 15 pages/cpu s32396 r8192 d20852 u61440 [ 0.000000] pcpu-alloc: s32396 r8192 d20852 u61440 alloc=15*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 411520 [ 0.000000] Kernel command line: console=ttyS2,115200n8 root=PARTUUID=58aa3047-02 rw [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Memory: 1462308K/1650688K available (10240K kernel code, 340K rwdata, 2872K rodata, 2048K init, 272K bss, 32732K reserved, 155648K cma-reserved, 1135616K highmem) [ 0.000000] Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xffc00000 - 0xfff00000 (3072 kB) vmalloc : 0xe0800000 - 0xff800000 ( 496 MB) lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .text : 0x(ptrval) - 0x(ptrval) (12256 kB) .init : 0x(ptrval) - 0x(ptrval) (2048 kB) .data : 0x(ptrval) - 0x(ptrval) ( 341 kB) .bss : 0x(ptrval) - 0x(ptrval) ( 273 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] Tasks RCU enabled. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] OMAP clockevent source: timer1 at 32786 Hz [ 0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns [ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns [ 0.000018] Switching to timer-based delay loop, resolution 162ns [ 0.000288] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns [ 0.000297] OMAP clocksource: 32k_counter at 32768 Hz [ 0.000749] Console: colour dummy device 80x30 [ 0.000792] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475) [ 0.000806] pid_max: default: 32768 minimum: 301 [ 0.000926] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.000939] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.001478] CPU: Testing write buffer coherency: ok [ 0.001513] CPU0: Spectre v2: using ICIALLU workaround [ 0.001721] /cpus/cpu@0 missing clock-frequency property [ 0.001741] /cpus/cpu@1 missing clock-frequency property [ 0.001755] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.059917] Setting up static identity map for 0x80200000 - 0x80200060 [ 0.079929] rcu: Hierarchical SRCU implementation. [ 0.100121] EFI services will not be available. [ 0.119987] smp: Bringing up secondary CPUs ... [ 0.200353] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.200359] CPU1: Spectre v2: using ICIALLU workaround [ 0.200482] smp: Brought up 1 node, 2 CPUs [ 0.200495] SMP: Total of 2 processors activated (24.59 BogoMIPS). [ 0.200503] CPU: All CPU(s) started in HYP mode. [ 0.200511] CPU: Virtualization extensions available. [ 0.200940] devtmpfs: initialized [ 0.218247] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0 [ 0.218499] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.218518] futex hash table entries: 512 (order: 3, 32768 bytes) [ 0.221135] pinctrl core: initialized pinctrl subsystem [ 0.221647] DMI not present or invalid. [ 0.221917] NET: Registered protocol family 16 [ 0.223007] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.223895] omap_hwmod: l3_main_2 using broken dt data from ocp [ 0.416104] cpuidle: using governor ladder [ 0.416139] cpuidle: using governor menu [ 0.426344] gpio gpiochip0: (gpio-0-31): added GPIO chardev (254:0) [ 0.426411] gpiochip_setup_dev: registered GPIOs 0 to 31 on device: gpiochip0 (gpio-0-31) [ 0.426454] OMAP GPIO hardware version 0.1 [ 0.427072] gpio gpiochip1: (gpio-32-63): added GPIO chardev (254:1) [ 0.427140] gpiochip_setup_dev: registered GPIOs 32 to 63 on device: gpiochip1 (gpio-32-63) [ 0.427768] gpio gpiochip2: (gpio-64-95): added GPIO chardev (254:2) [ 0.427837] gpiochip_setup_dev: registered GPIOs 64 to 95 on device: gpiochip2 (gpio-64-95) [ 0.428468] gpio gpiochip3: (gpio-96-127): added GPIO chardev (254:3) [ 0.428533] gpiochip_setup_dev: registered GPIOs 96 to 127 on device: gpiochip3 (gpio-96-127) [ 0.429155] gpio gpiochip4: (gpio-128-159): added GPIO chardev (254:4) [ 0.429219] gpiochip_setup_dev: registered GPIOs 128 to 159 on device: gpiochip4 (gpio-128-159) [ 0.429854] gpio gpiochip5: (gpio-160-191): added GPIO chardev (254:5) [ 0.429918] gpiochip_setup_dev: registered GPIOs 160 to 191 on device: gpiochip5 (gpio-160-191) [ 0.430572] gpio gpiochip6: (gpio-192-223): added GPIO chardev (254:6) [ 0.430642] gpiochip_setup_dev: registered GPIOs 192 to 223 on device: gpiochip6 (gpio-192-223) [ 0.431278] gpio gpiochip7: (gpio-224-255): added GPIO chardev (254:7) [ 0.431342] gpiochip_setup_dev: registered GPIOs 224 to 255 on device: gpiochip7 (gpio-224-255) [ 0.451218] No ATAGs? [ 0.451287] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.451303] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.452143] OMAP DMA hardware revision 0.0 [ 0.464097] edma 43300000.edma: memcpy is disabled [ 0.467483] edma 43300000.edma: TI EDMA DMA engine driver [ 0.474659] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported) [ 0.475187] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator-vmain[0]' [ 0.475420] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator-v3_3d[0]' [ 0.475661] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator-vtt[0]' [ 0.478131] omap-iommu 40d01000.mmu: 40d01000.mmu registered [ 