Other Parts Discussed in Thread: TIDEP-0090
I followed the instructions in the TIDEP-0090 software getting started and when I ran the "gmake all" command I got the following linker error:
<Linking>
"dss/dss_mmw_linker.cmd", line 49: warning #10068-D: no matching section
"dss/dss_mmw_linker.cmd", line 38: error #10099-D: program will not fit into available memory. run placement with alignment fails for section ".fastCode" size 0x7000 . Available memory ranges:
L1PSRAM size: 0x4000 unused: 0x4000 max hole: 0x4000
"C:/ti/mmwave_sdk_01_00_00_05/packages/ti/platform/xwr16xx/c674x_linker.cmd", line 91: error #10099-D: program will not fit into available memory. run placement with alignment fails for section ".stack" size 0x1000 . Available memory ranges:
L2SRAM_UMAP0 size: 0x20000 unused: 0xbd6 max hole: 0xbc4
L2SRAM_UMAP1 size: 0x20000 unused: 0x0 max hole: 0x0
error #10010: errors encountered during linking; "xwr16xx_mmw_demo_dss.xe674" not built
>> Compilation failure
gmake: *** [dssDemo] Error 1
Can someone please help!!
