Other Parts Discussed in Thread: TMP006
6 months ago, I started the project to use TMP006 to measure case temperature. I have done many experiments to find the best result. But I am sorry
the result is not same as I expected. I still struggle to find the root cause. Could you please clarify following questions as more as possible?
1) What does standard 3D equation, which was stated in Transient Correction Algorithm created by Ian, mean?
2) When TMP006 works in a stable enviroment and no object is placed in front of TMP006, the calculated result will rise from 10 degree to 17 degree in about 8 minutes.
The increased amount seemed similar to self-heating. What is problem with TMP006 or calculating equations?
3) Regarding S0 calibration, I have posted some questions in another thread. But I did not receive answers.
http://e2e.ti.com/support/other_analog/temperature_sensors/f/243/p/241371/865352.aspx#865352
Several days ago I used 7.0E-14 as S0 to run the test again, the calculated result was far smaller than physical temperature.
What is the problem?
BRs,
Luo
