Hi TI experts,
We have custom board and are using 1G DDR based on PROCESSOR_SDK_VISION 03_07_00_00, to boot from sd or emmc.
A feature to Early boot and late attach of remote cores,and works well.
Try to config DDR 512MB to follow section "6.6 How To - Modify 1GB Linux Memory map to 512MB Linux Memory map" in VisionSDK_UserGuide_MemoryMap.pdf.
Scenario #1
In this case while booting kernel panic happened.
U-Boot SPL 2016.05 (Jan 08 2021 - 00:58:40) DRA722-GP ES2.1 Trying to boot from MMC1 reading dra7-ipu2-fw.lzop Error loading remotecore IPU2!,Continuing with boot ... spl: falcon_args_file not set in environment, falling back to default reading single-stage-boot.dtb reading uImage reading uImage [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.4.84 (user@ubuntu) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #25 SMP PREEMPT Fri Jan 8 00:59:18 PST 2021 [ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [ 0.000000] Machine model: TI DRA718 EVM [ 0.000000] bootconsole [earlycon0] enabled [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000040300000, size 3 MiB [ 0.000000] Reserved memory: initialized node cmem@40300000, compatible id shared-dma-pool [ 0.000000] Reserved memory: regions without no-map are not yet supported [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 32 MiB [ 0.000000] Reserved memory: initialized node ipu2_cma@99000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009d200000, size 32 MiB [ 0.000000] Reserved memory: initialized node cmem@9D200000, compatible id shared-dma-pool [ 0.000000] Reserved memory: regions without no-map are not yet supported [ 0.000000] cma: Reserved 64 MiB at 0x0000000095000000 [ 0.000000] Forcing write-allocate cache policy for SMP [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] OMAP4: Map 0x000000009fd00000 to fe600000 for dram barrier [ 0.000000] Hit pending asynchronous external abort (FSR=0x00000211) during first unmask, this is most likely caused by a firmware/bootloader bug. [ 0.000000] DRA722 ES2.1 [ 0.000000] PERCPU: Embedded 11 pages/cpu @df5d6000 s14912 r8192 d21952 u45056 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 120960 [ 0.000000] Kernel command line: console=ttyO0,115200n8 elevator=noop root=/dev/mmcblk0p2 rw rootwait earlyprintk fixrtc omapdrm.num_crtc=2 consoleblank=0 cma=64M rootfstype=ext4 snd.slots_reserved=1,1 loglevel=7 init=/home/root/init-demo.sh clk_ignore_unused [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Memory: 163556K/488448K available (4610K kernel code, 206K rwdata, 752K rodata, 292K init, 136K bss, 226588K reserved, 98304K cma-reserved, 0K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff800000 ( 496 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0544f74 (5364 kB) [ 0.000000] .init : 0xc0545000 - 0xc058e000 ( 292 kB) [ 0.000000] .data : 0xc058e000 - 0xc05c1840 ( 207 kB) [ 0.000000] .bss : 0xc05c3000 - 0xc05e5364 ( 137 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 32. [ 0.000000] RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1. [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1 [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] OMAP clockevent source: timer1 at 32786 Hz [ 0.000000] Architected cp15 timer(s) running at 6.14MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns [ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns [ 0.008309] Switching to timer-based delay loop, resolution 162ns [ 0.014957] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns [ 0.025215] OMAP clocksource: 32k_counter at 32768 Hz [ 0.030912] Console: colour dummy device 80x30 [ 0.035569] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0' [ 0.042369] This ensures that you still see kernel messages. Please [ 0.048882] update your kernel commandline. [ 0.053275] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475) [ 0.063913] pid_max: default: 32768 minimum: 301 [ 0.068829] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.075720] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.083537] Initializing cgroup subsys io [ 0.087766] Initializing cgroup subsys memory [ 0.092342] Initializing cgroup subsys devices [ 0.096994] Initializing cgroup subsys freezer [ 0.101653] Initializing cgroup subsys perf_event [ 0.106573] Initializing cgroup subsys pids [ 0.110969] CPU: Testing write buffer coherency: ok [ 0.116260] /cpus/cpu@0 missing clock-frequency property [ 0.121803] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.127722] Setting up static identity map for 0x80008380 - 0x800083e0 [ 0.177947] Brought up 1 CPUs [ 0.181080] SMP: Total of 1 processors activated (12.29 BogoMIPS). [ 0.187510] CPU: All CPU(s) started in HYP mode. [ 0.192343] CPU: Virtualization extensions available. [ 0.197921] devtmpfs: initialized [ 0.232545] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0 [ 0.241228] omap_hwmod: l3_main_2 using broken dt data from ocp [ 0.349619] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.359817] futex hash table entries: 256 (order: 2, 16384 bytes) [ 0.371883] pinctrl core: initialized pinctrl subsystem [ 0.378046] NET: Registered protocol family 16 [ 0.383711] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.412777] cpuidle: using governor ladder [ 0.442800] cpuidle: using governor menu [ 0.453828] platform 43300000.edma: Cannot lookup hwmod 'tpcc' [ 0.460180] platform 43400000.tptc: Cannot lookup hwmod 'tptc0' [ 0.466631] platform 43500000.tptc: Cannot lookup hwmod 'tptc1' [ 0.473902] OMAP GPIO hardware version 0.1 [ 0.484675] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 ! [ 0.512508] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.520811] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.527296] omap4_sram_init:Unable to allocate sram needed to handle errata I688 [ 0.534973] omap4_sram_init:Unable to get sram pool needed to handle errata I688 [ 0.542923] OMAP DMA hardware revision 0.0 [ 0.622510] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported) [ 0.632808] edma3-tptc 43400000.tptc: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info [ 0.642043] edma3-tptc 43500000.tptc: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info [ 0.651479] edma 43300000.edma: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info [ 0.660139] edma 43300000.edma: pm_runtime_get_sync() failed [ 0.669296] omap-iommu 40d01000.mmu: 40d01000.mmu registered [ 0.675343] omap-iommu 40d02000.mmu: 40d02000.mmu registered [ 0.681393] omap-iommu 58882000.mmu: 58882000.mmu registered [ 0.687412] omap-iommu 55082000.mmu: 55082000.mmu registered [ 0.695874] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz [ 0.701857] pps_core: LinuxPPS API ver. 1 registered [ 0.707059] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.716534] PTP clock support registered [ 0.720653] EDAC MC: Ver: 3.0.0 [ 0.731189] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400 [ 0.737702] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400 [ 0.744911] clocksource: Switched to clocksource arch_sys_counter [ 0.760782] NET: Registered protocol family 2 [ 0.765846] TCP established hash table entries: 4096 (order: 2, 16384 bytes) [ 0.773198] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 0.779977] TCP: Hash tables configured (established 4096 bind 4096) [ 0.786637] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 0.792725] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 0.799379] NET: Registered protocol family 1 [ 0.804874] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available [ 0.832548] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.838646] ntfs: driver 2.1.32 [Flags: R/O]. [ 0.844385] io scheduler noop registered (default) [ 0.849461] io scheduler deadline registered [ 0.853955] io scheduler cfq registered [ 0.860920] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128 [ 0.868499] pinctrl-single 4a002e8c.pinmux: 1 pins at pa fc002e8c size 4 [ 0.928532] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 0.937907] omap8250 4806a000.serial: Can't verify DMA configuration (-19) [ 0.945568] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 301, base_baud = 3000000) is a 8250 [ 0.954749] console [ttyS0] enabled [ 0.954749] console [ttyS0] enabled [ 0.961960] bootconsole [earlycon0] disabled [ 0.961960] bootconsole [earlycon0] disabled [ 0.971192] omap8250 4806c000.serial: Can't verify DMA configuration (-19) [ 0.978592] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 302, base_baud = 3000000) is a 8250 [ 0.987860] omap8250 48020000.serial: Can't verify DMA configuration (-19) [ 0.995240] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 303, base_baud = 3000000) is a 8250 [ 1.004557] [drm] Initialized drm 1.1.0 20060810 [ 1.009954] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 1.016646] [drm] No driver support for vblank timestamp query. [ 1.022767] [drm] Initialized vdrm 1.0.0 20110917 on minor 0 [ 1.045753] vmemexp device MAJOR num = 249 [ 1.049881] vmemexp class registered [ 1.053583] /dev/vmemexp device registered [ 1.057714] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120 [ 1.063193] libphy: Fixed MDIO Bus: probed [ 1.114943] davinci_mdio 48485000.mdio: davinci mdio revision 1.6 [ 1.121066] libphy: 48485000.mdio: probed [ 1.137332] davinci_mdio 48485000.mdio: phy[0]: device 48485000.mdio:00, driver unknown [ 1.145910] cpsw 48484000.ethernet: Detected MACID = 68:47:49:6f:f0:9e [ 1.152567] cpsw 48484000.ethernet: cpts: overflow check period 800 [ 1.160301] i2c /dev entries driver [ 1.166844] omap_hsmmc 4809c000.mmc: Got CD GPIO [ 1.171953] vsys_3v3: supplied by evm_12v0 [ 1.176136] evm_3v3: supplied by vsys_3v3 [ 1.180172] evm_3v3_sd: supplied by evm_3v3 [ 1.235380] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode [ 1.241765] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode [ 1.295280] omap_hsmmc 480d1000.mmc: no pinctrl state for sdr25 mode [ 1.301664] omap_hsmmc 480d1000.mmc: no pinctrl state for sdr12 mode [ 1.324918] omap_hsmmc 480d1000.mmc: no pinctrl state for hs mode [ 1.366302] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@99000000 [ 1.374123] remoteproc0: 55020000.ipu is available [ 1.394941] remoteproc0: Note: remoteproc is still under development and considered experimental. [ 1.403937] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [ 1.434994] remoteproc0: Direct firmware load for dra7-ipu2-fw.xem4 failed with error -2 [ 1.443205] remoteproc0: Falling back to user helper [ 1.449348] NET: Registered protocol family 10 [ 1.475249] sit: IPv6 over IPv4 tunneling driver [ 1.480434] NET: Registered protocol family 17 [ 1.494930] NET: Registered protocol family 41 [ 1.499520] omap_voltage_late_init: Voltage driver support not added [ 1.515477] Power Management for TI OMAP4+ devices. [ 1.520570] Registering SWP/SWPB emulation handler [ 1.565101] hctosys: unable to open rtc device (rtc0) [ 1.570595] aic_dvdd: disabling [ 1.573754] clk: Not disabling unused clocks [ 1.586763] omap8250 4806a000.serial: failed to request DMA [ 1.592530] Waiting for root device /dev/mmcblk0p2... [ 1.637008] omap_hsmmc 4809c000.mmc: card busy [ 1.701952] mmc0: host does not support reading read-only switch, assuming write-enable [ 1.711927] mmc0: new high speed SDHC card at address 59b4 [ 1.727880] mmcblk0: mmc0:59b4 USD00 14.7 GiB [ 1.733473] mmcblk0: p1 p2 p3 [ 1.857590] mmc1: MAN_BKOPS_EN bit is not set [ 1.866998] mmc1: new HS200 MMC card at address 0001 [ 1.882418] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB [ 1.892640] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 1.900935] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 1.907012] mmcblk1boot0: mmc1:0001 8GTF4R partition 1 4.00 MiB [ 1.913850] devtmpfs: error mounting -2 [ 1.917911] Freeing unused kernel memory: 292K [ 1.922372] This architecture does not have kernel memory protection. [ 1.929130] mmcblk1boot1: mmc1:0001 8GTF4R partition 2 4.00 MiB [ 1.936192] mmcblk1: p1 p2 p3 [ 2.000387] Kernel Entry time 31709 ticks mount: mount point /sys does not exist mount: mount point /dev does not exist mount: mount point /proc does not exist mount: mount point /var/volatile does not exist mkdir: can't create directory '/var/volatile/tmp': No such file or directory System time before build time, advancing clock. [ 2.622947] random: systemd: uninitialized urandom read (16 bytes read, 9 bits of entropy available) [ 2.634578] random: systemd: uninitialized urandom read (16 bytes read, 9 bits of entropy available) [ 2.646250] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN) [ 2.665933] systemd[1]: Detected architecture arm. Welcome to Arago 2016.12! [ 2.672646] systemd[1]: Set hostname to <dra7xx-evm>. [ 2.681201] random: systemd: uninitialized urandom read (16 bytes read, 9 bits of entropy available) [ 2.690443] systemd[1]: Initializing machine ID from random generator. [ 2.753474] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 10 bits of entropy available) [ 2.775912] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 11 bits of entropy available) [ 2.786459] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 11 bits of entropy available) [ 2.799087] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 11 bits of entropy available) [ 2.813982] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 11 bits of entropy available) [ 2.968192] random: systemd: uninitialized urandom read (16 bytes read, 14 bits of entropy available) [ 2.977692] random: systemd: uninitialized urandom read (16 bytes read, 14 bits of entropy available) [ 3.140633] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start [ 3.148536] systemd[1]: sysinit.target: Found dependency on alignment.service/start [ 3.156809] systemd[1]: sysinit.target: Found dependency on sysinit.target/start [ 3.164245] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start [ 3.174361] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start [ SKIP ] Ordering cycle found, skipping alignment.se[ 3.189143] systemd[1]: Listening on Journal Socket (/dev/log). rvice [ 3.198764] systemd[1]: Reached target Swap. [ OK ] Listening on Journal Socket (/dev/log). [ 3.203685] systemd[1]: Listening on Syslog Socket. [ OK ] Reached target Swap. [ OK ] Listening on Syslog Socket. [ 3.227669] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 3.233374] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ OK ] Listening on /dev/initctl Compatibility Named[ 3.246707] systemd[1]: Created slice System Slice. Pipe. [ OK ] Created slice System Slice. [ 3.256633] systemd[1]: Created slice system-serial\x2dgetty.slice. [ OK ] Created slice system-serial\x2dgetty.slice. [ 3.267829] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 3.278716] systemd[1]: Reached target Slices. [ OK ] Reached target Slices. [ 3.288668] systemd[1]: Listening on Network Service Netlink Socket. [ 3.298898] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket.[ 3.311889] systemd[1]: Starting Rebuild Dynamic Linker Cache... Starting Rebuild Dynamic Linker Cache... [ 3.326171] systemd[1]: Starting Rebuild Journal Catalog... Starting Rebuild Journal Catalog... [ 3.339328] systemd[1]: Starting Create list of required static device nodes for the current kernel... Starting Create list of required st... nodes for the current kernel... [ 3.362743] systemd[1]: Starting Journal Service... Starting Journal Service... [ 3.381300] systemd[1]: Mounting /var/volatile... Mounting /var/volatile... [ 3.415713] systemd[1]: Mounting Temporary Directory... Mounting Temporary Directory... [ 3.423533] systemd[1]: Starting Apply Kernel Variables... Starting Apply Kernel Variables... [ 3.456048] systemd[1]: Starting Setup Virtual Console... [ 3.466324] systemd[1]: Started Forward Password Requests to Wall Directory Watch. Starting Setup Virtual Console... [ OK ] Started Forward Password Requests to Wall Dir[ 3.483449] systemd[1]: Created slice system-getty.slice. ectory Watch. [ 3.491278] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Created slice system-getty.slice. [ 3.500525] systemd[1]: Reached target Paths. [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ OK ] Reached target Paths. [ 3.517345] systemd[1]: Mounting POSIX Message Queue File System... [ 3.542894] systemd[1]: Listening on udev Kernel Socket. Mounting POSIX Message Queue File System... [ OK ] Listening on udev Kernel Socket. [ 3.572389] systemd[1]: Starting Rebuild Hardware Database... Starting Rebuild Hardware Database... [ 3.608086] systemd[1]: Mounted POSIX Message Queue File System. [ OK ] Mounted POSIX Message Queue File System. [ 3.627192] systemd[1]: Mounted Temporary Directory. [ OK ] Mounted Temporary Directory. [ 3.671339] systemd[1]: Mounted /var/volatile. [ OK ] Mounted /var/volatile. [ 3.692158] systemd[1]: Started Journal Service. [ OK ] Started Journal Service. [ OK ] Started Create list of required sta...ce nodes for the current kernel. [ OK ] Started Apply Kernel Variables. [ OK ] Started Setup Virtual Console. [ OK ] Started Rebuild Journal Catalog. Starting Create Static Device Nodes in /dev... Starting Flush Journal to Persistent Storage... Starting Load/Save Random Seed... [ OK ] Started Load/Save Random Seed. [ OK ] Started Create Static Device Nodes in /dev. [ 4.690779] systemd-journald[77]: Received request to flush runtime journal from PID 1 [ OK ] Started Flush Journal to Persistent Storage. Starting Create Volatile Files and Directories... Starting udev Kernel Device Manager... [ OK ] Started Create Volatile Files and Directories. Starting Update UTMP about System Boot/Shutdown... Starting Network Time Synchronization... Starting Opkg first boot configure... [ OK ] Started Network Time Synchronization. [ OK ] Started Update UTMP about System Boot/Shutdown. Starting Synchronize System and HW clocks... [ OK ] Reached target System Time Synchronized. [ OK ] Started udev Kernel Device Manager. [FAILED] Failed to start Synchronize System and HW clocks. See 'systemctl status sync-clocks.service' for details. Starting apps.out for lvds output..................................... [ 5.927577] DMA: Module install successful, device major num = 246 [ 5.944077] DRV: Module install successful [ OK ] Started Rebuild Hardware Database. [ OK ] Started Opkg first boot configure. Starting udev Coldplug all Devices... [ OK ] Started apps.out for lvds output...................................... [ 7.278282] omap8250 4806c000.serial: failed to request DMA [ OK ] Started Rebuild Dynamic Linker Cache. Starting Update is Completed... [ 8.085559] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2 [ OK ] Started Update is Completed. [ OK ] Started udev Coldplug all Devices. [ OK ] Found device /dev/ttyS0. [ 8.410245] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm [ 8.471182] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm [ 8.530228] cpu0 supply vdd not found, using dummy regulator [ 8.569259] ti_oppdm 4a003b20.oppdm: Unable to get vbb regulator:-517 [ 8.618964] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm [ 8.700349] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm [ 8.760612] cpu0 supply vdd not found, using dummy regulator [ 8.826749] ti_oppdm 4a003b20.oppdm: Unable to get vbb regulator:-517 [ OK ] Reached target System Initialization. [ OK ] Listening on D-Bus System Message Bus Socket. [ OK ] Listening on dropbear.socket. [ OK ] Reached target Sockets. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target Timers. [ OK ] Reached target Basic System. Starting Login Service... [ OK ] Started D-Bus System Message Bus. [ 9.373047] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm [ 9.448335] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm [ 9.545348] cpu0 supply vdd not found, using dummy regulator [ 9.617809] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3 Starting Network Service... [ 9.651777] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm Starting rc.pvr.service... Starting Permit User Sessions... [ 9.736555] EXT4-fs (mmcblk1p3): recovery complete [ 9.750923] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm [ 9.778286] EXT4-fs (mmcblk1p2): recovery complete [ OK ] Started System Logging Service. [ 9.802127] EXT4-fs (mmcblk1p3): mounted filesystem with ordered data mode. Opts: (null) [ 9.815500] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 9.848129] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ OK ] Started Kernel Logging Service. [ 9.875765] cpu0 supply vdd not found, using dummy regulator [ 9.939636] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3 [ 9.983416] omap-aes 4b500000.aes: Unable to request in DMA channel [ 10.097093] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3 [ 10.114812] net eth0: initializing cpsw version 1.15 (0) [ OK ] Started Network Service. [ 10.135289] omap-aes 4b700000.aes: Unable to request in DMA channel [ OK ] Started Permit User Sessions. [ 10.175773] net eth0: initialized cpsw ale version 1.4 [ 10.223450] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1 [ 10.239637] net eth0: ALE Table size 1024 [ 10.346492] net eth0: phy found : id is : 0x2000a253 [ 10.363407] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ] [ 10.477756] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 10.784046] dmm 4e000000.dmm: workaround for errata i878 in use [ 10.864571] dmm 4e000000.dmm: initialized all PAT entries [ 10.881645] remoteproc0: powering up 55020000.ipu [ 10.905116] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null) [ 10.930538] remoteproc0: Booting fw image dra7-ipu2-fw.xem4, size 6201620 [ 10.967560] [drm] Initialized omapdrm 1.0.0 20110917 on minor 2 [ 11.029004] ------------[ cut here ]------------ [ 11.033652] WARNING: CPU: 0 PID: 14 at drivers/bus/omap_l3_noc.c:147 0xc024ff10() [ 11.041169] 44000000.ocp:L3 Standard Error: MASTER MPU TARGET IPU2 (Read Link): At Address: 0x0008204C : Data Access in User mode during Functional access [ 11.055048] Modules linked in: omapdrm(+) omapdss_base bc_example(O) extcon_usb_gpio pvrsrvkm(O) vfat fat omap_aes_driver omap_sham phy_omap_usb2 ti_abb_regulator ti_opp_domain dwc3_omap extcon omap_des memcache(O) sch_fq_codel [ 11.075454] CPU: 0 PID: 14 Comm: kworker/0:1 Tainted: G O 4.4.84 #25 [ 11.082967] Hardware name: Generic DRA72X (Flattened Device Tree) [ 11.089086] Workqueue: events 0xc02fd554 [ 11.093029] Backtrace: [ 11.095491] Function entered at [<c0013124>] from [<c0013310>] [ 11.101347] r7:c024ff10 r6:200e0193 r5:00000000 r4:c05aa5b8 [ 11.107062] Function entered at [<c00132f8>] from [<c022c248>] [ 11.112917] Function entered at [<c022c1bc>] from [<c0037028>] [ 11.118770] r7:c024ff10 r6:00000093 r5:00000009 r4:dcde98d0 [ 11.124483] Function entered at [<c0036fa0>] from [<c0037090>] [ 11.130337] r8:00000017 r7:c04eb298 r6:00000004 r5:c04eb34c r4:c04eb3fc [ 11.137104] Function entered at [<c003705c>] from [<c024ff10>] [ 11.142959] r3:dcdc7700 r2:c04eb3fc [ 11.146562] r4:80080001 [ 11.149109] Function entered at [<c024fcb4>] from [<c0081fd4>] [ 11.154963] r10:c05c0b29 r9:dcdcb000 r8:00000017 r7:00000000 r6:00000000 r5:dcdcb060 [ 11.162865] r4:dcdc7c00 [ 11.165412] Function entered at [<c0081f20>] from [<c00820c0>] [ 11.171266] r10:00000000 r9:c2834000 r8:dcc06000 r7:00000000 r6:c0595b3c r5:dcdcb060 [ 11.179169] r4:dcdcb000 [ 11.181718] Function entered at [<c0082080>] from [<c0085404>] [ 11.187572] r7:00000000 r6:c0595b3c r5:dcdcb060 r4:dcdcb000 [ 11.193286] Function entered at [<c0085344>] from [<c0081634>] [ 11.199140] r7:00000000 r6:00000000 r5:00000017 r4:c058b41c [ 11.204852] Function entered at [<c0081608>] from [<c008190c>] [ 11.210707] Function entered at [<c00818a8>] from [<c000948c>] [ 11.216560] r9:c2834000 r8:fa213000 r7:fa212000 r6:dcde9a90 r5:fa21200c r4:c05908e4 [ 11.224375] Function entered at [<c000944c>] from [<c0013e00>] [ 11.230231] Exception stack(0xdcde9a90 to 0xdcde9ad8) [ 11.235302] 9a80: dce0fa10 00000000 00000000 00000000 [ 11.243515] 9aa0: 00008000 00000000 dc29f180 00000000 dc29f154 c2834000 00000000 dcde9afc [ 11.251726] 9ac0: dcde9b00 dcde9ae0 c02431e8 c0243144 200e0013 ffffffff [ 11.258365] r9:c2834000 r8:dc29f154 r7:dcde9ac4 r6:ffffffff r5:200e0013 r4:c0243144 [ 