Hi experts:
we have more then 7-channel capture of 720p yuv and it will be send to a15 though IPC(ipcin & ipcout * 6), see here.
if IPC_IN_LINK_TIME_OUT_IN_MS is 25 or 30, a lot of msg drop though IPC are observed. but if wen change it to 10ms, the IPU1 cpu load(swi > 30%) is very much high.
now when we'd like to enlarge
SYSTEM_IPC_OUT_LINK_IPC_QUE_MAX_ELEMENTS to about 32. so SYSTEM_IPC_SHM_SIZE should be 1MiB
this is what we are using:
SR0_SIZE = 1024*KB; REMOTE_LOG_SIZE = 256*KB; LINK_STATS_SIZE = 512*KB; SYSTEM_IPC_SHM_SIZE = 512*KB; HDVPSS_DESC_SIZE = 1024*KB; TRACE_BUF_LEN = 384*KB; EXC_DATA_LEN = 64*KB; PM_DATA_LEN = 512*KB; DCAN_X_LEN = 4*MB + 512*KB;
if i change to
SR0_SIZE = 1024*KB; REMOTE_LOG_SIZE = 256*KB; LINK_STATS_SIZE = 512*KB; SYSTEM_IPC_SHM_SIZE = 512*KB + 512*KB; HDVPSS_DESC_SIZE = 1024*KB; TRACE_BUF_LEN = 256*KB; EXC_DATA_LEN = 64*KB; PM_DATA_LEN = 128*KB; DCAN_X_LEN = 4*MB + 512*KB;
we got :
[IPU2] socket bind failed (Invalid argument, 22) !!!
SYSTEM: IPC: Notify init in progress !!!
SYSTEM: IPC: [IPU2] Notify RX channel create failed (endpoint = 81) !!!
SYSTEM: System_ipcNotifyInit -1!
dmesg | grep remoteproc
[ 1.050657] remoteproc0: 58820000.ipu is available
[ 1.050666] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 1.050675] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 1.050904] remoteproc1: 55020000.ipu is available
[ 1.050912] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 1.050920] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 1.051194] remoteproc2: 40800000.dsp is available
[ 1.051203] remoteproc2: Note: remoteproc is still under development and considered experimental.
[ 1.051211] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 1.051569] remoteproc3: 41000000.dsp is available
[ 1.051577] remoteproc3: Note: remoteproc is still under development and considered experimental.
[ 1.051585] remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 1.053400] remoteproc0: Direct firmware load for dra7-ipu1-fw.xem4 failed with error -2
[ 1.053410] remoteproc0: Falling back to user helper
[ 1.064055] remoteproc1: Direct firmware load for dra7-ipu2-fw.xem4 failed with error -2
[ 1.064065] remoteproc1: Falling back to user helper
[ 1.078681] remoteproc2: Direct firmware load for dra7-dsp1-fw.xe66 failed with error -2
[ 1.078691] remoteproc2: Falling back to user helper
[ 1.083080] remoteproc3: Direct firmware load for dra7-dsp2-fw.xe66 failed with error -2
[ 1.083090] remoteproc3: Falling back to user helper
[ 2.536998] remoteproc2: powering up 40800000.dsp
[ 2.537021] remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 1177374
[ 2.546518] remoteproc2: remote processor 40800000.dsp is now up
[ 2.548920] remoteproc2: registered virtio0 (type 7)
[ 2.918279] remoteproc3: powering up 41000000.dsp
[ 2.918299] remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 1190441
[ 2.946306] remoteproc3: remote processor 41000000.dsp is now up
[ 2.946831] remoteproc3: registered virtio1 (type 7)
[ 3.139558] remoteproc0: powering up 58820000.ipu
[ 3.139580] remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 2941252
[ 3.147287] remoteproc0: remote processor 58820000.ipu is now up
[ 3.147663] remoteproc0: registered virtio2 (type 7)
[ 3.227415] remoteproc1: powering up 55020000.ipu
[ 3.227435] remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 1056664
[ 3.238278] remoteproc1: remote processor 55020000.ipu is now up
[ 3.238854] remoteproc1: registered virtio3 (type 7)
U-Boot SPL 2016.05-svn46206 (May 15 2019 - 20:13:59) RESET reg=0xc000e Loading the remote cores done [ 0.301595] omap_hwmod: dss_dispc: _wait_target_ready failed: -16 [ 0.304197] omap_hwmod: dss_hdmi: _wait_target_ready failed: -16 [ 0.626313] omap_mbox_probe start0 [ 0.626327] omap_mbox_probe start1 [ 0.626341] omap_mbox_probe start2 [ 0.626372] omap_mbox_probe start3 [ 0.626430] finfo->tx_id=6,finfo->rx_id=4,finfo->name=mbox_ipu1_ipc3x [ 0.626481] finfo->tx_id=5,finfo->rx_id=1,finfo->name=mbox_dsp1_ipc3x [ 0.626488] omap_mbox_probe start4 [ 0.626693] mbox_controller_register test [ 0.626703] omap_mbox_probe start5 [ 0.626726] omap_mbox_probe start6 [ 0.626780] omap_mbox_probe start0 [ 0.626792] omap_mbox_probe start1 [ 0.626805] omap_mbox_probe start2 [ 0.626835] omap_mbox_probe start3 [ 0.626889] finfo->tx_id=6,finfo->rx_id=4,finfo->name=mbox_ipu2_ipc3x [ 0.626939] finfo->tx_id=5,finfo->rx_id=1,finfo->name=mbox_dsp2_ipc3x [ 0.626946] omap_mbox_probe start4 [ 0.627153] mbox_controller_register test [ 0.627162] omap_mbox_probe start5 [ 0.627181] omap_mbox_probe start6 [ 0.676364] ehrpwm_pwm_config start [ 0.676376] ehrpwm_pwm_config cmp_reg=0x12 [ 0.676384] ehrpwm_pwm_config ok [ 0.676392] LCD backlight set successfully [ 0.812912] sock connect fail, ret=-101 [ 0.816767] connect fail, ret=-101 [ 0.951143] cpsw-phy-sel 4a002554.cpsw-phy-sel: invalid resource [ 0.999258] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode [ 1.005644] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode [ 1.072153] omap_voltage_late_init: Voltage driver support not added [ 1.189572] mmc1: mmc_select_hs200 failed, error -74 hwclock: can't open '/dev/misc/rtc': No such file or directory /opt/upgraded used 65 user partition used 71 mmcblk0p3 upgraded used 65 Please press Enter to activate this console. ln: /opt/user/firmware/configdata/Config: Read-only file system[ 1.981549] jacinto6_gpio_init v0.01 /opt/user/sbin/upgraded: error while loading shared libraries: libosa.so: cannot open shared object file: No such file or directory [ 2.012872] DH9910_0 Init DONE [ 2.016274] DH9910_1 Init DONE [ 2.019397] DH9910 DRV INIT DONE [ 2.022648] adCount = 2 [ 2.330522] tty_store success! Sat Feb 2 00:00:00 UTC 2019 config not equal have activation_code 2299+1 records in 2299+1 records out 1177374 bytes (1.1MB) copied, 0.092754 seconds, 12.1MB/s [LPCan] systemCanGetInstCount = 2, systemCanGetVirtualInstCount = 8[ 2.539029] mbox_queue_alloc mbox_kfifo_size=1024 [libcan] create CAN channel:0 type:Physics endpoint:Client in progress !!! finfo.smem_len:6291456, finfo.line_length:8192 [OSA-APP] map a02c0000 <-> 100000 [OSA-APP] MEM: 0: Mapped 0xa0100000 to 0xb63bb000 of size 0x00100000 [OSA-APP] MEM: 1: Mapped 0x84203000 to 0xa19bb000 of size 0x14a00000 [OSA-APP] MEM: 2: Mapped 0xa0200000 to 0xa197b000 of size 0x00040000 [OSA-APP] MEM: 3: Mapped 0xa02c0000 to 0xa1700000 of size 0x00100000 [OSA-APP] MEM: 4: Mapped 0xb3000000 to 0x93e7f000 of size 0x0d000000 [OSA-APP] MEM: 5: Mapped 0xa0530000 to 0x939ff000 of size 0x00480000 [libcan] poolSize: 524428, timersSize: 0, eXchangeSize: 4195936 [4718592] [libcan] table[0]: a0530200 -> a055028c, pool[0]: a055028c -> a058028c, pool[1]: a058028c -> a05b028c [libcan] table[1]: a05b028c -> a05d0318, pool[0]: a05d0318 -> a0600318, pool[1]: a0600318 -> a0630318 [libcan] table[2]: a0630318 -> a06503a4, pool[0]: a06503a4 -> a06803a4, pool[1]: a06803a4 -> a06b03a4 [libcan] table[3]: a06b03a4 -> a06d0430, pool[0]: a06d0430 -> a0700430, pool[1]: a0700430 -> a0730430 [libcan] table[4]: a0730430 -> a07504bc, pool[0]: a07504bc -> a07804bc, pool[1]: a07804bc -> a07b04bc [libcan] table[5]: a07b04bc -> a07d0548, pool[0]: a07d0548 -> a0800548, pool[1]: a0800548 -> a0830548 [libcan] table[6]: a0830548 -> a08505d4, pool[0]: a08505d4 -> a08805d4, pool[1]: a08805d4 -> a08b05d4 [libcan] table[7]: a08b05d4 -> a08d0660, pool[0]: a08d0660 -> a0900660, pool[1]: a0900660 -> a0930660 [libcan] System dcan Timer DISABLE !!! [libcan] System dcanInfo parse DONE !!! [libcan] Get unUsed pool: 4 [libcan] create CAN channel:0 type:Physics endpoint:Client at pool[4] DONE !!! [libcan] create CAN channel:1 type:Physics endpoint:Client in progress !!! [libcan] System_dcanInit is already DONE !!! [libcan] Get unUsed pool: 5 [libcan] create CAN channel:1 type:Physics endpoint:Client at pool[5] DONE !!! [LPCan] Create Can[0-1] success [libcan] create CAN channel:0 type:Virtual endpoint:Server in progress !!! [libcan] poolSize: 524428, eXchangeSize: 4195936 [4718592] [libcan] rxQue[0] IN 8191 DONE !!! [libcan] txQue[0] total: 8191 [libcan] txQue[0] IN 8191 DONE !!! [libcan] rxQue[1] IN 8191 DONE !!! [libcan] txQue[1] total: 8191 [libcan] txQue[1] IN 8191 DONE !!! [libcan] rxQue[2] IN 8191 DONE !!! [libcan] txQue[2] total: 8191 [libcan] txQue[2] IN 8191 DONE !!! [libcan] rxQue[3] IN 8191 DONE !!! [libcan] txQue[3] total: 8191 [libcan] txQue[3] IN 8191 DONE !!! [libcan] rxQue[4] IN 8191 DONE !!! [libcan] txQue[4] total: 8191 [libcan] txQue[4] IN 8191 DONE !!! [libcan] rxQue[5] IN 8191 DONE !!! [libcan] txQue[5] total: 8191 [libcan] txQue[5] IN 8191 DONE !!! [libcan] rxQue[6] IN 8191 DONE !!! [libcan] txQue[6] total: 8191 [libcan] txQue[6] IN 8191 DONE !!! [libcan] rxQue[7] IN 8191 DONE !!! [libcan] txQue[7] total: 8191 [libcan] txQue[7] IN 8191 DONE !!! [libcan] table[0]: 9357f200 -> 9359f28c, pool[0]: 9359f28c -> 935cf28c, pool[1]: 935cf28c -> 935ff28c [libcan] table[1]: 935ff28c -> 9361f318, pool[0]: 9361f318 -> 9364f318, pool[1]: 9364f318 -> 9367f318 [libcan] table[2]: 9367f318 -> 9369f3a4, pool[0]: 9369f3a4 -> 936cf3a4, pool[1]: 936cf3a4 -> 936ff3a4 [libcan] table[3]: 936ff3a4 -> 9371f430, pool[0]: 9371f430 -> 9374f430, pool[1]: 9374f430 -> 9377f430 [libcan] table[4]: 9377f430 -> 9379f4bc, pool[0]: 9379f4bc -> 937cf4bc, pool[1]: 937cf4bc -> 937ff4bc [libcan] table[5]: 937ff4bc -> 9381f548, pool[0]: 9381f548 -> 9384f548, pool[1]: 9384f548 -> 9387f548 [libcan] table[6]: 9387f548 -> 9389f5d4, pool[0]: 9389f5d4 -> 938cf5d4, pool[1]: 938cf5d4 -> 938ff5d4 [libcan] table[7]: 938ff5d4 -> 9391f660, pool[0]: 9391f660 -> 9394f660, pool[1]: 9394f660 -> 9397f660[ 2.920566] mbox_queue_alloc mbox_kfifo_size=1024 [libcan] eXchangePoolsBaseAddr: 9357f000 [libcan] eXchangePoolsSize: 480000 [libcan] Virtual dcanInfo set DONE !!! [libcan] Get unUsed pool: 0 [libcan] create CAN channel:0 type:Virtual endpoint:Server at pool[0] DONE !!! [libcan] create CAN channel:0 type:VirtualIpc endpoint:Client in progress !!! [libcan] System_dcanInit is already DONE !!! [libcan] Get occupy Virtual pool: 0 [libcan] create CAN channel:0 type:VirtualIpc endpoint:Client at pool[0] DONE !!! [libcan] create CAN channel:1 type:Virtual endpoint:Server in progress !!! [libcan] Get unUsed pool: 1 [libcan] create CAN channel:1 type:Virtual endpoint:Server at pool[1] DONE !!! 2325+1 records in 2325+1 records out [libcan] start instId: 0, type: Physics, poolId: 4, endpoint: Client DONE !!! 1190441 bytes (1.1MB) copied, 0.157058 seconds, 7.2MB/s [libcan] start instId: 0, type: VirtualIpc, poolId: 0, endpoint: Client DONE !!! [libcan] start instId: 1, type: Physics, poolId: 5, endpoint: Client DONE !!! 5744+1 records in 5744+1 records out 2941252 bytes (2.8MB) copied, [ 3.141552] mbox_queue_alloc mbox_kfifo_size=1024 0.216272 seconds, 13.0MB/s 2063+1 records in 2063+1 records out 1056664 bytes (1.0MB) copied, [ 3.229073] mbox_queue_alloc mbox_kfifo_size=1024 0.080329 seconds, 12.5MB/s [ 3.275899] line=75, func=usb_extcon_detect_cable, usb_num=1 [ 3.282422] line=75, func=usb_extcon_detect_cable, usb_num=2 [Sonia| ../src/main.cpp(121)]: [Sonia| ../src/main.cpp(122)]: [Sonia| ../src/main.cpp(123)]: [qtHmi]:mac:9C:14:63:4E:3B:56 len:17 [qtHmi]:open eeprom success! [qtHmi]:mac:9C:14:63:4E:3B:56 macValue len:19 [qtHmi]:system :94ms [qtHmi]:begin1:0ms [qtHmi]:begin2:0ms PVR:(Error): Couldn't load WS module libpvrws_WAYLAND.so [0, ] Unable to query physical screen size, defaulting to 100 dpi. To override, set QT_QPA_EGLFS_PHYSICAL_WIDTH and QT_QPA_EGLFS_PHYSICAL_HEIGHT (in millimeters). LP-ICU010-AA_V1.00.58_T_20200408.bin [dandelion]Error (VideoDec_CreateVideoDecoder : 56)create decoder error! [LPVIDEO]:TCP server start... [LPVIDEO]:Thread_clientProcess socketIndex = 3 [LPVIDEO]:Thread_clientProcess socketIndex = 0 [LPVIDEO]:Thread_clientSendVideo socketIndex = 3 [LPVIDEO]:Thread_clientProcess socketIndex = 1 [LPVIDEO]:Thread_clientProcess socketIndex = 2 [LPVIDEO]:Thread_clientSendVideo socketIndex = 0 [LPVIDEO]:Thread_clientSendVideo socketIndex = 1 [LPVIDEO]:Thread_clientSendVideo socketIndex = 2 [HOST] Input parm->usecase=-1 [HOST] Input parm->algacc1 @ osa.c:OSA_init:113 [HOST] OSA: MEM: 0: Mapped 0xa0100000 to 0xb59dc000 of size 0x00100000 [HOST] OSA: MEM: 1: Mapped 0x84203000 to 0xa0fdc000 of size 0x14a00000 [HOST] OSA: MEM: 2: Mapped 0xa0200000 to 0xa0e9c000 of size 0x00040000 [HOST] OSA: MEM: 3: Mapped 0xa02c0000 to 0xa0edc000 of size 0x00100000 [HOST] OSA: MEM: region is NULL [HOST] OSA: MEM: 5: Mapped 0xb3000000 to 0x93e9c000 of size 0x0d000000 @ osa.c:OSA_init:116 @ osa.c:OSA_init:119 @ osa.c:OSA_init:122 [HOST] OSA: IPU1-0 Remote Log Shared Memory @ 0xa0200000 [HOST] OSA: HOST Remote Log Shared Memory @ 0xa024f140 [HOST] OSA: DSP1 Remote Log Shared Memory @ 0xa02769e0 [HOST] OSA: DSP2 Remote Log Shared Memory @ 0xa029e280 [HOST] OSA: IPU2 Remote Log Shared Memory @ 0xa0363da0 @ osa.c:OSA_init:128 @ system_common.c:System_init:449 @ system_common.c:System_init:452 @ system_common.c:System_init:455 SYSTEM: Waiting1 IPU1-0 Init SUCCESS !!! SYSTEM: Waiting2 DSP1 Init SUCCESS !!! SYSTEM: Waiting2 DSP2 Init SUCCESS !!! SYSTEM: Waiting2 IPU2 Init SUCCESS !!! SYSTEM: IPC: Init in progress !!! : dbgmsg running : msgrcv :: cmdid = 199 : Terminal path: /dev/console : User message: pcore=all:1 [HOST] [IPU1-0] 75774.507594 s: PRCM Init Done !!! [HOST] [IPU1-0] 75774.535045 s: ***** IPU1_0 Firmware build time 17:12:43 Apr 14 2020 [HOST] [IPU1-0] 75774.535289 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz> [HOST] [IPU1-0] 75774.538217 s: SYSTEM: System Common Init in progress !!! [HOST] [IPU1-0] 75774.557036 s: SYSTEM: IPC init in progress !!! [HOST] [IPU1-0] 75774.557158 s: SYSTEM: Attaching to [IPU2] ... [HOST] [IPU1-0] 75774.831574 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!! [HOST] [IPU1-0] 75774.834197 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!! [HOST] [IPU1-0] 75774.837186 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!! [HOST] [IPU1-0] 75774.837278 s: SYSTEM: Notify register to [IPU2] line 0, event 15... [HOST] [IPU1-0] 75774.837430 s: SYSTEM: Notify register to [DSP1] line 0, event 15... [HOST] [IPU1-0] 75774.837583 s: SYSTEM: Notify register to [DSP2] line 0, event 15... [HOST] [IPU1-0] 75774.837735 s: SYSTEM: Notify init done !!! [HOST] [IPU1-0] 75774.839504 s: SYSTEM: MsgQ init done !!! [HOST] [IPU1-0] 75774.840450 s: RpmsgInit in progress... [HOST] [IPU1-0] 75774.840572 s: SYSTEM: IPC init DONE !!! [HOST] [IPU1-0] 75774.848502 s: SYSTEM: System Common Init Done !!! [HOST] [IPU1-0] 75774.848624 s: SYSTEM: System Init in progress !!! [HOST] [IPU1-0] 75774.848715 s: SYSTEM: BSP Common Init in progress !!! [HOST] [IPU1-0] 75774.848776 s: SYSTEM: BSP Common Init Done !!! [HOST] [IPU1-0] 75774.848898 s: SYSTEM: BSP Platform Init in progress !!! [HOST] [IPU1-0] 75774.849020 s: SYSTEM: BSP I2C3 PinMux ! [HOST] [IPU1-0] 75774.849112 s: SYSTEM: BSP Platform Init Done !!! [HOST] [IPU1-0] 75774.849173 s: SYSTEM: FVID2 Init in progress !!! [HOST] [IPU1-0] 75774.849356 s: SYSTEM: FVID2 Init Done !!! [HOST] [IPU1-0] 75774.849447 s: BOARD: I2C1@0x48072000 Init !!! [HOST] [IPU1-0] 75774.849539 s: BOARD: I2C2@0x48060000 Init !!! [HOST] [IPU1-0] 75774.849722 s: BOARD: isI2cProbingReq is TRUE !!! [HOST] [IPU1-0] 75774.849813 s: BSP: Device I2C: Init instId=1, i2c1, 0x48072000 [HOST] [IPU1-0] 75774.850271 s: BSP: Device I2C: Init instId=2, i2c2, 0x48060000 [HOST] [IPU1-0] 75774.984566 s: I2C2: Passed for address 0x1a !!! [HOST] [IPU1-0] 75775.073293 s: DH9910: Registering drvId=0x1006 to FVID2 driver manager [HOST] [IPU1-0] 75775.073415 s: DH9910: instId=2, i2cAddr=0x31,0x30, numDevicesAtPort=2 [HOST] [IPU1-0] 75775.074666 s: SYSTEM: DH9910-0: chipId=0x9910 ! [HOST] [IPU1-0] 75775.128926 s: SYSTEM: DH9910-1: chipId=0x9910 ! [HOST] [IPU1-0] 75775.182394 s: SYSTEM: VPS Init in progress !!! [HOST] [IPU1-0] 75775.182486 s: SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0x80000000 -> 0x80000000] [HOST] [IPU1-0] 75775.185567 s: *** VPDMA Firmware Loading... *** [HOST] [IPU1-0] 75775.185719 s: VPDMA Firmware Address = 0xa03dba40 [HOST] [IPU1-0] 75775.185811 s: VPDMA Load Address = 0x4897d004 [HOST] [IPU1-0] 75775.185963 s: VPDMA Firmware Version = 0x4d0001b8 [HOST] [IPU1-0] 75775.186055 s: VPDMA List Busy Status = 0x00000000 [HOST] [IPU1-0] 75775.186146 s: *** VPDMA Firmware Load Success *** SYSTEM: IPC: Notify init in progress !!! SYSTEM: IPC: [IPU2] Notify RX channel create failed (endpoint = 81) !!! SYSTEM: System_ipcNotifyInit -1! [qtHmi]:open the light! time1:763 [LPVIDEO]:2019/02/02 00:00:02 [qtHmi]:open gpio success! [HOST] [IPU1-0] 75775.186482 s: *** VPDMA Firmware Loading... *** [HOST] [IPU1-0] 75775.186573 s: VPDMA Firmware Address = 0xa03dba40 [HOST] [IPU1-0] 75775.186665 s: VPDMA Load Address = 0x4899d004 [HOST] [IPU1-0] 75775.186756 s: VPDMA Firmware Version = 0x4d0001b8 [HOST] [IPU1-0] 75775.186848 s: VPDMA List Busy Status = 0x00000000 [HOST] [IPU1-0] 75775.186970 s: *** VPDMA Firmware Load Success *** [HOST] [IPU1-0] 75775.187305 s: *** VPDMA Firmware Loading... *** [HOST] [IPU1-0] 75775.187397 s: VPDMA Firmware Address = 0xa03dba40 [HOST] [IPU1-0] 75775.187488 s: VPDMA Load Address = 0x489bd004 [HOST] [IPU1-0] 75775.187580 s: VPDMA Firmware Version = 0x4d0001b8 [HOST] [IPU1-0] 75775.187671 s: VPDMA List Busy Status = 0x00000000 [HOST] [IPU1-0] 75775.187763 s: *** VPDMA Firmware Load Success *** [HOST] [IPU1-0] 75775.188129 s: *** VPDMA Firmware Loading... *** [HOST] [IPU1-0] 75775.188220 s: VPDMA Firmware Address = 0xa03dba40 [qtHmi]:Last charge: eages = 70791.348079, Today: eages = 0.000000 [HOST] [IPU1-0] 75775.188312 s: VPDMA Load Address = 0x489dd004 [HOST] [IPU1-0] 75775.188434 s: VPDMA Firmware Version = 0x4d0001b8 [HOST] [IPU1-0] 75775.188525 s: VPDMA List Busy Status = 0x00000000 QObject::connect: No such slot CanApp::slot_parkinglot_info_timer_proc() [HOST] [IPU1-0] 75775.188586 s: *** VPDMA Firmware Load Success *** [HOST] [IPU1-0] 75775.245653 s: SYSTEM: VPS Init Done !!! [HOST] [IPU1-0] 75775.247453 s: UTILS: DMA: HWI Create for INT34 !!! [HOST] [IPU1-0] 75775.247727 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [HOST] [IPU1-0] 75775.247849 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 257520 B (251 KB) [HOST] [IPU1-0] 75775.248063 s: SYSTEM: Heap = SR2_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB) [HOST] [IPU1-0] 75775.248215 s: SYSTEM: Heap = SR1_DDR_CACHED @ 0x84203000, Total size = 346030080 B (330 MB), Free size = 346030080 B (330 MB) [HOST] [IPU1-0] 75775.248429 s: SYSTEM: Heap = SR0_DDR_NON_CACHED @ 0xa0100000, Total size = 1046784 B (0 MB), Free size = 991488 B (0 MB) [HOST] [IPU1-0] 75775.248581 s: SYSTEM: Heap = SR3_NON_CACHED @ 0xb3000000, Total size = 218103680 B (207 MB), Free size = 218103680 B (207 MB) [HOST] [IPU1-0] 75775.248764 s: SYSTEM: Initializing Links !!! [HOST] [IPU1-0] 75775.572500 s: SYSTEM: Initializing Links ... DONE !!! 72611] [seven] nau8822_hw_params: CHAINS: Application Started !!! [HOST] [IPU1-0] 75775.642530 s: CHAINS: Sv + Adas Sysbios Started !!! [HOST] [IPU1-0] 75775.643048 s: SetAppPrms in progress !!! [HOST] [IPU1-0] 75775.643140 s: Capture Params Set in progress !!! [HOST] [IPU1-0] 75775.643262 s: chains_vipMultiCamEncodeSurroundViewSgxAdasSysbios_SetCapturePrms DONE !!! [HOST] [IPU1-0] 75775.643384 s: Vpe Params Set in progress !!! [HOST] [IPU1-0] 75775.643445 s: chains_vipMultiCamEncodeSurroundViewSgxAdasSysbios_SetVpePrm DONE !!! [HOST] [IPU1-0] 75775.643567 s: Encode Params Set in progress !!! [HOST] [IPU1-0] 75775.643658 s: SetAppPrms DONE !!! [HOST] [IPU1-0] 75775.643841 s: CAPTURE: Create in progress !!! [HOST] [IPU1-0] 75775.644177 s: (VPS_VIP2, VPS_VIP_S1, VPS_VIP_PORTB) VIN_1 -> VIN4A [HOST] [IPU1-0] 75775.644390 s: CAPTURE: VIP2 Slice1 PortA capture mode is [ 8-bit] !!! [HOST] [IPU1-0] 75775.645641 s: CAPTURE: ch-0: bufId-0: source: 0x9ed818f0 [HOST] [IPU1-0] 75775.645763 s: CAPTURE: ch-0: bufId-1: source: 0x9ed81988 [HOST] [IPU1-0] 75775.645885 