TDA4VM: SDK 7.01 build error
Part Number: TDA4VM
Dear Sir/madam,
I am using TDA4VMEVM.
I downloaded the SDK 7.01 from www.ti.com/.../PROCESSOR-SDK-DRA8X-TDA4X.
It get error message when I build vision_apps.
I use default tiovx/build_flags.mak .
cd vision_apps
make vision_apps
[GCC] Compiling C99 app_ipc_linux.c
/home/jason/ti_tda4x_7_01/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/vision_apps/utils/ipc/src/app_ipc_linux.c:62:10: fatal error: ti_rpmsg_char.h: No such file or directory
62 | #include <ti_rpmsg_char.h>
compilation terminated.
concerto/finale.mak:308: recipe for target '/home/jason/ti_tda4x_7_01/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/vision_apps/out/J7/A72/LINUX/release/module/utils.ipc.src/app_ipc_linux.o' failed
make[1]: *** [/home/jason/ti_tda4x_7_01/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/vision_apps/out/J7/A72/LINUX/release/module/utils.ipc.src/app_ipc_linux.o] Error 1
make[1]: Leaving directory '/home/jason/ti_tda4x_7_01/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/vision_apps'
Makefile:159: recipe for target 'vision_apps' failed
make: *** [vision_apps] Error 2
Could you give me suggestion?
Best regards
-Jason
  • Hi Jason,
    Can you please first try "make sdk" command? This command will build all required/dependent components and then will build vision apps.
    I am assuming that you have run psdk_rtos\scripts\setup_psdk_rtos.sh before starting building..
    Brijesh
  • Hi Brijesh,
    Yes , I did  psdk_rtos\scripts\setup_psdk_rtos.sh before starting building.
    I following your suggestion.
    I tried "make sdk" command.
    But I got same error message.
    make[2]: *** [/home/jason/ti_tda4x_7_01/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/vision_apps/out/J7/A72/LINUX/release/module/utils.ipc.src/app_ipc_linux.o] Error 1
    make[2]: Leaving directory '/home/jason/ti_tda4x_7_01/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/vision_apps'
    make[1]: *** [vision_apps] Error 2
    Makefile:167: recipe for target 'sdk' failed
    make: *** [sdk] Error 2
    I tried to find ti_rpmsg_char.h by "locate" command.
    But it no found ti_rpmsg_char.h file.
    Best regards
    -Jason
  • Hi Jason,
    This file is actually part of the file system. So could you please download the new filesystem from the release link and install it?
    When you run psdk_rtos\scripts\setup_psdk_rtos.sh script, it will give error if filesystem is not installed. can you check if you are seeing any error?
    Brijesh
  • Hi Brijesh,
    I found the problem.
    I installed old version PSDK Linux.
    The build OK after install ti-processor-sdk-rtos-j721e-evm-07_01_00_11-linux-x64-installer.run
    Thank you very much.
    -Jason
  • Hi Jason,
    Glad to know it is resolved.
    Please close the thread if the question is answered.
    Rgds,
    Brijesh