11.266181] Function entered at [<c02431cc>] from [<c02aef88>] [ 11.272035] r5:dce96700 r4:dce99210 [ 11.275638] Function entered at [<c02aec74>] from [<c02acc8c>] [ 11.281491] r10:d15e2b80 r9:dce0a610 r8:dc4cc820 r7:dc4cc9a4 r6:dc4cc9ac r5:dc29f154 [ 11.289393] r4:00000000 [ 11.291941] Function entered at [<c02acc00>] from [<c037740c>] [ 11.297795] r7:dc4cc9a4 r6:dc4cc9ac r5:00000000 r4:dc4cc800 [ 11.303508] Function entered at [<c037712c>] from [<c0377f40>] [ 11.309362] r10:dc4cc820 r9:00000002 r8:c04eda28 r7:dc02d410 r6:dc02d5e8 r5:dcde9c3c [ 11.317264] r4:00000002 [ 11.319813] Function entered at [<c0377db4>] from [<c037b274>] [ 11.325667] r10:00000000 r9:00000000 r8:dc02d410 r7:dcde9c30 r6:dc4cc800 r5:dc32e680 [ 11.333568] r4:c0377db4 [ 11.336116] Function entered at [<c037b1b8>] from [<c02783d4>] [ 11.341970] r10:00000000 r9:00000000 r8:00000000 r7:dc02d420 r6:dc02d410 r5:00000000 [ 11.349869] r4:00000000 [ 11.352417] Function entered at [<c02781a4>] from [<c02e96a4>] [ 11.358271] r10:00000000 r9:00000000 r8:00000014 r7:c05b8f00 r6:00000000 r5:dc02d420 [ 11.366171] r4:c05dc1cc [ 11.368719] Function entered at [<c02e94a0>] from [<c02e98bc>] [ 11.374572] r9:00000000 r8:c05dc1a8 r7:00000001 r6:dc02d420 r5:dcde9d50 r4:c05b8f00 [ 11.382386] Function entered at [<c02e9830>] from [<c02e79ec>] [ 11.388240] r7:00000001 r6:c02e9830 r5:dcde9d50 r4:00000000 [ 11.393953] Function entered at [<c02e7984>] from [<c02e93f8>] [ 11.399808] r6:dc02d454 r5:dc02d420 r4:dc02d420 [ 11.404466] Function entered at [<c02e9340>] from [<c02e9930>] [ 11.410321] r7:00000000 r6:c05ac404 r5:dc02d420 r4:dc02d428 [ 11.416032] Function entered at [<c02e991c>] from [<c02e8910>] [ 11.421887] Function entered at [<c02e8884>] from [<c02e6a70>] [ 11.427741] r7:00000000 r6:dc02d420 r5:dc4cc820 r4:dc02d428 [ 11.433453] Function entered at [<c02e667c>] from [<c02e6c14>] [ 11.439307] r10:c0375ac4 r9:dc4cc820 r8:00000060 r7:dc4cc820 r6:dc02d420 r5:c0377bd4 [ 11.447209] r4:dc02d420 [ 11.449756] Function entered at [<c02e6bf8>] from [<c0277fe0>] [ 11.455610] r5:c0377bd4 r4:dc02d410 [ 11.459213] Function entered at [<c0277f2c>] from [<c0378114>] [ 11.465067] r7:dc4cc820 r6:00000007 r5:dc4cc820 r4:dc02d400 [ 11.470780] Function entered at [<c03780c8>] from [<c0375bfc>] [ 11.476635] r7:dc4cc820 r6:dc4cc800 r5:dc02d400 r4:dc230860 [ 11.482347] Function entered at [<c0375ac4>] from [<c0375d14>] [ 11.488201] r9:dc4cc820 r8:c05079b0 r7:c05b8dc4 r6:00000488 r5:dc4cc800 r4:00000000 [ 11.496016] Function entered at [<c0375cb0>] from [<c0375e90>] [ 11.501870] r10:df5d89c0 r9:00000000 r8:df5dc100 r7:00000488 r6:e1b3d000 r5:dc4ce740 [ 11.509771] r4:dc4cc800 r3:ffffffff [ 11.513373] Function entered at [<c0375d98>] from [<c02fd58c>] [ 11.519226] r7:00000000 r6:df5d89c0 r5:dcde4380 r4:dc4ce700 [ 11.524938] Function entered at [<c02fd554>] from [<c004c37c>] [ 11.530792] r4:dc4ce700 [ 11.533340] Function entered at [<c004c258>] from [<c004c698>] [ 11.539194] r10:df5d89c0 r9:dcde4380 r8:00000008 r7:dcde8000 r6:df5d89d4 r5:dcde4398 [ 11.547096] r4:df5d89c0 [ 11.549644] Function entered at [<c004c64c>] from [<c00521d0>] [ 11.555498] r10:00000000 r9:00000000 r8:c004c64c r7:dcde4380 r6:dcde8000 r5:dcdddf40 [ 11.563400] r4:00000000 [ 11.565948] Function entered at [<c00520d0>] from [<c000fb08>] [ 11.571803] r8:00000000 r7:00000000 r6:00000000 r5:c00520d0 r4:dcdddf40 [ 11.578571] ---[ end trace 2f600e4fc5f2059d ]--- [ 11.583364] Unhandled fault: asynchronous external abort (0x1211) at 0x00000000 [ 11.590705] pgd = c0003000 [ 11.593421] [00000000] *pgd=80000080004003, *pmd=00000000 [ 11.598858] Internal error: : 1211 [#1] PREEMPT SMP ARM [ 11.604103] Modules linked in: omapdrm(+) omapdss_base bc_example(O) extcon_usb_gpio pvrsrvkm(O) vfat fat omap_aes_driver omap_sham phy_omap_usb2 ti_abb_regulator ti_opp_domain dwc3_omap extcon omap_des memcache(O) sch_fq_codel [ 11.624496] CPU: 0 PID: 14 Comm: kworker/0:1 Tainted: G W O 4.4.84 #25 [ 11.632007] Hardware name: Generic DRA72X (Flattened Device Tree) [ 11.638125] Workqueue: events 0xc02fd554 [ 11.642068] task: dcc99200 ti: dcde8000 task.ti: dcde8000 [ 11.647490] pc : [<c0243144>] lr : [<c02431e8>] psr: 200e0013 [ 11.647490] sp : dcde9ae0 ip : dcde9b00 fp : dcde9afc [ 11.659015] r10: 00000000 r9 : c2834000 r8 : dc29f154 [ 11.664260] r7 : 00000000 r6 : dc29f180 r5 : 00000000 r4 : 00008000 [ 11.670813] r3 : 00000000 r2 : 00000000 r1 : 00000000 r0 : dce0fa10 [ 11.677367] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel [ 11.684706] Control: 30c5387d Table: 917f2040 DAC: fffffffd [ 11.690475] Process kworker/0:1 (pid: 14, stack limit = 0xdcde8210) [ 11.696766] Stack: (0xdcde9ae0 to 0xdcdea000) [ 11.701142] 9ae0: 00008000 00000000 dce99210 dce96700 dcde9b44 dcde9b00 c02aef88 c02431d8 [ 11.709354] 9b00: 00008000 00000000 dc29f150 dce0a610 c02af030 00000000 dc4cc9ac 00000000 [ 11.717567] 9b20: dc29f154 dc4cc9ac dc4cc9a4 dc4cc820 dce0a610 d15e2b80 dcde9b64 dcde9b48 [ 11.725778] 9b40: c02acc8c c02aec80 dc4cc800 00000000 dc4cc9ac dc4cc9a4 dcde9bac dcde9b68 [ 11.733989] 9b60: c037740c c02acc0c 00000000 dc29f154 dcde9bac d15e2b80 c0278bd4 c0111460 [ 11.742201] 9b80: dc02d410 00000002 dcde9c3c dc02d5e8 dc02d410 c04eda28 00000002 dc4cc820 [ 11.750413] 9ba0: dcde9c14 dcde9bb0 c0377f40 c0377138 00000000 d9004000 c0377b80 c037af00 [ 11.758624] 9bc0: c04eda28 c30b0a50 00000100 dc4cc800 c0377b80 d9004000 dc02d400 c037af00 [ 11.766836] 9be0: dcde9c34 c04c3458 c022de50 c0377db4 dc32e680 dc4cc800 dcde9c30 dc02d410 [ 11.775047] 9c00: 00000000 00000000 dcde9c7c dcde9c18 c037b274 c0377dc0 c04c3454 c30b0550 [ 11.783259] 9c20: dcde9c64 dcde9c30 c01819ec c01817f0 c037af2c c037af00 dc231000 dc231800 [ 11.791472] 9c40: dcde9c64 dcde9c50 c03780a4 c0279a48 dc02d410 00000000 00000000 dc02d410 [ 11.799683] 9c60: dc02d420 00000000 00000000 00000000 dcde9cdc dcde9c80 c02783d4 c037b1c4 [ 11.807894] 9c80: c0183f8c c01807b0 dc02d420 00000000 dc02d410 c05b8f00 00000001 00000000 [ 11.816106] 9ca0: dc02d420 c05b8f00 c0184008 c0183f20 dcde9cdc c05dc1cc dc02d420 00000000 [ 