TRF37B32: Using the mixer with 50 Ohm single ended output
Part Number: TRF37B32
Any suggestion on how to convert the 200 Ohm differential output to 50 Ohm single ended? The schematic with differential output is here on page 6: http://www.ti.com/lit/ug/slwu088/slwu088.pdf
I have attached an image of what that looks like. Should I just short that highlighted transformer output to ground? Any suggestion on how to find a more integrated/smaller solution?
Thank you.
