I am getting this Fatal error many times when building the Z-Stack Home Automation - 'Sample Light' project on IAR EWARM. I paste the code below.
I was getting many other errors before mainly because it was not finding include files. So I added more paths to the Preprocessor Options. Now that is ok and I am now getting the Fatal error many times. Thanking you for your kind help.
* ------------------------------------------------------------------------------------------------ * Compiler Abstraction * ------------------------------------------------------------------------------------------------ */ /* ---------------------- IAR Compiler ---------------------- */ #if defined (ewarm) #define HAL_COMPILER_IAR #define HAL_MCU_LITTLE_ENDIAN() __LITTLE_ENDIAN__ /* ---------------------- Keil Compiler ---------------------- */ #elif defined (__KEIL__) #define HAL_COMPILER_KEIL #define HAL_MCU_LITTLE_ENDIAN() 0 /* ------------------ Unrecognized Compiler ------------------ */ #elif defined (ccs) #define HAL_MCU_LITTLE_ENDIAN() 0 //do nothig for now #else #error "ERROR: Unknown compiler." #endif
