We have an AM5728 board which feeds the VIP1a/b ports with an external signal.
If there is no video signal on the port when streaming is enabled, the SDK 6.1.0.8 VIP driver is continuously reporting overflow and "num_recovery limit exceeded, leaving disabled" errors (PORTx_OUTPUT_FIFO_YUV).
However, we wish to simply detect that there is no signal (so that we can supply a test pattern) in this case without disabling.
Why does overflow occur if there is no signal, and what would be the recommended method to detect signal loss and avoid continuous recoveries?
Note that video capture works fine as long as a signal is present.
---Chris
