From my customer...
Now we are facing noise floor issue of TRF370417. We tested the EVB of TRF370417 and found the test result worse than the value specified in datasheet. could you please check if our test condition and ways are right? In the meantime, could you please show us the detailed test condition and how to get the performance of noise floor specified in the datasheet? As this is a little urgent for our a NPI solution decision, we highly appreciate your quick response.
Test result:
Test results(PXA Avg type: RMS. Preamp on and NFE on) for your information:
2140MHz, offset 13MHz, ~ -158dBm/Hz. Round 4dB gap with datasheet
2400MHz, offset 13MHz, ~ -157dBm/Hz. Round 3dB gap with datasheet
3400MHz, offset 13MHz, ~ -154.5dBm/Hz. Round 4.5dB gap with datasheet