s: CAPTURE: ch-0: bufId-2: source: 0x9ed81a20 [qtHmi]:sound file valid [Sonia| ../src/videoAnalyse/adasanalyse.cpp(471)]: m_AdasCtlMessage::ICU_SVEnable, = 1 [Sonia| ../src/videoAnalyse/adasanalyse.cpp(479)]: m_AdasCtlMessage::ICU_APAEnable, = 1 [qtHmi]:time2 :1170ms [HOST] [IPU1-0] 75775.646007 s: CAPTURE: ch-0: bufId-3: source: 0x9ed81ab8 [HOST] [IPU1-0] 75775.646129 s: CAPTURE: ch-0: bufId-4: source: 0x9ed81b50 [HOST] [IPU1-0] 75775.646220 s: CAPTURE: ch-0: bufId-5: source: 0x9ed81be8 [HOST] [IPU1-0] 75775.646312 s: CAPTURE: ch-0: bufId-6: source: 0x9ed81c80 [HOST] [IPU1-0] 75775.646403 s: CAPTURE: ch-0: bufId-7: source: 0x9ed81d18 [HOST] [IPU1-0] 75775.646647 s: (VPS_VIP2, VPS_VIP_S1, VPS_VIP_PORTB) VIN_2 -> VIN2B [HOST] [IPU1-0] 75775.646861 s: CAPTURE: VIP1 Slice1 PortB capture mode is [ 8-bit] !!! [HOST] [IPU1-0] 75775.648111 s: CAPTURE: ch-1: bufId-0: source: 0x9ed844a8 [HOST] [IPU1-0] 75775.648234 s: CAPTURE: ch-1: bufId-1: source: 0x9ed84540 [HOST] [IPU1-0] 75775.648325 s: CAPTURE: ch-1: bufId-2: source: 0x9ed845d8 [HOST] [IPU1-0] 75775.648447 s: CAPTURE: ch-1: bufId-3: source: 0x9ed84670 [HOST] [IPU1-0] 75775.648539 s: CAPTURE: ch-1: bufId-4: source: 0x9ed84708 [HOST] [IPU1-0] 75775.648630 s: CAPTURE: ch-1: bufId-5: source: 0x9ed847a0 [HOST] [IPU1-0] 75775.648722 s: CAPTURE: ch-1: bufId-6: source: 0x9ed84838 [HOST] [IPU1-0] 75775.648844 s: CAPTURE: ch-1: bufId-7: source: 0x9ed848d0 [HOST] [IPU1-0] 75775.649088 s: (VPS_VIP2, VPS_VIP_S1, VPS_VIP_PORTB) VIN_3 -> VIN2A [HOST] [IPU1-0] 75775.649301 s: CAPTURE: VIP1 Slice1 PortA capture mode is [ 8-bit] !!! [HOST] [IPU1-0] 75775.650643 s: CAPTURE: ch-2: bufId-0: source: 0x9ed87060 [HOST] [IPU1-0] 75775.650765 s: CAPTURE: ch-2: bufId-1: source: 0x9ed870f8 [HOST] [IPU1-0] 75775.650857 s: CAPTURE: ch-2: bufId-2: source: 0x9ed87190 [HOST] [IPU1-0] 75775.651009 s: CAPTURE: ch-2: bufId-3: source: 0x9ed87228 SYSTEM: IPC: Notify init in progress !!! SYSTEM: IPC: [IPU2] Notify RX channel create failed (endpoint = 81) !!! SYSTEM: System_ipcNotifyInit -1! [HOST] [IPU1-0] 75775.651101 s: CAPTURE: ch-2: bufId-4: source: 0x9ed872c0 [HOST] [IPU1-0] 75775.651192 s: CAPTURE: ch-2: bufId-5: source: 0x9ed87358 [qtHmi]:tmp = 158 [qtHmi]:time3 :1351ms [HOST] [IPU1-0] 75775.651284 s: CAPTURE: ch-2: bufId-6: source: 0x9ed873f0 [HOST] [IPU1-0] 75775.651406 s: CAPTURE: ch-2: bufId-7: source: 0x9ed87488 [HOST] [IPU1-0] 75775.651619 s: (VPS_VIP1, VPS_VIP_S1, VPS_VIP_PORTA) VIN_4 -> VIN1A [HOST] [IPU1-0] 75775.651833 s: CAPTURE: VIP1 Slice0 PortA capture mode is [ 8-bit] !!! [qtHmi]:initSemAndShm failed, i = 5 [HOST] [IPU1-0] 75775.653144 s: CAPTURE: ch-3: bufId-0: source: 0x9ed89c18 [HOST] [IPU1-0] 75775.653266 s: CAPTURE: ch-3: bufId-1: source: 0x9ed89cb0 [qtHmi]:set m_accMode 0 setBcmIcuScreenNotDisplay=0 [HOST] [IPU1-0] 75775.65even] into nau8822_set_bias_level, SND_SOC_BIAS_PREPARE 3358 s: CAPTURE: ch-3: bufId-2: source: 0x9ed89d48 [LPVIDEO]:New connection, client ip = 192.167.0.11 [LPVIDEO]:Add new client socket, clientSocketFd = 5 - 5, socketIndex = 0, gConnectCnt = 1 SYSTEM: IPC: Notify init in progress !!! [HOST] [IPU1-0] 75775.653449 s: CAPTURE: ch-3: bu[Id-3: source: 0x9ed89de0 SYSTEM: IPC: [IPU2] Notify RX channel create failed (endpoint = 81) !!! SYSTEM: System_ipcNotifyInit -1! [LPVIDEO]:Recv json = {"data":{"num":1,"action":1},"type":"liveVideo"} [LPVIDEO]:gChanelConnectCnt[4] = 1 [LPVIDEO]:Open videoIndex = 4 [LPVIDEO]: set Video index:4 onOff:1 5.176923] [seven] into nau8822_set_bias_level, SND_SOC_BIAS_PREPARE9ed89e78 [qtHmi]:ui control time1:47 [qtHmi]:ui control time2324 [HOST] [IPU1-0] 75775.653663 s: CAPTURE: ch-3: bufId-5: source: 0x9ed89f10 [HOST] [IPU1-0] 75775.653754 s: CAPTURE: ch-3: bufId-6: source: 0x9ed89fa8 [HOST] [IPU1-0] 75775.653846 s: CAPTURE: ch-3: bufId-7: source: 0x9ed8a040 [qtHmi]:buffer_size = 8192 [qtHmi]:buffer_time = 185759 dir = 1 period_frames = 0 [qtHmi]:period_time = 46439 buffer_frames = 0 [HOST] [IPU1-0] 75775.654090 s: (VPS_VIP1, VPS_VIP_S1, VPS_VIP_PORTB) VIN_5 -> VIN1B [HOST] [IPU1-0] 75775.654181 s: (VPS_VIP1, VPS_VIP_S1, VPS_VIP_PORTB) VIN_5 -> VIN1B [HOST] [IPU1-0] 75775.654395 s: CAPTURE: VIP1 Slice0 PortB capture mode is [ 8-bit] !!! [HOST] [IPU1-0] 75775.655676 s: CAPTURE: ch-4: bufId-0: source: 0x9ed8c7d0 [HOST] [IPU1-0] 75775.655798 s: CAPTURE: ch-4: bufId-1: source: 0x9ed8c868 [HOST] [IPU1-0] 75775.655950 s: CAPTURE: ch-4: bufId-2: source: 0x9ed8c900 [HOST] [IPU1-0] 75775.656042 s: CAPTURE: ch-4: bufId-3: source: 0x9ed8c998 [HOST] [IPU1-0] 75775.656133 s: CAPTURE: ch-4: bufId-4: source: 0x9ed8ca30 [qtHmi]:ui control time3:408 [qtHmi]:time4 :1759ms [HOST] [IPU1-0] 75775.656225 s: CAPTURE: ch-4: bufId-5: source: 0x9ed8cac8 [HOST] [IPU1-0] 75775.656347 s: CAPTURE: ch-4: bufId-6: source: 0x9ed8cb60 [HOST] [IPU1-0] 75775.656438 s: CAPTURE: ch-4: bufId-7: source: 0x9ed8cbf8 [HOST] [IPU1-0] 75775.656652 s: (VPS_VIP3, VPS_VIP_S1, VPS_VIP_PORTA) VIN_6 -> VIN6A [HOST] [IPU1-0] 75775.656926 s: CAPTURE: VIP3 Slice1 PortA capture mode is [ 8-bit] !!! [LPVIDEO]:New connection, client ip = 192.167.0.11 [LPVIDEO]:Add new client socket, clientSocketFd = 6 - 6, socketIndex = 1, gConnectCnt = 2 [HOST] [IPU1-0] 75775.658177 s: CAPTURE: ch-5: bufId-0: source: 0x9ed8f388 [HOST] [IPU1-0] 75775.658299 s: CAPTURE: ch-5: bufId-1: source: 0x9ed8f420 [HOST] [IPU1-0] 75775.658421 s: CAPTURE: ch-5: bufId-2: source: 0x9ed8f4b8 [LPVIDEO]:Recv json = {"data":{"num":13,"action":1},"type":"liveVideo"} [LPVIDEO]:gChanelConnectCnt[7] = 1 [LPVIDEO]:Open videoIndex = 7 [LPVIDEO]: set Video index:7 onOff:1 [LPVIDEO]:before create [LPVIDEO]:finish create [HOST] [IPU1-0] 75775.658512 s: CAPTURE: ch-5: bufId-3: source: 0x9ed8f550 [HOST] [IPU1-0] 75775.658604 s: CAPTURE: ch-5: bufId-4: source: 0x9ed8f5e8 [HOST] [IPU1-0] 75775.658695 s: CAPTURE: ch-5: bufId-5: source: 0x9ed8f680 [HOST] [IPU1-0] 75775.658787 s: CAPTURE: ch-5: bufId-6: source: 0x9ed8f718 [HOST] [IPU1-0] 75775.658939 s: CAPTURE: ch-5: bufId-7: source: 0x9ed8f7b0 [HOST] [IPU1-0] 75775.659153 s: (VPS_VIP3, VPS_VIP_S0, VPS_VIP_PORTA) VIN_COM -> VIN5A [HOST] [IPU1-0] 75775.659366 s: CAPTURE: VIP3 Slice0 PortA capture mode is [ 8-bit] !!! [HOST] [IPU1-0] 75775.660739 s: CAPTURE: ch-6: bufId-0: source: 0x9ed91f40 [HOST] [IPU1-0] 75775.660861 s: CAPTURE: ch-6: bufId-1: source: 0x9ed91fd8 [HOST] [IPU1-0] 75775.661013 s: CAPTURE: ch-6: bufId-2: source: 0x9ed92070 [HOST] [IPU1-0] 75775.661105 s: CAPTURE: ch-6: bufId-3: source: 0x9ed92108 [HOST] [IPU1-0] 75775.661196 s: CAPTURE: ch-6: bufId-4: source: 0x9ed921a0 [HOST] [IPU1-0] 75775.661288 s: CAPTURE: ch-6: bufId-5: source: 0x9ed92238 [HOST] [IPU1-0] 75775.661410 s: CAPTURE: ch-6: bufId-6: source: 0x9ed922d0 [HOST] [IPU1-0] 75775.661501 s: CAPTURE: ch-6: bufId-7: source: 0x9ed92368 [HOST] [IPU1-0] 75775.662020 s: CAPTURE: Create Done !!! [HOST] [IPU1-0] 75775.662325 s: pPrm->inQueParams.prevLinkQueId= 0, pObj->inTskInfo.numQue= 1 [HOST] [IPU1-0] 75775.666473 s: IPC_IN_0 : Create in progress !!! [HOST] [IPU1-0] 75775.666809 s: pPrm->inQueParams.prevLinkQueId= 0, pObj->inTskInfo.numQue= 1 [HOST] [IPU1-0] 75775.671140 s: MERGE: linkId: 41, inQue: 0, prevLinkId: 25, prevLinkQueId: 2, chId: 0, flags: 7, numOutCh: 0, inQue: 0, chId: 0, numCh: 7 [HOST] [IPU1-0] 75775.671384 s: MERGE: linkId: 41, inQue: 0, prevLinkId: 25, prevLinkQueId: 2, chId: 1, flags: 7, numOutCh: 1, inQue: 0, chId: 1, numCh: 7 [HOST] [IPU1-0] 75775.671567 s: MERGE: linkId: 41, inQue: 0, prevLinkId: 25, prevLinkQueId: 2, chId: 2, flags: 7, numOutCh: 2, inQue: 0, chId: 2, numCh: 7 [HOST] [IPU1-0] 75775.671780 s: MERGE: linkId: 41, inQue: 0, prevLinkId: 25, prevLinkQueId: 2, chId: 3, flags: 7, numOutCh: 3, inQue: 0, chId: 3, numCh: 7 [HOST] [IPU1-0] 75775.671994 s: MERGE: linkId: 41, inQue: 0, prevLinkId: 25, prevLinkQueId: 2, chId: 4, flags: 7, numOutCh: 4, inQue: 0, chId: 4, numCh: 7 [qtHmi]:current first init time1:112 SYSTEM: IPC: Notify init in progress !!! SYSTEM: IPC: [IPU2] Notify RX channel create failed (endpoint = 81) !!! SYSTEM: System_ipcNotifyInit -1! [LPVIDEO]:2019/02/02 00:00:03 [HOST] [IPU1-0] 75775.672207 s: MERGE: linkId: 41, inQue: 0, prevLinkId: 25, prevLinkQueId: 2, chId: 5, flags: 7, numOutCh: 5, inQue: 0, chId: 5, numCh: 7 [qtHmi]:scientific init time1:1 [HOST] [IPU1-0] 75775.672390 s: MERGE: linkId: 41, inQue: 0, prevLinkId: 25, prevLinkQueId: 2, chId: 6, flags: 7, numOutCh: 6, inQue: 0, chId: 6, numCh: 7 [HOST] [IPU1-0] 75775.774385 s: NULL_SRC2 : ch-0: bufId-0: source: 0x9ee5de40 [HOST] [IPU1-0] 75775.774537 s: NULL_SRC2 : ch-0: bufId-1: source: 0x9ee5ded8 [HOST] [IPU1-0] 75775.774659 s: NULL_SRC2 : ch-0: bufId-2: source: 0x9ee5df70 [HOST] [IPU1-0] 75775.774751 s: NULL_SRC2 : ch-0: bufId-3: source: 0x9ee5e008 [HOST] [IPU1-0] 75775.774873 s: NULL_SRC2 : ch-0: bufId-4: source: 0x9ee5e0a0 [HOST] [IPU1-0] 75775.775025 s: NULL_SRC2 : ch-0: bufId-5: source: 0x9ee5e138 [HOST] [IPU1-0] 75775.775147 s: NULL_SRC2 : ch-0: bufId-6: source: 0x9ee5e1d0 [HOST] [IPU1-0] 75775.775239 s: NULL_SRC2 : ch-0: bufId-7: source: 0x9ee5e268 [HOST] [IPU1-0] 75775.775788 s: DECODE: Create in progress ... !!! [HOST] [IPU1-0] 75775.942749 s: DECODE: Creating CH0 of 1280 x 720 [1] [0],target bitrate = 10000 Kbps ... [HOST] [IPU1-0] 75775.943725 s: DECODE: All CH Create ... DONE !!! [HOST] [IPU1-0] 75775.946135 s: DECODE: Create ... DONE !!! [HOST] [IPU1-0] 75775.946501 s: MERGE: linkId: 40, inQue: 0, prevLinkId: 25, prevLinkQueId: 1, chId: 0, flags: 7, numOutCh: 0, inQue: 0, chId: 0, numCh: 7 [HOST] [IPU1-0] 75775.946715 s: MERGE: linkId: 40, inQue: 0, prevLinkId: 25, prevLinkQueId: 1, chId: 1, flags: 7, numOutCh: 1, inQue: 0, chId: 1, numCh: 7 [HOST] [IPU1-0] 75775.946959 s: MERGE: linkId: 40, inQue: 0, prevLinkId: 25, prevLinkQueId: 1, chId: 2, flags: 7, numOutCh: 2, inQue: 0, chId: 2, numCh: 7 [HOST] [IPU1-0] 75775.947142 s: MERGE: linkId: 40, inQue: 0, prevLinkId: 25, prevLinkQueId: 1, chId: 3, flags: 7, numOutCh: 3, inQue: 0, chId: 3, numCh: 7 [HOST] [IPU1-0] 75775.947355 s: MERGE: linkId: 40, inQue: 0, prevLinkId: 25, prevLinkQueId: 1, chId: 4, flags: 7, numOutCh: 4, inQue: 0, chId: 4, numCh: 7 [HOST] [IPU1-0] 75775.947538 s: MERGE: linkId: 40, inQue: 0, prevLinkId: 25, prevLinkQueId: 1, chId: 5, flags: 7, numOutCh: 5, inQue: 0, chId: 5, numCh: 7 [HOST] [IPU1-0] 75775.947752 s: MERGE: linkId: 40, inQue: 0, prevLinkId: 25, prevLinkQueId: 1, chId: 6, flags: 7, numOutCh: 6, inQue: 0, chId: 6, numCh: 7 [HOST] [IPU1-0] 75775.948057 s: MERGE: linkId: 40, inQue: 1, prevLinkId: 76, prevLinkQueId: 0, chId: 0, flags: 7, numOutCh: 7, inQue: 1, chId: 0, numCh: 1 [HOST] [IPU1-0] 75775.948392 s: VPE: Create in progress !!! [qtHmi]:scientific init time2:47 [HOST] [IPU1-0] 75775.951381 s: VPE: ch-0: bufId-0: source: 0x9ecb7100 [HOST] [IPU1-0] 75775.951534 s: VPE: ch-0: bufId-1: source: 0x9ecb7198 [HOST] [IPU1-0] 75775.951656 s: VPE: ch-0: bufId-2: source: 0x9ecb7230 [HOST] [IPU1-0] 75775.952083 s: VPE: ch-1: bufId-0: source: 0x9ecb76f0 [HOST] [IPU1-0] 75775.952235 s: VPE: ch-1: bufId-1: source: 0x9ecb7788 [HOST] [IPU1-0] 75775.952327 s: VPE: ch-1: bufId-2: source: 0x9ecb7820 [HOST] [IPU1-0] 75775.952754 s: VPE: ch-2: bufId-0: source: 0x9ecb7ce0 [HOST] [IPU1-0] 75775.952967 s: VPE: ch-2: bufId-1: source: 0x9ecb7d78 [HOST] [IPU1-0] 75775.953059 s: VPE: ch-2: bufId-2: source: 0x9ecb7e10 [HOST] [IPU1-0] 75775.953486 s: VPE: ch-3: bufId-0: source: 0x9ecb82d0 [HOST] [IPU1-0] 75775.953608 s: VPE: ch-3: bufId-1: source: 0x9ecb8368 [HOST] [IPU1-0] 75775.953730 s: VPE: ch-3: bufId-2: source: 0x9ecb8400 [HOST] [IPU1-0] 75775.954187 s: VPE: ch-4: bufId-0: source: 0x9ecb88c0 [HOST] [IPU1-0] 75775.954309 s: VPE: ch-4: bufId-1: source: 0x9ecb8958 [HOST] [IPU1-0] 75775.954431 s: VPE: ch-4: bufId-2: source: 0x9ecb89f0 [HOST] [IPU1-0] 75775.954858 s: VPE: ch-5: bufId-0: source: 0x9ecb8eb0 [HOST] [IPU1-0] 75775.955041 s: VPE: ch-5: bufId-1: source: 0x9ecb8f48 [qtHmi]:scientific init time3:82 [qtHmi]:scientific init time4:83 [HOST] [IPU1-0] 75775.955163 s: VPE: ch-5: bufId-2: source: 0x9ecb8fe0 [HOST] [IPU1-0] 75775.955590 s: VPE: ch-6: bufId-0: source: 0x9ecb94a0 [HOST] [IPU1-0] 75775.955743 s: VPE: ch-6: bufId-1: source: 0x9ecb9538 [HOST] [IPU1-0] 75775.955834 s: VPE: ch-6: bufId-2: source: 0x9ecb95d0 [HOST] [IPU1-0] 75775.956322 s: VPE: ch-7: bufId-0: source: 0x9ecb9a90 [HOST] [IPU1-0] 75775.956444 s: VPE: ch-7: bufId-1: source: 0x9ecb9b28 [dandelion]Error (VideoDec_CreateVideoDecoder : 56)create decoder error! SYSTEM: IPC: Notify init in progress !!! SYSTEM: IPC: [IPU2] Notify RX channel create failed (endpoint = 81) !!! SYSTEM: System_ipcNotifyInit -1! [HOST] [IPU1-0] 75775.956566 s: VPE: ch-7: bufId-2: source: 0x9ecb9bc0 [HOST] [IPU1-0] 75776.192643 s: VPE: Loading Down-scaling Co-effs [HOST] [IPU1-0] 75776.193009 s: VPE: Co-effs Loading ... DONE !!! [HOST] [IPU1-0] 75776.193436 s: VPE: Create Done !!! [HOST] [IPU1-0] 75776.193619 s: IPC_OUT_3: Detailed IPC LINK: [ IPU1-0(00000047) -> IPU1-0 -> INVALID PROC(ffffffff) ] [HOST] [IPU1-0] 75776.194442 s: IPC_OUT_3 : Create Done !!! [HOST] [IPU1-0] 75776.194808 s: SELECT: OUT QUE0: OUT CH0: IN CH0: 1280 x 720, pitch = (1280, 1280) [HOST] [IPU1-0] 75776.195022 s: SELECT: OUT QUE0: OUT CH1: IN CH2: 1280 x 720, pitch = (1280, 1280) [HOST] [IPU1-0] 75776.195174 s: SELECT: OUT QUE0: OUT CH2: IN CH5: 1280 x 720, pitch = (1280, 1280) [HOST] [IPU1-0] 