Im trying to install Voxel library on SO Debian 8 and i have some problems. After install all dependecies, the make command fails and show:
Linking CXX shared library ../lib/libvoxelpcl.so
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/4.9/../../../aarch64-linux-gnu/libpthread.a(pthread_mutex_init.o)(.text+0xa8): unresolvable R_AARCH64_ADR_PREL_PG_HI21 relocation against symbol `__sched_fifo_min_prio'
/usr/bin/ld: final link failed: Nonrepresentable section on output
collect2: error: ld returned 1 exit status
VoxelPCL/CMakeFiles/voxelpcl.dir/build.make:260: recipe for target 'lib/libvoxelpcl.so.0.6.11' failed
make[2]: *** [lib/libvoxelpcl.so.0.6.11] Error 1
CMakeFiles/Makefile2:142: recipe for target 'VoxelPCL/CMakeFiles/voxelpcl.dir/all' failed
make[1]: *** [VoxelPCL/CMakeFiles/voxelpcl.dir/all] Error 2
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
You know what the problem is?
Kind Regards
Cristóbal Rojas
