Other Parts Discussed in Thread: LDC1101
Hello!
Can you learn more about the principle of determining Rp by example?
The SNAA221A instruction states that the LDS introduces Rp_min and Rp_max. Because of this, when Rp_min enters, an increase in amplitude occurs.
In connection with the questions (please reply in order):
1. How is the 1 measurement cycle Rp?
2. When the target is not near the coil, I connected the oscilloscope to the INA and INB, then I saw that the amplitude increases and then decreases (the amplitude of the oscillation of the natural frequency is modulated by the exponent and so cyclically). Due to what the amplitude increases at a constant Rp? (options: a) LDC increases the voltage (with a constant resistance) b) the LDS artificially increases the current (with a constant resistance) c) the LDS changes its resistance (with the current that does not change).
2. When the target is near the coil, how does the calculation of Rp take place? (I'm thinking of comparing the varying voltage on the circuit with some kind of reference one)