75776.195296 s: SELECT: OUT QUE0: OUT CH3: IN CH1: 1280 x 720, pitch = (1280, 1280) [HOST] [IPU1-0] 75776.195449 s: SELECT: OUT QUE1: OUT CH0: IN CH4: 1280 x 720, pitch = (1280, 1280) [HOST] [IPU1-0] 75776.195601 s: SELECT: OUT QUE2: OUT CH0: IN CH6: 1280 x 720, pitch = (1280, 1280) [HOST] [IPU1-0] 75776.195723 s: SELECT: OUT QUE2: OUT CH1: IN CH3: 1280 x 720, pitch = (1280, 1280) [HOST] [IPU1-0] 75776.196120 s: pPrm->inQueParams.prevLinkQueId= 1, pObj->inTskInfo.numQue= 3 [HOST] [IPU1-0] 75776.200298 s: IPC_OUT_6: Detailed IPC LINK: [ IPU1-0(0000001c) -> IPU1-0 -> DSP2(0400000b) ] [HOST] [IPU1-0] 75776.201091 s: IPC_OUT_6 : Create Done !!! [HOST] [IPU1-0] 75776.204081 s: IPC_IN_3 : Create in progress !!! [HOST] [IPU1-0] 75776.205972 s: IPC_IN_3 : Create Done !!! [HOST] [IPU1-0] 75776.206338 s: pPrm->inQueParams.prevLinkQueId= 0, pObj->inTskInfo.numQue= 3 [HOST] [IPU1-0] 75776.212255 s: MERGE: linkId: 38, inQue: 0, prevLinkId: 26, prevLinkQueId: 2, chId: 0, flags: 7, numOutCh: 0, inQue: 0, chId: 0, numCh: 4 [HOST] [IPU1-0] 75776.212499 s: MERGE: linkId: 38, inQue: 0, prevLinkId: 26, prevLinkQueId: 2, chId: 1, flags: 7, numOutCh: 1, inQue: 0, chId: 1, numCh: 4 [HOST] [IPU1-0] 75776.212682 s: MERGE: linkId: 38, inQue: 0, prevLinkId: 26, prevLinkQueId: 2, chId: 2, flags: 7, numOutCh: 2, inQue: 0, chId: 2, numCh: 4 [HOST] [IPU1-0] 75776.212926 s: MERGE: linkId: 38, inQue: 0, prevLinkId: 26, prevLinkQueId: 2, chId: 3, flags: 7, numOutCh: 3, inQue: 0, chId: 3, numCh: 4 [HOST] [IPU1-0] 75776.213261 s: MERGE: linkId: 38, inQue: 1, prevLinkId: 43, prevLinkQueId: 2, chId: 0, flags: 7, numOutCh: 4, inQue: 1, chId: 0, numCh: 2 [HOST] [IPU1-0] 75776.213475 s: MERGE: linkId: 38, inQue: 1, prevLinkId: 43, prevLinkQueId: 2, chId: 1, flags: 7, numOutCh: 5, inQue: 1, chId: 1, numCh: 2 [HOST] [IPU1-0] 75776.213780 s: MERGE: linkId: 38, inQue: 2, prevLinkId: 28, prevLinkQueId: 1, chId: 0, flags: 7, numOutCh: 6, inQue: 2, chId: 0, numCh: 1 [HOST] [IPU1-0] 75776.214268 s: MERGE: linkId: 38, inQue: 4, prevLinkId: 57, prevLinkQueId: 0, chId: 0, flags: 7, numOutCh: 7, inQue: 4, chId: 0, numCh: 2 [HOST] [IPU1-0] 75776.214481 s: MERGE: linkId: 38, inQue: 4, prevLinkId: 57, prevLinkQueId: 0, chId: 1, flags: 7, numOutCh: 8, inQue: 4, chId: 1, numCh: 2 [HOST] [IPU1-0] 75776.214817 s: MERGE: linkId: 38, inQue: 5, prevLinkId: 58, prevLinkQueId: 0, chId: 0, flags: 7, numOutCh: 9, inQue: 5, chId: 0, numCh: 1 [HOST] [IPU1-0] 75776.215213 s: SWOSD: Create in progress !!! [qtHmi]:scientific init time5:484 [HOST] [IPU1-0] 75776.215427 s: SWOSD: inTskInfo: numQue: 1, numCh: 10, 1280x720 [qtHmi]:scientific init time6:486 [qtHmi]:iconName = :/scientific/prompt/00.png, noti = 低压蓄电池需要检修 [qtHmi]:get info:0 [qtHmi]:m_prompt[i].info:0 [HOST] [IPU1-0] 75776.226590 s: SWOSD: Pools Size = 174256 at b8fa5800, infoSize = 10416, latticeSize = 8192 !!! [qtHmi]:iconName = :/scientific/prompt/01.png, noti = 转向柱锁故障 [qtHmi]:get info:1 [qtHmi]:m_prompt[i].info:1 [qtHmi]:iconName = :/scientific/prompt/02.png, noti = 系统故障,请联系维修 [qtHmi]:get info:2 [qtHmi]:m_prompt[i].info:2 [qtHmi]:iconName = :/scientific/prompt/03.png, noti = 电动真空泵故障 [qtHmi]:get info:3 [qtHmi]:m_prompt[i].info:3 [qtHmi]:iconName = :/scientific/prompt/04.png, noti = 请补充制动液 [HOST] [IPU1-0] 75776.227810 s: SWOSD: Create Done !!! [LPVIDEO]:2019/02/02 00:00:04 SYSTEM: IPC: Notify init in progress !!! SYSTEM: IPC: [IPU2] Notify RX channel create failed (endpoint = 81) !!! SYSTEM: System_ipcNotifyInit -1! [HOST] [IPU1-0] 75776.228085 s: ENCODE: Create in progress ... !!! [qtHmi]:get info:4 [qtHmi]:m_prompt[i].info:4 [qtHmi]:iconName = :/scientific/prompt/05.png, noti = 车辆触发防盗报警 [qtHmi]:get info:5 [qtHmi]:m_prompt[i].info:5 [qtHmi]:iconName = :/scientific/prompt/06.png, noti = 车辆启动失败 [qtHmi]:get info:6 [qtHmi]:m_prompt[i].info:6 [qtHmi]:iconName = :/scientific/prompt/07.png, noti = [qtHmi]:get info:7 [qtHmi]:m_prompt[i].info:7 [qtHmi]:iconName = :/scientific/prompt/08.png, noti = 自动泊车故障 [qtHmi]:get info:8 [qtHmi]:m_prompt[i].info:8 [qtHmi]:iconName = :/scientific/prompt/09.png, noti = 动力电池电量过低,请及时充电 [qtHmi]:get info:9 [qtHmi]:m_prompt[i].info:9 [qtHmi]:iconName = :/scientific/prompt/10.png, noti = 动力电池电量已耗尽,请停车 [qtHmi]:get info:10 [qtHmi]:m_prompt[i].info:10 [qtHmi]:iconName = :/scientific/prompt/11.png, noti = 防撞雷达故障 [qtHmi]:get info:11 [qtHmi]:m_prompt[i].info:11 [qtHmi]:iconName = :/scientific/prompt/12.png, noti = 真空助力低 [qtHmi]:get info:12 [qtHmi]:m_prompt[i].info:12 [qtHmi]:scientific init time7:816 [qtHmi]:scientific init time8:816 [HOST] [IPU1-0] 75776.231806 s: ENCODE: ch-0: bufId-0/0: source: 0x9ec3f6b0 [HOST] [IPU1-0] 75776.232019 s: ENCODE: ch-0: bufId-1/1: source: 0x9ec3f748 [HOST] [IPU1-0] 75776.232141 s: ENCODE: ch-0: bufId-2/2: source: 0x9ec3f7e0 [HOST] [IPU1-0] 75776.232233 s: ENCODE: ch-0: bufId-3/3: source: 0x9ec3f878 [HOST] [IPU1-0] 75776.232385 s: ENCODE: ch-1: bufId-0/4: source: 0x9ec3f910 [HOST] [IPU1-0] 75776.232507 s: ENCODE: ch-1: bufId-1/5: source: 0x9ec3f9a8 [HOST] [IPU1-0] 75776.232629 s: ENCODE: ch-1: bufId-2/6: source: 0x9ec3fa40 [HOST] [IPU1-0] 75776.232751 s: ENCODE: ch-1: bufId-3/7: source: 0x9ec3fad8 [HOST] [IPU1-0] 75776.232934 s: ENCODE: ch-2: bufId-0/8: source: 0x9ec3fb70 [HOST] [IPU1-0] 75776.233056 s: ENCODE: ch-2: bufId-1/9: source: 0x9ec3fc08 [HOST] [IPU1-0] 75776.233178 s: ENCODE: ch-2: bufId-2/10: source: 0x9ec3fca0 [HOST] [IPU1-0] 75776.233300 s: ENCODE: ch-2: bufId-3/11: source: 0x9ec3fd38 [HOST] [IPU1-0] 75776.233453 s: ENCODE: ch-3: bufId-0/12: source: 0x9ec3fdd0 [qtHmi]:style start time1:844 [qtHmi]:style start time2:844 [qtHmi]:current first init time2:1219 [HOST] [IPU1-0] 75776.233575 s: ENCODE: ch-3: bufId-1/13: source: 0x9ec3fe68 [HOST] [IPU1-0] 75776.233697 s: ENCODE: ch-3: bufId-2/14: source: 0x9ec3ff00 [HOST] [IPU1-0] 75776.233819 s: ENCODE: ch-3: bufId-3/15: source: 0x9ec3ff98 [HOST] [IPU1-0] 75776.233971 s: ENCODE: ch-3: bufId-4/16: source: 0x9ec40030 [HOST] [IPU1-0] 75776.234063 s: ENCODE: ch-3: bufId-5/17: source: 0x9ec400c8 [HOST] [IPU1-0] 75776.234185 s: ENCODE: ch-3: bufId-6/18: source: 0x9ec40160 [HOST] [IPU1-0] 75776.234307 s: ENCODE: ch-3: bufId-7/19: source: 0x9ec401f8 [HOST] [IPU1-0] 75776.234459 s: ENCODE: ch-4: bufId-0/20: source: 0x9ec40290 [HOST] [IPU1-0] 75776.234581 s: ENCODE: ch-4: bufId-1/21: source: 0x9ec40328 [HOST] [IPU1-0] 75776.234703 s: ENCODE: ch-4: bufId-2/22: source: 0x9ec403c0 [HOST] [IPU1-0] 75776.234825 s: ENCODE: ch-4: bufId-3/23: source: 0x9ec40458 [HOST] [IPU1-0] 75776.235008 s: ENCODE: ch-5: bufId-0/24: source: 0x9ec404f0 [HOST] [IPU1-0] 75776.235130 s: ENCODE: ch-5: bufId-1/25: source: 0x9ec40588 [HOST] [IPU1-0] 75776.235252 s: ENCODE: ch-5: