Part Number: HDC1080
Our customer wants the leads of this device conformally coated (Humiseal #UV40-250), and we will need to mask the sensor area on top to ensure coating does not enter the sensor. Is synthetic latex solder mask safe to apply to the sensor area? It would then be removed after spraying the leads with the coating.
www.techspray.com/p-69-wondermask-p-peelable-solder-mask.aspx
I believe the device is not available with a tape seal already on the sensor.
Thanks you,
