When debugging, everything works well when 204B interface channel rate is 10G. When at 12G, the SYNC signal is occasionally pulled low, causing resynchronization.
The other registers are unchanged, except for the corresponding modification to the two registers 0X3B,0X3C associated with the SERDES PLL. Then the customer has tried other channel rates, 8G is normal, but 11G is unstable. So the customer wonders it might be because of the high rate that caused instability.
The DAC is direct-picking and does not use up-conversion frequency and PLL.
The 8G and 10G are good, so the basic configuration should be fine.
The customer would like to know what need to be aware when configuring.
Thanks a lot!
Cherry Zhou
