Dear TI team,
based on the datasheet, I could not find any description of the behaviour of the output voltage at higher flux densities. What I understood is that the current sense amplifier overrange flag will be set, as soon as the current sense amplifier clips to the rails and at even higher flux densities the fluxgate will saturate, hence does not provide a valid output signal.
Is the behaviour of the output signal defined (means it is wrong, but always wrong in the same way: e.g. the output clamps to the last linear output value)?
Thank you very much.
Kind regards
Michael