bufId-2/26: source: 0x9ec40620 [HOST] [IPU1-0] 75776.235374 s: ENCODE: ch-5: bufId-3/27: source: 0x9ec406b8 [HOST] [IPU1-0] 75776.235466 s: ENCODE: ch-5: bufId-4/28: source: 0x9ec40750 [HOST] [IPU1-0] 75776.235588 s: ENCODE: ch-5: bufId-5/29: source: 0x9ec407e8 [HOST] [IPU1-0] 75776.235710 s: ENCODE: ch-5: bufId-6/30: source: 0x9ec40880 [Sonia| ../src/FaceDetection/lpfacedetection.cpp(758)]: Create capture face videoInput failed SYSTEM: IPC: Notify init in progress !!! SYSTEM: IPC: [IPU2] Notify RX channel create failed (endpoint = 81) !!! SYSTEM: System_ipcNotifyInit -1! [HOST] [IPU1-0] 75776.235832 s: ENCODE: ch-5: bufId-7/31: source: 0x9ec40918 [HOST] [IPU1-0] 75776.236015 s: ENCODE: ch-6: bufId-0/32: source: 0x9ec409b0 [HOST] [IPU1-0] 75776.236137 s: ENCODE: ch-6: bufId-1/33: source: 0x9ec40a48 [HOST] [IPU1-0] 75776.236259 s: ENCODE: ch-6: bufId-2/34: source: 0x9ec40ae0 [HOST] [IPU1-0] 75776.236381 s: ENCODE: ch-6: bufId-3/35: source: 0x9ec40b78 [HOST] [IPU1-0] 75776.236503 s: ENCODE: ch-6: bufId-4/36: source: 0x9ec40c10 [HOST] [IPU1-0] 75776.236625 s: ENCODE: ch-6: bufId-5/37: source: 0x9ec40ca8 [HOST] [IPU1-0] 75776.236747 s: ENCODE: ch-6: bufId-6/38: source: 0x9ec40d40 [HOST] [IPU1-0] 75776.236838 s: ENCODE: ch-6: bufId-7/39: source: 0x9ec40dd8 [HOST] [IPU1-0] 75776.237021 s: ENCODE: ch-7: bufId-0/40: source: 0x9ec40e70 [HOST] [IPU1-0] 75776.237174 s: ENCODE: ch-7: bufId-1/41: source: 0x9ec40f08 [HOST] [IPU1-0] 75776.237265 s: ENCODE: ch-7: bufId-2/42: source: 0x9ec40fa0 [HOST] [IPU1-0] 75776.237387 s: ENCODE: ch-7: bufId-3/43: source: 0x9ec41038 [HOST] [IPU1-0] 75776.237509 s: ENCODE: ch-7: bufId-4/44: source: 0x9ec410d0 [HOST] [IPU1-0] 75776.237631 s: ENCODE: ch-7: bufId-5/45: source: 0x9ec41168 [HOST] [IPU1-0] 75776.237753 s: ENCODE: ch-7: bufId-6/46: source: 0x9ec41200 [HOST] [IPU1-0] 75776.237875 s: ENCODE: ch-7: bufId-7/47: source: 0x9ec41298 [HOST] [IPU1-0] 75776.238119 s: ENCODE: ch-8: bufId-0/48: source: 0x9ec41330 [HOST] [IPU1-0] 75776.238272 s: ENCODE: ch-8: bufId-1/49: source: 0x9ec413c8 [HOST] [IPU1-0] 75776.238394 s: ENCODE: ch-8: bufId-2/50: source: 0x9ec41460 [HOST] [IPU1-0] 75776.238485 s: ENCODE: ch-8: bufId-3/51: source: 0x9ec414f8 [HOST] [IPU1-0] 75776.238607 s: ENCODE: ch-8: bufId-4/52: source: 0x9ec41590 [HOST] [IPU1-0] 75776.238729 s: ENCODE: ch-8: bufId-5/53: source: 0x9ec41628 [HOST] [IPU1-0] 75776.238851 s: ENCODE: ch-8: bufId-6/54: source: 0x9ec416c0 [HOST] [IPU1-0] 75776.239004 s: ENCODE: ch-8: bufId-7/55: source: 0x9ec41758 [HOST] [IPU1-0] 75776.239126 s: ENCODE: ch-8: bufId-8/56: source: 0x9ec417f0 [HOST] [IPU1-0] 75776.239248 s: ENCODE: ch-8: bufId-9/57: source: 0x9ec41888 [HOST] [IPU1-0] 75776.239370 s: ENCODE: ch-8: bufId-10/58: source: 0x9ec41920 [HOST] [IPU1-0] 75776.239492 s: ENCODE: ch-8: bufId-11/59: source: 0x9ec419b8 [HOST] [IPU1-0] 75776.239614 s: ENCODE: ch-8: bufId-12/60: source: 0x9ec41a50 [HOST] [IPU1-0] 75776.239736 s: ENCODE: ch-8: bufId-13/61: source: 0x9ec41ae8 [HOST] [IPU1-0] 75776.239858 s: ENCODE: ch-8: bufId-14/62: source: 0x9ec41b80 [HOST] [IPU1-0] 75776.240010 s: ENCODE: ch-8: bufId-15/63: source: 0x9ec41c18 [HOST] [IPU1-0] 75776.240132 s: ENCODE: ch-8: bufId-16/64: source: 0x9ec41cb0 [HOST] [IPU1-0] 75776.240224 s: ENCODE: ch-8: bufId-17/65: source: 0x9ec41d48 [HOST] [IPU1-0] 75776.240346 s: ENCODE: ch-8: bufId-18/66: source: 0x9ec41de0 [HOST] [IPU1-0] 75776.240468 s: ENCODE: ch-8: bufId-19/67: source: 0x9ec41e78 [HOST] [IPU1-0] 75776.240590 s: ENCODE: ch-8: bufId-20/68: source: 0x9ec41f10 [HOST] [IPU1-0] 75776.240712 s: ENCODE: ch-8: bufId-21/69: source: 0x9ec41fa8 [HOST] [IPU1-0] 75776.240834 s: ENCODE: ch-8: bufId-22/70: source: 0x9ec42040 [HOST] [IPU1-0] 75776.240987 s: ENCODE: ch-8: bufId-23/71: source: 0x9ec420d8 [HOST] [IPU1-0] 75776.241109 s: ENCODE: ch-8: bufId-24/72: source: 0x9ec42170 [HOST] [IPU1-0] 75776.241231 s: ENCODE: ch-8: bufId-25/73: source: 0x9ec42208 [HOST] [IPU1-0] 75776.241353 s: ENCODE: ch-8: bufId-26/74: source: 0x9ec422a0 [HOST] [IPU1-0] 75776.241475 s: ENCODE: ch-8: bufId-27/75: source: 0x9ec42338 [HOST] [IPU1-0] 75776.241566 s: ENCODE: ch-8: bufId-28/76: source: 0x9ec423d0 [HOST] [IPU1-0] 75776.241688 s: ENCODE: ch-8: bufId-29/77: source: 0x9ec42468 [HOST] [IPU1-0] 75776.241810 s: ENCODE: ch-8: bufId-30/78: source: 0x9ec42500 [HOST] [IPU1-0] 75776.241963 s: ENCODE: ch-8: bufId-31/79: source: 0x9ec42598 [HOST] [IPU1-0] 75776.242146 s: ENCODE: ch-9: bufId-0/80: source: 0x9ec42630 [HOST] [IPU1-0] 75776.242268 s: ENCODE: ch-9: bufId-1/81: source: 0x9ec426c8 [HOST] [IPU1-0] 75776.242390 s: ENCODE: ch-9: bufId-2/82: source: 0x9ec42760 [qtHmi]:current first init time3:1793 [qtHmi]:current first init time4:1958 [qtHmi]:current first init time5:1958 SYSTEM: IPC: Notify init in progress !!! SYSTEM: IPC: [IPU2] Notify RX channel create failed (endpoint = 81) !!! SYSTEM: System_ipcNotifyInit -1! [HOST] [IPU1-0] 75776.242512 s: ENCODE: ch-9: bufId-3/83: source: 0x9ec427f8 [HOST] [IPU1-0] 75776.242634 s: ENCODE: ch-9: bufId-4/84: source: 0x9ec42890 7.245555] ehrpwm_pwm_config startCODE: ch-9: bufId-5/85: source: 0x9ec42928 [HOST] [IPU1-0] 75776.242878 s: ENCODE: ch-9: bufId-6/86: sorce: 0x9ec429c0 [HOST] [IPU1-0] 75776.243030 s: ENCODE: ch-9: bufId-7/87: source: 0x9ec42a58 [HOST] [IPU1-0] 75776.249496 s: ENCODE: Creating CH0 of 1280 x 720, pitch = (1280, 1280) [1] [0], bitrate = 4000 Kbps ... [qtHmi]:time4.5 :3731ms [qtHmi]:time5 :3731ms [qtHmi]:time6 :3731ms [HOST] [IPU1-0] 75776.316812 s: ENCODE: CH0: H264EncCreated:H264ENC_TI DEV.500.V.H264AVC.E.IVAHD.02.01.09.01 [HOST] [IPU1-0] 75776.317208 s: ENCODE: chId-0 match poolId=0 !!! [HOST] [IPU1-0] 75776.317330 s: ENCODE: Creating CH1 of 1280 x 720, pitch = (1280, 1280) [1] [0], bitrate = 4000 Kbps ... [HOST] [IPU1-0] 75776.386323 s: ENCODE: CH1: H264EncCreated:H264ENC_TI DEV.500.V.H264AVC.E.IVAHD.02.01.09.01 [HOST] [IPU1-0] 75776.386628 s: ENCODE: chId-1 match poolId=1 !!! [HOST] [IPU1-0] 75776.386719 s: ENCODE: Creating CH2 of 1280 x 720, pitch = (1280, 1280) [1] [0], bitrate = 4000 Kbps ... [HOST] [IPU1-0] 75776.453760 s: ENCODE: CH2: H264EncCreated:H264ENC_TI DEV.500.V.H264AVC.E.IVAHD.02.01.09.01 [qtHmi]:begin3:3745ms [qtHmi]:stBlkArgs.uiDutyNs = 0 [HOST] [IPU1-0] 75776.454157 s: ENCODE: chId-2 match poolId=2 !!! 