I'm testing the LMV225SDEVAL output voltage vs Input power at 868MHz. A repetitive DC offset is measured that causes a wrong output measurement.
Did you have any explanation
Hi Houdali,
What are the output voltages you are seeing for the range of input power you are putting in?
What voltages are you applying to VDD and ENABLE?
David Chaparro
The output voltage fits the datasheet curve with a offset voltage between 100mV and 175mV vs (Pin=-30dBm to -1dBm).
The Vdd and Enable voltage is 3V.
Thanks for supporting us.
For the offset voltage, are you seeing the 100mV above or below what the datasheet curve shows? If it is below, then there may be some loss in power somewhere in the setup.
David
Hi Houdali,
How are you producing the 868MHz signal? Are you connecting the signal directly to the evaluation board or is there something between them like an amplifier?
David
This is a pure 868MHz tone (no modulated signal). Yes, I connect the signal directly to the eval board.
Kind regards
Were any additional components installed on the evaluation board?
Are you able to verify the exact power level of the signal you are sending? Would it be possible for you to try with a higher frequency input and verify that you are seeing the same offset?
David
Yes, I'm able to ckeck the signal level at RFIN with a spectrum analyzer and it's done. I already tried with a higher frequency of 2GHz gave that gave me the same DC voltage.
What voltage do you read when there is no RF input?
Can you make sure that the 100pF coupling capacitor is installed on the EVM.
David
This is in line with the datasheet.
Can you check the DC output voltage near the logarithmic intercept (-45 to -43 dBm). The output voltage should be about 208mV. Also can you share the exact voltage you are seeing for the -30dBm and 0dBm levels.
David
