Other Parts Discussed in Thread: TRF370333, TSW3003
I am working on a design using the TRF370333 modulator and would like to use a single-ended LO input. The datasheet says in that case to terminate the LON pin with 50 ohms to ground but does not say if there is DC present on the pins. Can anyone tell me if I need a blocking cap on the pin as well, or just a 50 ohm resistor to ground?
Russ