11.824317] 9cc0: c05b8f00 00000014 00000000 00000000 dcde9d04 dcde9ce0 c02e96a4 c02781b0 [ 11.832530] 9ce0: c05b8f00 dcde9d50 dc02d420 00000001 c05dc1a8 00000000 dcde9d24 dcde9d08 [ 11.840741] 9d00: c02e98bc c02e94ac 00000000 dcde9d50 c02e9830 00000001 dcde9d4c dcde9d28 [ 11.848953] 9d20: c02e79ec c02e983c dcc72970 dce9bc38 dc02d420 dc02d420 dc02d420 dc02d454 [ 11.857165] 9d40: dcde9d74 dcde9d50 c02e93f8 c02e7990 dc02d420 00000001 dc02d428 dc02d420 [ 11.865377] 9d60: c05ac404 00000000 dcde9d84 dcde9d78 c02e9930 c02e934c dcde9da4 dcde9d88 [ 11.873587] 9d80: c02e8910 c02e9928 dc02d428 dc4cc820 dc02d420 00000000 dcde9de4 dcde9da8 [ 11.881799] 9da0: c02e6a70 c02e8890 dcde9dcc dcde9db8 c02f3ca4 c00720ec dc02d420 dc02d420 [ 11.890011] 9dc0: c0377bd4 dc02d420 dc4cc820 00000060 dc4cc820 c0375ac4 dcde9dfc dcde9de8 [ 11.898224] 9de0: c02e6c14 c02e6688 dc02d410 c0377bd4 dcde9e1c dcde9e00 c0277fe0 c02e6c04 [ 11.906436] 9e00: dc02d400 dc4cc820 00000007 dc4cc820 dcde9e3c dcde9e20 c0378114 c0277f38 [ 11.914648] 9e20: dc230860 dc02d400 dc4cc800 dc4cc820 dcde9e64 dcde9e40 c0375bfc c03780d4 [ 11.922860] 9e40: 00000000 dc4cc800 00000488 c05b8dc4 c05079b0 dc4cc820 dcde9e94 dcde9e68 [ 11.931072] 9e60: c0375d14 c0375ad0 ffffffff dc4cc800 dc4ce740 e1b3d000 00000488 df5dc100 [ 11.939283] 9e80: 00000000 df5d89c0 dcde9ebc dcde9e98 c0375e90 c0375cbc dcde4380 00000488 [ 11.947495] 9ea0: dc4ce700 dcde4380 df5d89c0 00000000 dcde9edc dcde9ec0 c02fd58c c0375da4 [ 11.955707] 9ec0: dc4ce700 dc4ce740 df5d89c0 dc4ce700 dcde9f1c dcde9ee0 c004c37c c02fd560 [ 11.963919] 9ee0: df5d89c0 df5d89d4 dcde8000 00000008 dcde4380 df5d89c0 dcde4398 df5d89d4 [ 11.972131] 9f00: dcde8000 00000008 dcde4380 df5d89c0 dcde9f54 dcde9f20 c004c698 c004c264 [ 11.980342] 9f20: dcde4380 c0590100 00000000 00000000 dcdddf40 dcde8000 dcde4380 c004c64c [ 11.988554] 9f40: 00000000 00000000 dcde9fac dcde9f58 c00521d0 c004c658 00000000 00000000 [ 11.996766] 9f60: 00000000 dcde4380 00000000 00000000 dcde9f70 dcde9f70 00000000 00000000 [ 12.004977] 9f80: dcde9f80 dcde9f80 dcde9fac dcdddf40 c00520d0 00000000 00000000 00000000 [ 12.013190] 9fa0: 00000000 dcde9fb0 c000fb08 c00520dc 00000000 00000000 00000000 00000000 [ 12.021401] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 12.029612] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000802 00000002 [ 12.037820] Backtrace: [ 12.040281] Function entered at [<c02431cc>] from [<c02aef88>] [ 12.046135] r5:dce96700 r4:dce99210 [ 12.049740] Function entered at [<c02aec74>] from [<c02acc8c>] [ 12.055593] r10:d15e2b80 r9:dce0a610 r8:dc4cc820 r7:dc4cc9a4 r6:dc4cc9ac r5:dc29f154 [ 12.063496] r4:00000000 [ 12.066044] Function entered at [<c02acc00>] from [<c037740c>] [ 12.071898] r7:dc4cc9a4 r6:dc4cc9ac r5:00000000 r4:dc4cc800 [ 12.077609] Function entered at [<c037712c>] from [<c0377f40>] [ 12.083464] r10:dc4cc820 r9:00000002 r8:c04eda28 r7:dc02d410 r6:dc02d5e8 r5:dcde9c3c [ 12.091364] r4:00000002 [ 12.093911] Function entered at [<c0377db4>] from [<c037b274>] [ 12.099766] r10:00000000 r9:00000000 r8:dc02d410 r7:dcde9c30 r6:dc4cc800 r5:dc32e680 [ 12.107665] r4:c0377db4 [ 12.110212] Function entered at [<c037b1b8>] from [<c02783d4>] [ 12.116067] r10:00000000 r9:00000000 r8:00000000 r7:dc02d420 r6:dc02d410 r5:00000000 [ 12.123967] r4:00000000 [ 12.126513] Function entered at [<c02781a4>] from [<c02e96a4>] [ 12.132366] r10:00000000 r9:00000000 r8:00000014 r7:c05b8f00 r6:00000000 r5:dc02d420 [ 12.140268] r4:c05dc1cc [ 12.142816] Function entered at [<c02e94a0>] from [<c02e98bc>] [ 12.148670] r9:00000000 r8:c05dc1a8 r7:00000001 r6:dc02d420 r5:dcde9d50 r4:c05b8f00 [ 12.156486] Function entered at [<c02e9830>] from [<c02e79ec>] [ 12.162340] r7:00000001 r6:c02e9830 r5:dcde9d50 r4:00000000 [ 12.168053] Function entered at [<c02e7984>] from [<c02e93f8>] [ 12.173908] r6:dc02d454 r5:dc02d420 r4:dc02d420 [ 12.178564] Function entered at [<c02e9340>] from [<c02e9930>] [ 12.184418] r7:00000000 r6:c05ac404 r5:dc02d420 r4:dc02d428 [ 12.190130] Function entered at [<c02e991c>] from [<c02e8910>] [ 12.195985] Function entered at [<c02e8884>] from [<c02e6a70>] [ 12.201839] r7:00000000 r6:dc02d420 r5:dc4cc820 r4:dc02d428 [ 12.207552] Function entered at [<c02e667c>] from [<c02e6c14>] [ 12.213407] r10:c0375ac4 r9:dc4cc820 r8:00000060 r7:dc4cc820 r6:dc02d420 r5:c0377bd4 [ 12.221307] r4:dc02d420 [ 12.223853] Function entered at [<c02e6bf8>] from [<c0277fe0>] [ 12.229708] r5:c0377bd4 r4:dc02d410 [ 12.233309] Function entered at [<c0277f2c>] from [<c0378114>] [ 12.239163] r7:dc4cc820 r6:00000007 r5:dc4cc820 r4:dc02d400 [ 12.244875] Function entered at [<c03780c8>] from [<c0375bfc>] [ 12.250729] r7:dc4cc820 r6:dc4cc800 r5:dc02d400 r4:dc230860 [ 12.256442] Function entered at [<c0375ac4>] from [<c0375d14>] [ 12.262296] r9:dc4cc820 r8:c05079b0 r7:c05b8dc4 r6:00000488 r5:dc4cc800 r4:00000000 [ 12.270110] Function entered at [<c0375cb0>] from [<c0375e90>] [ 12.275965] r10:df5d89c0 r9:00000000 r8:df5dc100 r7:00000488 r6:e1b3d000 r5:dc4ce740 [ 12.283866] r4:dc4cc800 r3:ffffffff [ 12.287469] Function entered at [<c0375d98>] from [<c02fd58c>] [ 12.293322] r7:00000000 r6:df5d89c0 r5:dcde4380 r4:dc4ce700 [ 12.299035] Function entered at [<c02fd554>] from [<c004c37c>] [ 12.304888] r4:dc4ce700 [ 12.307436] Function entered at [<c004c258>] from [<c004c698>] [ 12.313290] r10:df5d89c0 r9:dcde4380 r8:00000008 r7:dcde8000 r6:df5d89d4 r5:dcde4398 [ 12.321188] r4:df5d89c0 [ 12.323737] Function entered at [<c004c64c>] from [<c00521d0>] [ 12.329590] r10:00000000 r9:00000000 r8:c004c64c r7:dcde4380 r6:dcde8000 r5:dcdddf40 [ 12.337489] r4:00000000 [ 12.340036] Function entered at [<c00520d0>] from [<c000fb08>] [ 12.345891] r8:00000000 r7:00000000 r6:00000000 r5:c00520d0 r4:dcdddf40 [ 12.352663] Code: e24cb004 e5910000 ebf76694 e89da800 (e1a0c00d) [ 12.358782] ---[ end trace 2f600e4fc5f2059e ]--- [ 12.363419] note: kworker/0:1[14] exited with preempt_count 1 [ OK ] Started rc.pvr.service. [ OK ] Started Login Service. Starting tiipclad-daemon.service... Starting telnetd.service... [ OK ] Started Serial Getty on ttyS0 -----...