0.478307] omap-iommu 40d02000.mmu: 40d02000.mmu registered [ 0.478562] omap-iommu 58882000.mmu: 58882000.mmu registered [ 0.478805] omap-iommu 55082000.mmu: 55082000.mmu registered [ 0.479173] omap-iommu 41501000.mmu: 41501000.mmu registered [ 0.479351] omap-iommu 41502000.mmu: 41502000.mmu registered [ 0.479619] iommu: Adding device 58820000.ipu to group 1 [ 0.479696] iommu: Adding device 55020000.ipu to group 2 [ 0.479823] iommu: Adding device 40800000.dsp to group 0 [ 0.480046] iommu: Adding device 41000000.dsp to group 3 [ 0.481325] SCSI subsystem initialized [ 0.481494] libata version 3.00 loaded. [ 0.482488] palmas 0-0058: Irq flag is 0x00000004 [ 0.512630] palmas 0-0058: Muxing GPIO 2b, PWM 0, LED 0 [ 0.514324] SMPS12: supplied by regulator-dummy [ 0.516018] SMPS3: supplied by VMAIN [ 0.517588] SMPS45: supplied by regulator-dummy [ 0.519409] SMPS6: supplied by VMAIN [ 0.521067] SMPS7: supplied by VMAIN [ 0.522906] SMPS8: supplied by VMAIN [ 0.524159] SMPS9: supplied by VMAIN [ 0.525100] LDO1: supplied by VMAIN [ 0.531212] random: fast init done [ 0.531633] LDO2: supplied by VMAIN [ 0.541496] LDO3: supplied by VMAIN [ 0.551492] LDO4: supplied by VMAIN [ 0.561520] LDO5: supplied by regulator-dummy [ 0.562202] LDO6: supplied by regulator-dummy [ 0.562885] LDO7: supplied by regulator-dummy [ 0.563553] LDO8: supplied by regulator-dummy [ 0.564224] LDO9: supplied by VMAIN [ 0.571838] LDOLN: supplied by VMAIN [ 0.581540] LDOUSB: supplied by VMAIN [ 0.593526] gpiochip_find_base: found new base at 504 [ 0.593666] gpio gpiochip8: (48070000.i2c:tps659038@58:tps659038_gpio): added GPIO chardev (254:8) [ 0.593735] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip8 (48070000.i2c:tps659038@58:tps659038_gpio) [ 0.594184] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz [ 0.594396] media: Linux media interface: v0.10 [ 0.594434] videodev: Linux video capture interface: v2.00 [ 0.594508] pps_core: LinuxPPS API ver. 1 registered [ 0.594518] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.594541] PTP clock support registered [ 0.594571] EDAC MC: Ver: 3.0.0 [ 0.601574] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400 [ 0.601823] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400 [ 0.602321] Advanced Linux Sound Architecture Driver Initialized. [ 0.603070] clocksource: Switched to clocksource arch_sys_counter [ 0.611260] NET: Registered protocol family 2 [ 0.611822] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes) [ 0.611851] TCP established hash table entries: 4096 (order: 2, 16384 bytes) [ 0.611893] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 0.611962] TCP: Hash tables configured (established 4096 bind 4096) [ 0.612029] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 0.612053] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 0.612176] NET: Registered protocol family 1 [ 0.632609] RPC: Registered named UNIX socket transport module. [ 0.632620] RPC: Registered udp transport module. [ 0.632629] RPC: Registered tcp transport module. [ 0.632637] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.632649] PCI: CLS 0 bytes, default 64 [ 0.633653] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 0.633860] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available [ 0.634823] Initialise system trusted keyrings [ 0.634953] workingset: timestamp_bits=14 max_order=19 bucket_order=5 [ 0.639875] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.650359] NFS: Registering the id_resolver key type [ 0.650382] Key type id_resolver registered [ 0.650391] Key type id_legacy registered [ 0.650431] ntfs: driver 2.1.32 [Flags: R/O]. [ 0.652057] Key type asymmetric registered [ 0.652069] Asymmetric key parser 'x509' registered [ 0.652123] bounce: pool size: 64 pages [ 0.652158] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.652169] io scheduler noop registered [ 0.652178] io scheduler deadline registered [ 0.652269] io scheduler cfq registered (default) [ 0.652281] io scheduler mq-deadline registered [ 0.652290] io scheduler kyber registered [ 0.657988] pinctrl-single 4a003400.pinmux: 282 pins, size 1128 [ 0.661807] dra7-pcie 51000000.pcie: Linked as a consumer to phy-4a094000.pciephy.1 [ 0.661980] dra7-pcie 51000000.pcie: GPIO lookup for consumer (null) [ 0.661987] dra7-pcie 51000000.pcie: using device tree for GPIO lookup [ 0.662020] of_get_named_gpiod_flags: parsed 'gpios' property of node '/ocp/axi@0/pcie@51000000[0]' - status (0) [ 0.662054] gpio gpiochip2: Persistence not supported for GPIO 23 [ 0.662231] dra7-pcie 51000000.pcie: host bridge /ocp/axi@0/pcie@51000000 ranges: [ 0.662273] dra7-pcie 51000000.pcie: IO 0x20003000..0x20012fff -> 0x00000000 [ 0.662301] dra7-pcie 51000000.pcie: MEM 0x20013000..0x2fffffff -> 0x20013000 [ 1.662574] dra7-pcie 51000000.pcie: Phy link never came up [ 1.662710] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00 [ 1.662724] pci_bus 0000:00: root bus resource [bus 00-ff] [ 1.662736] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] [ 