Hi Team,
For this AFE7769, Could you please explain the exact use case of the pins AUXADC1 - AUXADC6.
Hi Nimesh,
The functionality of AUXADC1 - AUXADC6 is explained in section 9.3.14 of the AFE7769 datasheet. Please let us know if you have any questions after reading it.
Hi Kevin dai,
In our design, we have an E-FUSE TPS16530RGE. We designed its IMON pin for VIMON=4V & IMON=0.616A.
Can we connect that IMON pin of TPS16530RGE to the AUXADC Pins of AFE7769D for current monitoring purposes? could you please confirm please refer to the attached image.
Nimesh,
The AUX ADC pins should be able to monitor the 4v voltage supply coming from TPS16530RGE.
Kevin
Hi Kevin Dai,
So as per the discussion we had, I have given connections like this
we are using 4 such TPS16530RGE in our design. So I used 4 AUXADC pins for connection and the other 2 AUXADC I grounded. This will be okay right? please give your feedback.
Yes, connecting the 2 unused AUXADC to ground should not cause any issues. In fact, in the AFE7769 EVM schematic, thats how the AUXADC pins are connected.
Kevin
