VXL file format differs with 32 bit build and 64 bit build of Voxel SDK
we recently discovered a platform dependency in the VXL file format. First of all, here is what the first image in a recording done on a 64 bit platform looks like:
(The recording was done using the OPT 8241 EVM and the result is regardless of the version of VoxelSDK and VoxelViewer)
If you read that recording with a 32 bit build of Voxel SDK, you get the following vertical stripes effect for every frame:
If you do it vice versa, i.e. record with 32 bit Voxel SDK or VoxelViewer and try to read it on a 64 bit platform, it will crash. We tracked that down due to the usage of size_t. The number of bytes required to store a size_t is platform-dependent and VoxelSDK does not have a check here, but just reads/writes size_t with the number of bytes it uses on the current platform.
We plan to send a merge-request on the repository.
Best regards
Thilo