-------------------------------. [ OK ] Started Getty on tty1 +++++++++++++...+++++++++++++++++++++++++++++++. [ OK ] Reached target Network. Starting Network Name Resolution... [ 14.107891] Unable to handle kernel paging request at virtual address ffffffec [ 14.115151] pgd = c0003000 [ 14.117869] [ffffffec] *pgd=80000080007003, *pmd=9facb003, *pte=00000000 [ 14.124626] Internal error: Oops: 207 [#2] PREEMPT SMP ARM [ 14.130134] Modules linked in: omapdrm omapdss_base bc_example(O) extcon_usb_gpio pvrsrvkm(O) vfat fat omap_aes_driver omap_sham phy_omap_usb2 ti_abb_regulator ti_opp_domain dwc3_omap extcon omap_des memcache(O) sch_fq_codel [ 14.150270] CPU: 0 PID: 14 Comm: kworker/0:1 Tainted: G D W O 4.4.84 #25 [ 14.157784] Hardware name: Generic DRA72X (Flattened Device Tree) [ 14.163910] task: dcc99200 ti: dcde8000 task.ti: dcde8000 [ 14.169331] pc : [<c0052620>] lr : [<c004d448>] psr: 200e0093 [ 14.169331] sp : dcde9888 ip : dcde9898 fp : dcde9894 [ 14.180857] r10: 00000000 r9 : df5d8e40 r8 : dcc995a8 [ 14.186101] r7 : c05906dc r6 : c058ce40 r5 : dcc99200 r4 : 00000000 [ 14.192653] r3 : 00000000 r2 : 00000000 r1 : 00000000 r0 : dcc99200 [ 14.199208] Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user [ 14.206459] Control: 30c5387d Table: 9c569480 DAC: fffffffd [ 14.212227] Process kworker/0:1 (pid: 14, stack limit = 0xdcde8210) [ 14.218518] Stack: (0xdcde9888 to 0xdcdea000) [ 14.222893] 9880: dcde98ac dcde9898 c004d448 c005261c df5d8e40 dcc99200 [ 14.231106] 98a0: dcde9904 dcde98b0 c0483210 c004d440 c05c3d14 dcc7bd40 dcde98d4 dcde98c8 [ 14.239318] 98c0: c008dd30 c008dab4 dcde991c c0483448 00000000 c008dd24 c003808c dcde8000 [ 14.247530] 98e0: dcde95ec dcc74000 dcde9928 dcc99520 c04c9a00 c04c9a08 dcde991c dcde9908 [ 14.255741] 9900: c0483448 c0482d94 dcc99200 dcde95ec dcde9944 dcde9920 c0039d88 c0483400 [ 14.263953] 9920: c0243146 00000000 dcde9928 dcde9928 c0037134 00000001 dcde99cc dcde9948 [ 14.272164] 9940: c0013560 c0039754 dcde8210 0000000b 00000000 00000008 00000000 00000000 [ 14.280375] 9960: c0243148 600e0193 65080a44 62633432 20343030 31393565 30303030 66626520 [ 14.288587] 9980: 39363637 38652034 38616439 28203030 30613165 64303063 dc002029 dcde99b8 [ 14.296798] 99a0: c001be8c c0594e54 00001211 00000007 00000000 dcde9a90 c2834000 00000000 [ 14.305010] 99c0: dcde99dc dcde99d0 c0013758 c0013320 dcde9a8c dcde99e0 c0009314 c0013744 [ 14.313221] 99e0: 00000000 c048c088 00000007 00000000 00000000 00000000 dcde9a2c ffffe000 [ 14.321433] 9a00: 00000012 00000000 dcde8000 00000012 00000000 00000000 dcde9a3c dcde9a28 [ 14.329644] 9a20: c003aed0 c008ee00 c058b41c 00000012 dcde9a64 dcde9a40 c0081910 c003ae3c [ 14.337856] 9a40: c05908e4 fa21200c dcde9a90 fa212000 fa213000 c2834000 dcde9a8c dcde9a68 [ 14.346068] 9a60: c000948c c00818b4 c0243144 c0243144 200e0013 ffffffff dcde9ac4 dc29f154 [ 14.354280] 9a80: dcde9afc dcde9a90 c0013d98 c000926c dce0fa10 00000000 00000000 00000000 [ 14.362491] 9aa0: 00008000 00000000 dc29f180 00000000 dc29f154 c2834000 00000000 dcde9afc [ 14.370702] 9ac0: dcde9b00 dcde9ae0 c02431e8 c0243144 200e0013 ffffffff dce8ce24 00000000 [ 14.378914] 9ae0: 00008000 00000000 dce99210 dce96700 dcde9b44 dcde9b00 c02aef88 c02431d8 [ 14.387125] 9b00: 00008000 00000000 dc29f150 dce0a610 c02af030 00000000 dc4cc9ac 00000000 [ 14.395336] 9b20: dc29f154 dc4cc9ac dc4cc9a4 dc4cc820 dce0a610 d15e2b80 dcde9b64 dcde9b48 [ 14.403549] 9b40: c02acc8c c02aec80 dc4cc800 00000000 dc4cc9ac dc4cc9a4 dcde9bac dcde9b68 [ 14.411760] 9b60: c037740c c02acc0c 00000000 dc29f154 dcde9bac d15e2b80 c0278bd4 c0111460 [ 14.419971] 9b80: dc02d410 00000002 dcde9c3c dc02d5e8 dc02d410 c04eda28 00000002 dc4cc820 [ 14.428183] 9ba0: dcde9c14 dcde9bb0 c0377f40 c0377138 00000000 d9004000 c0377b80 c037af00 [ 14.436395] 9bc0: c04eda28 c30b0a50 00000100 dc4cc800 c0377b80 d9004000 dc02d400 c037af00 [ 14.444606] 9be0: dcde9c34 c04c3458 c022de50 c0377db4 dc32e680 dc4cc800 dcde9c30 dc02d410 [ 14.452817] 9c00: 00000000 00000000 dcde9c7c dcde9c18 c037b274 c0377dc0 c04c3454 c30b0550 [ 14.461029] 9c20: dcde9c64 dcde9c30 c01819ec c01817f0 c037af2c c037af00 dc231000 dc231800 [ 14.469239] 9c40: dcde9c64 dcde9c50 c03780a4 c0279a48 dc02d410 00000000 00000000 dc02d410 [ 14.477451] 9c60: dc02d420 00000000 00000000 00000000 dcde9cdc dcde9c80 c02783d4 c037b1c4 [ 14.485662] 9c80: c0183f8c c01807b0 dc02d420 00000000 dc02d410 c05b8f00 00000001 00000000 [ 14.493874] 9ca0: dc02d420 c05b8f00 c0184008 c0183f20 dcde9cdc c05dc1cc dc02d420 00000000 [ 14.502087] 9cc0: c05b8f00 00000014 00000000 00000000 dcde9d04 dcde9ce0 c02e96a4 c02781b0 [ 14.510298] 9ce0: c05b8f00 dcde9d50 dc02d420 00000001 c05dc1a8 00000000 dcde9d24 dcde9d08 [ 14.518510] 9d00: c02e98bc c02e94ac 00000000 dcde9d50 c02e9830 00000001 dcde9d4c dcde9d28 [ 14.526721] 9d20: c02e79ec c02e983c dcc72970 dce9bc38 dc02d420 dc02d420 dc02d420 dc02d454 [ 14.534932] 9d40: dcde9d74 dcde9d50 c02e93f8 c02e7990 dc02d420 00000001 dc02d428 dc02d420 [ 14.543144] 9d60: c05ac404 00000000 dcde9d84 dcde9d78 c02e9930 c02e934c dcde9da4 dcde9d88 [ 14.551355] 9d80: c02e8910 c02e9928 dc02d428 dc4cc820 dc02d420 00000000 dcde9de4 dcde9da8 [ 14.559567] 9da0: c02e6a70 c02e8890 dcde9dcc dcde9db8 c02f3ca4 c00720ec dc02d420 dc02d420 [ 14.567778] 9dc0: c0377bd4 dc02d420 dc4cc820 00000060 dc4cc820 c0375ac4 dcde9dfc dcde9de8 [ 14.575990] 9de0: c02e6c14 c02e6688 dc02d410 c0377bd4 dcde9e1c dcde9e00 c0277fe0 c02e6c04 [ 14.584202] 9e00: dc02d400 dc4cc820 00000007 dc4cc820 dcde9e3c dcde9e20 c0378114 c0277f38 [ 14.592413] 9e20: dc230860 dc02d400 dc4cc800 dc4cc820 dcde9e64 dcde9e40 c0375bfc c03780d4 [ 14.600625] 9e40: 00000000 dc4cc800 00000488 c05b8dc4 c05079b0 dc4cc820 dcde9e94 dcde9e68 [ 14.608836] 9e60: c0375d14 c0375ad0 ffffffff dc4cc800 dc4ce740 e1b3d000 00000488 df5dc100 [ 14.617047] 9e80: 00000000 df5d89c0 dcde9ebc dcde9e98 c0375e90 c0375cbc dcde4380 00000488 [ 14.625259] 9ea0: dc4ce700 dcde4380 df5d89c0 00000000 dcde9edc dcde9ec0 c02fd58c c0375da4 [ 14.633470] 9ec0: dc4ce700 dc4ce740 df5d89c0 dc4ce700 