1.662748] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff] [ 1.662784] pci 0000:00:00.0: [104c:8888] type 01 class 0x060400 [ 1.662816] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit] [ 1.662879] pci 0000:00:00.0: supports D1 [ 1.662887] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 1.668610] PCI: bus0: Fast back to back transfers disabled [ 1.674067] PCI: bus1: Fast back to back transfers enabled [ 1.674111] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff 64bit] [ 1.674132] pci 0000:00:00.0: PCI bridge to [bus 01-ff] [ 1.674449] pcieport 0000:00:00.0: Signaling PME with IRQ 173 [ 1.674579] pcieport 0000:00:00.0: AER enabled with IRQ 173 [ 1.678214] V3_3D: supplied by smps9 [ 1.678449] vtt_fixed: supplied by V3_3D [ 1.723306] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 1.726838] console [ttyS2] disabled [ 1.726894] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 45, base_baud = 3000000) is a 8250 [ 2.785383] console [ttyS2] enabled [ 2.790954] omap_rng 48090000.rng: Random Number Generator ver. 20 [ 2.791488] random: crng init done [ 2.798055] omapdss_dss 58000000.dss: Linked as a consumer to regulator.20 [ 2.807705] DSS: OMAP DSS rev 6.1 [ 2.813963] omapdss_hdmi5 58040000.encoder: Linked as a consumer to regulator.13 [ 2.821472] omapdss_hdmi5 58040000.encoder: Dropping the link to regulator.13 [ 2.829046] tpd12s015 encoder@0: GPIO lookup for consumer (null) [ 2.829054] tpd12s015 encoder@0: using device tree for GPIO lookup [ 2.829071] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/encoder@0[0]' [ 2.829085] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/encoder@0[0]' [ 2.829094] tpd12s015 encoder@0: using lookup tables for GPIO lookup [ 2.829102] tpd12s015 encoder@0: No GPIO consumer (null) found [ 2.829110] tpd12s015 encoder@0: GPIO lookup for consumer (null) [ 2.829116] tpd12s015 encoder@0: using device tree for GPIO lookup [ 2.829130] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/encoder@0[1]' [ 2.829143] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/encoder@0[1]' [ 2.829151] tpd12s015 encoder@0: using lookup tables for GPIO lookup [ 2.829157] tpd12s015 encoder@0: No GPIO consumer (null) found [ 2.829164] tpd12s015 encoder@0: GPIO lookup for consumer (null) [ 2.829171] tpd12s015 encoder@0: using device tree for GPIO lookup [ 2.829197] of_get_named_gpiod_flags: parsed 'gpios' property of node '/encoder@0[2]' - status (0) [ 2.829232] gpio gpiochip6: Persistence not supported for GPIO 12 [ 2.829952] connector-hdmi connector@0: GPIO lookup for consumer hpd [ 2.829959] connector-hdmi connector@0: using device tree for GPIO lookup [ 2.829974] of_get_named_gpiod_flags: can't parse 'hpd-gpios' property of node '/connector@0[0]' [ 2.829988] of_get_named_gpiod_flags: can't parse 'hpd-gpio' property of node '/connector@0[0]' [ 2.829997] connector-hdmi connector@0: using lookup tables for GPIO lookup [ 2.830004] connector-hdmi connector@0: No GPIO consumer hpd found [ 2.841487] brd: module loaded [ 2.850712] loop: module loaded [ 2.855448] ahci 4a140000.sata: controller can't do 64bit DMA, forcing 32bit [ 2.862549] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled [ 2.869355] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode [ 2.877961] ahci 4a140000.sata: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst [ 2.887583] scsi host0: ahci [ 2.890770] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 81 [ 2.903631] m25p80 spi0.0: s25fl256s1 (32768 Kbytes) [ 2.908687] 7 fixed-partitions partitions found on MTD device spi0.0 [ 2.915098] Creating 7 MTD partitions on "spi0.0": [ 2.919915] 0x000000000000-0x000000040000 : "QSPI.SPL" [ 2.925803] 0x000000040000-0x000000140000 : "QSPI.u-boot" [ 2.931893] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os" [ 2.938616] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env" [ 2.945074] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1" [ 2.952207] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel" [ 2.958300] 0x0000009e0000-0x000002000000 : "QSPI.file-system" [ 2.965377] mdio_bus fixed-0: GPIO lookup for consumer reset [ 2.965385] mdio_bus fixed-0: using lookup tables for GPIO lookup [ 2.965392] mdio_bus fixed-0: No GPIO consumer reset found [ 2.965419] libphy: Fixed MDIO Bus: probed [ 2.973138] mdio_bus 48485000.mdio: GPIO lookup for consumer reset [ 2.973146] mdio_bus 48485000.mdio: using device tree for GPIO lookup [ 2.973169] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/ethernet@48484000/mdio@48485000[0]' [ 2.973184] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp/ethernet@48484000/mdio@48485000[0]' [ 2.973193] mdio_bus 48485000.mdio: using lookup tables for GPIO lookup [ 2.973201] mdio_bus 48485000.mdio: No GPIO consumer reset found [ 3.033107] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000 [ 3.040802] davinci_mdio 48485000.mdio: detected phy mask fffffffc [ 3.052036] libphy: 48485000.mdio: probed [ 3.056103] davinci_mdio 48485000.mdio: phy[0]: device 48485000.mdio:00, driver Micrel