275435] ehrpwm_pwm_config cmp_reg=0x12 [ 7.389149] ehrpwm_pwm_config ok [ 7.392584] LCD backlight set successfullyeating CH3 of 1280 x720, pitch = (1280, 1280) [1] [0], bitrate = 4000 Kbps ... [0m[Sonia| ../src/FaceDetection/lpfacedetection.cpp(214)]: Sop recognize face, isSendInputPsw = 0[ 7.408099] ehrpwm_pwm_config start [qtHmi]:stBlkArgs.uiDutyNs = 74 [HOST] [IPU1-0] 75776.51411 s: ENCODE: CH3: H264EncCreated:H264ENC_TI DEV.500.V.H264AVC.E.IVAHD.02.01.09.01 [ 7.421084] ehrpwm_pwm_config cmp_reg=0x12 [ 7.438799] ehrpwm_pwm_config ok [ 7.442312] LCD backlight set successfullyId-3 match poolId=3 !! [ HOST] [IPU1-0] 75776.521869 s: ENCODE:C reating CH4 of 1280 x720, pitch = (1280, 1280) [1] [0], bitrate = 4000 Kbps ... [qtHmi]:slotCurrentMilTimeOut!!! [HOST] [IPU1-0] 75776.589062 s: ENCODE: CH4: H264EncCreated:H264ENC_TI DEV.500.V.H264AVC.E.IVAHD.02.01.09.01 [qtHmi]:slotCurrentMilTimeOut!!! [HOST] [IPU1-0] 75776.589397 s: ENCODE: chId-4 match poolId=4 !!! [HOST] [IPU1-0] 75776.589489 s: ENCODE: Creating CH5 of 1280 x 720, pitch = (1280, 1280) [1] [0], bitrate = 4000 Kbps ... [HOST] [IPU1-0] 75776.656713 s: ENCODE: CH5: H264EncCreated:H264ENC_TI DEV.500.V.H264AVC.E.IVAHD.02.01.09.01 [HOST] [IPU1-0] 75776.657109 s: ENCODE: chId-5 match poolId=5 !!! [HOST] [IPU1-0] 75776.657231 s: ENCODE: Creating CH6 of 1280 x 720, pitch = (1280, 1280) [1] [0], bitrate = 4000 Kbps ... [HOST] [IPU1-0] 75776.724516 s: ENCODE: CH6: H264EncCreated:H264ENC_TI DEV.500.V.H264AVC.E.IVAHD.02.01.09.01 [HOST] [IPU1-0] 75776.724821 s: ENCODE: chId-6 match poolId=6 !!! [HOST] [IPU1-0] 75776.724974 s: ENCODE: Creating CH7 of 1280 x 720, pitch = (1280, 1280) [1] [0], bitrate = 4000 Kbps ... [HOST] [IPU1-0] 75776.792289 s: ENCODE: CH7: H264EncCreated:H264ENC_TI DEV.500.V.H264AVC.E.IVAHD.02.01.09.01 [LPVIDEO]:2019/02/02 00:00:05 [HOST] [IPU1-0] 75776.792624 s: ENCODE: chId-7 match poolId=7 !!! [HOST] [IPU1-0] 75776.792716 s: ENCODE: Creating CH8 of 1280 x 720, pitch = (1280, 1280) [1] [0], bitrate = 4000 Kbps ... [HOST] [IPU1-0] 75776.859879 s: ENCODE: CH8: H264EncCreated:H264ENC_TI DEV.500.V.H264AVC.E.IVAHD.02.01.09.01 [HOST] [IPU1-0] 75776.860367 s: ENCODE: chId-8 match poolId=8 !!! [HOST] [IPU1-0] 75776.860489 s: ENCODE: Creating CH9 of 1280 x 720, pitch = (1280, 1280) [1] [0], bitrate = 10000 Kbps ... [HOST] [IPU1-0] 75776.861678 s: ENCODE: CH9: JPEGDecCreated:@(#)Id:JPEGVENC_TI Ver:01.00.16.01 Released by:500_V_MJPEG_E_01_00 Built:Jul 9 2014 14:46:40 [HOST] [IPU1-0] 75776.861983 s: ENCODE: chId-9 match poolId=9 !!! [HOST] [IPU1-0] 75776.862075 s: ENCODE: All CH Create ... DONE !!! [HOST] [IPU1-0] 75776.863966 s: ENCODE: Create ... DONE !!! [HOST] [IPU1-0] 75776.864179 s: IPC_OUT_2: Detailed IPC LINK: [ IPU1-0(0000004b) -> IPU1-0 -> INVALID PROC(ffffffff) ] [HOST] [IPU1-0] 75776.865033 s: IPC_OUT_2 : Create Done !!! [HOST] [IPU1-0] 75776.866101 s: pPrm->inQueParams.prevLinkQueId= 0, pObj->inTskInfo.numQue= 1 [HOST] [IPU1-0] 75776.870340 s: IPC_OUT_5: Detailed IPC LINK: [ IPU1-0(0000001b) -> IPU1-0 -> DSP2(0400000a) ] [HOST] [IPU1-0] 75776.871195 s: IPC_OUT_5 : Create Done !!! [HOST] [IPU1-0] 75776.874916 s: IPC_IN_2 : Create in progress !!! [HOST] [IPU1-0] 75776.876837 s: IPC_IN_2 : Create Done !!! [HOST] [IPU1-0] 75776.877142 s: IPC_OUT_4: Detailed IPC LINK: [ IPU1-0(0000001b) -> IPU1-0 -> DSP1(0300000a) ] [HOST] [IPU1-0] 75776.877966 s: IPC_OUT_4 : Create Done !!! [HOST] [IPU1-0] 75776.880894 s: IPC_IN_1 : Create in progress !!! [HOST] [IPU1-0] 75776.882754 s: IPC_IN_1 : Create Done !!! [HOST] [IPU1-0] 75776.883151 s: MERGE: linkId: 39, inQue: 0, prevLinkId: 11, prevLinkQueId: 0, chId: 0, flags: 7, numOutCh: 0, inQue: 0, chId: 0, numCh: 1 SYSTEM: IPC: Notify init in progress !!! SYSTEM: IPC: [IPU2] Notify RX channel create failed (endpoint = 81) !!! SYSTEM: System_ipcNotifyInit -1! [HOST] [IPU1-0] 75776.883486 s: MERGE: linkId: 39, inQue: 1, prevLinkId: 12, prevLinkQueId: 0, chId: 0, flags: 7, numOutCh: 1, inQue: 1, chId: 0, numCh: 1 [HOST] [IPU1-0] 75776.883791 s: MERGE: linkId: 39, inQue: 2, prevLinkId: 13, prevLinkQueId: 0, chId: 0, flags: 7, numOutCh: 2, inQue: 2, chId: 0, numCh: 1 [HOST] [IPU1-0] 75776.884218 s: IPC_OUT_1: Detailed IPC LINK: [ IPU1-0(00000027) -> IPU1-0 -> INVALID PROC(ffffffff) ] [HOST] [IPU1-0] 75776.885072 s: IPC_OUT_1 : Create Done !!! [HOST] [IPU1-0] 75776.886048 s: IPC_OUT_0: Detailed IPC LINK: [ IPU1-0(00000022) -> IPU1-0 -> INVALID PROC(ffffffff) ] [HOST] [IPU1-0] 75776.886841 s: IPC_OUT_0 : Create Done !!! [HOST] [IPU1-0] 75776.888824 s: ENCODE: Get cmd: 0x1 [HOST] [IPU1-0] 75776.888977 s: ENCODE: Process cmd: 0x1 DONE [HOST] [IPU1-0] 75776.891112 s: CAPTURE: Start in progress !!! [HOST] [IPU1-0] 75776.905355 s: CAPTURE: Start Done !!! [HOST] [IPU1-0] 75776.905538 s: CHAINS: Sv + Adas Sysbios Started DONE !!! [HOST] [IPU1-0] 75777.907124 s: SYSTEM: Running: ENCODE: task-49, proc-0, new-0, encoded-0, newline-0, encline-0 [HOST] [IPU1-0] 75777.907307 s: SYSTEM: Running: NULLSRC-2: main-1, run-0, newline-0, peekline-0 SYSTEM: IPC: Notify init in progress !!! SYSTEM: IPC: [IPU2] Notify RX channel create failed (endpoint = 81) !!! SYSTEM: System_ipcNotifyInit -1! time7 :3537ms error config: no item: crop_face [HOST] [IPU1-0] 75777.907430 s: SYSTEM: Running: 0x08100000 stat: 0 [HOST] [IPU1-0] 75778.315317 s: Connection established with HLOS, calling rpmsgInit [HOST] [IPU1-0] 75780.987128 s: SYSTEM: Running: ENCODE: task-199, proc-0, new-0, encoded-0, newline-0, encline-0 [HOST] [IPU1-0] 75780.987281 s: SYSTEM: Running: NULLSRC-2: main-1, run-0, newline-0, peekline-0 [HOST] [IPU1-0] 75780.987403 s: SYSTEM: Running: 0x08100000 stat: 0 [HOST] [HOST ] 75779.317178 s: SYSTEM: System A15 Init in progress !!! [HOST] [HOST ] 75779.705545 s: SYSTEM: IPC: [IPU1-0] socket bind success !!! (dst vproc = 0, endpt = 81) [HOST] [HOST ] 75779.705575 s: SYSTEM: IPC: [IPU1-0] socket info (family = 41, dst proc id = -1, endpt = 81) !!! [HOST] [HOST ] 75779.705636 s: SYSTEM: IPC: [IPU1-0] socket connect success !!! (dst vproc = 0, endpt = 80) [HOST] [HOST ] 75779.705636 s: SYSTEM: IPC: [IPU1-0] socket info (family = 41, dst proc id = -1, endpt = 1024) !!! [HOST] [HOST ] 75779.705697 s: SYSTEM: IPC: [IPU2] socket bind failed (Invalid argument, 22) !!! [HOST] [HOST ] 75780.006618 s: SYSTEM: IPC: [IPU1-0] socket bind success !!! (dst vproc = 0, endpt = 81) [HOST] [HOST ] 75780.006649 s: SYSTEM: IPC: [IPU1-0] socket info (family = 41, dst proc id = -1, endpt = 81) !!! [HOST] [HOST ] 75780.006679 s: SYSTEM: IPC: [IPU1-0] socket connect success !!! (dst vproc = 0, endpt = 80) [HOST] [HOST ] 75780.006679 s: SYSTEM: IPC: [IPU1-0] socket info (family = 41, dst proc id = -1, endpt = 1024) !!! [HOST] [HOST ] 75780.006710 s: SYSTEM: IPC: [IPU2] socket bind failed (Invalid argument, 22) !!! [HOST] [HOST ] 75780.332214 s: SYSTEM: IPC: [IPU1-0] socket bind success !!! (dst vproc = 0, endpt = 81) [HOST] [HOST ] 75780.332214 s: SYSTEM: IPC: [IPU1-0] socket info (family = 41, dst proc id = -1, endpt = 81) !!!
log is attached.
any suggestion will be appreciated.
regards, wen