dcde9f1c dcde9ee0 c004c37c c02fd560 [ 14.641682] 9ee0: df5d89c0 df5d89d4 dcde8000 00000008 dcde4380 df5d89c0 dcde4398 df5d89d4 [ 14.649894] 9f00: dcde8000 00000008 dcde4380 df5d89c0 dcde9f54 dcde9f20 c004c698 c004c264 [ 14.658105] 9f20: dcde4380 c0590100 00000000 00000000 dcdddf40 dcde8000 dcde4380 c004c64c [ 14.666317] 9f40: 00000000 00000000 dcde9fac dcde9f58 c00521d0 c004c658 00000000 00000000 [ 14.674529] 9f60: 00000000 dcde4380 00000000 00000000 dcde9f70 dcde9f70 00000001 00010001 [ 14.682740] 9f80: dcde9f80 dcde9f80 dcde9fac dcdddf40 c00520d0 00000000 00000000 00000000 [ 14.690951] 9fa0: 00000000 dcde9fb0 c000fb08 c00520dc 00000000 00000000 00000000 00000000 [ 14.699163] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 14.707374] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000802 00000002 [ 14.715582] Backtrace: [ 14.718043] Function entered at [<c0052610>] from [<c004d448>] [ 14.723897] Function entered at [<c004d434>] from [<c0483210>] [ 14.729752] r5:dcc99200 r4:df5d8e40 [ 14.733357] Function entered at [<c0482d88>] from [<c0483448>] [ 14.739212] r10:c04c9a08 r9:c04c9a00 r8:dcc99520 r7:dcde9928 r6:dcc74000 r5:dcde95ec [ 14.747115] r4:dcde8000 [ 14.749663] Function entered at [<c04833f4>] from [<c0039d88>] [ 14.755517] r5:dcde95ec r4:dcc99200 [ 14.759120] Function entered at [<c0039748>] from [<c0013560>] [ 14.764974] r7:00000001 [ 14.767523] Function entered at [<c0013314>] from [<c0013758>] [ 14.773377] r10:00000000 r9:c2834000 r8:dcde9a90 r7:00000000 r6:00000007 r5:00001211 [ 14.781278] r4:c0594e54 [ 14.783825] Function entered at [<c0013738>] from [<c0009314>] [ 14.789680] Function entered at [<c0009260>] from [<c0013d98>] [ 14.795535] Exception stack(0xdcde9a90 to 0xdcde9ad8) [ 14.800606] 9a80: dce0fa10 00000000 00000000 00000000 [ 14.808818] 9aa0: 00008000 00000000 dc29f180 00000000 dc29f154 c2834000 00000000 dcde9afc [ 14.817027] 9ac0: dcde9b00 dcde9ae0 c02431e8 c0243144 200e0013 ffffffff [ 14.823667] r8:dc29f154 r7:dcde9ac4 r6:ffffffff r5:200e0013 r4:c0243144 [ 14.830435] Function entered at [<c02431cc>] from [<c02aef88>] [ 14.836288] r5:dce96700 r4:dce99210 [ 14.839892] Function entered at [<c02aec74>] from [<c02acc8c>] [ 14.845746] r10:d15e2b80 r9:dce0a610 r8:dc4cc820 r7:dc4cc9a4 r6:dc4cc9ac r5:dc29f154 [ 14.853646] r4:00000000 [ 14.856194] Function entered at [<c02acc00>] from [<c037740c>] [ 14.862048] r7:dc4cc9a4 r6:dc4cc9ac r5:00000000 r4:dc4cc800 [ 14.867761] Function entered at [<c037712c>] from [<c0377f40>] [ 14.873616] r10:dc4cc820 r9:00000002 r8:c04eda28 r7:dc02d410 r6:dc02d5e8 r5:dcde9c3c [ 14.881518] r4:00000002 [ 14.884064] Function entered at [<c0377db4>] from [<c037b274>] [ 14.889918] r10:00000000 r9:00000000 r8:dc02d410 r7:dcde9c30 r6:dc4cc800 r5:dc32e680 [ 14.897820] r4:c0377db4 [ 14.900368] Function entered at [<c037b1b8>] from [<c02783d4>] [ 14.906221] r10:00000000 r9:00000000 r8:00000000 r7:dc02d420 r6:dc02d410 r5:00000000 [ 14.914119] r4:00000000 [ 14.916666] Function entered at [<c02781a4>] from [<c02e96a4>] [ 14.922521] r10:00000000 r9:00000000 r8:00000014 r7:c05b8f00 r6:00000000 r5:dc02d420 [ 14.930421] r4:c05dc1cc [ 14.932969] Function entered at [<c02e94a0>] from [<c02e98bc>] [ 14.938822] r9:00000000 r8:c05dc1a8 r7:00000001 r6:dc02d420 r5:dcde9d50 r4:c05b8f00 [ 14.946635] Function entered at [<c02e9830>] from [<c02e79ec>] [ 14.952488] r7:00000001 r6:c02e9830 r5:dcde9d50 r4:00000000 [ 14.958200] Function entered at [<c02e7984>] from [<c02e93f8>] [ 14.964055] r6:dc02d454 r5:dc02d420 r4:dc02d420 [ 14.968712] Function entered at [<c02e9340>] from [<c02e9930>] [ 14.974567] r7:00000000 r6:c05ac404 r5:dc02d420 r4:dc02d428 [ 14.980278] Function entered at [<c02e991c>] from [<c02e8910>] [ 14.986133] Function entered at [<c02e8884>] from [<c02e6a70>] [ 14.991987] r7:00000000 r6:dc02d420 r5:dc4cc820 r4:dc02d428 [ 14.997699] Function entered at [<c02e667c>] from [<c02e6c14>] [ 15.003553] r10:c0375ac4 r9:dc4cc820 r8:00000060 r7:dc4cc820 r6:dc02d420 r5:c0377bd4 [ 15.011455] r4:dc02d420 [ 15.014002] Function entered at [<c02e6bf8>] from [<c0277fe0>] [ 15.019856] r5:c0377bd4 r4:dc02d410 [ 15.023460] Function entered at [<c0277f2c>] from [<c0378114>] [ 15.029313] r7:dc4cc820 r6:00000007 r5:dc4cc820 r4:dc02d400 [ 15.035026] Function entered at [<c03780c8>] from [<c0375bfc>] [ 15.040879] r7:dc4cc820 r6:dc4cc800 r5:dc02d400 r4:dc230860 [ 15.046592] Function entered at [<c0375ac4>] from [<c0375d14>] [ 15.052446] r9:dc4cc820 r8:c05079b0 r7:c05b8dc4 r6:00000488 r5:dc4cc800 r4:00000000 [ 15.060262] Function entered at [<c0375cb0>] from [<c0375e90>] [ 15.066115] r10:df5d89c0 r9:00000000 r8:df5dc100 r7:00000488 r6:e1b3d000 r5:dc4ce740 [ 15.074016] r4:dc4cc800 r3:ffffffff [ 15.077618] Function entered at [<c0375d98>] from [<c02fd58c>] [ 15.083473] r7:00000000 r6:df5d89c0 r5:dcde4380 r4:dc4ce700 [ 15.089187] Function entered at [<c02fd554>] from [<c004c37c>] [ 15.095041] r4:dc4ce700 [ 15.097589] Function entered at [<c004c258>] from [<c004c698>] [ 15.103444] r10:df5d89c0 r9:dcde4380 r8:00000008 r7:dcde8000 r6:df5d89d4 r5:dcde4398 [ 15.111343] r4:df5d89c0 [ 15.113891] Function entered at [<c004c64c>] from [<c00521d0>] [ 15.119744] r10:00000000 r9:00000000 r8:c004c64c r7:dcde4380 r6:dcde8000 r5:dcdddf40 [ 15.127643] r4:00000000 [ 15.130190] Function entered at [<c00520d0>] from [<c000fb08>] [ 15.136045] r8:00000000 r7:00000000 r6:00000000 r5:c00520d0 r4:dcdddf40 [ 15.142816] Code: e1a0c00d e92dd800 e24cb004 e5903378 (e5130014) [ 15.148936] ---[ end trace 2f600e4fc5f2059f ]--- [ 15.153571] Fixing recursive fault but reboot is needed!
Scenario #2
Keep the same DDR 512M setting. AND disable Early boot and late attach of remote cores.
===> Boot success !
Scenario #3
For DDR 512M and Early boot and late attach of remote cores.
CONFIG_FW_LOADER_USER_HELPER=n
CONFIG_FW_LOADER_USER_HELPER_FALLBACK=n
===> Boot success !
BUT apps.out couldn't be executive(HALT) .
Do you have any clear instruction or some hints for us to achieve this(DDR 512M and Early boot and late attach of remote cores)?
Could you
Matt