KSZ9031 Gigabit PHY [ 3.065842] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver Micrel KSZ9031 Gigabit PHY [ 3.076269] cpsw 48484000.ethernet: Detected MACID = 90:9a:77:57:03:6c [ 3.082886] cpsw 48484000.ethernet: initialized cpsw ale version 1.4 [ 3.089313] cpsw 48484000.ethernet: ALE Table size 1024 [ 3.094621] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies) [ 3.102596] cpsw 48484000.ethernet: cpsw: Detected MACID = 90:9a:77:57:03:6d [ 3.110929] i2c /dev entries driver [ 3.119433] cpu cpu0: Linked as a consumer to regulator.4 [ 3.124955] cpu cpu0: Linked as a consumer to regulator.27 [ 3.132100] sdhci: Secure Digital Host Controller Interface driver [ 3.138365] sdhci: Copyright(c) Pierre Ossman [ 3.143914] sdhci-pltfm: SDHCI platform and OF driver helper [ 3.150169] sdhci-omap 4809c000.mmc: GPIO lookup for consumer cd [ 3.150175] sdhci-omap 4809c000.mmc: using device tree for GPIO lookup [ 3.150198] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp/mmc@4809c000[0]' - status (0) [ 3.150210] gpio gpiochip5: Persistence not supported for GPIO 27 [ 3.150218] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22) [ 3.159275] sdhci-omap 4809c000.mmc: Got CD GPIO [ 3.163927] sdhci-omap 4809c000.mmc: GPIO lookup for consumer wp [ 3.163931] sdhci-omap 4809c000.mmc: using device tree for GPIO lookup [ 3.163942] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@4809c000[0]' [ 3.163952] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@4809c000[0]' [ 3.163959] sdhci-omap 4809c000.mmc: using lookup tables for GPIO lookup [ 3.163964] sdhci-omap 4809c000.mmc: No GPIO consumer wp found [ 3.164085] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.26 [ 3.171111] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.11 [ 3.177990] sdhci-omap 4809c000.mmc: Dropping the link to regulator.11 [ 3.184614] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.2 [ 3.191527] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.11 [ 3.198440] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_3_3v mode [ 3.231378] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA [ 3.238716] sdhci-omap 480b4000.mmc: GPIO lookup for consumer wp [ 3.238723] sdhci-omap 480b4000.mmc: using device tree for GPIO lookup [ 3.238737] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@480b4000[0]' [ 3.238750] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@480b4000[0]' [ 3.238757] sdhci-omap 480b4000.mmc: using lookup tables for GPIO lookup [ 3.238764] sdhci-omap 480b4000.mmc: No GPIO consumer wp found [ 3.238924] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.2 [ 3.245719] sdhci-omap 480b4000.mmc: Dropping the link to regulator.2 [ 3.252245] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.2 [ 3.283393] mmc1: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA [ 3.291513] of_get_named_gpiod_flags: parsed 'gpios' property of node '/status-leds/cpu0-led[0]' - status (0) [ 3.291550] gpio gpiochip3: Persistence not supported for GPIO 0 [ 3.291555] no flags found for gpios [ 3.291656] of_get_named_gpiod_flags: parsed 'gpios' property of node '/status-leds/usr0-led[0]' - status (0) [ 3.291670] gpio gpiochip2: Persistence not supported for GPIO 11 [ 3.291675] no flags found for gpios [ 3.291768] of_get_named_gpiod_flags: parsed 'gpios' property of node '/status-leds/heartbeat-led[0]' - status (0) [ 3.291781] gpio gpiochip2: Persistence not supported for GPIO 12 [ 3.291786] no flags found for gpios [ 3.291876] of_get_named_gpiod_flags: parsed 'gpios' property of node '/status-leds/cpu1-led[0]' - status (0) [ 3.291889] gpio gpiochip2: Persistence not supported for GPIO 10 [ 3.291894] no flags found for gpios [ 3.291983] of_get_named_gpiod_flags: parsed 'gpios' property of node '/status-leds/usr1-led[0]' - status (0) [ 3.292015] gpio gpiochip6: Persistence not supported for GPIO 23 [ 3.292020] no flags found for gpios [ 3.292116] of_get_named_gpiod_flags: parsed 'gpios' property of node '/status-leds/mmc0-led[0]' - status (0) [ 3.292129] gpio gpiochip6: Persistence not supported for GPIO 22 [ 3.292134] no flags found for gpios [ 3.292756] ledtrig-cpu: registered to indicate activity on CPUs [ 3.305283] NET: Registered protocol family 10 [ 3.310427] Segment Routing with IPv6 [ 3.314162] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 3.320419] NET: Registered protocol family 17 [ 3.325250] Key type dns_resolver registered [ 3.329609] Registering SWP/SWPB emulation handler [ 3.334434] omap_voltage_late_init: Voltage driver support not added [ 3.340834] Power Management for TI OMAP4+ devices. [ 3.346492] Loading compiled-in X.509 certificates [ 3.369555] dmm 4e000000.dmm: workaround for errata i878 in use [ 3.377087] dmm 4e000000.dmm: initialized all PAT entries [ 3.383405] omapdss_hdmi5 58040000.encoder: Linked as a consumer to regulator.13 [ 3.390918] omapdss_hdmi5 58040000.encoder: Dropping the link to regulator.13 [ 3.398572] tpd12s015 encoder@0: GPIO lookup for consumer (null) [ 3.398577] tpd12s015 encoder@0: using device