Other Parts Discussed in Thread: CC2650
i have made an humidity sensor for iot application with TI CC2650 processor and an HDC2010 sensor. The sensor is on a specific small board to be mounted on the edge of the housing.
I have a climatic chamber to make tests with different temperature and humidity level with a thermo hygrometer datalogger for control (calibrated).
When i use my board and the sensor directly on the climatic chamber all is fine but if i put the system on a box with holes for humidity measurement the value is not good.
Did the HDC2010 can be uses directly on the air ? No filter ?
Did you have filters or other systems to make a box with the HDC2010 sensor and protect it ?
Did you know a packing solution who work fine ?
Thank's for help.
Pierre
