AFE7769-3P5EVM: I am observing the below error find the screen shot attached
Part Number: AFE7769-3P5EVM
The errors I am getting are
1) AFE configuration in progress.
2) Could not detect FPGA Reset FTDI, Please reset FPGA manually.
Thanks and Regards,
Kalyan Giri
  • Hi Kalyan,
    You can ignore that error and continue. with the next steps in the quick start guide.
    Please let me know if you face any issues in next steps.
    Bhavesh Atul Rathod.
  • Hi Bhavesh,
           Ok, we continued with the next step in the quick start quide. In the GUI we are able to observe the spectrum as per the waveform we loaded. but when are measuring in the MXA we are not able see the spectrum. Only a tone is visible.
    VI_ERROR_LIBRARY_NFOUND: A code library required by VISA could not be located or loaded.
    Missing VISA Libraries: Only Dummy Instruments will be created.
    Please install VISA Libraries for connecting to instruments.
    Installation Information:
    Keysight VISA Libraries: Keysight IO Libraries Suite 2024, Release Date: 25-March-2024, Build No.: 18.4.30319.0 .
    Keysight IO Libraries Suite 2024 can be found in "Previous Versions" section from below link or by visting the Keysight website directly.
    https://www.keysight.com/in/en/lib/software-detail/computer-software/io-libraries-suite-downloads-2175637.html
    AFE77xxDLibraryPG1p0
    spi - USB Instrument created.
    resetDevice
    Kintex RegProgrammer - USB Instrument created.
    Misc-B RegProgrammer - USB Instrument created.
    Reset the FPGA and try again.
    Loaded Libraries
    FPGA Reset device not found
    Refreshed GUI
    Power Card - USB Instrument created.
    #================ ERRORS:5, WARNINGS:1 ================#
    #================ ERRORS:0, WARNINGS:0 ================#
    Refreshed GUI
    Device Initialization for ChipVersion: 1.0
    2T2R1F Number: 0
    Valid Configuration: True
    laneRateRx: 9830.4
    laneRateRx1: 9830.4
    laneRateFb: 9830.4
    laneRateTx0: 9830.4
    laneRateTx1: 9830.4
    2T2R1F Number: 1
    laneRateRx: 9830.4
    laneRateRx1: 9830.4
    laneRateFb: 9830.4
    laneRateTx0: 9830.4
    laneRateTx1: 9830.4
    DONOT_OPEN_Afe77xxDPG1p0_FULL - Device registers reset.
    chipType: 0xa
    chipId: 0x77d
    chipVersion: 0x10
    LMK Clock Divider - Device registers reset.
    REFCLOCK is used from LMK source, ensure board connections are ok to do the same
    LMK Configured.
    Fuse farm load autoload done successful
    No autload error
    No autload error
    AFE Reset Done.
    pll1: True; LO Frequency: 2949.12
    FPGA Configured.
    AFE MCU Wake up done.
    pll0: True; LO Frequency: 3500.0
    pll2: True; LO Frequency: 1900.0
    AFE all PLLs configured.
    AFE SerDes configured.
    AFE Digital Chains configured.
    AFE PAP configured.
    AFE DAC Analog Writes configured.
    AFE RX Analog Writes configured.
    AFE FB Analog Writes configured.
    AFE JESD configured.
    AFE GPIO configured.
    AFE TX IQMC-LOL Correction configuration Complete
    AFE DPD Block configuration
    AFE DPD Block configuration Complete
    AFE RX IQMC configuration Complete
    AFE RX AGC configuration Complete
    AFE CFR configuration Complete
    ###########Device DAC JESD-RX 0 Link Status###########
    Comma Align Lock Lane0: False; Please check if the transmitter is sending data and eye is good.
    Comma Align Lock Lane1: False; Please check if the transmitter is sending data and eye is good.
    lane0 Errors=0b10000000000000; Got errors: Serdes loss of signal(LOS) indicator;
    lane1 Errors=0b10000000000000; Got errors: Serdes loss of signal(LOS) indicator;
    CS State TX0: 0b00000000 . It is expected to be 0b00001010
    FS State TX0: 0b00000000 . It is expected to be 0b00000101
    Couldn't get the link up for device RX: 0
    AFE Configuration Complete
    #================ ERRORS:7, WARNINGS:0 ================#
    #Error: name 'resync' is not defined
    # "", line 1, in
    # NameError: name 'resync' is not defined
    #================ ERRORS:1, WARNINGS:0 ================#
    # "", line 1, in
    Signal Info:
    ____ RMS power (dBFs): -8.222
    ____ Peak power (dBFs): -0.202
    ____ PAR (dB): 8.02
    ____ DC Value (dBFs): -66.305
    ____ Frequency: -25.0 - 25.0 : -11.149
    Signal Info:
    ____ RMS power (dBFs): -15.008
    ____ Peak power (dBFs): -4.008
    ____ PAR (dB): 11.0
    ____ DC Value (dBFs): -73.477
    ____ Frequency: -25.0 - 25.0 : -15.008
    Setting RBD to: 2.0
    Sent Custom Signal
    setOverrideTdd(0, 1367)
    TDD Set.
    setRxDsaAttn(0, 15, 0)
    Set RX DSA
    setFbDsa(0, 3, 0)
    Set FB DSA
    setTxDsaAttn(0, 15, 48)
    Set TX DSA
    Set RX DSA
    setFbDsa(0, 3, 0)
    Set FB DSA
    setTxDsaAttn(0, 1, 0)
    setTxDsaAttn(0, 14, 48)
    Set TX DSA
    TDD Set.
    Signal Info:
    ____ RMS power (dBFs): -8.227
    ____ PAR (dB): 8.025
    ____ DC Value (dBFs): -59.241
    ____ Frequency: -25.0 - 25.0 : -8.227
    Setting RBD to: 2.0
    Sent Custom Signal
    Signal Info:
    ____ PAR (dB): 11.0
    Setting RBD to: 2.0
    Sent 5G Signal
    Setting RBD to: 2.0
    Sent 5G Signal
    Signal Info:
    ____ RMS power (dBFs): -16.299
    ____ Peak power (dBFs): -3.803
    ____ PAR (dB): 12.496
    ____ DC Value (dBFs): -79.682
    ____ Frequency: -25.0 - 25.0 : -16.299
    Signal Info:
    ____ RMS power (dBFs): -8.223
    ____ Peak power (dBFs): -0.203
    ____ PAR (dB): 8.02
    ____ DC Value (dBFs): -138.222
    ____ Frequency: -25.0 - 25.0 : -11.234
    Setting RBD to: 2.0
    Sent Custom Signal
    TDD Set.
    Thanks and Regards,
    Kalyan Giri
  • Hi Kalyan,
    I see that the FPGA is not connected to Latte. Can you please connect with me on the forum I can share more details and debug steps there as this is a public post.
    In the meantime you can try the following:
    1. Close the latte
    2. Power cycle FPGA and EVM
    3. Start Latte (make sure you see AEF EVM card detected)
    4. Proceed with steps in quick start guide. (The latest version of Latte SW is 1.6 I am assuming you are using latest version)