tree for GPIO lookup [ 3.398590] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/encoder@0[0]' [ 3.398600] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/encoder@0[0]' [ 3.398606] tpd12s015 encoder@0: using lookup tables for GPIO lookup [ 3.398611] tpd12s015 encoder@0: No GPIO consumer (null) found [ 3.398617] tpd12s015 encoder@0: GPIO lookup for consumer (null) [ 3.398621] tpd12s015 encoder@0: using device tree for GPIO lookup [ 3.398630] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/encoder@0[1]' [ 3.398638] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/encoder@0[1]' [ 3.398643] tpd12s015 encoder@0: using lookup tables for GPIO lookup [ 3.398648] tpd12s015 encoder@0: No GPIO consumer (null) found [ 3.398653] tpd12s015 encoder@0: GPIO lookup for consumer (null) [ 3.398657] tpd12s015 encoder@0: using device tree for GPIO lookup [ 3.398675] of_get_named_gpiod_flags: parsed 'gpios' property of node '/encoder@0[2]' - status (0) [ 3.398686] gpio gpiochip6: Persistence not supported for GPIO 12 [ 3.399442] omapdss_hdmi5 58040000.encoder: Linked as a consumer to regulator.13 [ 3.403097] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 3.407289] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops) [ 3.420934] ata1.00: ATA-10: Corsair Force LS SSD, S9FM01.8, max UDMA/133 [ 3.421145] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops) [ 3.427764] ata1.00: 117231408 sectors, multi 16: LBA48 NCQ (depth 32) [ 3.442352] ata1.00: configured for UDMA/133 [ 3.443320] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 3.453420] [drm] No driver support for vblank timestamp query. [ 3.457015] scsi 0:0:0:0: Direct-Access ATA Corsair Force LS 01.8 PQ: 0 ANSI: 5 [ 3.459510] [drm] Cannot find any crtc or sizes [ 3.472355] sd 0:0:0:0: [sda] 117231408 512-byte logical blocks: (60.0 GB/55.9 GiB) [ 3.480220] sd 0:0:0:0: [sda] Write Protect is off [ 3.485970] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 0 [ 3.493105] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 3.493191] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 3.493731] hctosys: unable to open rtc device (rtc0) [ 3.508320] ALSA device list: [ 3.511325] No soundcards found. [ 3.518342] sda: sda1 sda2 [ 3.521889] sd 0:0:0:0: [sda] Attached SCSI disk [ 3.527016] EXT4-fs (sda2): mounting ext3 file system using the ext4 subsystem [ 3.572877] EXT4-fs (sda2): recovery complete [ 3.579843] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null) [ 3.587587] VFS: Mounted root (ext3 filesystem) on device 8:2. [ 3.595678] devtmpfs: mounted [ 3.600156] Freeing unused kernel memory: 2048K [ 3.604823] Run /sbin/init as init process [ 3.673552] systemd[1]: System time before build time, advancing clock. [ 3.689298] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid) [ 3.710953] systemd[1]: Detected architecture arm. [ 3.753517] systemd[1]: Set hostname to <am57xx-evm>. [ 3.839360] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling. [ 3.856517] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.) [ 4.003225] systemd[1]: Listening on Network Service Netlink Socket. [ 4.044030] systemd[1]: Listening on Journal Socket (/dev/log). [ 4.075878] systemd[1]: Created slice system-getty.slice. [ 4.118681] systemd[1]: Listening on Process Core Dump Socket. [ 4.154404] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 4.399787] cmemk: loading out-of-tree module taints kernel. [ 4.406841] CMEMK module: reference Linux version 4.19.94 [ 4.412749] allocated heap buffer 0x40500000 of size 0x100000 [ 4.418598] cmemk initialized [ 4.434542] cryptodev: driver 1.9 loaded. [ 4.502396] usbcore: registered new interface driver usbfs [ 4.523251] usbcore: registered new interface driver hub [ 4.528677] usbcore: registered new device driver usb [ 4.548658] usbcore: registered new interface driver ftdi_sio [ 4.553152] [drm] Cannot find any crtc or sizes [ 4.554801] usbserial: USB Serial support registered for FTDI USB Serial Device [ 4.709512] EXT4-fs (sda2): re-mounted. Opts: (null) [ 5.171247] systemd-journald[96]: Received request to flush runtime journal from PID 1 [ 5.445826] omap-rproc 58820000.ipu: ignoring dependency for device, assuming no driver [ 5.482188] omap-rproc 58820000.ipu: ignoring dependency for device, assuming no driver [ 5.507442] omap-rproc 58820000.ipu: assigned reserved memory node ipu1-memory@9d000000 [ 5.521583] remoteproc remoteproc0: 58820000.ipu is available [ 5.549340] omap-rproc 55020000.ipu: ignoring dependency for device, assuming no driver [ 5.578744] remoteproc remoteproc0: powering up 58820000.ipu [ 5.584750] omap-rproc 55020000.ipu: ignoring dependency for device, assuming no driver [ 5.592793] omap-rproc 55020000.ipu: assigned reserved memory node ipu2-memory@95800000 [ 5.623318] remoteproc remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 6887428 [ 5.651703] virtio_rpmsg_bus virtio0: rpmsg host is online [ 5.667397] remoteproc remoteproc1: 55020000.ipu is available [ 5.692570] remoteproc remoteproc0: registered virtio0 (type 7) [ 5.705750] omap-rproc 40800000.dsp: ignoring dependency for device, assuming no driver [ 5.726043] remoteproc remoteproc1: powering up 55020000.ipu [ 5.727316] remoteproc remoteproc0: remote processor 58820000.ipu is now up [ 5.731740] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3747220 [ 5.741926] omap-rproc 40800000.dsp: ignoring dependency for device, assuming no driver [ 5.790153] omap-rproc 40800000.dsp: assigned reserved memory node dsp1-memory@99000000 [ 5.807218] remoteproc remoteproc2: 40800000.dsp is available [ 5.872484] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1 [ 5.901260] omap-rproc 41000000.dsp: ignoring dependency for device, assuming no driver [ 5.910809] Driver for 1-wire Dallas network protocol. [ 5.917414] ov2659 0-0030: GPIO lookup for consumer pwrdn [ 5.917422] ov2659 0-0030: using device tree for GPIO lookup [ 5.917445] of_get_named_gpiod_flags: parsed 'pwrdn-gpios' property of node '/ocp/i2c@48070000/ov2659@30[0]' - status (0) [ 5.917458] gpio gpiochip5: Persistence not supported for GPIO 14 [ 5.926106] ov2659 0-0030: Sensor detection failed (0000, 0) [ 5.932269] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2 [ 5.969687] gpiochip_find_base: found new base at 496 [ 5.969818] gpio gpiochip9: (tpic2810): added GPIO chardev (254:9) [ 5.969878] gpiochip_setup_dev: registered GPIOs 496 to 503 on device: gpiochip9 (tpic2810) [ 5.987911] omap-rproc 41000000.dsp: ignoring dependency for device, assuming no driver [ 5.998994] omap-rproc 41000000.dsp: assigned reserved memory node dsp2-memory@9f000000 [ 6.007687] omap-des 480a5000.des: will run requests pump with realtime priority [ 6.017779] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: GPIO lookup for consumer id [ 6.017786] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using device tree for GPIO lookup [ 6.017799] of_get_named_gpiod_flags: can't parse 'id-gpios' property of node '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]' [ 6.017819] of_get_named_gpiod_flags: parsed 'id-gpio' property of node '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]' - status (0) [ 6.017832] gpio gpiochip2: Persistence not supported for GPIO 16 [ 6.017840] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: GPIO lookup for consumer vbus [ 6.017844] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using device tree for GPIO lookup [ 6.017855] of_get_named_gpiod_flags: can't parse 'vbus-gpios' property of node '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]' [ 6.017870] of_get_named_gpiod_flags: parsed 'vbus-gpio' property of node '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]' - status (0) [ 6.017879] gpio gpiochip2: Persistence not supported for GPIO 26 [ 6.017888] omap_gpio 48057000.gpio: Could not set line 16 debounce to 20000 microseconds (-22) [ 6.025034] omap_hdq 480b2000.1w: OMAP HDQ Hardware Rev 0.:. Driver in Interrupt mode [ 6.040068] remoteproc remoteproc3: 41000000.dsp is available [ 6.040392] rtc rtc0: 48070000.i2c:tps659038@58:tps659038_rtc: dev (253:0) [ 6.046960] pisosr-gpio spi1.0: GPIO lookup for consumer load [ 6.046969] pisosr-gpio spi1.0: using device tree for GPIO lookup [ 6.046997] of_get_named_gpiod_flags: parsed 'load-gpios' property of node '/ocp/spi@480b8000/sn65hvs882@0[0]' - status (0) [ 6.047016] gpio gpiochip2: Persistence not supported for GPIO 19 [ 6.047037] gpiochip_find_base: found new base at 488 [ 6.047233] gpio gpiochip10: (pisosr-gpio): added GPIO chardev (254:10) [ 6.047321] gpiochip_setup_dev: registered GPIOs 488 to 495 on device: gpiochip10 (pisosr-gpio) [ 6.072336] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: rtc core: registered 48070000.i2c:tps659038@58:tps659038_rtc as rtc0 [ 6.099034] remoteproc remoteproc2: powering up 40800000.dsp [ 6.151449] remoteproc remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 20482288 [ 6.210042] omap_rtc 48838000.rtc: char device (253:1) [ 6.210051] omap_rtc 48838000.rtc: registered as rtc1 [ 6.222137] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0 [ 6.228125] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0 [ 6.239839] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin [ 6.270089] w1_master_driver w1_bus_master1: Attaching one wire slave 01.000000000000 crc 3d [ 6.283365] vpe 489d0000.vpe: Device registered as /dev/video0 [ 6.300918] remoteproc remoteproc3: powering up 41000000.dsp [ 6.325479] w1_master_driver w1_bus_master1: Family 1 for 01.000000000000.3d is not registered. [ 6.337962] remoteproc remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 20482288 [ 6.366742] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0 [ 6.372697] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0 [ 6.387035] vip 48990000.vip: loading firmware vpdma-1b8.bin [ 6.397605] net eth1: initializing cpsw version 1.15 (0) [ 6.420664] virtio_rpmsg_bus virtio1: rpmsg host is online [ 6.430514] remoteproc remoteproc1: registered virtio1 (type 7) [ 6.433282] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x65 [ 6.438227] vip 48990000.vip: VPDMA firmware loaded [ 6.448357] remoteproc remoteproc1: remote processor 55020000.ipu is now up [ 6.497825] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x66 [ 6.516817] phy phy-4a084000.phy.3: Linked as a consumer to regulator.21 [ 6.543665] phy phy-4a085000.phy.4: Linked as a consumer to regulator.21 [ 6.560268] libata: exports duplicate symbol ata_dev_printk (owned by kernel) [ 6.590259] Micrel KSZ9031 Gigabit PHY 48485000.mdio:01: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=48485000.mdio:01, irq=POLL) [ 6.619346] virtio_rpmsg_bus virtio2: rpmsg host is online [ 6.626259] remoteproc remoteproc2: registered virtio2 (type 7) [ 6.627696] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ 6.632208] remoteproc remoteproc2: remote processor 40800000.dsp is now up [ 6.665082] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3 [ 6.672585] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3 [ 6.692415] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready [ 6.711984] libata: exports duplicate symbol ata_dev_printk (owned by kernel) [ 6.719253] CAN device driver interface [ 6.725517] omap-aes 4b500000.aes: will run requests pump with realtime priority [ 6.747283] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x3d [ 6.763291] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=644dbd48, irq=89) [ 6.779824] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3 [ 6.800151] omap-aes 4b700000.aes: will run requests pump with realtime priority [ 6.822354] virtio_rpmsg_bus virtio3: rpmsg host is online [ 6.830797] remoteproc remoteproc3: registered virtio3 (type 7) [ 6.851698] [drm] Initialized pvr 1.17.4948957 20110701 for 56000000.gpu on minor 1 [ 6.857194] remoteproc remoteproc3: remote processor 41000000.dsp is now up [ 6.905964] virtio_rpmsg_bus virtio3: creating channel rpmsg-proto addr 0x3d [ 6.980855] net eth0: initializing cpsw version 1.15 (0) [ 7.031865] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ] [ 7.066109] omap-hdmi-audio omap-hdmi-audio.0.auto: snd-soc-dummy-dai <-> 58040000.encoder mapping ok [ 7.110356] omap-hdmi-audio omap-hdmi-audio.0.auto: ASoC: no DMI vendor name! [ 7.197233] Micrel KSZ9031 Gigabit PHY 48485000.mdio:00: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=48485000.mdio:00, irq=POLL) [ 7.272163] mdio_bus 4b2b2400.mdio: GPIO lookup for consumer reset [ 7.272171] mdio_bus 4b2b2400.mdio: using device tree for GPIO lookup [ 7.272193] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/ocp/pruss-soc-bus@4b2a6004/pruss@4b280000/mdio@4b2b2400[0]' - status (0) [ 7.272238] gpio gpiochip4: Persistence not supported for GPIO 8 [ 7.272249] mdio_bus 4b2b2400.mdio: GPIO lookup for consumer reset [ 7.272254] mdio_bus 4b2b2400.mdio: using device tree for GPIO lookup [ 7.272272] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/ocp/pruss-soc-bus@4b2a6004/pruss@4b280000/mdio@4b2b2400[1]' - status (0) [ 7.272280] gpio gpiochip4: Persistence not supported for GPIO 9 [ 7.272290] mdio_bus 4b2b2400.mdio: GPIO lookup for consumer reset [ 7.272295] mdio_bus 4b2b2400.mdio: using device tree for GPIO lookup [ 7.272308] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/pruss-soc-bus@4b2a6004/pruss@4b280000/mdio@4b2b2400[2]' [ 7.272318] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp/pruss-soc-bus@4b2a6004/pruss@4b280000/mdio@4b2b2400[2]' [ 7.272323] mdio_bus 4b2b2400.mdio: using lookup tables for GPIO lookup [ 7.272329] mdio_bus 4b2b2400.mdio: No GPIO consumer reset found [ 7.305943] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 7.323114] davinci_mdio 4b2b2400.mdio: davinci mdio revision 1.6, bus freq 1000000 [ 7.345907] libphy: 4b2b2400.mdio: probed [ 7.371305] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/pruss-soc-bus@4b2a6004/pruss@4b280000/mdio@4b2b2400/ethernet-phy@0[0]' [ 7.404552] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/pruss-soc-bus@4b2a6004/pruss@4b280000/mdio@4b2b2400/ethernet-phy@1[0]' [ 7.404680] davinci_mdio 4b2b2400.mdio: phy[0]: device 4b2b2400.mdio:00, driver unknown [ 7.428384] davinci_mdio 4b2b2400.mdio: phy[1]: device 4b2b2400.mdio:01, driver unknown [ 7.521146] remoteproc remoteproc4: 4b234000.pru is available [ 7.580798] pru-rproc 4b234000.pru: PRU rproc node pru@4b234000 probed successfully [ 7.636473] remoteproc remoteproc5: 4b238000.pru is available [ 7.660823] pru-rproc 4b238000.pru: PRU rproc node pru@4b238000 probed successfully [ 7.724143] remoteproc remoteproc6: 4b2b4000.pru is available [ 7.765247] pru-rproc 4b2b4000.pru: PRU rproc node pru@4b2b4000 probed successfully [ 7.798611] remoteproc remoteproc7: 4b2b8000.pru is available [ 7.840979] pru-rproc 4b2b8000.pru: PRU rproc node pru@4b2b8000 probed successfully [ 7.943779] prueth pruss2_eth: pruss_fw_drop_untagged_vlan 0 [ 7.949483] prueth pruss2_eth: pruss MC Mask (Port 0) ff:ff:ff:ff:ff:ff [ 7.999231] prueth pruss2_eth: pruss MC Mask (Port 1) ff:ff:ff:ff:ff:ff [ 8.044556] prueth pruss2_eth: TI PRU ethernet (type 0) driver initialized [ 8.704102] dwc3 48890000.usb: Failed to get clk 'ref': -2 [ 8.730320] dwc3 488d0000.usb: Failed to get clk 'ref': -2 [ 8.764264] rpmsg_rpc virtio1.rpmsg-rpc.-1.101: probing service dce-callback with src 1024 dst 101 [ 8.779537] NET: Registered protocol family 45 [ 8.799787] rpmsg_rpc virtio1.rpmsg-rpc.-1.102: probing service rpmsg-dce with src 1025 dst 102 [ 8.799892] rpmsg_rpc virtio1.rpmsg-rpc.-1.101: published functions = 4 [ 8.848600] rpmsg_rpc virtio1.rpmsg-rpc.-1.102: published functions = 9 [ 8.935569] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 8.974437] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1 [ 9.031336] iep ptp bc clkid -1 [ 9.034850] remoteproc remoteproc6: powering up 4b2b4000.pru [ 9.042350] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010 [ 9.052328] remoteproc remoteproc6: Booting fw image ti-pruss/am57xx-pru0-prueth-fw.elf, size 7228 [ 9.054447] xhci-hcd xhci-hcd.1.auto: irq 182, io mem 0x48890000 [ 9.067866] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [ 9.069019] pruss 4b280000.pruss: configured system_events[63-0] = 00000600,04500000 [ 9.076255] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 9.091450] usb usb1: Product: xHCI Host Controller [ 9.096481] usb usb1: Manufacturer: Linux 4.19.94-gbe5389fd85 xhci-hcd [ 9.103190] usb usb1: SerialNumber: xhci-hcd.1.auto [ 9.103890] pruss 4b280000.pruss: configured intr_channels = 0x000000d5 host_intr = 0x00000155 [ 9.118118] hub 1-0:1.0: USB hub found [ 9.118864] remoteproc remoteproc6: remote processor 4b2b4000.pru is now up [ 9.122210] hub 1-0:1.0: 1 port detected [ 9.133326] net eth2: started [ 9.134545] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 9.141977] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2 [ 9.142309] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready [ 9.149734] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed [ 9.162233] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 9.170629] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19 [ 9.179230] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 9.186664] usb usb2: Product: xHCI Host Controller [ 9.191574] usb usb2: Manufacturer: Linux 4.19.94-gbe5389fd85 xhci-hcd [ 9.198286] usb usb2: SerialNumber: xhci-hcd.1.auto [ 9.205605] hub 2-0:1.0: USB hub found [ 9.206097] remoteproc remoteproc7: powering up 4b2b8000.pru [ 9.210350] hub 2-0:1.0: 1 port detected [ 9.219650] remoteproc remoteproc7: Booting fw image ti-pruss/am57xx-pru1-prueth-fw.elf, size 7256 [ 9.227345] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 9.229553] pruss 4b280000.pruss: configured system_events[63-0] = 00600000,08a00000 [ 9.243151] pruss 4b280000.pruss: configured intr_channels = 0x0000032a host_intr = 0x000002aa [ 9.248349] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 3 [ 9.253535] remoteproc remoteproc7: remote processor 4b2b8000.pru is now up [ 9.267373] net eth3: started [ 9.271061] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready [ 9.273583] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010 [ 9.287181] xhci-hcd xhci-hcd.2.auto: irq 183, io mem 0x488d0000 [ 9.293559] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [ 9.301875] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 9.309301] usb usb3: Product: xHCI Host Controller [ 9.315432] usb usb3: Manufacturer: Linux 4.19.94-gbe5389fd85 xhci-hcd [ 9.322125] usb usb3: SerialNumber: xhci-hcd.2.auto [ 9.328151] hub 3-0:1.0: USB hub found [ 9.331959] hub 3-0:1.0: 1 port detected [ 9.337101] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 9.342633] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 4 [ 9.350507] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed [ 9.357277] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ 9.365564] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19 [ 9.374026] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 9.381397] usb usb4: Product: xHCI Host Controller [ 9.386361] usb usb4: Manufacturer: Linux 4.19.94-gbe5389fd85 xhci-hcd [ 9.393033] usb usb4: SerialNumber: xhci-hcd.2.auto [ 9.399003] hub 4-0:1.0: USB hub found [ 9.402920] hub 4-0:1.0: 1 port detected [ 12.234805] prueth pruss2_eth eth2: Link is Up - 100Mbps/Full - flow control off [ 12.271942] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready [ 12.701962] NOHZ: local_softirq_pending 08 [ 12.944723] NOHZ: local_softirq_pending 08 [ 13.071918] NOHZ: local_softirq_pending 08 [ 13.243477] NOHZ: local_softirq_pending 08 [ 13.296942] NOHZ: local_softirq_pending 08 [ 13.332374] NOHZ: local_softirq_pending 08 [ 13.337434] NOHZ: local_softirq_pending 08 [ 13.354674] NOHZ: local_softirq_pending 08 [ 13.391886] NOHZ: local_softirq_pending 08 [ 13.449813] NOHZ: local_softirq_pending 08 [ 126.662811] NET: Registered protocol family 15 [ 126.738837] Initializing XFRM netlink socket [ 268.626084] omap-mailbox 48840000.mailbox: Try increasing MBOX_TX_QUEUE_LEN [ 268.633088] omap-rproc 58820000.ipu: PM mbox_send_message failed: -105
BR,
Oleg
